Sony S570 stuttering - how do I change the socket buffer?
• Page 1 of 1
I am suffering from stuttering on m2ts files with HD audio. I believe I need to change the socket buffer? How do I do this please?
Re: Sony S570 stuttering - how do I change the socket buffer
See FAQ: How to pass system properties to Serviio
http://www.serviio.org/component/content/article/21#q7
Thanks but I need it spelling out a bit more if possible
I'm not the most computer literate.
Any chance of a step by step please?
For windows users:
- Edit [Serviio_Install_Path]\bin\ServiioService.exe.vmoptions file with Notepad
- You will find this line "-Xmx384m"
- Add this line "-Dserviio.socketBuffer=<number of bytes>" with <number of bytes> default value is 65536, you can change value
- Save file.
- Restart the Serviio service
- Check on [Serviio]\log\serviio.log logging file if socketbuffer change
- Save file.
Many thanks.
I have accessed the file and added the line -Dserviio.socketBuffer=<100000> but the log file does not update?
Petr
Help translate Serviio
Thanks again. Done bu sadly makes no difference. What is the maximum figure?
Up to you
Petr
Has made no difference. Is there anything else I can try please?
post ffmpeg -i of the file
Petr
I have the same problem with a KDL-32EX500.
I tried setting the socketbuffer to 262144 and then 33554432, that didn't seem to change anything.
The serviio log confirms the setting were applied.
here's the ffmpg -i output for the file :
FFmpeg version git-N-29157-gc967860, Copyright (c) 2000-2011 the FFmpeg developers
built on Apr 17 2011 13:48:41 with gcc 4.5.2
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --enable-memalign-hack --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb
--enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enabl
e-libx264 --enable-libxavs --enable-libxvid --enable-zlib --cross-prefix=x86_64-w64-mingw32- --target-os=mingw32 --arch=x86_64 --extra-cflags=-I/home/kyle/software/ffmpeg/external-libraries/win64/incl
ude --extra-ldflags=-L/home/kyle/software/ffmpeg/external-libraries/win64/lib --pkg-config=pkg-config
libavutil 50. 40. 1 / 50. 40. 1
libavcodec 52.119. 1 / 52.119. 1
libavformat 52.108. 0 / 52.108. 0
libavdevice 52. 4. 0 / 52. 4. 0
libavfilter 1. 79. 0 / 1. 79. 0
libswscale 0. 13. 0 / 0. 13. 0
[matroska,webm @ 00000000003FA420] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (24000/1001)
Input #0, matroska,webm, from '_hd\The.Animatrix.2003.720p.BluRay.x264-HANGOVER\h-animatrix-x264.mkv':
Duration: 01:40:50.68, start: 0.000000, bitrate: 640 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x528, PAR 1:1 DAR 80:33, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s (default)
Could you check the average and peak video bitrate of your file with that tool : viewtopic.php?f=17&t=2133 ?
Illico wrote:Could you check the average and peak video bitrate of your file with that tool : viewtopic.php?f=17&t=2133 ?
The average bitarate on this file is 5572 kbps and the highest peak 25363 kbps.
This file played nicely today, even over wifi !
I'm wondering if the fact I had a download running on the disk when I tried it yesterday wasn't responsible for the stuttering.
Or maybe some other processes were slowing it down...
Anyway, I'm very happy to be able to play 1080p over wifi now
Dejavu wrote:This file played nicely today, even over wifi !
Good, but I think you'll have stuttering with such movie, 25Mbps its a very high bitrate for Wifi
• Page 1 of 1
