Serviio not detected by my TV
daej
Post Wed Nov 11, 2020 7:42 pm
I installed Serviio 3 weeks ago on a new notebook (Windows 10) to watch media on my Samsung TV.
I use DLNA through my internet box (Orange Livebox) and Orange TV box decoder. The netbook is connecting to the local network via Wifi and the other devices via ethernet.
It worked fine for 2 weeks but it no longer works since last sunday : Serviio is no longer detected by the TV decoder. Since then, I tried everything including uninstalling then reinstalling Serviio.
I use a VPN (NordVPN). If I disable it, no change.
I tried several times to stop the service (services.msc,) then restart it, no change
A library "Serviio + the name of my notebbok" was added in Windows Media Player, but it is empty too
Thanks for your help.
Post Wed Nov 11, 2020 10:23 pm
Re: Serviio not detected by my TV
It's more than likely related to a recent Windows update. Microsoft has a habit of resetting the firewall settings with an update. On my computers, I simply disable the firewall because I'm comfortable with the security of my network. But I can understand that not everyone has that comfort level.
As a test, turn the firewall off temporally. If Serviio is now visible, then you've identified the problem. I forget exactly which port(s) must be opened for Serviio, but someone here can probably answer that.
daej
Post Wed Nov 11, 2020 10:54 pm
I temporarily disabled Defender and Serviio is still not visible. My problem then seems to be due to something else.
Post Thu Nov 12, 2020 12:39 am
Just a note, Windows Media Player will show the Serviio source, but it won't show content. So don't worry that it doesn't show anything there.
Since WMP does show Serviio, that means the Serviio service is working correctly. If you have Serviio Pro, or if you are still within the 15 day test period, see if MediaBrowser is showing up and playing your media. All that shows Serviio working right.
So, where's the network issue? When you have a combination of wireless and wired settings, sometimes there are security settings in the router that blocks wireless devices from seeing anything on the network. So it's worth checking the wireless settings in the router. And I'm still suspicious of the VPN, too. :D
daej
Post Thu Nov 12, 2020 12:29 pm
atc98092 wrote:So, where's the network issue? When you have a combination of wireless and wired settings, sometimes there are security settings in the router that blocks wireless devices from seeing anything on the network. So it's worth checking the wireless settings in the router. And I'm still suspicious of the VPN, too. :D
I used Serviio without any problem for 6 months with my previous notebook
With the current notebook, which I bought 20 days ago, it worked till last sunday :
- My router settings didn't change for years, so I do not think there might be a problem on that side
- When I disable VPN, Serviio is still not detected on my TV
- WMP is detected on my TV, Serviio isn't
- I just started my old notebook : My TV sees Serviio on that old notebook (same rooter and local network of course). VPN is working on that old notebook too.
Post Thu Nov 12, 2020 4:23 pm
OK, that narrows the issue to be specifically the new notebook. And since Windows Media Services is visible on the TV but Serviio is not (both on the same computer, right?), then something is blocking Serviio somewhere on that computer. First, I'd look at the Serviio log to ensure it's running properly. Open MediaBrowser and see if everything shows up as expected (assuming you have Serviio Pro or are within the 15 day demo period). Since it's a notebook, you probably have a wired and wireless connection. Serviio might have bound itself to the one you aren't using. You can check that in the Serviio console at the bottom of the Status page. It's probably set to Auto and you might need to manually tell it which network card to use.
Can you connect to the Serviio console from a different computer? That would indicate if Serviio is visible on the network as well. We need to determine if Serviio can be seen from any computer other than the one it's installed on.
daej
Post Thu Nov 12, 2020 5:22 pm
atc98092 wrote:OK, that narrows the issue to be specifically the new notebook. And since Windows Media Services is visible on the TV but Serviio is not (both on the same computer, right?), then something is blocking Serviio somewhere on that computer.
Yes on same computer. I now disabled network discovery and logicallay no longer see VMP on that computer. I disabled it because it is disabled on the old computer working fine with Serviio.
atc98092 wrote:First, I'd look at the Serviio log to ensure it's running properly. Open MediaBrowser and see if everything shows up as expected (assuming you have Serviio Pro or are within the 15 day demo period). Since it's a notebook, you probably have a wired and wireless connection. Serviio might have bound itself to the one you aren't using. You can check that in the Serviio console at the bottom of the Status page. It's probably set to Auto and you might need to manually tell it which network card to use.
What Mediabrowser are you talking about ? How do I get a log ?
Serviio server status is running
Bound IP address is set on "Automatically detected". If I choose the other IPs in the liste, no change
- one is VPN Tunnel
- one is the IP address of my computer and my Wifi card is mentionned
atc98092 wrote:Can you connect to the Serviio console from a different computer? That would indicate if Serviio is visible on the network as well. We need to determine if Serviio can be seen from any computer other than the one it's installed on.
Yes, this is what I previously wrote :
daej wrote:- I just started my old notebook : My TV sees Serviio on that old notebook (same rooter and local network of course). VPN is working on that old notebook too.
daej
Post Thu Nov 12, 2020 6:04 pm
I checked that link https://wiki.serviio.org/doku.php?id=detail_logging and got a debug log.
241 lines. Do I post it here ?
Post Thu Nov 12, 2020 6:58 pm
You didn't need to switch to debug logging yet, as the basic log might have contained enough info. But since you did, sure go ahead and post it here. However, 241 lines sounds awfully small for a debug log. I'm suspicious if Serviio is running properly. A debug log usually exceeds 1000 lines very quickly after startup.
MediaBrowser is something included with Serviio Pro (the paid version) and is enabled as a trial for the first 15 days after installation. You access it on the same computer using http://localhost:23424/MediaBrowser. On a different computer, substitute the word "localhost" with either the name or the IP address of the Serviio computer.
Yes, you should not be using the VPN network connection. I understand changing the setting didn't alter anything, but Serviio has to be on your actual local network connection. I seem to recall someone else having issues due to a VPN, even when it was "off". I believe that once some settings were changed in the VPN to allow local access to Serviio it began working. But I have zero experience with software based VPNs, so can't offer any guidance on how/what to whitelist in the VPN settings.
daej
Post Thu Nov 12, 2020 7:13 pm
Only 241 lines because I started Serviio from "outside", via services.msc. Libraries files are not listed then.
I used Serviio for more than 6 months without any problem, while using a VPN. The VPN settings are same on this new notebook as on the old one with which I used Serviio for more than 6 months.
2020-11-12 18:57:41,886 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2020-11-12 18:57:41,887 INFO  [MediaServer] ------------------------------------------------------------------------
2020-11-12 18:57:41,887 INFO  [MediaServer] Serviio DLNA media streaming server v 2.1 (rev. 64e78caaeacb5eafe11b93197db80b99f812bfb8)
2020-11-12 18:57:41,887 INFO  [MediaServer] Petr Nejedly 2009-2018
2020-11-12 18:57:41,887 INFO  [MediaServer] http://www.serviio.org
2020-11-12 18:57:41,887 INFO  [MediaServer] Java 1.8.0_242-BellSoft x86
2020-11-12 18:57:41,887 INFO  [MediaServer] OS Windows 10 10.0
2020-11-12 18:57:41,887 INFO  [MediaServer] File encoding: windows-1252
2020-11-12 18:57:41,916 INFO  [MediaServer] Headless mode enabled: true
2020-11-12 18:57:41,916 INFO  [MediaServer] User: LAPTOP-83VE8R2T$
2020-11-12 18:57:41,916 INFO  [MediaServer] User home dir: C:\Windows\system32\config\systemprofile
2020-11-12 18:57:41,916 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2020-11-12 18:57:41,916 INFO  [MediaServer] ------------------------------------------------------------------------
2020-11-12 18:57:41,918 DEBUG [MediaServer] Runtime params: -Dexe4j.semaphoreName=Local\c:_program_files_pc5dczc_bin_serviioservice.exe0, -Dexe4j.isService=true, -Dexe4j.moduleName=C:\Program Files\Serviio\bin\ServiioService.exe, -Dexe4j.tempDir=C:\Windows\TEMP\e4j4350.tmp_dir1605203861, -Dexe4j.unextractedPosition=413627, -Djava.library.path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files (x86)\Calibre2\;C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\WindowsApps;c:\program files\serviio\jre\bin, -Dexe4j.consoleCodepage=cp0, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dserviio.home=C:\Program Files\Serviio\bin\\.., -Dderby.system.home=C:\Program Files\Serviio\bin\\..\library, -Xmx512m, -Xrs
2020-11-12 18:57:41,923 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2020-11-12 18:57:41,931 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2020-11-12 18:57:41,932 INFO  [DatabaseManager] Using DERBY database language
2020-11-12 18:57:42,413 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2020-11-12 18:57:42,413 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2020-11-12 18:57:42,413 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2020-11-12 18:57:42,414 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2020-11-12 18:57:42,414 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2020-11-12 18:57:42,414 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2020-11-12 18:57:42,414 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2020-11-12 18:57:42,415 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2020-11-12 18:57:42,415 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2020-11-12 18:57:42,415 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2020-11-12 18:57:42,415 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2020-11-12 18:57:42,416 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2020-11-12 18:57:42,416 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2020-11-12 18:57:42,416 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2020-11-12 18:57:42,416 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2020-11-12 18:57:42,417 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2020-11-12 18:57:42,417 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2020-11-12 18:57:42,417 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2020-11-12 18:57:42,418 DEBUG [DBLogDAOImpl] Checking if script 'script-1.6.sql' has been run
2020-11-12 18:57:42,418 DEBUG [DBLogDAOImpl] Checking if script 'script-1.7.sql' has been run
2020-11-12 18:57:42,418 DEBUG [DBLogDAOImpl] Checking if script 'script-1.8.sql' has been run
2020-11-12 18:57:42,418 DEBUG [DBLogDAOImpl] Checking if script 'script-1.9.sql' has been run
2020-11-12 18:57:42,420 DEBUG [DBLogDAOImpl] Checking if script 'script-2.0.sql' has been run
2020-11-12 18:57:42,480 INFO  [WebServer] Socket buffer set to 65535 bytes
2020-11-12 18:57:42,480 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2020-11-12 18:57:42,481 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2020-11-12 18:57:42,482 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2020-11-12 18:57:42,482 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2020-11-12 18:57:42,852 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/cds) exposed on port 23424
2020-11-12 18:57:42,852 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/mediabrowser) exposed on port 23424
2020-11-12 18:57:42,853 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/cds) exposed on port 23524
2020-11-12 18:57:42,853 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/mediabrowser) exposed on port 23524
2020-11-12 18:57:42,871 DEBUG [LicensingManager] Updating license
2020-11-12 18:57:42,873 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2020-11-12 18:57:42,876 DEBUG [LicenseValidator] Validating license file (350 bytes)
2020-11-12 18:57:42,907 INFO  [MediaServer] ------------------------------------------------------------------------
2020-11-12 18:57:42,907 INFO  [MediaServer] License: FREE
2020-11-12 18:57:42,909 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2020-11-12 18:57:43,298 INFO  [Device] Created UPnP Device with UUID: 9242584b-e2fc-3a84-9150-871cd521a190, bound address: 10.5.0.2
2020-11-12 18:57:43,348 INFO  [ProfileManager] Loading profiles from file /profiles.xml
2020-11-12 18:57:43,450 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2020-11-12 18:57:43,453 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2020-11-12 18:57:43,478 INFO  [CustomisationManager] No customisation properties found
2020-11-12 18:57:43,502 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2020-11-12 18:57:43,502 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2020-11-12 18:57:43,505 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2020-11-12 18:57:43,505 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2020-11-12 18:57:43,507 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2020-11-12 18:57:43,507 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2020-11-12 18:57:43,507 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2020-11-12 18:57:43,507 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ps4
2020-11-12 18:57:43,507 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2020-11-12 18:57:43,507 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2020-11-12 18:57:43,507 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2020-11-12 18:57:43,508 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2020-11-12 18:57:43,514 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2020-11-12 18:57:43,514 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_h
2020-11-12 18:57:43,515 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2020-11-12 18:57:43,515 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_j
2020-11-12 18:57:43,515 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2020-11-12 18:57:43,515 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_m
2020-11-12 18:57:43,515 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (M-series)' (id=sam_m)
2020-11-12 18:57:43,516 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Samsung_NU
2020-11-12 18:57:43,516 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (NU-series)' (id=Samsung_NU)
2020-11-12 18:57:43,516 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2020-11-12 18:57:43,516 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2020-11-12 18:57:43,516 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2020-11-12 18:57:43,517 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2020-11-12 18:57:43,517 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2020-11-12 18:57:43,517 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2020-11-12 18:57:43,517 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2020-11-12 18:57:43,520 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2020-11-12 18:57:43,520 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2020-11-12 18:57:43,520 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2020-11-12 18:57:43,520 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2013
2020-11-12 18:57:43,520 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2020-11-12 18:57:43,520 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2020-11-12 18:57:43,521 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2020-11-12 18:57:43,521 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2020-11-12 18:57:43,521 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2020-11-12 18:57:43,521 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2020-11-12 18:57:43,521 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2020-11-12 18:57:43,521 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2020-11-12 18:57:43,521 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2020-11-12 18:57:43,521 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2020-11-12 18:57:43,521 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2020-11-12 18:57:43,521 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile tosh2012
2020-11-12 18:57:43,521 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2020-11-12 18:57:43,522 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2020-11-12 18:57:43,522 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2020-11-12 18:57:43,522 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2020-11-12 18:57:43,522 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2020-11-12 18:57:43,522 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2020-11-12 18:57:43,522 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2020-11-12 18:57:43,522 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2020-11-12 18:57:43,522 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2020-11-12 18:57:43,522 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2020-11-12 18:57:43,523 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2020-11-12 18:57:43,523 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2020-11-12 18:57:43,523 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2020-11-12 18:57:43,523 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2020-11-12 18:57:43,523 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2020-11-12 18:57:43,523 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2020-11-12 18:57:43,523 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2020-11-12 18:57:43,523 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2020-11-12 18:57:43,523 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2020-11-12 18:57:43,523 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2020-11-12 18:57:43,523 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2020-11-12 18:57:43,523 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2020-11-12 18:57:43,524 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2020-11-12 18:57:43,524 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2013
2020-11-12 18:57:43,524 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2020-11-12 18:57:43,524 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2020-11-12 18:57:43,524 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2020-11-12 18:57:43,524 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2020-11-12 18:57:43,524 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2020-11-12 18:57:43,524 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2020-11-12 18:57:43,524 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2009
2020-11-12 18:57:43,524 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2009)' (id=viera2009)
2020-11-12 18:57:43,524 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2020-11-12 18:57:43,524 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2020-11-12 18:57:43,524 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2020-11-12 18:57:43,524 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2020-11-12 18:57:43,524 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2020-11-12 18:57:43,525 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2020-11-12 18:57:43,525 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2020-11-12 18:57:43,525 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2020-11-12 18:57:43,525 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2020-11-12 18:57:43,525 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2020-11-12 18:57:43,525 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2020-11-12 18:57:43,525 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2020-11-12 18:57:43,525 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2020-11-12 18:57:43,525 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2020-11-12 18:57:43,525 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2020-11-12 18:57:43,525 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2020-11-12 18:57:43,525 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuMPApp
2020-11-12 18:57:43,530 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2020-11-12 18:57:43,530 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kMPApp
2020-11-12 18:57:43,531 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K Media Player (2016+)' (id=Roku4kMPApp)
2020-11-12 18:57:43,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuNo4kApp
2020-11-12 18:57:43,531 INFO  [ProfilesDefinitionParser] Added profile 'Roku 1080 Media Player (2016+)' (id=RokuNo4kApp)
2020-11-12 18:57:43,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuTV
2020-11-12 18:57:43,531 INFO  [ProfilesDefinitionParser] Added profile 'Roku TV (non 4K)' (id=RokuTV)
2020-11-12 18:57:43,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kTV
2020-11-12 18:57:43,531 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K TV' (id=Roku4kTV)
2020-11-12 18:57:43,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kMPM2
2020-11-12 18:57:43,531 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K Media Player w/MPEG2' (id=Roku4kMPM2)
2020-11-12 18:57:43,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2020-11-12 18:57:43,531 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2020-11-12 18:57:43,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2020-11-12 18:57:43,531 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2020-11-12 18:57:43,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one_s_x
2020-11-12 18:57:43,532 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One S/Xbox One X' (id=xbox_one_s_x)
2020-11-12 18:57:43,532 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2020-11-12 18:57:43,532 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2020-11-12 18:57:43,532 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile raumfeld
2020-11-12 18:57:43,533 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2020-11-12 18:57:43,533 INFO  [ProfileManager] Loading profiles from file /application-profiles.xml
2020-11-12 18:57:43,542 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2020-11-12 18:57:43,542 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2020-11-12 18:57:43,542 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2020-11-12 18:57:43,542 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5
2020-11-12 18:57:43,543 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2020-11-12 18:57:43,543 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5_mobile
2020-11-12 18:57:43,543 INFO  [ProfilesDefinitionParser] Added profile 'HTML5 Mobile' (id=html5_mobile)
2020-11-12 18:57:43,543 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2020-11-12 18:57:43,543 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2020-11-12 18:57:43,543 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2020-11-12 18:57:43,543 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2020-11-12 18:57:43,543 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2020-11-12 18:57:43,543 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2020-11-12 18:57:43,543 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2020-11-12 18:57:43,543 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile googlecast
2020-11-12 18:57:43,544 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2020-11-12 18:57:43,544 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile chromecast
2020-11-12 18:57:43,544 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2020-11-12 18:57:43,544 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile alexa
2020-11-12 18:57:43,544 INFO  [ProfilesDefinitionParser] Added profile 'Alexa' (id=alexa)
2020-11-12 18:57:43,544 INFO  [ProfileManager] User profiles definition (user-profiles.xml) not found, using built-in profiles only
2020-11-12 18:57:43,562 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2020-11-12 18:57:43,562 INFO  [PluginCompilerThread] Started looking for plugins
2020-11-12 18:57:43,563 INFO  [UpdateChecker] Checking if a new version is available
2020-11-12 18:57:43,570 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2020-11-12 18:57:43,572 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2020-11-12 18:57:43,623 INFO  [FFMPEGWrapper] Found FFmpeg: C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2020-11-12 18:57:43,623 INFO  [FFMPEGWrapper] FFmpeg details: [version=3.4.4, libRtpmPresent=true, libAssPresent=true, libShinePresent=false, libMxfPresent=false]
2020-11-12 18:57:43,624 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib\dcraw.exe
2020-11-12 18:57:43,628 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\dcraw.exe
2020-11-12 18:57:43,685 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2020-11-12 18:57:43,738 INFO  [TrakttvService] Started trakt.tv sync updater
2020-11-12 18:57:43,739 INFO  [TrakttvService] Started trakt.tv scrobble poster
2020-11-12 18:57:43,745 INFO  [PlaybackProgressUpdater] Started playback progress updater
2020-11-12 18:57:43,754 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2020-11-12 18:57:43,755 INFO  [WebServer] WebServer starting on port 8895
2020-11-12 18:57:44,118 INFO  [Device] Updated bound IP address of Device with UUID: 9242584b-e2fc-3a84-9150-871cd521a190, bound address: 10.5.0.2
2020-11-12 18:57:44,122 DEBUG [DiscoveryManager] UPNP device 9242584b-e2fc-3a84-9150-871cd521a190 (10.5.0.2) is available
2020-11-12 18:57:44,122 INFO  [EventDispatcher] Starting EventDispatcher
2020-11-12 18:57:44,122 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2020-11-12 18:57:44,122 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2020-11-12 18:57:44,124 INFO  [RendererSearchSender] Starting Renderer searcher process
2020-11-12 18:57:44,124 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2020-11-12 18:57:44,381 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net7 (NordLynx Tunnel) and address 10.5.0.2, timeout = 0
2020-11-12 18:57:44,390 DEBUG [RendererSearchSender] Searching for Renderer devices
2020-11-12 18:57:44,392 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface net7 (NordLynx Tunnel) and address 10.5.0.2, timeout = 0
2020-11-12 18:57:44,403 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2020-11-12 18:57:44,408 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /10.5.0.2:62650s
2020-11-12 18:57:44,409 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /10.5.0.2:62650s
2020-11-12 18:57:44,409 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.5.0.2
2020-11-12 18:57:44,421 DEBUG [RendererService] Rendered f41172ed-0419-4d6b-a995-c13f1da0e732 doesn't have a User assigned to it, using Default
2020-11-12 18:57:44,450 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net7 (NordLynx Tunnel) and address 10.5.0.2, timeout = 0
2020-11-12 18:57:44,452 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 9242584b-e2fc-3a84-9150-871cd521a190
2020-11-12 18:57:46,404 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2020-11-12 18:57:50,409 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2020-11-12 18:57:54,442 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net7 (NordLynx Tunnel) and address 10.5.0.2, timeout = 0
2020-11-12 18:57:54,442 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 9242584b-e2fc-3a84-9150-871cd521a190
daej
Post Thu Nov 12, 2020 7:45 pm
I think I found out.
daej wrote:Bound IP address is set on "Automatically detected". If I choose the other IPs in the list, no change
- one is VPN Tunnel
On the older notebook, Bound IP address is also set on "Automatically detected"
If on the new notebook, I set it on the IP address of this new notebook, my TV can see Serviio. I already tried earlier ("If I choose the other IPs in the list, no change") and it did not work, now it does. May be I did something wrong at that time, like not restarting the server ???
Thnaks again for your help, I just hope this time will be the good one.
Post Thu Nov 12, 2020 8:59 pm
Perhaps you didn't click the save button the first time. But whatever the reason, I'm glad you resolved it. :D
daej
Post Thu Nov 12, 2020 9:06 pm
Users browsing this forum: No registered users and 100 guests
