embedded subtitles not working
ricobico
Post Tue Mar 26, 2019 10:27 pm
hello.
First off, love the software and it is working well with some minor issues. I have searched here for my question and I think this is just an issue that may not have an answer but I'll try anyway.
I have tons of MKV videos that have subtitles included/embeded in them; not hardcoded, not a separate subtitle like an SRT, but part of the original file. The subtitles just wont play on my samsung C630 TV. Prior to having serviio, I used WD TV Live and I could select the subs. now if I run serviio or even if I run WD TV LIVE through the serviio server, I cannot get any subs. for the few files I have that do have an SRT, those seem to work.
I have every box checked under the Serviio subtitles section except the hardcoding/transcending box.
Any thoughts?
Post Sun Mar 31, 2019 12:35 am
Re: embedded subtitles not working
Firstly which problem are you trying to solve - for the Samsung TV or the WD TV Live box?
For the Samsung TV, it appears from the info you've provided it doesnt support subtitles (have you tried the Generic profile), so you will need to burn them in - you will need to enable "Enable extraction of text-based subtitles embedded in video files" and "Enable burned-in subtitles" in the Delivery, Subtitles areas of Serviio Console. Press Save.
The above may also fix the issue for the WD Live. It shouldn't however be needed - to see what's going on post MediaInfo details of one of the offending files.
companion
Post Mon Nov 30, 2020 7:04 pm
I had the same problem with no Subtitles on my movie “Amelie” (which is a French movie, and one of my favorites). I solved the issue in stages. First, make sure “Subtitles” are turned ON in Serviio, which is under the Delivery section; and check every box. But this was not the real problem in my case. The problem was that my Samsung TV (series 6) did not have “captions” turned on. Now, Captions and Subtitles are technically different; but in the Samsung TV, it is considered the same setting. This is found under the “Accessibility” section in Samsung Settings in their Smart Hub. Simply click on the “Captions” to turn it on. The setting which worked for me was “Default.” Then turn off your TV, wait 30 seconds, and turn it back on so that the Samsung TV (or whatever TV or device you use) loads to the new configuration. It worked immediately. :D
Users browsing this forum: Google [Bot] and 23 guests
