serviio and Fedora
_david_
Post Fri Dec 04, 2020 10:21 pm
serviio and Fedora
There is an error, or at the very least, a clarification that needs to be be made on this link: https://www.serviio.org/index.php?optio ... quirements
Under minimal requirements, it states that Linux must have Java 8 installed.
I can confirm that serviio runs exceedingly well with the default java in Fedora, java-11-openjdk-headless-11.0.9.11-0.fc33.x86_64.
I actually took the advice to heart and installed Java 8. I wasn't able to get serviio to work until I uninstalled Java 8 and relied on the java that was installed with Fedora.
This page should be updated to recommend running serviio with the default java for the particular distro, and if that fails, try java 8.
cmakula
Post Fri Dec 18, 2020 7:15 pm
Re: serviio and Fedora
I can confirm that openjdk-8-jre-1.8.0_254 (which is Java 8) works properly with Serviio 2.1 under Debian, Ubuntu, Mint, and CentOS.
Java 8 is listed as a minimum requirement, and since 11>8, the fact that it works properly with the default version 11 under Fedora is not surprising.
Debian and Ubuntu (by default) do not come with any Java preinstalled, so having Java 8 listed in the minimum requirements for Linux is important.
If you have any important changes to the installation procedures/requirements under Fedora, they should be updated at the Fedora installation wiki page ( https://wiki.serviio.org/doku.php?id=ho ... all:fedora ). (Please do, because the Fedora page is not really valid anymore because it is extremely out of date.)
:ugeek:
Serviio Server - Dell PowerEdge R420, Dual Xeon E5-2420, 4x120 GB SSD RAID 0, 64 GB RAM (Serviio running from RAMdisk), 4 NICs (aggregated to LAN), 10Gbe to NAS, Ubuntu Server 24.04.3
NFS File Server - Synology DS1517+, 20TB disk space (5x4TB), 4 NICs (aggregated to LAN), 10Gbe to Serviio Server
Users browsing this forum: No registered users and 50 guests
