LOW RESOLUTION METADATA
Paul C
Post Wed Feb 20, 2019 1:37 pm
Re: LOW RESOLUTION METADATA
BlueMan wrote:Thanks again for your help and your great Serviio software. ;)
Best regards.
Just to clarify I do not work for Serviio - I am a user just like yourself.
Paul C
Post Fri Mar 01, 2019 11:25 am
see feature request viewtopic.php?f=3&t=25218
Paul C
Post Fri Mar 01, 2019 11:45 am
Re: LOW RESOLUTION ARTWORK/METADATA
See feature request and invitation to comment viewtopic.php?f=3&t=25218&p=120942#p120942
Sargon
Post Tue Nov 30, 2021 8:47 pm
Is there still no convenient way to re-create the thumbnails with higher resolution?
I have updated my settings and verified that a new audio rip is displaying perfectly, but my existing library is still showing the tiny thumbnails. Is the only option to re-copy all the files or remove the shared folder and rescan everything?
K1327
Post Sun Jan 30, 2022 7:31 pm
BlueMan wrote:Hello Paul!
Thanks a lot!
So, here is what i have done :
- i modified my generic profile file, the lines <ThumbnailsResolution>DLNA</ThumbnailsResolution> into <ThumbnailsResolution>HD</ThumbnailsResolution> (i have 5 lines like that in this file but i add only to modify one of them).
- I stopped the Serviio service
- I added in the ServiioService.exe.vmoptions file the line -Dserviio.hdThumbnailResolution=1000
- i started again the Serviio service
- i launched the Servioo console.
- i suppressed the folder of my music.
- i recreate it, checking the probe function.
- I saved.
- I ask top refresh the libray
- i DID NOT restart my computer and went directly to my Samsung tablet to operate
and now it WORKS PERFECTLY with high definition nice images for my music in the following Android application :
- Yamaha MusiCast
- Hi-Fi Cast
:D
Thank you VERY MUCH!
Hope that my experience will help!
Thanks again!
Thanks Mate... It helps alot
Previous
Return to General discussion
Users browsing this forum: Baidu [Spider] and 11 guests
