Re: LOW RESOLUTION METADATA
BlueMan wrote:Thanks again for your help and your great Serviio software.
Best regards.
Just to clarify I do not work for Serviio - I am a user just like yourself.
Best regards.
BlueMan wrote:Hello Paul!
Thanks a lot!
So, here is what i have done :
- i modified my generic profile file, the lines <ThumbnailsResolution>DLNA</ThumbnailsResolution> into <ThumbnailsResolution>HD</ThumbnailsResolution> (i have 5 lines like that in this file but i add only to modify one of them).
- I stopped the Serviio service
- I added in the ServiioService.exe.vmoptions file the line -Dserviio.hdThumbnailResolution=1000
- i started again the Serviio service
- i launched the Servioo console.
- i suppressed the folder of my music.
- i recreate it, checking the probe function.
- I saved.
- I ask top refresh the libray
- i DID NOT restart my computer and went directly to my Samsung tablet to operate
and now it WORKS PERFECTLY with high definition nice images for my music in the following Android application :
- Yamaha MusiCast
- Hi-Fi Cast
Thank you VERY MUCH!
Hope that my experience will help!
Thanks again!
