Serviio stopped sharing new stuff.
oldyellr
Post Thu May 19, 2022 6:56 pm
Re: Serviio stopped sharing new stuff.
Okay, this thread has been going on for a month and still no satisfactory resolution. Used to be that whenever I added a new mp3 or video in a shared folder on my laptop, it immediately appeared on my smart TV. Now it doesn't. I can force music to show up using the Poller method, but not videos.
Is Serviio well and truly broken? Any Serviio developers here who can help?
Win 7 Laptop, Samsung UN55MU6300F Smart TV, DIR-867 AC1750 Wi-Fi Router, Serviio v2.2.1
Post Thu May 19, 2022 11:07 pm
There's only one Serviio developer. This is not run by a corporation. Zip is still working on the next build, but when I spoke with him within the past few days he didn't have a firm timeline for the next release. I'm simply a moderator for him on this forum, and I'm currently fighting that stupid Covid.
When you enabled the Poller function, did you do it on each folder? Simply enabling it on your music folder won't change your video folders. Under Windows 10, mine is hit or miss using the OS function, but poller does just fine for me.
oldyellr
Post Thu May 19, 2022 11:54 pm
Thanks for the update.Yes, I have Poller enabled I hope a new version, whenever that's released, fixes the problem, although I'm mystified why it stopped working in the first place. This is a long shot, but I wonder if this has anything to do with me migrating my HD to SSD in January?
Another question, I have the free version. Does the paid version also have this problem?
Post Fri May 20, 2022 9:03 pm
For this functionality, there's no difference between the free and paid versions. Both operate identically in this regard.
If your media is stored on an SSD, that certainly might be a factor. An SSD drive really isn't designed for streaming media like this. I use an SSD as the OS drive on all of my computers, but for media storage I add additional standard hard drives.
oldyellr
Post Fri May 20, 2022 9:35 pm
I migrated to SSD a few months ago. I'd read that for SSD I should disable Windows indexing, which I did and it took a couple of hours updating the next time I started Windows. Should I re-enable Windows indexing and wait a couple of hours to see if Serviio will work again?
The kicker is that using Samsung Allshare works perfectly and I can add a new shared folder, put a video or music into it, and Allshare sees it on my TV. Doing the same with Serviio does not work. It appears to be broken.
Post Sat May 21, 2022 5:31 pm
Well, I can't say it's broken, since it works on the numerous installs that I have with several family members. It's something specific with your computer, but I can't begin to guess why. I notice your sig line mentions Windows 7. Microsoft discontinued support for Win 7 a bit over two years ago. If that's what Serviio is running under, that might be one possibility.
oldyellr
Post Sat May 21, 2022 7:10 pm
I'd say something is broken. There's nothing that says Serviio has stopped working for Windows 7. It still works for music, why not videos anymore? That started happening a month or two ago.
Post Sat May 21, 2022 10:32 pm
Serviio hasn't had any updates in that timeframe. 2.2.1 was released last December, and there's been nothing since. So if it was worked and then something changed, it would seem to be OS related. What that would be, I have no idea. I don't know if looking at your Serviio log would provide any insight, and I'm not certain I have the knowledge to recognize it if I saw it.
freaknik
Post Mon May 30, 2022 3:01 pm
This has been a problem for me for about a month. I initiated the poller and did all the steps, did complete reinstall of serviio, and it wouldn't index one of my folders that has my snowboarding videos in it.
I add an underscore to all the files and folders, and then remove it, with the poller on. it starts scanning and indexing the files! Then it stops on the new one I have been trying to add in the first place since a month ago.
Here's the mediainfo for the file that stops the scan:
Complete name               : E:\mo gnar gnar\Cheers 2010.mp4
Format                      : MPEG-4
Format profile              : Base Media
Codec ID                    : isom
File size                   : 881 MiB
Duration                    : 49mn 59s
Overall bit rate mode       : Variable
Overall bit rate            : 2 462 Kbps
Writing application         : Lavf58.65.100
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : High@L3.1
Format settings, CABAC      : Yes
Format settings, ReFrames   : 4 frames
Codec ID                    : avc1
Codec ID/Info               : Advanced Video Coding
Duration                    : 49mn 59s
Bit rate                    : 2 400 Kbps
Maximum bit rate            : 2 361 Kbps
Width                       : 1 280 pixels
Height                      : 720 pixels
Display aspect ratio        : 16:9
Frame rate mode             : Constant
Frame rate                  : 30.000 fps
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.087
Stream size                 : 844 MiB (96%)
Writing library             : x264 core 157 r2965 861cec4
Encoding settings           : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=150 / keyint_min=76 / scenecut=0 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2400 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=2640 / vbv_bufsize=2880 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Format                      : AAC
Format/Info                 : Advanced Audio Codec
Format profile              : LC
Codec ID                    : 40
Duration                    : 49mn 59s
Bit rate mode               : Variable
Bit rate                    : 93.4 Kbps
Maximum bit rate            : 97.0 Kbps / 97.0 Kbps
Channel(s)                  : 2 channels
Channel positions           : Front: L R
Sampling rate               : 48.0 KHz
Compression mode            : Lossy
Stream size                 : 33.4 MiB (4%)
I repeated this twice and it stops at this point in the scan each time. How can I get all my movies scanned back into serviio?
Here's the log, it won't attach and says The file is too big, maximum allowed size is 500 KiB.
2022-05-28T12:23:26,009 INFO  [MediaFileIndexer] Added file 'E:\cartoons\[Dragon Ball Z - Battle of Gods][1080P][x264].mkv' (title: Dragon Ball Z: Battle of Gods) to Library
2022-05-28T12:23:27,015 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\&quot;siberian_wild&quot;_1280x720.mp4' (title: &quot;siberian_wild&quot;_1280x720) to Library
2022-05-29T11:02:00,367 INFO  [UpdateChecker] Checking if a new version is available
2022-05-30T10:32:53,504 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\12 months.mp4). Message: Unknown video file type.
2022-05-30T10:32:53,541 INFO  [LibraryOneTimeScanner] Interrupting library scan
2022-05-30T10:32:53,541 INFO  [LibraryDeltaScanner] Stopping the library delta scan
2022-05-30T10:32:53,543 INFO  [PlaylistMaintainerWorker] Finished looking for playlist changes
2022-05-30T10:32:53,839 INFO  [LocalLibraryManager] Starting automatic library scan
2022-05-30T10:32:57,749 INFO  [LibraryDeltaScanner] Added repository 'E:\aint you seen my movies' to delta scanner (POLLER)
2022-05-30T10:33:09,728 INFO  [LibraryDeltaScanner] Added repository 'E:\cartoons' to delta scanner (POLLER)
2022-05-30T10:33:09,758 INFO  [LibraryDeltaScanner] Added repository 'E:\mo gnar gnar' to delta scanner (POLLER)
2022-05-30T10:33:09,758 INFO  [LibraryDeltaScanner] Starting the library delta scan
2022-05-30T10:33:11,629 INFO  [PlaylistMaintainerWorker] Started looking for playlist changes
2022-05-30T10:33:13,035 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\blood.and.oil.2015.s01e09.720p.hdtv.hevc.x265.rmteam.mkv). Message: Unknown video file type.
2022-05-30T10:33:14,186 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\Nova - The Spy Factory Full Video-ZdPpdu8OGDQ.mkv). Message: Unknown video codec.
2022-05-30T10:33:15,535 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Disney\peter.pan.1953.720p.bluray.x264.yify___571a4a81945dd.mp4). Message: Unknown video file type.
2022-05-30T10:33:17,617 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 101 Manrattan [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:18,722 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 102 Inherit the Cheese [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:19,128 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 103 Spring of Love [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:20,345 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 104 Rat Day Afternoon [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:21,085 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 105 Mergers and Acquisitions [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:22,022 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 106 Old Flame [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:22,367 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 107 The Reunion [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:22,700 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 108 Sleeps with the Fishes [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:23,130 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 109 Strange Bedfellows [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:23,536 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 110 This Is Not a Pipe [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:23,975 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111a Catch Me If You Can [andy5421].avi). Message: Unknown video file type.
2022-05-30T10:33:24,620 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111b King of Rats.avi). Message: Unknown video file type.
2022-05-30T10:33:25,012 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 112a Future Ex-Wife.avi). Message: Unknown video file type.
2022-05-30T10:33:25,401 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 113 A Good Execution.avi). Message: Unknown video file type.
2022-05-30T10:33:25,977 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Lupin III Part II\70b350608b81210b37a74f1d56b4c2ed-70b350608b81210b37a74f1d56b4c2ed.mp4). Message: Unknown video file type.
2022-05-30T10:33:26,992 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Ronin Warriors\Ronin Warriors- Ep 7.mkv). Message: Unknown video file type.
2022-05-30T10:33:28,852 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\v.mp4). Message: Unknown video file type.
2022-05-30T10:34:56,877 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\12 months.mp4). Message: Unknown video file type.
2022-05-30T10:34:56,919 INFO  [LibraryOneTimeScanner] Interrupting library scan
2022-05-30T10:34:56,919 INFO  [LibraryDeltaScanner] Stopping the library delta scan
2022-05-30T10:34:56,920 INFO  [PlaylistMaintainerWorker] Finished looking for playlist changes
2022-05-30T10:34:57,078 INFO  [LocalLibraryManager] Starting automatic library scan
2022-05-30T10:34:57,818 INFO  [LibraryDeltaScanner] Added repository 'E:\aint you seen my movies' to delta scanner (POLLER)
2022-05-30T10:34:59,318 INFO  [LibraryDeltaScanner] Added repository 'E:\cartoons' to delta scanner (POLLER)
2022-05-30T10:34:59,319 WARN  [FileDeltaWatcher] There was an error while adding seen directory E:\mo gnar gnar
java.nio.file.NotDirectoryException: E:\mo gnar gnar\Cooking With Gas S03E02.ts
   at sun.nio.fs.WindowsDirectoryStream.<init>(WindowsDirectoryStream.java:84) ~[?:1.8.0_242]
   at sun.nio.fs.WindowsFileSystemProvider.newDirectoryStream(WindowsFileSystemProvider.java:518) ~[?:1.8.0_242]
   at java.nio.file.Files.newDirectoryStream(Files.java:457) ~[?:1.8.0_242]
   at java.nio.file.FileTreeWalker.visit(FileTreeWalker.java:300) ~[?:1.8.0_242]
   at java.nio.file.FileTreeWalker.next(FileTreeWalker.java:372) ~[?:1.8.0_242]
   at java.nio.file.Files.walkFileTree(Files.java:2706) ~[?:1.8.0_242]
   at java.nio.file.Files.walkFileTree(Files.java:2742) ~[?:1.8.0_242]
   at org.serviio.library.local.indexing.watching.FileDeltaWatcher.seeDirectory(FileDeltaWatcher.java:362) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.watching.FileDeltaWatcher.registerDirectory(FileDeltaWatcher.java:301) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.watching.FileDeltaWatcher.register(FileDeltaWatcher.java:285) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.watching.FileDeltaWatcher.registerAll(FileDeltaWatcher.java:264) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.watching.FileDeltaWatcher.repositoryAdded(FileDeltaWatcher.java:144) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.LibraryDeltaScanner.repositoryAdded(LibraryDeltaScanner.java:117) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.LibraryDeltaScanner.registerRepository(LibraryDeltaScanner.java:105) ~[serviio.jar:?]
   at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183) ~[?:1.8.0_242]
   at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175) ~[?:1.8.0_242]
   at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382) ~[?:1.8.0_242]
   at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482) ~[?:1.8.0_242]
   at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472) ~[?:1.8.0_242]
   at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:1.8.0_242]
   at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:1.8.0_242]
   at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_242]
   at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:485) ~[?:1.8.0_242]
   at org.serviio.library.local.indexing.LibraryDeltaScanner.reloadRepositories(LibraryDeltaScanner.java:101) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.LocalLibraryManager.performManualScan(LocalLibraryManager.java:196) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.LocalLibraryManager.startLibraryScanning(LocalLibraryManager.java:122) ~[serviio.jar:?]
   at org.serviio.ui.resources.server.RepositoryServerResource.lambda$save$0(RepositoryServerResource.java:109) ~[serviio.jar:?]
   at java.lang.Thread.run(Thread.java:748) [?:1.8.0_242]
2022-05-30T10:34:59,320 INFO  [LibraryDeltaScanner] Added repository 'E:\mo gnar gnar' to delta scanner (NATIVE)
2022-05-30T10:34:59,320 INFO  [LibraryDeltaScanner] Starting the library delta scan
2022-05-30T10:35:02,537 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\blood.and.oil.2015.s01e09.720p.hdtv.hevc.x265.rmteam.mkv). Message: Unknown video file type.
2022-05-30T10:35:03,557 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\Nova - The Spy Factory Full Video-ZdPpdu8OGDQ.mkv). Message: Unknown video codec.
2022-05-30T10:35:03,576 INFO  [PlaylistMaintainerWorker] Started looking for playlist changes
2022-05-30T10:35:04,562 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Disney\peter.pan.1953.720p.bluray.x264.yify___571a4a81945dd.mp4). Message: Unknown video file type.
2022-05-30T10:35:05,701 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 101 Manrattan [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:05,985 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 102 Inherit the Cheese [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:06,310 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 103 Spring of Love [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:06,593 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 104 Rat Day Afternoon [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:06,908 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 105 Mergers and Acquisitions [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:07,221 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 106 Old Flame [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:07,545 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 107 The Reunion [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:07,887 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 108 Sleeps with the Fishes [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:08,195 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 109 Strange Bedfellows [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:08,646 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 110 This Is Not a Pipe [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:09,207 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111a Catch Me If You Can [andy5421].avi). Message: Unknown video file type.
2022-05-30T10:35:09,977 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111b King of Rats.avi). Message: Unknown video file type.
2022-05-30T10:35:10,256 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 112a Future Ex-Wife.avi). Message: Unknown video file type.
2022-05-30T10:35:10,606 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 113 A Good Execution.avi). Message: Unknown video file type.
2022-05-30T10:35:11,138 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Lupin III Part II\70b350608b81210b37a74f1d56b4c2ed-70b350608b81210b37a74f1d56b4c2ed.mp4). Message: Unknown video file type.
2022-05-30T10:35:11,636 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Ronin Warriors\Ronin Warriors- Ep 7.mkv). Message: Unknown video file type.
2022-05-30T10:35:12,283 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\v.mp4). Message: Unknown video file type.
2022-05-30T10:35:42,706 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_alps.mp4' (title: _alps) to Library
2022-05-30T10:35:45,353 INFO  [MediaFileIndexer] Removing '_alps' (E:\mo gnar gnar\_alps.mp4) from Library
2022-05-30T10:35:48,843 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\alps.mp4' (title: alps) to Library
2022-05-30T10:37:25,468 WARN  [FileDeltaWatcher] There was an error while adding files from directory E:\mo gnar gnar\_Cooking With Gas S03E02.ts
java.nio.file.NotDirectoryException: E:\mo gnar gnar\_Cooking With Gas S03E02.ts
   at java.nio.file.FileTreeWalker.walk(FileTreeWalker.java:322) ~[?:1.8.0_242]
   at java.nio.file.Files.walkFileTree(Files.java:2662) ~[?:1.8.0_242]
   at org.serviio.library.local.indexing.watching.FileDeltaWatcher.addAllFilesInFolder(FileDeltaWatcher.java:322) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.watching.FileDeltaWatcher.access$1200(FileDeltaWatcher.java:66) ~[serviio.jar:?]
   at org.serviio.library.local.indexing.watching.FileDeltaWatcher$FileDeltaWatcherWorker.lambda$run$0(FileDeltaWatcher.java:447) ~[serviio.jar:?]
   at java.util.Optional.ifPresent(Optional.java:159) [?:1.8.0_242]
   at org.serviio.library.local.indexing.watching.FileDeltaWatcher$FileDeltaWatcherWorker.run(FileDeltaWatcher.java:419) [serviio.jar:?]
2022-05-30T10:37:28,438 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ1.ts' (title: BOJ1) to Library
2022-05-30T10:37:31,480 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ2.ts' (title: BOJ2) to Library
2022-05-30T10:37:33,936 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ3.ts' (title: BOJ3) to Library
2022-05-30T10:37:37,200 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ4.ts' (title: BOJ4) to Library
2022-05-30T10:37:39,358 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ5.ts' (title: BOJ5) to Library
2022-05-30T10:37:42,758 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ6.ts' (title: BOJ6) to Library
2022-05-30T10:37:45,791 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ7.ts' (title: BOJ7) to Library
2022-05-30T10:37:47,656 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_[Snowboard 2010] - Almost Dead - XVid+Mp3.avi' (title: _[Snowboard 2010] - Almost Dead - XVid+Mp3) to Library
2022-05-30T10:37:49,400 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_[Snowboard 2010] - Get In The Van [XVid+Mp3].avi' (title: _[Snowboard 2010] - Get In The Van [XVid+Mp3]) to Library
2022-05-30T10:37:51,463 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi' (title: _[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]) to Library
2022-05-30T10:37:51,503 WARN  [FileDeltaWatcher] There was an error while adding files from directory E:\mo gnar gnar\Cooking With Gas S03E02.ts
2022-05-30T10:37:52,270 WARN  [MetadataExtractionCoordinator] Cannot read metadata of file E:\mo gnar gnar\_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi via extractor EMBEDDED. Message: File E:\mo gnar gnar\_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi cannot be read to extract metadata
2022-05-30T10:37:52,304 INFO  [MediaFileIndexer] Removing '&quot;siberian_wild&quot;_1280x720' (E:\mo gnar gnar\&quot;siberian_wild&quot;_1280x720.mp4) from Library
2022-05-30T10:37:52,403 INFO  [MediaFileIndexer] Removing 'alps' (E:\mo gnar gnar\alps.mp4) from Library
2022-05-30T10:38:46,767 INFO  [LocalLibraryManager] Starting manual library scan
2022-05-30T10:41:02,169 WARN  [MetadataExtractionCoordinator] Cannot read metadata of file E:\mo gnar gnar\_Cheers 2010.mp4 via extractor EMBEDDED. Message: File E:\mo gnar gnar\_Cheers 2010.mp4 cannot be read to extract metadata
2022-05-30T10:41:02,794 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\12 months.mp4). Message: Unknown video file type.
2022-05-30T10:41:02,902 INFO  [LibraryOneTimeScanner] Interrupting library scan
2022-05-30T10:41:02,906 INFO  [PlaylistMaintainerWorker] Finished looking for playlist changes
2022-05-30T10:41:03,004 INFO  [LibraryDeltaScanner] Stopping the library delta scan
2022-05-30T10:41:03,010 INFO  [PlaylistMaintainerWorker] Started looking for playlist changes
2022-05-30T10:41:03,073 INFO  [LocalLibraryManager] Starting automatic library scan
2022-05-30T10:41:03,719 INFO  [LibraryDeltaScanner] Added repository 'E:\aint you seen my movies' to delta scanner (POLLER)
2022-05-30T10:41:05,112 INFO  [LibraryDeltaScanner] Added repository 'E:\cartoons' to delta scanner (POLLER)
2022-05-30T10:41:05,160 INFO  [LibraryDeltaScanner] Added repository 'E:\mo gnar gnar' to delta scanner (POLLER)
2022-05-30T10:41:05,160 INFO  [LibraryDeltaScanner] Starting the library delta scan
2022-05-30T10:41:07,948 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\blood.and.oil.2015.s01e09.720p.hdtv.hevc.x265.rmteam.mkv). Message: Unknown video file type.
2022-05-30T10:41:09,585 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\Nova - The Spy Factory Full Video-ZdPpdu8OGDQ.mkv). Message: Unknown video codec.
2022-05-30T10:41:10,911 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Disney\peter.pan.1953.720p.bluray.x264.yify___571a4a81945dd.mp4). Message: Unknown video file type.
2022-05-30T10:41:12,254 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 101 Manrattan [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:12,542 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 102 Inherit the Cheese [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:12,886 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 103 Spring of Love [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:13,194 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 104 Rat Day Afternoon [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:13,742 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 105 Mergers and Acquisitions [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:14,911 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 106 Old Flame [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:15,926 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 107 The Reunion [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:16,280 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 108 Sleeps with the Fishes [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:16,814 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 109 Strange Bedfellows [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:17,232 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 110 This Is Not a Pipe [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:17,707 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111a Catch Me If You Can [andy5421].avi). Message: Unknown video file type.
2022-05-30T10:41:18,457 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111b King of Rats.avi). Message: Unknown video file type.
2022-05-30T10:41:18,770 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 112a Future Ex-Wife.avi). Message: Unknown video file type.
2022-05-30T10:41:19,145 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 113 A Good Execution.avi). Message: Unknown video file type.
2022-05-30T10:41:19,643 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Lupin III Part II\70b350608b81210b37a74f1d56b4c2ed-70b350608b81210b37a74f1d56b4c2ed.mp4). Message: Unknown video file type.
2022-05-30T10:41:20,298 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Ronin Warriors\Ronin Warriors- Ep 7.mkv). Message: Unknown video file type.
2022-05-30T10:41:21,287 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\v.mp4). Message: Unknown video file type.
2022-05-30T10:41:22,690 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\&quot;siberianwild&quot;1280x720.mp4' (title: &quot;siberianwild&quot;1280x720) to Library
2022-05-30T10:43:13,552 INFO  [MediaFileIndexer] Removing '&quot;siberianwild&quot;1280x720' (E:\mo gnar gnar\&quot;siberianwild&quot;1280x720.mp4) from Library
2022-05-30T10:43:15,883 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_&quot;siberianwild&quot;1280x720.mp4' (title: _&quot;siberianwild&quot;1280x720) to Library
2022-05-30T10:43:17,915 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_2010-burton.snowboards-the.b.avi' (title: _2010-burton.snowboards-the.b) to Library
2022-05-30T10:43:21,030 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_28 Winters.mp4' (title: _28 Winters) to Library
2022-05-30T10:43:22,773 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi' (title: _[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]) to Library
2022-05-30T10:43:24,979 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4' (title: _A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112) to Library
2022-05-30T10:43:27,395 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_A Place Called Kookabunga.mp4' (title: _A Place Called Kookabunga) to Library
2022-05-30T10:43:29,792 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Absinthe.Films.Heavy.Mental.mp4' (title: _Absinthe.Films.Heavy.Mental) to Library
2022-05-30T10:43:31,637 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Absinthe.Neverland.2009.DVDRip.XviD-XB.avi' (title: _Absinthe.Neverland.2009.DVDRip.XviD-XB) to Library
2022-05-30T10:43:34,208 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_AfterForever-455822.mp4' (title: _AfterForever-455822) to Library
2022-05-30T10:43:36,127 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_alps.mp4' (title: _alps) to Library
2022-05-30T10:43:37,521 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi' (title: _Alterna.Films-Elektro.2009.DVDRiP.XViD-XB) to Library
2022-05-30T10:43:39,488 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Apples & Oranges  -by fester.avi' (title: _Apples & Oranges  -by fester) to Library
2022-05-30T10:43:41,096 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Appreciate.That.mp4' (title: _Appreciate.That) to Library
2022-05-30T10:43:42,725 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Approach and Attack.mp4' (title: _Approach and Attack) to Library
2022-05-30T10:43:45,017 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_As The Crow Flies.ts' (title: _As The Crow Flies) to Library
2022-05-30T10:43:46,776 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4' (title: _ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow) to Library
2022-05-30T10:43:51,810 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk.mkv' (title: _AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk) to Library
2022-05-30T10:43:54,111 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_B Proddi - The Full Length.mp4' (title: _B Proddi - The Full Length) to Library
2022-05-30T10:43:55,534 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Beyond.Medals.Betty.Ford.mkv' (title: _Beyond.Medals.Betty.Ford) to Library
2022-05-30T10:43:57,009 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_big jean fantasy.mp4' (title: _big jean fantasy) to Library
2022-05-30T10:43:58,699 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Blood Brothers.mp4' (title: _Blood Brothers) to Library
2022-05-30T10:44:00,038 WARN  [MetadataExtractionCoordinator] Cannot read metadata of file E:\mo gnar gnar\_BOOM.ts via extractor EMBEDDED. Message: E:\mo gnar gnar\_BOOM.ts (The system cannot find the file specified)
2022-05-30T10:44:17,107 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\&quot;siberianwild&quot;1280x720.mp4' (title: &quot;siberianwild&quot;1280x720) to Library
2022-05-30T10:44:18,492 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\2010-burton.snowboards-the.b.avi' (title: 2010-burton.snowboards-the.b) to Library
2022-05-30T10:44:20,863 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\28 Winters.mp4' (title: 28 Winters) to Library
2022-05-30T10:44:22,367 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Almost Dead - XVid+Mp3.avi' (title: [Snowboard 2010] - Almost Dead - XVid+Mp3) to Library
2022-05-30T10:44:23,876 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Get In The Van [XVid+Mp3].avi' (title: [Snowboard 2010] - Get In The Van [XVid+Mp3]) to Library
2022-05-30T10:44:25,303 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi' (title: [Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]) to Library
2022-05-30T10:44:26,625 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi' (title: [Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]) to Library
2022-05-30T10:44:26,627 INFO  [MediaFileIndexer] Removing '_&quot;siberianwild&quot;1280x720' (E:\mo gnar gnar\_&quot;siberianwild&quot;1280x720.mp4) from Library
2022-05-30T10:44:26,699 INFO  [MediaFileIndexer] Removing '_2010-burton.snowboards-the.b' (E:\mo gnar gnar\_2010-burton.snowboards-the.b.avi) from Library
2022-05-30T10:44:26,744 INFO  [MediaFileIndexer] Removing '_28 Winters' (E:\mo gnar gnar\_28 Winters.mp4) from Library
2022-05-30T10:44:26,794 INFO  [MediaFileIndexer] Removing '_[Snowboard 2010] - Almost Dead - XVid+Mp3' (E:\mo gnar gnar\_[Snowboard 2010] - Almost Dead - XVid+Mp3.avi) from Library
2022-05-30T10:44:26,853 INFO  [MediaFileIndexer] Removing '_[Snowboard 2010] - Get In The Van [XVid+Mp3]' (E:\mo gnar gnar\_[Snowboard 2010] - Get In The Van [XVid+Mp3].avi) from Library
2022-05-30T10:44:26,895 INFO  [MediaFileIndexer] Removing '_[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]' (E:\mo gnar gnar\_[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi) from Library
2022-05-30T10:44:26,962 INFO  [MediaFileIndexer] Removing '_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]' (E:\mo gnar gnar\_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi) from Library
2022-05-30T10:44:27,004 INFO  [MediaFileIndexer] Removing '_A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112' (E:\mo gnar gnar\_A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4) from Library
2022-05-30T10:44:27,068 INFO  [MediaFileIndexer] Removing '_A Place Called Kookabunga' (E:\mo gnar gnar\_A Place Called Kookabunga.mp4) from Library
2022-05-30T10:44:27,111 INFO  [MediaFileIndexer] Removing '_Absinthe.Films.Heavy.Mental' (E:\mo gnar gnar\_Absinthe.Films.Heavy.Mental.mp4) from Library
2022-05-30T10:44:27,170 INFO  [MediaFileIndexer] Removing '_Absinthe.Neverland.2009.DVDRip.XviD-XB' (E:\mo gnar gnar\_Absinthe.Neverland.2009.DVDRip.XviD-XB.avi) from Library
2022-05-30T10:44:27,212 INFO  [MediaFileIndexer] Removing '_AfterForever-455822' (E:\mo gnar gnar\_AfterForever-455822.mp4) from Library
2022-05-30T10:44:27,263 INFO  [MediaFileIndexer] Removing '_alps' (E:\mo gnar gnar\_alps.mp4) from Library
2022-05-30T10:44:27,303 INFO  [MediaFileIndexer] Removing '_Alterna.Films-Elektro.2009.DVDRiP.XViD-XB' (E:\mo gnar gnar\_Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi) from Library
2022-05-30T10:44:27,345 INFO  [MediaFileIndexer] Removing '_Apples & Oranges  -by fester' (E:\mo gnar gnar\_Apples & Oranges  -by fester.avi) from Library
2022-05-30T10:44:27,395 INFO  [MediaFileIndexer] Removing '_Appreciate.That' (E:\mo gnar gnar\_Appreciate.That.mp4) from Library
2022-05-30T10:44:27,445 INFO  [MediaFileIndexer] Removing '_Approach and Attack' (E:\mo gnar gnar\_Approach and Attack.mp4) from Library
2022-05-30T10:44:27,489 INFO  [MediaFileIndexer] Removing '_As The Crow Flies' (E:\mo gnar gnar\_As The Crow Flies.ts) from Library
2022-05-30T10:44:27,529 INFO  [MediaFileIndexer] Removing '_ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow' (E:\mo gnar gnar\_ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4) from Library
2022-05-30T10:44:27,586 INFO  [MediaFileIndexer] Removing '_AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk' (E:\mo gnar gnar\_AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk.mkv) from Library
2022-05-30T10:44:27,638 INFO  [MediaFileIndexer] Removing '_B Proddi - The Full Length' (E:\mo gnar gnar\_B Proddi - The Full Length.mp4) from Library
2022-05-30T10:44:27,686 INFO  [MediaFileIndexer] Removing 'BOJ1' (E:\mo gnar gnar\_Book of John\BOJ1.ts) from Library
2022-05-30T10:44:27,731 INFO  [MediaFileIndexer] Removing 'BOJ2' (E:\mo gnar gnar\_Book of John\BOJ2.ts) from Library
2022-05-30T10:44:27,770 INFO  [MediaFileIndexer] Removing 'BOJ3' (E:\mo gnar gnar\_Book of John\BOJ3.ts) from Library
2022-05-30T10:44:27,812 INFO  [MediaFileIndexer] Removing 'BOJ4' (E:\mo gnar gnar\_Book of John\BOJ4.ts) from Library
2022-05-30T10:44:27,853 INFO  [MediaFileIndexer] Removing 'BOJ5' (E:\mo gnar gnar\_Book of John\BOJ5.ts) from Library
2022-05-30T10:44:28,024 INFO  [MediaFileIndexer] Removing 'BOJ6' (E:\mo gnar gnar\_Book of John\BOJ6.ts) from Library
2022-05-30T10:44:28,065 INFO  [MediaFileIndexer] Removing 'BOJ7' (E:\mo gnar gnar\_Book of John\BOJ7.ts) from Library
2022-05-30T10:44:30,008 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4' (title: A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112) to Library
2022-05-30T10:44:32,265 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\A Place Called Kookabunga.mp4' (title: A Place Called Kookabunga) to Library
2022-05-30T10:44:34,503 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Absinthe.Films.Heavy.Mental.mp4' (title: Absinthe.Films.Heavy.Mental) to Library
2022-05-30T10:44:36,054 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Absinthe.Neverland.2009.DVDRip.XviD-XB.avi' (title: Absinthe.Neverland.2009.DVDRip.XviD-XB) to Library
2022-05-30T10:44:38,505 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\AfterForever-455822.mp4' (title: AfterForever-455822) to Library
2022-05-30T10:44:40,284 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\alps.mp4' (title: alps) to Library
2022-05-30T10:44:41,556 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi' (title: Alterna.Films-Elektro.2009.DVDRiP.XViD-XB) to Library
2022-05-30T10:44:43,503 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Apples & Oranges  -by fester.avi' (title: Apples & Oranges  -by fester) to Library
2022-05-30T10:44:45,218 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Appreciate.That.mp4' (title: Appreciate.That) to Library
2022-05-30T10:44:46,906 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Approach and Attack.mp4' (title: Approach and Attack) to Library
2022-05-30T10:44:48,801 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\As The Crow Flies.ts' (title: As The Crow Flies) to Library
2022-05-30T10:44:50,393 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4' (title: ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow) to Library
2022-05-30T10:44:54,879 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk.mkv' (title: AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk) to Library
2022-05-30T10:44:56,642 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\B Proddi - The Full Length.mp4' (title: B Proddi - The Full Length) to Library
2022-05-30T10:44:58,909 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ1.ts' (title: BOJ1) to Library
2022-05-30T10:45:01,356 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ2.ts' (title: BOJ2) to Library
2022-05-30T10:45:03,697 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ3.ts' (title: BOJ3) to Library
2022-05-30T10:45:05,839 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ4.ts' (title: BOJ4) to Library
2022-05-30T10:45:08,334 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ5.ts' (title: BOJ5) to Library
2022-05-30T10:45:11,667 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ6.ts' (title: BOJ6) to Library
2022-05-30T10:45:13,874 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ7.ts' (title: BOJ7) to Library
2022-05-30T10:45:16,054 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\BOOM.ts' (title: BOOM) to Library
2022-05-30T10:45:18,153 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\BRYAN FOX  LIFE IN GENERAL-Xo4gV3tuwoQ.mp4' (title: BRYAN FOX  LIFE IN GENERAL-Xo4gV3tuwoQ) to Library
2022-05-30T10:45:19,803 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Burton - Back Andes - 2017.mp4' (title: Burton - Back Andes - 2017) to Library
2022-05-30T10:45:22,241 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\CHAMäLEON.ts' (title: CHAMäLEON) to Library
2022-05-30T10:49:48,257 INFO  [LocalLibraryManager] Starting manual library scan
2022-05-30T10:51:11,194 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\Cheers 2010.mp4). Message: Unknown video file type.
2022-05-30T10:51:11,458 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\12 months.mp4). Message: Unknown video file type.
2022-05-30T10:51:11,488 INFO  [LibraryOneTimeScanner] Interrupting library scan
2022-05-30T10:51:11,489 INFO  [PlaylistMaintainerWorker] Finished looking for playlist changes
2022-05-30T10:51:11,588 INFO  [LibraryDeltaScanner] Stopping the library delta scan
2022-05-30T10:51:11,591 INFO  [PlaylistMaintainerWorker] Started looking for playlist changes
2022-05-30T10:51:11,624 INFO  [LocalLibraryManager] Starting automatic library scan
2022-05-30T10:51:12,300 INFO  [LibraryDeltaScanner] Added repository 'E:\aint you seen my movies' to delta scanner (POLLER)
2022-05-30T10:51:13,827 INFO  [LibraryDeltaScanner] Added repository 'E:\cartoons' to delta scanner (POLLER)
2022-05-30T10:51:13,875 INFO  [LibraryDeltaScanner] Added repository 'E:\mo gnar gnar' to delta scanner (POLLER)
2022-05-30T10:51:13,875 INFO  [LibraryDeltaScanner] Starting the library delta scan
2022-05-30T10:51:16,842 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\blood.and.oil.2015.s01e09.720p.hdtv.hevc.x265.rmteam.mkv). Message: Unknown video file type.
2022-05-30T10:51:18,306 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\Nova - The Spy Factory Full Video-ZdPpdu8OGDQ.mkv). Message: Unknown video codec.
2022-05-30T10:51:19,731 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Disney\peter.pan.1953.720p.bluray.x264.yify___571a4a81945dd.mp4). Message: Unknown video file type.
2022-05-30T10:51:21,101 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 101 Manrattan [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:21,490 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 102 Inherit the Cheese [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:21,823 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 103 Spring of Love [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:22,182 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 104 Rat Day Afternoon [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:22,490 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 105 Mergers and Acquisitions [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:22,852 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 106 Old Flame [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:23,198 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 107 The Reunion [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:23,505 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 108 Sleeps with the Fishes [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:23,815 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 109 Strange Bedfellows [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:24,192 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 110 This Is Not a Pipe [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:24,496 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111a Catch Me If You Can [andy5421].avi). Message: Unknown video file type.
2022-05-30T10:51:24,839 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111b King of Rats.avi). Message: Unknown video file type.
2022-05-30T10:51:25,171 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 112a Future Ex-Wife.avi). Message: Unknown video file type.
2022-05-30T10:51:25,483 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 113 A Good Execution.avi). Message: Unknown video file type.
2022-05-30T10:51:25,913 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Lupin III Part II\70b350608b81210b37a74f1d56b4c2ed-70b350608b81210b37a74f1d56b4c2ed.mp4). Message: Unknown video file type.
2022-05-30T10:51:26,349 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Ronin Warriors\Ronin Warriors- Ep 7.mkv). Message: Unknown video file type.
2022-05-30T10:51:26,893 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\v.mp4). Message: Unknown video file type.
2022-05-30T10:52:54,850 INFO  [MediaFileIndexer] Removing '&quot;siberianwild&quot;1280x720' (E:\mo gnar gnar\&quot;siberianwild&quot;1280x720.mp4) from Library
2022-05-30T10:52:54,946 INFO  [MediaFileIndexer] Removing '2010-burton.snowboards-the.b' (E:\mo gnar gnar\2010-burton.snowboards-the.b.avi) from Library
2022-05-30T10:52:54,994 INFO  [MediaFileIndexer] Removing '28 Winters' (E:\mo gnar gnar\28 Winters.mp4) from Library
2022-05-30T10:52:55,036 INFO  [MediaFileIndexer] Removing '[Snowboard 2010] - Almost Dead - XVid+Mp3' (E:\mo gnar gnar\[Snowboard 2010] - Almost Dead - XVid+Mp3.avi) from Library
2022-05-30T10:52:55,078 INFO  [MediaFileIndexer] Removing '[Snowboard 2010] - Get In The Van [XVid+Mp3]' (E:\mo gnar gnar\[Snowboard 2010] - Get In The Van [XVid+Mp3].avi) from Library
2022-05-30T10:52:55,119 INFO  [MediaFileIndexer] Removing '[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]' (E:\mo gnar gnar\[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi) from Library
2022-05-30T10:52:55,165 INFO  [MediaFileIndexer] Removing '[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]' (E:\mo gnar gnar\[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi) from Library
2022-05-30T10:52:55,212 INFO  [MediaFileIndexer] Removing '_big jean fantasy' (E:\mo gnar gnar\_big jean fantasy.mp4) from Library
2022-05-30T10:52:55,272 INFO  [MediaFileIndexer] Removing 'A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112' (E:\mo gnar gnar\A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4) from Library
2022-05-30T10:52:55,314 INFO  [MediaFileIndexer] Removing 'A Place Called Kookabunga' (E:\mo gnar gnar\A Place Called Kookabunga.mp4) from Library
2022-05-30T10:52:55,353 INFO  [MediaFileIndexer] Removing 'Absinthe.Films.Heavy.Mental' (E:\mo gnar gnar\Absinthe.Films.Heavy.Mental.mp4) from Library
2022-05-30T10:52:55,395 INFO  [MediaFileIndexer] Removing 'Absinthe.Neverland.2009.DVDRip.XviD-XB' (E:\mo gnar gnar\Absinthe.Neverland.2009.DVDRip.XviD-XB.avi) from Library
2022-05-30T10:52:55,445 INFO  [MediaFileIndexer] Removing 'AfterForever-455822' (E:\mo gnar gnar\AfterForever-455822.mp4) from Library
2022-05-30T10:52:55,486 INFO  [MediaFileIndexer] Removing 'alps' (E:\mo gnar gnar\alps.mp4) from Library
2022-05-30T10:52:55,528 INFO  [MediaFileIndexer] Removing 'Alterna.Films-Elektro.2009.DVDRiP.XViD-XB' (E:\mo gnar gnar\Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi) from Library
2022-05-30T10:52:55,569 INFO  [MediaFileIndexer] Removing 'Apples & Oranges  -by fester' (E:\mo gnar gnar\Apples & Oranges  -by fester.avi) from Library
2022-05-30T10:52:55,611 INFO  [MediaFileIndexer] Removing 'Appreciate.That' (E:\mo gnar gnar\Appreciate.That.mp4) from Library
2022-05-30T10:52:55,655 INFO  [MediaFileIndexer] Removing 'Approach and Attack' (E:\mo gnar gnar\Approach and Attack.mp4) from Library
2022-05-30T10:52:55,703 INFO  [MediaFileIndexer] Removing 'As The Crow Flies' (E:\mo gnar gnar\As The Crow Flies.ts) from Library
2022-05-30T10:52:55,753 INFO  [MediaFileIndexer] Removing 'ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow' (E:\mo gnar gnar\ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4) from Library
2022-05-30T10:52:55,795 INFO  [MediaFileIndexer] Removing 'AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk' (E:\mo gnar gnar\AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk.mkv) from Library
2022-05-30T10:52:55,862 INFO  [MediaFileIndexer] Removing 'B Proddi - The Full Length' (E:\mo gnar gnar\B Proddi - The Full Length.mp4) from Library
2022-05-30T10:52:55,943 INFO  [MediaFileIndexer] Removing 'BOJ1' (E:\mo gnar gnar\Book of John\BOJ1.ts) from Library
2022-05-30T10:52:56,001 INFO  [MediaFileIndexer] Removing 'BOJ2' (E:\mo gnar gnar\Book of John\BOJ2.ts) from Library
2022-05-30T10:52:56,063 INFO  [MediaFileIndexer] Removing 'BOJ3' (E:\mo gnar gnar\Book of John\BOJ3.ts) from Library
2022-05-30T10:52:56,118 INFO  [MediaFileIndexer] Removing 'BOJ4' (E:\mo gnar gnar\Book of John\BOJ4.ts) from Library
2022-05-30T10:52:56,237 INFO  [MediaFileIndexer] Removing 'BOJ5' (E:\mo gnar gnar\Book of John\BOJ5.ts) from Library
2022-05-30T10:52:56,290 INFO  [MediaFileIndexer] Removing 'BOJ6' (E:\mo gnar gnar\Book of John\BOJ6.ts) from Library
2022-05-30T10:52:56,363 INFO  [MediaFileIndexer] Removing 'BOJ7' (E:\mo gnar gnar\Book of John\BOJ7.ts) from Library
2022-05-30T10:52:56,566 INFO  [MediaFileIndexer] Removing 'BOOM' (E:\mo gnar gnar\BOOM.ts) from Library
2022-05-30T10:52:56,614 INFO  [MediaFileIndexer] Removing 'BRYAN FOX  LIFE IN GENERAL-Xo4gV3tuwoQ' (E:\mo gnar gnar\BRYAN FOX  LIFE IN GENERAL-Xo4gV3tuwoQ.mp4) from Library
2022-05-30T10:52:56,696 INFO  [MediaFileIndexer] Removing 'Burton - Back Andes - 2017' (E:\mo gnar gnar\Burton - Back Andes - 2017.mp4) from Library
2022-05-30T10:52:56,761 INFO  [MediaFileIndexer] Removing 'CHAMäLEON' (E:\mo gnar gnar\CHAMäLEON.ts) from Library
2022-05-30T10:52:59,404 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\~&quot;siberianwild&quot;1280x720.mp4' (title: ~&quot;siberianwild&quot;1280x720) to Library
2022-05-30T10:53:01,392 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\~2010-burton.snowboards-the.b.avi' (title: ~2010-burton.snowboards-the.b) to Library
2022-05-30T10:53:04,455 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\~28 Winters.mp4' (title: ~28 Winters) to Library
2022-05-30T10:53:13,180 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\&quot;siberianwild&quot;1280x720.mp4' (title: &quot;siberianwild&quot;1280x720) to Library
2022-05-30T10:53:14,566 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\2010-burton.snowboards-the.b.avi' (title: 2010-burton.snowboards-the.b) to Library
2022-05-30T10:53:15,902 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Almost Dead - XVid+Mp3.avi' (title: [Snowboard 2010] - Almost Dead - XVid+Mp3) to Library
2022-05-30T10:53:17,460 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Get In The Van [XVid+Mp3].avi' (title: [Snowboard 2010] - Get In The Van [XVid+Mp3]) to Library
2022-05-30T10:53:18,900 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi' (title: [Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]) to Library
2022-05-30T10:53:20,252 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi' (title: [Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]) to Library
2022-05-30T10:53:22,029 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\_big jean fantasy.mp4' (title: _big jean fantasy) to Library
2022-05-30T10:53:23,824 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4' (title: A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112) to Library
2022-05-30T10:53:26,139 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\A Place Called Kookabunga.mp4' (title: A Place Called Kookabunga) to Library
2022-05-30T10:53:28,358 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Absinthe.Films.Heavy.Mental.mp4' (title: Absinthe.Films.Heavy.Mental) to Library
2022-05-30T10:53:30,200 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Absinthe.Neverland.2009.DVDRip.XviD-XB.avi' (title: Absinthe.Neverland.2009.DVDRip.XviD-XB) to Library
2022-05-30T10:53:32,225 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\AfterForever-455822.mp4' (title: AfterForever-455822) to Library
2022-05-30T10:53:33,994 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\alps.mp4' (title: alps) to Library
2022-05-30T10:53:35,291 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi' (title: Alterna.Films-Elektro.2009.DVDRiP.XViD-XB) to Library
2022-05-30T10:53:37,233 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Apples & Oranges  -by fester.avi' (title: Apples & Oranges  -by fester) to Library
2022-05-30T10:53:38,776 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Appreciate.That.mp4' (title: Appreciate.That) to Library
2022-05-30T10:53:40,421 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Approach and Attack.mp4' (title: Approach and Attack) to Library
2022-05-30T10:53:42,923 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\As The Crow Flies.ts' (title: As The Crow Flies) to Library
2022-05-30T10:53:44,457 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4' (title: ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow) to Library
2022-05-30T10:53:48,568 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk.mkv' (title: AUSTEN SWEETIN  WIND SLAB-2hyw79e3wk) to Library
2022-05-30T10:53:50,665 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\B Proddi - The Full Length.mp4' (title: B Proddi - The Full Length) to Library
2022-05-30T10:53:52,045 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Beyond.Medals.Betty.Ford.mkv' (title: Beyond.Medals.Betty.Ford) to Library
2022-05-30T10:53:53,621 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Blood Brothers.mp4' (title: Blood Brothers) to Library
2022-05-30T10:53:55,915 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ1.ts' (title: BOJ1) to Library
2022-05-30T10:53:58,262 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ2.ts' (title: BOJ2) to Library
2022-05-30T10:54:00,585 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ3.ts' (title: BOJ3) to Library
2022-05-30T10:54:02,787 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ4.ts' (title: BOJ4) to Library
2022-05-30T10:54:04,785 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ5.ts' (title: BOJ5) to Library
2022-05-30T10:54:07,485 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ6.ts' (title: BOJ6) to Library
2022-05-30T10:54:09,529 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ7.ts' (title: BOJ7) to Library
2022-05-30T10:54:11,376 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\BOOM.ts' (title: BOOM) to Library
2022-05-30T10:54:13,201 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\BRYAN FOX  LIFE IN GENERAL-Xo4gV3tuwoQ.mp4' (title: BRYAN FOX  LIFE IN GENERAL-Xo4gV3tuwoQ) to Library
2022-05-30T10:54:15,037 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\Burton - Back Andes - 2017.mp4' (title: Burton - Back Andes - 2017) to Library
2022-05-30T10:54:17,068 INFO  [MediaFileIndexer] Added file 'E:\mo gnar gnar\CHAMäLEON.ts' (title: CHAMäLEON) to Library
Maybe something in windows 10 changed but serviio is not working correctly for me.
Previous
Users browsing this forum: No registered users and 74 guests
