Re: Serviio stopped sharing new stuff.
Is Serviio well and truly broken? Any Serviio developers here who can help?
Complete name : E:\mo gnar gnar\Cheers 2010.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 881 MiB
Duration : 49mn 59s
Overall bit rate : 2 462 Kbps
Writing application : Lavf58.65.100
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 49mn 59s
Bit rate : 2 400 Kbps
Maximum bit rate : 2 361 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.087
Stream size : 844 MiB (96%)
Writing library : x264 core 157 r2965 861cec4
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=150 / keyint_min=76 / scenecut=0 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2400 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=2640 / vbv_bufsize=2880 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 49mn 59s
Bit rate mode : Variable
Bit rate : 93.4 Kbps
Maximum bit rate : 97.0 Kbps / 97.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 33.4 MiB (4%)2022-05-28T12:23:26,009 INFO [MediaFileIndexer] Added file 'E:\cartoons\[Dragon Ball Z - Battle of Gods][1080P][x264].mkv' (title: Dragon Ball Z: Battle of Gods) to Library
2022-05-28T12:23:27,015 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\"siberian_wild"_1280x720.mp4' (title: "siberian_wild"_1280x720) to Library
2022-05-29T11:02:00,367 INFO [UpdateChecker] Checking if a new version is available
2022-05-30T10:32:53,504 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\12 months.mp4). Message: Unknown video file type.
2022-05-30T10:32:53,541 INFO [LibraryOneTimeScanner] Interrupting library scan
2022-05-30T10:32:53,541 INFO [LibraryDeltaScanner] Stopping the library delta scan
2022-05-30T10:32:53,543 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2022-05-30T10:32:53,839 INFO [LocalLibraryManager] Starting automatic library scan
2022-05-30T10:32:57,749 INFO [LibraryDeltaScanner] Added repository 'E:\aint you seen my movies' to delta scanner (POLLER)
2022-05-30T10:33:09,728 INFO [LibraryDeltaScanner] Added repository 'E:\cartoons' to delta scanner (POLLER)
2022-05-30T10:33:09,758 INFO [LibraryDeltaScanner] Added repository 'E:\mo gnar gnar' to delta scanner (POLLER)
2022-05-30T10:33:09,758 INFO [LibraryDeltaScanner] Starting the library delta scan
2022-05-30T10:33:11,629 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2022-05-30T10:33:13,035 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\blood.and.oil.2015.s01e09.720p.hdtv.hevc.x265.rmteam.mkv). Message: Unknown video file type.
2022-05-30T10:33:14,186 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\Nova - The Spy Factory Full Video-ZdPpdu8OGDQ.mkv). Message: Unknown video codec.
2022-05-30T10:33:15,535 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Disney\peter.pan.1953.720p.bluray.x264.yify___571a4a81945dd.mp4). Message: Unknown video file type.
2022-05-30T10:33:17,617 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 101 Manrattan [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:18,722 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 102 Inherit the Cheese [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:19,128 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 103 Spring of Love [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:20,345 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 104 Rat Day Afternoon [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:21,085 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 105 Mergers and Acquisitions [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:22,022 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 106 Old Flame [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:22,367 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 107 The Reunion [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:22,700 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 108 Sleeps with the Fishes [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:23,130 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 109 Strange Bedfellows [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:23,536 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 110 This Is Not a Pipe [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:33:23,975 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111a Catch Me If You Can [andy5421].avi). Message: Unknown video file type.
2022-05-30T10:33:24,620 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111b King of Rats.avi). Message: Unknown video file type.
2022-05-30T10:33:25,012 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 112a Future Ex-Wife.avi). Message: Unknown video file type.
2022-05-30T10:33:25,401 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 113 A Good Execution.avi). Message: Unknown video file type.
2022-05-30T10:33:25,977 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Lupin III Part II\70b350608b81210b37a74f1d56b4c2ed-70b350608b81210b37a74f1d56b4c2ed.mp4). Message: Unknown video file type.
2022-05-30T10:33:26,992 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Ronin Warriors\Ronin Warriors- Ep 7.mkv). Message: Unknown video file type.
2022-05-30T10:33:28,852 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\v.mp4). Message: Unknown video file type.
2022-05-30T10:34:56,877 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\12 months.mp4). Message: Unknown video file type.
2022-05-30T10:34:56,919 INFO [LibraryOneTimeScanner] Interrupting library scan
2022-05-30T10:34:56,919 INFO [LibraryDeltaScanner] Stopping the library delta scan
2022-05-30T10:34:56,920 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2022-05-30T10:34:57,078 INFO [LocalLibraryManager] Starting automatic library scan
2022-05-30T10:34:57,818 INFO [LibraryDeltaScanner] Added repository 'E:\aint you seen my movies' to delta scanner (POLLER)
2022-05-30T10:34:59,318 INFO [LibraryDeltaScanner] Added repository 'E:\cartoons' to delta scanner (POLLER)
2022-05-30T10:34:59,319 WARN [FileDeltaWatcher] There was an error while adding seen directory E:\mo gnar gnar
java.nio.file.NotDirectoryException: E:\mo gnar gnar\Cooking With Gas S03E02.ts
at sun.nio.fs.WindowsDirectoryStream.<init>(WindowsDirectoryStream.java:84) ~[?:1.8.0_242]
at sun.nio.fs.WindowsFileSystemProvider.newDirectoryStream(WindowsFileSystemProvider.java:518) ~[?:1.8.0_242]
at java.nio.file.Files.newDirectoryStream(Files.java:457) ~[?:1.8.0_242]
at java.nio.file.FileTreeWalker.visit(FileTreeWalker.java:300) ~[?:1.8.0_242]
at java.nio.file.FileTreeWalker.next(FileTreeWalker.java:372) ~[?:1.8.0_242]
at java.nio.file.Files.walkFileTree(Files.java:2706) ~[?:1.8.0_242]
at java.nio.file.Files.walkFileTree(Files.java:2742) ~[?:1.8.0_242]
at org.serviio.library.local.indexing.watching.FileDeltaWatcher.seeDirectory(FileDeltaWatcher.java:362) ~[serviio.jar:?]
at org.serviio.library.local.indexing.watching.FileDeltaWatcher.registerDirectory(FileDeltaWatcher.java:301) ~[serviio.jar:?]
at org.serviio.library.local.indexing.watching.FileDeltaWatcher.register(FileDeltaWatcher.java:285) ~[serviio.jar:?]
at org.serviio.library.local.indexing.watching.FileDeltaWatcher.registerAll(FileDeltaWatcher.java:264) ~[serviio.jar:?]
at org.serviio.library.local.indexing.watching.FileDeltaWatcher.repositoryAdded(FileDeltaWatcher.java:144) ~[serviio.jar:?]
at org.serviio.library.local.indexing.LibraryDeltaScanner.repositoryAdded(LibraryDeltaScanner.java:117) ~[serviio.jar:?]
at org.serviio.library.local.indexing.LibraryDeltaScanner.registerRepository(LibraryDeltaScanner.java:105) ~[serviio.jar:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183) ~[?:1.8.0_242]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175) ~[?:1.8.0_242]
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382) ~[?:1.8.0_242]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482) ~[?:1.8.0_242]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472) ~[?:1.8.0_242]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:1.8.0_242]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:1.8.0_242]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_242]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:485) ~[?:1.8.0_242]
at org.serviio.library.local.indexing.LibraryDeltaScanner.reloadRepositories(LibraryDeltaScanner.java:101) ~[serviio.jar:?]
at org.serviio.library.local.indexing.LocalLibraryManager.performManualScan(LocalLibraryManager.java:196) ~[serviio.jar:?]
at org.serviio.library.local.indexing.LocalLibraryManager.startLibraryScanning(LocalLibraryManager.java:122) ~[serviio.jar:?]
at org.serviio.ui.resources.server.RepositoryServerResource.lambda$save$0(RepositoryServerResource.java:109) ~[serviio.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_242]
2022-05-30T10:34:59,320 INFO [LibraryDeltaScanner] Added repository 'E:\mo gnar gnar' to delta scanner (NATIVE)
2022-05-30T10:34:59,320 INFO [LibraryDeltaScanner] Starting the library delta scan
2022-05-30T10:35:02,537 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\blood.and.oil.2015.s01e09.720p.hdtv.hevc.x265.rmteam.mkv). Message: Unknown video file type.
2022-05-30T10:35:03,557 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\Nova - The Spy Factory Full Video-ZdPpdu8OGDQ.mkv). Message: Unknown video codec.
2022-05-30T10:35:03,576 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2022-05-30T10:35:04,562 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Disney\peter.pan.1953.720p.bluray.x264.yify___571a4a81945dd.mp4). Message: Unknown video file type.
2022-05-30T10:35:05,701 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 101 Manrattan [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:05,985 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 102 Inherit the Cheese [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:06,310 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 103 Spring of Love [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:06,593 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 104 Rat Day Afternoon [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:06,908 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 105 Mergers and Acquisitions [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:07,221 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 106 Old Flame [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:07,545 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 107 The Reunion [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:07,887 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 108 Sleeps with the Fishes [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:08,195 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 109 Strange Bedfellows [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:08,646 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 110 This Is Not a Pipe [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:35:09,207 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111a Catch Me If You Can [andy5421].avi). Message: Unknown video file type.
2022-05-30T10:35:09,977 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111b King of Rats.avi). Message: Unknown video file type.
2022-05-30T10:35:10,256 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 112a Future Ex-Wife.avi). Message: Unknown video file type.
2022-05-30T10:35:10,606 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 113 A Good Execution.avi). Message: Unknown video file type.
2022-05-30T10:35:11,138 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Lupin III Part II\70b350608b81210b37a74f1d56b4c2ed-70b350608b81210b37a74f1d56b4c2ed.mp4). Message: Unknown video file type.
2022-05-30T10:35:11,636 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Ronin Warriors\Ronin Warriors- Ep 7.mkv). Message: Unknown video file type.
2022-05-30T10:35:12,283 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\v.mp4). Message: Unknown video file type.
2022-05-30T10:35:42,706 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_alps.mp4' (title: _alps) to Library
2022-05-30T10:35:45,353 INFO [MediaFileIndexer] Removing '_alps' (E:\mo gnar gnar\_alps.mp4) from Library
2022-05-30T10:35:48,843 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\alps.mp4' (title: alps) to Library
2022-05-30T10:37:25,468 WARN [FileDeltaWatcher] There was an error while adding files from directory E:\mo gnar gnar\_Cooking With Gas S03E02.ts
java.nio.file.NotDirectoryException: E:\mo gnar gnar\_Cooking With Gas S03E02.ts
at java.nio.file.FileTreeWalker.walk(FileTreeWalker.java:322) ~[?:1.8.0_242]
at java.nio.file.Files.walkFileTree(Files.java:2662) ~[?:1.8.0_242]
at org.serviio.library.local.indexing.watching.FileDeltaWatcher.addAllFilesInFolder(FileDeltaWatcher.java:322) ~[serviio.jar:?]
at org.serviio.library.local.indexing.watching.FileDeltaWatcher.access$1200(FileDeltaWatcher.java:66) ~[serviio.jar:?]
at org.serviio.library.local.indexing.watching.FileDeltaWatcher$FileDeltaWatcherWorker.lambda$run$0(FileDeltaWatcher.java:447) ~[serviio.jar:?]
at java.util.Optional.ifPresent(Optional.java:159) [?:1.8.0_242]
at org.serviio.library.local.indexing.watching.FileDeltaWatcher$FileDeltaWatcherWorker.run(FileDeltaWatcher.java:419) [serviio.jar:?]
2022-05-30T10:37:28,438 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ1.ts' (title: BOJ1) to Library
2022-05-30T10:37:31,480 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ2.ts' (title: BOJ2) to Library
2022-05-30T10:37:33,936 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ3.ts' (title: BOJ3) to Library
2022-05-30T10:37:37,200 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ4.ts' (title: BOJ4) to Library
2022-05-30T10:37:39,358 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ5.ts' (title: BOJ5) to Library
2022-05-30T10:37:42,758 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ6.ts' (title: BOJ6) to Library
2022-05-30T10:37:45,791 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Book of John\BOJ7.ts' (title: BOJ7) to Library
2022-05-30T10:37:47,656 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_[Snowboard 2010] - Almost Dead - XVid+Mp3.avi' (title: _[Snowboard 2010] - Almost Dead - XVid+Mp3) to Library
2022-05-30T10:37:49,400 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_[Snowboard 2010] - Get In The Van [XVid+Mp3].avi' (title: _[Snowboard 2010] - Get In The Van [XVid+Mp3]) to Library
2022-05-30T10:37:51,463 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi' (title: _[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]) to Library
2022-05-30T10:37:51,503 WARN [FileDeltaWatcher] There was an error while adding files from directory E:\mo gnar gnar\Cooking With Gas S03E02.ts
2022-05-30T10:37:52,270 WARN [MetadataExtractionCoordinator] Cannot read metadata of file E:\mo gnar gnar\_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi via extractor EMBEDDED. Message: File E:\mo gnar gnar\_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi cannot be read to extract metadata
2022-05-30T10:37:52,304 INFO [MediaFileIndexer] Removing '"siberian_wild"_1280x720' (E:\mo gnar gnar\"siberian_wild"_1280x720.mp4) from Library
2022-05-30T10:37:52,403 INFO [MediaFileIndexer] Removing 'alps' (E:\mo gnar gnar\alps.mp4) from Library
2022-05-30T10:38:46,767 INFO [LocalLibraryManager] Starting manual library scan
2022-05-30T10:41:02,169 WARN [MetadataExtractionCoordinator] Cannot read metadata of file E:\mo gnar gnar\_Cheers 2010.mp4 via extractor EMBEDDED. Message: File E:\mo gnar gnar\_Cheers 2010.mp4 cannot be read to extract metadata
2022-05-30T10:41:02,794 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\12 months.mp4). Message: Unknown video file type.
2022-05-30T10:41:02,902 INFO [LibraryOneTimeScanner] Interrupting library scan
2022-05-30T10:41:02,906 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2022-05-30T10:41:03,004 INFO [LibraryDeltaScanner] Stopping the library delta scan
2022-05-30T10:41:03,010 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2022-05-30T10:41:03,073 INFO [LocalLibraryManager] Starting automatic library scan
2022-05-30T10:41:03,719 INFO [LibraryDeltaScanner] Added repository 'E:\aint you seen my movies' to delta scanner (POLLER)
2022-05-30T10:41:05,112 INFO [LibraryDeltaScanner] Added repository 'E:\cartoons' to delta scanner (POLLER)
2022-05-30T10:41:05,160 INFO [LibraryDeltaScanner] Added repository 'E:\mo gnar gnar' to delta scanner (POLLER)
2022-05-30T10:41:05,160 INFO [LibraryDeltaScanner] Starting the library delta scan
2022-05-30T10:41:07,948 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\blood.and.oil.2015.s01e09.720p.hdtv.hevc.x265.rmteam.mkv). Message: Unknown video file type.
2022-05-30T10:41:09,585 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\Nova - The Spy Factory Full Video-ZdPpdu8OGDQ.mkv). Message: Unknown video codec.
2022-05-30T10:41:10,911 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Disney\peter.pan.1953.720p.bluray.x264.yify___571a4a81945dd.mp4). Message: Unknown video file type.
2022-05-30T10:41:12,254 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 101 Manrattan [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:12,542 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 102 Inherit the Cheese [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:12,886 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 103 Spring of Love [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:13,194 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 104 Rat Day Afternoon [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:13,742 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 105 Mergers and Acquisitions [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:14,911 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 106 Old Flame [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:15,926 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 107 The Reunion [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:16,280 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 108 Sleeps with the Fishes [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:16,814 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 109 Strange Bedfellows [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:17,232 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 110 This Is Not a Pipe [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:41:17,707 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111a Catch Me If You Can [andy5421].avi). Message: Unknown video file type.
2022-05-30T10:41:18,457 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111b King of Rats.avi). Message: Unknown video file type.
2022-05-30T10:41:18,770 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 112a Future Ex-Wife.avi). Message: Unknown video file type.
2022-05-30T10:41:19,145 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 113 A Good Execution.avi). Message: Unknown video file type.
2022-05-30T10:41:19,643 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Lupin III Part II\70b350608b81210b37a74f1d56b4c2ed-70b350608b81210b37a74f1d56b4c2ed.mp4). Message: Unknown video file type.
2022-05-30T10:41:20,298 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Ronin Warriors\Ronin Warriors- Ep 7.mkv). Message: Unknown video file type.
2022-05-30T10:41:21,287 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\v.mp4). Message: Unknown video file type.
2022-05-30T10:41:22,690 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\"siberianwild"1280x720.mp4' (title: "siberianwild"1280x720) to Library
2022-05-30T10:43:13,552 INFO [MediaFileIndexer] Removing '"siberianwild"1280x720' (E:\mo gnar gnar\"siberianwild"1280x720.mp4) from Library
2022-05-30T10:43:15,883 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_"siberianwild"1280x720.mp4' (title: _"siberianwild"1280x720) to Library
2022-05-30T10:43:17,915 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_2010-burton.snowboards-the.b.avi' (title: _2010-burton.snowboards-the.b) to Library
2022-05-30T10:43:21,030 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_28 Winters.mp4' (title: _28 Winters) to Library
2022-05-30T10:43:22,773 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi' (title: _[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]) to Library
2022-05-30T10:43:24,979 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4' (title: _A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112) to Library
2022-05-30T10:43:27,395 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_A Place Called Kookabunga.mp4' (title: _A Place Called Kookabunga) to Library
2022-05-30T10:43:29,792 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Absinthe.Films.Heavy.Mental.mp4' (title: _Absinthe.Films.Heavy.Mental) to Library
2022-05-30T10:43:31,637 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Absinthe.Neverland.2009.DVDRip.XviD-XB.avi' (title: _Absinthe.Neverland.2009.DVDRip.XviD-XB) to Library
2022-05-30T10:43:34,208 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_AfterForever-455822.mp4' (title: _AfterForever-455822) to Library
2022-05-30T10:43:36,127 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_alps.mp4' (title: _alps) to Library
2022-05-30T10:43:37,521 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi' (title: _Alterna.Films-Elektro.2009.DVDRiP.XViD-XB) to Library
2022-05-30T10:43:39,488 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Apples & Oranges -by fester.avi' (title: _Apples & Oranges -by fester) to Library
2022-05-30T10:43:41,096 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Appreciate.That.mp4' (title: _Appreciate.That) to Library
2022-05-30T10:43:42,725 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Approach and Attack.mp4' (title: _Approach and Attack) to Library
2022-05-30T10:43:45,017 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_As The Crow Flies.ts' (title: _As The Crow Flies) to Library
2022-05-30T10:43:46,776 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4' (title: _ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow) to Library
2022-05-30T10:43:51,810 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_AUSTEN SWEETIN WIND SLAB-2hyw79e3wk.mkv' (title: _AUSTEN SWEETIN WIND SLAB-2hyw79e3wk) to Library
2022-05-30T10:43:54,111 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_B Proddi - The Full Length.mp4' (title: _B Proddi - The Full Length) to Library
2022-05-30T10:43:55,534 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Beyond.Medals.Betty.Ford.mkv' (title: _Beyond.Medals.Betty.Ford) to Library
2022-05-30T10:43:57,009 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_big jean fantasy.mp4' (title: _big jean fantasy) to Library
2022-05-30T10:43:58,699 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_Blood Brothers.mp4' (title: _Blood Brothers) to Library
2022-05-30T10:44:00,038 WARN [MetadataExtractionCoordinator] Cannot read metadata of file E:\mo gnar gnar\_BOOM.ts via extractor EMBEDDED. Message: E:\mo gnar gnar\_BOOM.ts (The system cannot find the file specified)
2022-05-30T10:44:17,107 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\"siberianwild"1280x720.mp4' (title: "siberianwild"1280x720) to Library
2022-05-30T10:44:18,492 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\2010-burton.snowboards-the.b.avi' (title: 2010-burton.snowboards-the.b) to Library
2022-05-30T10:44:20,863 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\28 Winters.mp4' (title: 28 Winters) to Library
2022-05-30T10:44:22,367 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Almost Dead - XVid+Mp3.avi' (title: [Snowboard 2010] - Almost Dead - XVid+Mp3) to Library
2022-05-30T10:44:23,876 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Get In The Van [XVid+Mp3].avi' (title: [Snowboard 2010] - Get In The Van [XVid+Mp3]) to Library
2022-05-30T10:44:25,303 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi' (title: [Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]) to Library
2022-05-30T10:44:26,625 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi' (title: [Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]) to Library
2022-05-30T10:44:26,627 INFO [MediaFileIndexer] Removing '_"siberianwild"1280x720' (E:\mo gnar gnar\_"siberianwild"1280x720.mp4) from Library
2022-05-30T10:44:26,699 INFO [MediaFileIndexer] Removing '_2010-burton.snowboards-the.b' (E:\mo gnar gnar\_2010-burton.snowboards-the.b.avi) from Library
2022-05-30T10:44:26,744 INFO [MediaFileIndexer] Removing '_28 Winters' (E:\mo gnar gnar\_28 Winters.mp4) from Library
2022-05-30T10:44:26,794 INFO [MediaFileIndexer] Removing '_[Snowboard 2010] - Almost Dead - XVid+Mp3' (E:\mo gnar gnar\_[Snowboard 2010] - Almost Dead - XVid+Mp3.avi) from Library
2022-05-30T10:44:26,853 INFO [MediaFileIndexer] Removing '_[Snowboard 2010] - Get In The Van [XVid+Mp3]' (E:\mo gnar gnar\_[Snowboard 2010] - Get In The Van [XVid+Mp3].avi) from Library
2022-05-30T10:44:26,895 INFO [MediaFileIndexer] Removing '_[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]' (E:\mo gnar gnar\_[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi) from Library
2022-05-30T10:44:26,962 INFO [MediaFileIndexer] Removing '_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]' (E:\mo gnar gnar\_[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi) from Library
2022-05-30T10:44:27,004 INFO [MediaFileIndexer] Removing '_A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112' (E:\mo gnar gnar\_A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4) from Library
2022-05-30T10:44:27,068 INFO [MediaFileIndexer] Removing '_A Place Called Kookabunga' (E:\mo gnar gnar\_A Place Called Kookabunga.mp4) from Library
2022-05-30T10:44:27,111 INFO [MediaFileIndexer] Removing '_Absinthe.Films.Heavy.Mental' (E:\mo gnar gnar\_Absinthe.Films.Heavy.Mental.mp4) from Library
2022-05-30T10:44:27,170 INFO [MediaFileIndexer] Removing '_Absinthe.Neverland.2009.DVDRip.XviD-XB' (E:\mo gnar gnar\_Absinthe.Neverland.2009.DVDRip.XviD-XB.avi) from Library
2022-05-30T10:44:27,212 INFO [MediaFileIndexer] Removing '_AfterForever-455822' (E:\mo gnar gnar\_AfterForever-455822.mp4) from Library
2022-05-30T10:44:27,263 INFO [MediaFileIndexer] Removing '_alps' (E:\mo gnar gnar\_alps.mp4) from Library
2022-05-30T10:44:27,303 INFO [MediaFileIndexer] Removing '_Alterna.Films-Elektro.2009.DVDRiP.XViD-XB' (E:\mo gnar gnar\_Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi) from Library
2022-05-30T10:44:27,345 INFO [MediaFileIndexer] Removing '_Apples & Oranges -by fester' (E:\mo gnar gnar\_Apples & Oranges -by fester.avi) from Library
2022-05-30T10:44:27,395 INFO [MediaFileIndexer] Removing '_Appreciate.That' (E:\mo gnar gnar\_Appreciate.That.mp4) from Library
2022-05-30T10:44:27,445 INFO [MediaFileIndexer] Removing '_Approach and Attack' (E:\mo gnar gnar\_Approach and Attack.mp4) from Library
2022-05-30T10:44:27,489 INFO [MediaFileIndexer] Removing '_As The Crow Flies' (E:\mo gnar gnar\_As The Crow Flies.ts) from Library
2022-05-30T10:44:27,529 INFO [MediaFileIndexer] Removing '_ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow' (E:\mo gnar gnar\_ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4) from Library
2022-05-30T10:44:27,586 INFO [MediaFileIndexer] Removing '_AUSTEN SWEETIN WIND SLAB-2hyw79e3wk' (E:\mo gnar gnar\_AUSTEN SWEETIN WIND SLAB-2hyw79e3wk.mkv) from Library
2022-05-30T10:44:27,638 INFO [MediaFileIndexer] Removing '_B Proddi - The Full Length' (E:\mo gnar gnar\_B Proddi - The Full Length.mp4) from Library
2022-05-30T10:44:27,686 INFO [MediaFileIndexer] Removing 'BOJ1' (E:\mo gnar gnar\_Book of John\BOJ1.ts) from Library
2022-05-30T10:44:27,731 INFO [MediaFileIndexer] Removing 'BOJ2' (E:\mo gnar gnar\_Book of John\BOJ2.ts) from Library
2022-05-30T10:44:27,770 INFO [MediaFileIndexer] Removing 'BOJ3' (E:\mo gnar gnar\_Book of John\BOJ3.ts) from Library
2022-05-30T10:44:27,812 INFO [MediaFileIndexer] Removing 'BOJ4' (E:\mo gnar gnar\_Book of John\BOJ4.ts) from Library
2022-05-30T10:44:27,853 INFO [MediaFileIndexer] Removing 'BOJ5' (E:\mo gnar gnar\_Book of John\BOJ5.ts) from Library
2022-05-30T10:44:28,024 INFO [MediaFileIndexer] Removing 'BOJ6' (E:\mo gnar gnar\_Book of John\BOJ6.ts) from Library
2022-05-30T10:44:28,065 INFO [MediaFileIndexer] Removing 'BOJ7' (E:\mo gnar gnar\_Book of John\BOJ7.ts) from Library
2022-05-30T10:44:30,008 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4' (title: A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112) to Library
2022-05-30T10:44:32,265 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\A Place Called Kookabunga.mp4' (title: A Place Called Kookabunga) to Library
2022-05-30T10:44:34,503 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Absinthe.Films.Heavy.Mental.mp4' (title: Absinthe.Films.Heavy.Mental) to Library
2022-05-30T10:44:36,054 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Absinthe.Neverland.2009.DVDRip.XviD-XB.avi' (title: Absinthe.Neverland.2009.DVDRip.XviD-XB) to Library
2022-05-30T10:44:38,505 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\AfterForever-455822.mp4' (title: AfterForever-455822) to Library
2022-05-30T10:44:40,284 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\alps.mp4' (title: alps) to Library
2022-05-30T10:44:41,556 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi' (title: Alterna.Films-Elektro.2009.DVDRiP.XViD-XB) to Library
2022-05-30T10:44:43,503 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Apples & Oranges -by fester.avi' (title: Apples & Oranges -by fester) to Library
2022-05-30T10:44:45,218 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Appreciate.That.mp4' (title: Appreciate.That) to Library
2022-05-30T10:44:46,906 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Approach and Attack.mp4' (title: Approach and Attack) to Library
2022-05-30T10:44:48,801 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\As The Crow Flies.ts' (title: As The Crow Flies) to Library
2022-05-30T10:44:50,393 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4' (title: ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow) to Library
2022-05-30T10:44:54,879 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\AUSTEN SWEETIN WIND SLAB-2hyw79e3wk.mkv' (title: AUSTEN SWEETIN WIND SLAB-2hyw79e3wk) to Library
2022-05-30T10:44:56,642 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\B Proddi - The Full Length.mp4' (title: B Proddi - The Full Length) to Library
2022-05-30T10:44:58,909 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ1.ts' (title: BOJ1) to Library
2022-05-30T10:45:01,356 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ2.ts' (title: BOJ2) to Library
2022-05-30T10:45:03,697 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ3.ts' (title: BOJ3) to Library
2022-05-30T10:45:05,839 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ4.ts' (title: BOJ4) to Library
2022-05-30T10:45:08,334 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ5.ts' (title: BOJ5) to Library
2022-05-30T10:45:11,667 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ6.ts' (title: BOJ6) to Library
2022-05-30T10:45:13,874 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ7.ts' (title: BOJ7) to Library
2022-05-30T10:45:16,054 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\BOOM.ts' (title: BOOM) to Library
2022-05-30T10:45:18,153 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\BRYAN FOX LIFE IN GENERAL-Xo4gV3tuwoQ.mp4' (title: BRYAN FOX LIFE IN GENERAL-Xo4gV3tuwoQ) to Library
2022-05-30T10:45:19,803 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Burton - Back Andes - 2017.mp4' (title: Burton - Back Andes - 2017) to Library
2022-05-30T10:45:22,241 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\CHAMäLEON.ts' (title: CHAMäLEON) to Library
2022-05-30T10:49:48,257 INFO [LocalLibraryManager] Starting manual library scan
2022-05-30T10:51:11,194 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\Cheers 2010.mp4). Message: Unknown video file type.
2022-05-30T10:51:11,458 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\mo gnar gnar\12 months.mp4). Message: Unknown video file type.
2022-05-30T10:51:11,488 INFO [LibraryOneTimeScanner] Interrupting library scan
2022-05-30T10:51:11,489 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2022-05-30T10:51:11,588 INFO [LibraryDeltaScanner] Stopping the library delta scan
2022-05-30T10:51:11,591 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2022-05-30T10:51:11,624 INFO [LocalLibraryManager] Starting automatic library scan
2022-05-30T10:51:12,300 INFO [LibraryDeltaScanner] Added repository 'E:\aint you seen my movies' to delta scanner (POLLER)
2022-05-30T10:51:13,827 INFO [LibraryDeltaScanner] Added repository 'E:\cartoons' to delta scanner (POLLER)
2022-05-30T10:51:13,875 INFO [LibraryDeltaScanner] Added repository 'E:\mo gnar gnar' to delta scanner (POLLER)
2022-05-30T10:51:13,875 INFO [LibraryDeltaScanner] Starting the library delta scan
2022-05-30T10:51:16,842 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\blood.and.oil.2015.s01e09.720p.hdtv.hevc.x265.rmteam.mkv). Message: Unknown video file type.
2022-05-30T10:51:18,306 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\aint you seen my movies\Nova - The Spy Factory Full Video-ZdPpdu8OGDQ.mkv). Message: Unknown video codec.
2022-05-30T10:51:19,731 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Disney\peter.pan.1953.720p.bluray.x264.yify___571a4a81945dd.mp4). Message: Unknown video file type.
2022-05-30T10:51:21,101 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 101 Manrattan [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:21,490 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 102 Inherit the Cheese [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:21,823 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 103 Spring of Love [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:22,182 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 104 Rat Day Afternoon [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:22,490 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 105 Mergers and Acquisitions [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:22,852 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 106 Old Flame [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:23,198 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 107 The Reunion [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:23,505 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 108 Sleeps with the Fishes [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:23,815 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 109 Strange Bedfellows [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:24,192 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 110 This Is Not a Pipe [TR-Wobbler].avi). Message: Unknown video file type.
2022-05-30T10:51:24,496 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111a Catch Me If You Can [andy5421].avi). Message: Unknown video file type.
2022-05-30T10:51:24,839 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 111b King of Rats.avi). Message: Unknown video file type.
2022-05-30T10:51:25,171 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 112a Future Ex-Wife.avi). Message: Unknown video file type.
2022-05-30T10:51:25,483 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Gary The Rat\Gary the Rat\Gary the Rat 113 A Good Execution.avi). Message: Unknown video file type.
2022-05-30T10:51:25,913 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Lupin III Part II\70b350608b81210b37a74f1d56b4c2ed-70b350608b81210b37a74f1d56b4c2ed.mp4). Message: Unknown video file type.
2022-05-30T10:51:26,349 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\Ronin Warriors\Ronin Warriors- Ep 7.mkv). Message: Unknown video file type.
2022-05-30T10:51:26,893 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (E:\cartoons\v.mp4). Message: Unknown video file type.
2022-05-30T10:52:54,850 INFO [MediaFileIndexer] Removing '"siberianwild"1280x720' (E:\mo gnar gnar\"siberianwild"1280x720.mp4) from Library
2022-05-30T10:52:54,946 INFO [MediaFileIndexer] Removing '2010-burton.snowboards-the.b' (E:\mo gnar gnar\2010-burton.snowboards-the.b.avi) from Library
2022-05-30T10:52:54,994 INFO [MediaFileIndexer] Removing '28 Winters' (E:\mo gnar gnar\28 Winters.mp4) from Library
2022-05-30T10:52:55,036 INFO [MediaFileIndexer] Removing '[Snowboard 2010] - Almost Dead - XVid+Mp3' (E:\mo gnar gnar\[Snowboard 2010] - Almost Dead - XVid+Mp3.avi) from Library
2022-05-30T10:52:55,078 INFO [MediaFileIndexer] Removing '[Snowboard 2010] - Get In The Van [XVid+Mp3]' (E:\mo gnar gnar\[Snowboard 2010] - Get In The Van [XVid+Mp3].avi) from Library
2022-05-30T10:52:55,119 INFO [MediaFileIndexer] Removing '[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]' (E:\mo gnar gnar\[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi) from Library
2022-05-30T10:52:55,165 INFO [MediaFileIndexer] Removing '[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]' (E:\mo gnar gnar\[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi) from Library
2022-05-30T10:52:55,212 INFO [MediaFileIndexer] Removing '_big jean fantasy' (E:\mo gnar gnar\_big jean fantasy.mp4) from Library
2022-05-30T10:52:55,272 INFO [MediaFileIndexer] Removing 'A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112' (E:\mo gnar gnar\A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4) from Library
2022-05-30T10:52:55,314 INFO [MediaFileIndexer] Removing 'A Place Called Kookabunga' (E:\mo gnar gnar\A Place Called Kookabunga.mp4) from Library
2022-05-30T10:52:55,353 INFO [MediaFileIndexer] Removing 'Absinthe.Films.Heavy.Mental' (E:\mo gnar gnar\Absinthe.Films.Heavy.Mental.mp4) from Library
2022-05-30T10:52:55,395 INFO [MediaFileIndexer] Removing 'Absinthe.Neverland.2009.DVDRip.XviD-XB' (E:\mo gnar gnar\Absinthe.Neverland.2009.DVDRip.XviD-XB.avi) from Library
2022-05-30T10:52:55,445 INFO [MediaFileIndexer] Removing 'AfterForever-455822' (E:\mo gnar gnar\AfterForever-455822.mp4) from Library
2022-05-30T10:52:55,486 INFO [MediaFileIndexer] Removing 'alps' (E:\mo gnar gnar\alps.mp4) from Library
2022-05-30T10:52:55,528 INFO [MediaFileIndexer] Removing 'Alterna.Films-Elektro.2009.DVDRiP.XViD-XB' (E:\mo gnar gnar\Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi) from Library
2022-05-30T10:52:55,569 INFO [MediaFileIndexer] Removing 'Apples & Oranges -by fester' (E:\mo gnar gnar\Apples & Oranges -by fester.avi) from Library
2022-05-30T10:52:55,611 INFO [MediaFileIndexer] Removing 'Appreciate.That' (E:\mo gnar gnar\Appreciate.That.mp4) from Library
2022-05-30T10:52:55,655 INFO [MediaFileIndexer] Removing 'Approach and Attack' (E:\mo gnar gnar\Approach and Attack.mp4) from Library
2022-05-30T10:52:55,703 INFO [MediaFileIndexer] Removing 'As The Crow Flies' (E:\mo gnar gnar\As The Crow Flies.ts) from Library
2022-05-30T10:52:55,753 INFO [MediaFileIndexer] Removing 'ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow' (E:\mo gnar gnar\ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4) from Library
2022-05-30T10:52:55,795 INFO [MediaFileIndexer] Removing 'AUSTEN SWEETIN WIND SLAB-2hyw79e3wk' (E:\mo gnar gnar\AUSTEN SWEETIN WIND SLAB-2hyw79e3wk.mkv) from Library
2022-05-30T10:52:55,862 INFO [MediaFileIndexer] Removing 'B Proddi - The Full Length' (E:\mo gnar gnar\B Proddi - The Full Length.mp4) from Library
2022-05-30T10:52:55,943 INFO [MediaFileIndexer] Removing 'BOJ1' (E:\mo gnar gnar\Book of John\BOJ1.ts) from Library
2022-05-30T10:52:56,001 INFO [MediaFileIndexer] Removing 'BOJ2' (E:\mo gnar gnar\Book of John\BOJ2.ts) from Library
2022-05-30T10:52:56,063 INFO [MediaFileIndexer] Removing 'BOJ3' (E:\mo gnar gnar\Book of John\BOJ3.ts) from Library
2022-05-30T10:52:56,118 INFO [MediaFileIndexer] Removing 'BOJ4' (E:\mo gnar gnar\Book of John\BOJ4.ts) from Library
2022-05-30T10:52:56,237 INFO [MediaFileIndexer] Removing 'BOJ5' (E:\mo gnar gnar\Book of John\BOJ5.ts) from Library
2022-05-30T10:52:56,290 INFO [MediaFileIndexer] Removing 'BOJ6' (E:\mo gnar gnar\Book of John\BOJ6.ts) from Library
2022-05-30T10:52:56,363 INFO [MediaFileIndexer] Removing 'BOJ7' (E:\mo gnar gnar\Book of John\BOJ7.ts) from Library
2022-05-30T10:52:56,566 INFO [MediaFileIndexer] Removing 'BOOM' (E:\mo gnar gnar\BOOM.ts) from Library
2022-05-30T10:52:56,614 INFO [MediaFileIndexer] Removing 'BRYAN FOX LIFE IN GENERAL-Xo4gV3tuwoQ' (E:\mo gnar gnar\BRYAN FOX LIFE IN GENERAL-Xo4gV3tuwoQ.mp4) from Library
2022-05-30T10:52:56,696 INFO [MediaFileIndexer] Removing 'Burton - Back Andes - 2017' (E:\mo gnar gnar\Burton - Back Andes - 2017.mp4) from Library
2022-05-30T10:52:56,761 INFO [MediaFileIndexer] Removing 'CHAMäLEON' (E:\mo gnar gnar\CHAMäLEON.ts) from Library
2022-05-30T10:52:59,404 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\~"siberianwild"1280x720.mp4' (title: ~"siberianwild"1280x720) to Library
2022-05-30T10:53:01,392 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\~2010-burton.snowboards-the.b.avi' (title: ~2010-burton.snowboards-the.b) to Library
2022-05-30T10:53:04,455 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\~28 Winters.mp4' (title: ~28 Winters) to Library
2022-05-30T10:53:13,180 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\"siberianwild"1280x720.mp4' (title: "siberianwild"1280x720) to Library
2022-05-30T10:53:14,566 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\2010-burton.snowboards-the.b.avi' (title: 2010-burton.snowboards-the.b) to Library
2022-05-30T10:53:15,902 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Almost Dead - XVid+Mp3.avi' (title: [Snowboard 2010] - Almost Dead - XVid+Mp3) to Library
2022-05-30T10:53:17,460 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Get In The Van [XVid+Mp3].avi' (title: [Snowboard 2010] - Get In The Van [XVid+Mp3]) to Library
2022-05-30T10:53:18,900 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3].avi' (title: [Snowboard 2010] - Hard To Earn - DVDRip [Xvid+Mp3]) to Library
2022-05-30T10:53:20,252 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\[Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3].avi' (title: [Snowboard 2010] - Road Warrior Esperanto [XVid+Mp3]) to Library
2022-05-30T10:53:22,029 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\_big jean fantasy.mp4' (title: _big jean fantasy) to Library
2022-05-30T10:53:23,824 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112.mp4' (title: A Land Shaped by Women - Gender equality in snowboarding-AA-22R2UDUTN2112) to Library
2022-05-30T10:53:26,139 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\A Place Called Kookabunga.mp4' (title: A Place Called Kookabunga) to Library
2022-05-30T10:53:28,358 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Absinthe.Films.Heavy.Mental.mp4' (title: Absinthe.Films.Heavy.Mental) to Library
2022-05-30T10:53:30,200 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Absinthe.Neverland.2009.DVDRip.XviD-XB.avi' (title: Absinthe.Neverland.2009.DVDRip.XviD-XB) to Library
2022-05-30T10:53:32,225 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\AfterForever-455822.mp4' (title: AfterForever-455822) to Library
2022-05-30T10:53:33,994 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\alps.mp4' (title: alps) to Library
2022-05-30T10:53:35,291 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Alterna.Films-Elektro.2009.DVDRiP.XViD-XB.avi' (title: Alterna.Films-Elektro.2009.DVDRiP.XViD-XB) to Library
2022-05-30T10:53:37,233 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Apples & Oranges -by fester.avi' (title: Apples & Oranges -by fester) to Library
2022-05-30T10:53:38,776 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Appreciate.That.mp4' (title: Appreciate.That) to Library
2022-05-30T10:53:40,421 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Approach and Attack.mp4' (title: Approach and Attack) to Library
2022-05-30T10:53:42,923 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\As The Crow Flies.ts' (title: As The Crow Flies) to Library
2022-05-30T10:53:44,457 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow.mp4' (title: ATTUNGA+A+Higher+Place+-+Full+Movie++Volcom+Snow) to Library
2022-05-30T10:53:48,568 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\AUSTEN SWEETIN WIND SLAB-2hyw79e3wk.mkv' (title: AUSTEN SWEETIN WIND SLAB-2hyw79e3wk) to Library
2022-05-30T10:53:50,665 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\B Proddi - The Full Length.mp4' (title: B Proddi - The Full Length) to Library
2022-05-30T10:53:52,045 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Beyond.Medals.Betty.Ford.mkv' (title: Beyond.Medals.Betty.Ford) to Library
2022-05-30T10:53:53,621 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Blood Brothers.mp4' (title: Blood Brothers) to Library
2022-05-30T10:53:55,915 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ1.ts' (title: BOJ1) to Library
2022-05-30T10:53:58,262 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ2.ts' (title: BOJ2) to Library
2022-05-30T10:54:00,585 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ3.ts' (title: BOJ3) to Library
2022-05-30T10:54:02,787 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ4.ts' (title: BOJ4) to Library
2022-05-30T10:54:04,785 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ5.ts' (title: BOJ5) to Library
2022-05-30T10:54:07,485 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ6.ts' (title: BOJ6) to Library
2022-05-30T10:54:09,529 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Book of John\BOJ7.ts' (title: BOJ7) to Library
2022-05-30T10:54:11,376 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\BOOM.ts' (title: BOOM) to Library
2022-05-30T10:54:13,201 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\BRYAN FOX LIFE IN GENERAL-Xo4gV3tuwoQ.mp4' (title: BRYAN FOX LIFE IN GENERAL-Xo4gV3tuwoQ) to Library
2022-05-30T10:54:15,037 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\Burton - Back Andes - 2017.mp4' (title: Burton - Back Andes - 2017) to Library
2022-05-30T10:54:17,068 INFO [MediaFileIndexer] Added file 'E:\mo gnar gnar\CHAMäLEON.ts' (title: CHAMäLEON) to Library
