Transcoding audio only
tekiusfanatikus
Post Mon Apr 25, 2011 10:27 pm
Is it possible to only transcode audio? I'm assuming my difficulties are tied to an unsupported audio codec.
Post Mon Apr 25, 2011 11:05 pm
Re: Transcoding audio only
Sure. What's your device> Post details of the file (ffmpeg -i)
tekiusfanatikus
Post Tue Apr 26, 2011 7:11 pm
I have a Samsung BD-D5300. It says the supported audio are:
Dolby Digital Audio Decording Format available
Dolby Digital plus Audio Decording Format available
Dolby True HD Audio Decording Format
DTS Audio Decording Format available
LPCM Audio Decording Format available
AAC available
MP3 Audio Decording Format available
WMA Audio Decording Format available
Supported video formats are:
MPEG 2/4 available
DIVX (including XVID) available
DivX HD, Video Decoding Format available
AVCHD, Video Decoding Format available
MKV, Video Decoding Format available
WMV (1 / 2 / 3 / 7 / 9) available
JPEG available
HD JPEG, Video Decoding Format available
The video file I'm trying to view is an MKV with the following formats:
Video: MPEG4 ISO advanced
Audio: A_TRUEHD
FFmpeg version git-N-28463-gc5dcb3d, Copyright (c) 2000-2011 the FFmpeg developers
built on Apr 20 2011 10:16:52 with gcc 4.4.2
configuration: --enable-memalign-hack --arch=x86 --target-os=mingw32 --cross-prefix=i686-mingw32- --enable-static --disable-shared --enable-zlib --disable-ffprobe --disable-ffplay --prefix=/media/windows/ffmpeg --enable-libmp3lame --enable-libx264 --enable-gpl --extra-libs='-lx264 -lpthread' --enable-runtime-cpudetect --pkg-config=pkg-config
libavutil 50. 40. 1 / 50. 40. 1
libavcodec 52.120. 0 / 52.120. 0
libavformat 52.108. 0 / 52.108. 0
libavdevice 52. 4. 0 / 52. 4. 0
libavfilter 1. 79. 1 / 1. 79. 1
libswscale 0. 13. 0 / 0. 13. 0
[matroska,webm @ 01424cc0] max_analyze_duration reached
[matroska,webm @ 01424cc0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (20000000/417083) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'D:\streaming\Movies\abc.mkv':
Duration: 01:35:34.72, start: 0.000000, bitrate: N/A
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x816 [PAR 1:1 DAR 40:17], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
title : abc
Stream #0.1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (default)
title : abc
Stream #0.2(eng): Subtitle: dvdsub
title : abc
Stream #0.3(fre): Subtitle: dvdsub
title : abc
Stream #0.4(spa): Subtitle: dvdsub
title : abc
Stream #0.5(por): Subtitle: dvdsub
title : abc
---> DB Level Info: 41
IIRC, only transcoding the audio to something the D5300 understands and I'm set? However, if I could save time and effort, only transcoding the audio of the content would probably be a better idea.
Post Tue Apr 26, 2011 7:45 pm
I assume the file is not even added to the library? Truehd is not supported yet so I think it won't be added to the library. When it does it should play natively according to your list.
VenoushCZ
Post Tue May 17, 2011 7:06 pm
Hi! No news about the subj.? Same problem here :-(
Post Tue May 17, 2011 8:43 pm
there is an open ticket to support truehd audio track, should be in 0.6
