Transcoding audio only
• Page 1 of 1
Is it possible to only transcode audio? I'm assuming my difficulties are tied to an unsupported audio codec.
Re: Transcoding audio only
Sure. What's your device> Post details of the file (ffmpeg -i)
Petr
Help translate Serviio
I have a Samsung BD-D5300. It says the supported audio are:
Dolby Digital Audio Decording Format available
Dolby Digital plus Audio Decording Format available
Dolby True HD Audio Decording Format
DTS Audio Decording Format available
LPCM Audio Decording Format available
AAC available
MP3 Audio Decording Format available
WMA Audio Decording Format available
Supported video formats are:
MPEG 2/4 available
DIVX (including XVID) available
DivX HD, Video Decoding Format available
AVCHD, Video Decoding Format available
MKV, Video Decoding Format available
WMV (1 / 2 / 3 / 7 / 9) available
JPEG available
HD JPEG, Video Decoding Format available
The video file I'm trying to view is an MKV with the following formats:
Video: MPEG4 ISO advanced
Audio: A_TRUEHD
IIRC, only transcoding the audio to something the D5300 understands and I'm set? However, if I could save time and effort, only transcoding the audio of the content would probably be a better idea.
AAC available
MPEG 2/4 available
JPEG available
Audio: A_TRUEHD
- Code:
FFmpeg version git-N-28463-gc5dcb3d, Copyright (c) 2000-2011 the FFmpeg developers
built on Apr 20 2011 10:16:52 with gcc 4.4.2
configuration: --enable-memalign-hack --arch=x86 --target-os=mingw32 --cross-prefix=i686-mingw32- --enable-static --disable-shared --enable-zlib --disable-ffprobe --disable-ffplay --prefix=/media/windows/ffmpeg --enable-libmp3lame --enable-libx264 --enable-gpl --extra-libs='-lx264 -lpthread' --enable-runtime-cpudetect --pkg-config=pkg-config
libavutil 50. 40. 1 / 50. 40. 1
libavcodec 52.120. 0 / 52.120. 0
libavformat 52.108. 0 / 52.108. 0
libavdevice 52. 4. 0 / 52. 4. 0
libavfilter 1. 79. 1 / 1. 79. 1
libswscale 0. 13. 0 / 0. 13. 0
[matroska,webm @ 01424cc0] max_analyze_duration reached
[matroska,webm @ 01424cc0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (20000000/417083) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'D:\streaming\Movies\abc.mkv':
Duration: 01:35:34.72, start: 0.000000, bitrate: N/A
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x816 [PAR 1:1 DAR 40:17], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
title : abc
Stream #0.1(eng): Audio: truehd, 48000 Hz, 7.1, s32 (default)
title : abc
Stream #0.2(eng): Subtitle: dvdsub
title : abc
Stream #0.3(fre): Subtitle: dvdsub
title : abc
Stream #0.4(spa): Subtitle: dvdsub
title : abc
Stream #0.5(por): Subtitle: dvdsub
title : abc
---> DB Level Info: 41
I assume the file is not even added to the library? Truehd is not supported yet so I think it won't be added to the library. When it does it should play natively according to your list.
Petr
Hi! No news about the subj.? Same problem here
there is an open ticket to support truehd audio track, should be in 0.6
Petr
• Page 1 of 1
