42LV5500 Doesn't see Serviio
tdischino
Post Sat Apr 30, 2011 10:28 pm
Just bought an LG 42LV550 and am trying to confirm if it will work with Serviio. So far it doesn't see Serviio when I launch MediaLink on the home screen (it tells me I need to have Plex installed, although a Nero MediaHome CD was provided with the TV). I've bound the correct IP, opened/forwarded ports 8895 (TCP) and 1900 (UDP). How do I know if I missed something in setup? or is it possible some LG TV's just won't see it?
Is MediaLink the only way to find DLNA devices from the LG TV?
--UPDATE:
I found the device, through Inputs > DLNA > Network, I just have to now figure out why my files are not displaying. Will leave this post for future reference for anyone with the same TV.
throck
Post Mon May 02, 2011 11:21 pm
Re: 42LV5500 Doesn't see Serviio
Plex Is not DNLA. Plex is built with macintosh in mind. Similar but not the same. Nero mediohome is for your DLNA not Plex. If your tv is connected to the network and Nero mediahome server is also on the same LAN then change your TV input to Network. You will then see it. Plex is hot garbage. DNLA works great at least for me and my LG LV5500.
tdischino
Post Tue May 10, 2011 3:17 am
Thanks for the clarification. That makes sense, as plex doesn't show up when I use Network/DLNA input. Mediahome has been working great. I've been unable to see my shared folder (and files) with serviio. I've got 2 different server comps on the network, playing with both to see if different config changes make a difference, but still no luck.
I did find something in the FAQ indicated that the user that the serviio service runs under has to have adequate permissions. I tried changing the service properties to run under my main windows account (which has admin), but it didnt help. I looked at the Nero service properties, and it appears to run under a user account that it creates. I'm not savvy enough with windows user accounts to understand if I need to do something different at this point with the serviio service setup.
Post Tue May 10, 2011 11:12 am
Can you enable detailed logging (see signature) and post the log here. That will let us see what serviio is doing.
Also how is your network setup? what is the IP address for the TV and the computer running serviio. Are you using a router? Did you open the required ports on the router and firewall? See FAQ in signature on what ports to open.
Post Tue May 10, 2011 11:55 am
EDIT - i stand corrected by ZIP below.
Post Tue May 10, 2011 12:09 pm
LG plays almost everything and seems to transcode audio, so it's only DTS videos that will not work.
tdischino
Post Thu May 12, 2011 7:06 am
moltra wrote:Can you enable detailed logging (see signature) and post the log here. That will let us see what serviio is doing.
Ny Network:
DHCP behind a linksys router running DD-WRT. All ports opened as indicated in my original post, screen shots in attachments. Media server PC is IP 192.168.1.144 which I am binding to serviio. I see that Serviio sees my TV, as the log shows the TV's IP (192.168.1.126) as the renderer. Let me know if you need more detail on the network.
When I connect to the Serviio device from my TV, all I see is a folder named Audio, with a subfolder Artists, both folders are empty of files (I am not sharing a folder called audio or artists). The log shows the video files discovered in the shared folder, but I dont see them in the DLNA interface on the TV.
I wasnt sure how much logging you wanted, so I let it go for a few minutes. then shut down the service. Please let me know if you need additional info, I'd love to see this working. Thank you for your help and time.
something else just occurred to me... I have UPnP disabled on my router. Is it absolutely required for Serviio? I wouldnt think so, but figured I should mention it.
Port Forward screen shot 2
5-11-2011 11-26-23 PM.png (24.29 KiB) Viewed 28512 times
Port forward screen shot 1
5-11-2011 11-26-09 PM.png (24.4 KiB) Viewed 28512 times
(76.33 KiB) Downloaded 1733 times
tdischino
Post Tue May 17, 2011 12:16 am
^bump^
Post Tue May 17, 2011 12:56 am
I did not have to forward any ports on my router. Do you have windows firewall enabled? If so open the ports 8895 (TCP) and 1900 (UDP) there. Do you have any other computers, or xbox 360 or playstation in the house that you can make sure that the computer on which serviio is installed on is working properly for streaming the movies. Run the following command and let me know what it say. You will have to run it in a command window. If you do not know how type cmd in the run box and then run this command in it.
netstat -an |find /i "listening"
then with the mouse in the window right click and select all then hit ctrl-C to copy and post on here so we can see the results.
tdischino
Post Fri May 20, 2011 11:53 pm
As noted in my posts above, I can stream from this computer successfully with Nero MediaHome, and Windows Media Player. The TV sees the files that those servers are sharing. when I disable both of them and fire up Serviio, The TV sees the Serviio service on this computer, but doesnt see the files. My second computer, same thing, both of the other services work fine, but not serviio.
Here is the netstat from the main comp
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Tony>netstat -an |find /i "listening"
  TCP    0.0.0.0:135            0.0.0.0:0              LISTENING
  TCP    0.0.0.0:445            0.0.0.0:0              LISTENING
  TCP    0.0.0.0:711            0.0.0.0:0              LISTENING
  TCP    0.0.0.0:2869           0.0.0.0:0              LISTENING
  TCP    0.0.0.0:5800           0.0.0.0:0              LISTENING
  TCP    0.0.0.0:5900           0.0.0.0:0              LISTENING
  TCP    0.0.0.0:8895           0.0.0.0:0              LISTENING
  TCP    0.0.0.0:10243          0.0.0.0:0              LISTENING
  TCP    0.0.0.0:17500          0.0.0.0:0              LISTENING
  TCP    5.14.200.96:139        0.0.0.0:0              LISTENING
  TCP    127.0.0.1:5152         0.0.0.0:0              LISTENING
  TCP    127.0.0.1:5354         0.0.0.0:0              LISTENING
  TCP    127.0.0.1:23423        0.0.0.0:0              LISTENING
  TCP    127.0.0.1:24726        0.0.0.0:0              LISTENING
  TCP    127.0.0.1:24727        0.0.0.0:0              LISTENING
  TCP    127.0.0.1:27015        0.0.0.0:0              LISTENING
  TCP    192.168.1.144:139      0.0.0.0:0              LISTENING
  TCP    192.168.1.144:44331    0.0.0.0:0              LISTENING
  TCP    192.168.1.144:44332    0.0.0.0:0              LISTENING
tdischino
Post Sat May 21, 2011 12:36 am
Well this problem is resolved. I turned on UPnP in my router, and the files show up. I didnt want to turn it on, as I thought there were security concerns around having it on. However, it might be clearer if you indicate that UPnP is absolutely required. Not sure if I will go with Serviio due to the reliance on UPnP. Thanks for the (little bit) of help.
zoze
Post Sun Jul 31, 2011 3:44 pm
Hello, I´m new here, and kind of a noob as well.. :)
I bought a lv5500 and I installed the nero cd to use the dlna server. But in my INPUT menu on the TV, the DLNA icon is disabled, and when I click on the icon, it shows a message that the server is not available. The cables are ok and I´ve internet on the TV. I´ve also installed PLEX (sucks..)
My OS is XP32bit.
I installed Serviio and I still can´t get DLNA to work...
Please help... Any Ideas ?
Thanks in advance.
zoze
My OS is XP32bit.
Thanks in advance.
Post Sun Jul 31, 2011 3:47 pm
zoze wrote:Hello, I´m new here, and kind of a noob as well.. :)
My OS is XP32bit.
Thanks in advance.
please read teh FAQ pages and check you have the port open that serviio requires to function ( link in my signiture ). :)
zoze
Post Sun Jul 31, 2011 4:18 pm
The TCP port 8895 is open but it´s not communicating through the UDP 1900. I use Comodo IS and I don´t have a clue where I open this port. I looked around all the options of the firewall and I couldn´t find where to open a port. Sorry...
Also when I installed Serviio, I granted all the access through the firewall. It supposed to give access to UDP port as well, right?
Post Sun Jul 31, 2011 4:30 pm
zoze wrote:The TCP port 8895 is open but it´s not communicating through the UDP 1900. I use Comodo IS and I don´t have a clue where I open this port. I looked around all the options of the firewall and I couldn´t find where to open a port. Sorry...
not always no so you will need to open that udp port or serviio and most other dlna servers will not function.
zoze
Post Mon Aug 01, 2011 9:36 am
Done. I did it. Cheers mate.
Post Mon Aug 01, 2011 5:21 pm
welcomes :)
varta
Post Sun Oct 30, 2011 10:48 pm
hi, I have a similar problem so I thought I'd ask in this thread.
So, I have Serviio server installed on my PC (Win7 x64) which is in one room and an LG 42LV5500 in another room connected to the same LAN (both static IPs, Wi-Fi G-54Mbps).
The PC is conected to main router Dlink DI-524 by a LAN cable, the TV is connected to Well WRC3500 router by a LAN cable and this second router (Well) is connected to the Dlink router in a bridge mode (so the TV basically communicates with PC through only 1 router). Port forwarding is set up correctly, I can see the TV from the PC and the TV can usually see the PC (server).
When I start Serviio console, it sometimes detects the TV as 1. Media Renderer with green dot on the left side and sets the profile to Generic DLNA profile
or 2. LG TV/player and sets the profile to LG TV/player, however in this case the dot is yellow.
In either one or other situation the TV can (sometimes, when it "sees" the server) connect to the server and browse folders, however the folder structure is not complete and I can't see any actual file in these folders. It seems that it only shows the folders you choose to display in categories menu in Serviio console.
If I try to use Nero MediaHome I can see the folders AND files correctly but even going to a subdirectory means waiting over 1 minute and when I finally get to a folder with a file, the TV fails to play the file (loses connection).
If I try to use Plex, the TV doesn't see the server. Never.
I have tried to use the config I've found on this forum for some other LG TV model, but it didn't help.
Please can You help me to get it working? Thanks
Return to LG
