Sony BDP 570 not displaying Serviio
BluePriest
Post Thu May 19, 2011 2:01 am
I'm very confused as to what happend. My blu ray player isnt showing serviio off of either of my computers running it. The player has a connection, and so does the computer, just serviio isnt working. What could be the problem? I tried resetting both things, turned them both off and on, with no luck at all.
By the way, I went through all the steps in the FAQ for the device not showing...
Post Thu May 19, 2011 2:29 am
Re: Sony BDP 570 not displaying Serviio
can you post you serviio log.
BluePriest
Post Thu May 19, 2011 3:10 am
I think this is it....
2011-05-18 17:24:03,941 INFO  [LibraryAdditionsCheckerThread] Added file 'Limitless.2011.R5.Full.LiNE.XviD.AbSurdiTy.avi' (title: Limitless) to Library
2011-05-18 18:25:23,156 INFO  [ServiioConsole] Starting Serviio Console
2011-05-18 18:25:24,129 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 18:25:30,812 INFO  [MediaServer] ------------------------------------------------------------------------
2011-05-18 18:25:30,812 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 18:25:30,812 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-05-18 18:25:30,812 INFO  [MediaServer] http://www.serviio.org
2011-05-18 18:25:30,812 INFO  [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 18:25:30,812 INFO  [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 18:25:30,812 INFO  [MediaServer] File encoding: windows-1252
2011-05-18 18:25:31,483 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 18:25:31,873 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 18:25:43,277 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 18:25:57,161 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 18:25:58,471 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 18:25:58,892 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 18:25:59,079 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 18:25:59,235 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 18:25:59,438 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 18:25:59,532 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 18:25:59,813 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 18:25:59,875 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 18:26:00,405 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 18:26:01,092 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 18:26:01,591 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 18:26:01,809 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 18:26:02,153 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 18:26:02,184 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-05-18 18:26:02,309 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 18:26:03,728 INFO  [Device] Created UPnP Device with UUID: 24da2adc-a745-301f-bd8e-4588fd81c846, bound address: 192.168.1.134
2011-05-18 18:26:07,098 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 18:26:07,145 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 18:26:07,145 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 18:26:07,160 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 18:26:07,160 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 18:26:07,160 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 18:26:07,160 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305761167160, LastAccessTime = 1305761167160, getTimeToLiveSeconds() = -1, createTime = 1305761167160 ]
2011-05-18 18:26:07,160 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 18:26:07,191 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 18:26:07,191 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 18:26:07,191 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 18:26:07,191 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 18:26:07,191 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 18:26:07,191 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 18:26:07,191 INFO  [CompositeCacheConfigurator] Finished configuration in 46 ms.
2011-05-18 18:26:07,301 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 18:26:07,301 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 18:26:07,316 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 18:26:07,316 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 18:26:07,332 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 18:26:07,332 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 18:26:17,797 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 18:26:17,937 INFO  [UpdateChecker] Checking if a new version is available
2011-05-18 18:26:26,330 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 18:26:27,360 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 18:26:36,423 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 18:26:36,455 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 18:47:15,978 INFO  [RendererManager] Stored a new renderer: uuid='b6130dc6-12bb-4852-b2e7-1174c05e915e', name = 'Sony BD Player', ipAddress='192.168.1.135', profile = '10'
2011-05-18 20:47:40,443 INFO  [WebServer] WebServer shutting down
2011-05-18 20:47:40,444 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 20:47:40,452 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 20:47:40,453 INFO  [EventDispatcher] Leaving EventDispatcher
2011-05-18 20:47:41,414 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-05-18 20:47:42,506 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 20:47:42,513 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 20:47:42,595 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 20:47:42,657 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 20:47:42,720 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 20:47:42,720 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 20:47:43,496 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-05-18 20:48:30,068 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-05-18 20:48:30,277 INFO  [WebServer] WebServer shutting down
2011-05-18 20:48:30,278 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 20:48:30,279 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 20:48:30,279 INFO  [EventDispatcher] Leaving EventDispatcher
2011-05-18 20:48:30,888 INFO  [DatabaseManager] Shutting down database
2011-05-18 20:48:31,184 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 20:49:42,492 INFO  [MediaServer] ------------------------------------------------------------------------
2011-05-18 20:49:42,607 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 20:49:42,607 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-05-18 20:49:42,607 INFO  [MediaServer] http://www.serviio.org
2011-05-18 20:49:42,608 INFO  [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 20:49:42,608 INFO  [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 20:49:42,608 INFO  [MediaServer] File encoding: windows-1252
2011-05-18 20:49:42,608 INFO  [MediaServer] ------------------------------------------------------------------------
2011-05-18 20:49:43,488 INFO  [ServiioConsole] Starting Serviio Console
2011-05-18 20:49:43,942 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 20:49:44,406 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 20:49:44,579 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 20:49:53,281 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 20:50:00,083 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 20:50:02,329 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 20:50:03,000 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 20:50:03,530 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 20:50:04,170 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 20:50:04,810 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 20:50:05,044 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 20:50:05,652 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 20:50:05,777 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 20:50:06,775 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 20:50:07,914 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 20:50:08,195 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 20:50:08,476 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 20:50:09,256 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 20:50:09,349 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-05-18 20:50:09,724 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 20:50:13,561 INFO  [Device] Created UPnP Device with UUID: 24da2adc-a745-301f-bd8e-4588fd81c846, bound address: 192.168.1.134
2011-05-18 20:50:13,624 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 20:50:13,639 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 20:50:13,655 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 20:50:13,655 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 20:50:13,655 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 20:50:13,655 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 20:50:13,655 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305769813655, LastAccessTime = 1305769813655, getTimeToLiveSeconds() = -1, createTime = 1305769813655 ]
2011-05-18 20:50:13,655 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 20:50:13,686 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 20:50:13,686 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 20:50:13,686 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 20:50:13,686 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 20:50:13,686 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 20:50:13,686 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 20:50:13,686 INFO  [CompositeCacheConfigurator] Finished configuration in 47 ms.
2011-05-18 20:50:13,733 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 20:50:13,748 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 20:50:13,893 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 20:50:13,908 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 20:50:13,924 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 20:50:13,940 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 20:50:25,125 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 20:50:25,250 INFO  [UpdateChecker] Checking if a new version is available
2011-05-18 20:50:33,923 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 20:50:35,218 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 20:50:43,658 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 20:50:43,658 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 21:03:58,568 INFO  [RendererManager] Stored a new renderer: uuid='7d25df7a-76cf-452e-b7fd-e15d289a9fc4', name = 'Unrecognized device', ipAddress='192.168.1.124', profile = '1'
2011-05-18 21:05:44,791 INFO  [WebServer] WebServer shutting down
2011-05-18 21:05:44,792 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:05:44,792 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:05:44,793 INFO  [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:05:46,340 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-05-18 21:05:46,347 INFO  [Device] Updated bound IP address of Device with UUID: 24da2adc-a745-301f-bd8e-4588fd81c846, bound address: 192.168.1.135
2011-05-18 21:05:46,368 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:05:46,539 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:05:46,552 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 21:05:46,554 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:05:46,555 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 21:05:49,287 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-05-18 21:08:02,586 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:08:02,596 INFO  [WebServer] WebServer shutting down
2011-05-18 21:08:02,597 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:08:02,598 INFO  [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:08:05,032 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:08:05,215 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 21:08:05,215 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:08:05,216 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:08:05,216 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 21:09:59,710 INFO  [ServiioConsole] Leaving Serviio Console
2011-05-18 21:10:00,541 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-05-18 21:10:00,847 INFO  [WebServer] WebServer shutting down
2011-05-18 21:10:00,848 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:10:00,849 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:10:00,850 INFO  [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:10:02,214 INFO  [DatabaseManager] Shutting down database
2011-05-18 21:10:03,019 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:10:28,767 INFO  [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:10:28,770 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 21:10:28,770 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-05-18 21:10:28,770 INFO  [MediaServer] http://www.serviio.org
2011-05-18 21:10:28,770 INFO  [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 21:10:28,770 INFO  [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 21:10:28,771 INFO  [MediaServer] File encoding: windows-1252
2011-05-18 21:10:28,771 INFO  [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:10:29,027 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 21:10:29,378 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 21:10:32,249 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 21:10:33,623 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 21:10:33,960 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 21:10:34,139 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 21:10:34,277 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 21:10:35,319 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 21:10:35,452 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 21:10:35,721 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 21:10:35,811 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 21:10:36,490 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 21:10:37,542 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 21:10:37,752 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 21:10:38,065 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 21:10:38,373 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:10:38,469 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-05-18 21:10:38,586 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 21:10:38,600 INFO  [Device] Created UPnP Device with UUID: e6d7c36c-a17d-3810-8c21-7795ba2933b0, bound address: 192.168.1.135
2011-05-18 21:10:38,675 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 21:10:38,706 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 21:10:38,714 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 21:10:38,715 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 21:10:38,718 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:10:38,718 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 21:10:38,718 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305771038718, LastAccessTime = 1305771038718, getTimeToLiveSeconds() = -1, createTime = 1305771038718 ]
2011-05-18 21:10:38,728 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 21:10:38,763 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 21:10:38,764 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:10:38,764 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 21:10:38,764 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 21:10:38,767 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:10:38,767 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 21:10:38,768 INFO  [CompositeCacheConfigurator] Finished configuration in 58 ms.
2011-05-18 21:10:39,073 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:10:39,087 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 21:10:39,088 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:10:39,096 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 21:10:39,096 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:10:47,639 INFO  [ServiioConsole] Starting Serviio Console
2011-05-18 21:10:47,855 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:10:49,949 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 21:10:50,709 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 21:10:50,838 INFO  [UpdateChecker] Checking if a new version is available
2011-05-18 21:10:58,262 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 21:10:59,537 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 21:11:08,667 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 21:11:08,672 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 21:12:55,263 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-05-18 21:12:55,432 INFO  [WebServer] WebServer shutting down
2011-05-18 21:12:55,433 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:12:55,434 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:12:55,434 INFO  [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:12:56,652 INFO  [DatabaseManager] Shutting down database
2011-05-18 21:12:56,917 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:14:03,561 INFO  [ServiioConsole] Starting Serviio Console
2011-05-18 21:14:05,080 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:14:16,387 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-05-18 21:14:24,421 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-05-18 21:14:24,671 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 21:14:31,971 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-05-18 21:14:42,189 INFO  [ServiioConsole] Leaving Serviio Console
2011-05-18 21:14:54,576 INFO  [ServiioConsole] Starting Serviio Console
2011-05-18 21:14:54,997 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:15:03,218 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-05-18 21:15:10,457 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-05-18 21:15:10,675 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 21:15:17,945 WARN  [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-05-18 21:15:20,971 INFO  [ServiioConsole] Leaving Serviio Console
2011-05-18 21:15:43,451 INFO  [ServiioConsole] Starting Serviio Console
2011-05-18 21:15:43,669 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:15:51,710 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-05-18 21:15:55,784 INFO  [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:15:55,800 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 21:15:55,800 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-05-18 21:15:55,800 INFO  [MediaServer] http://www.serviio.org
2011-05-18 21:15:55,800 INFO  [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 21:15:55,800 INFO  [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 21:15:55,800 INFO  [MediaServer] File encoding: windows-1252
2011-05-18 21:15:55,800 INFO  [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:15:56,128 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 21:15:56,268 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 21:15:59,747 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 21:16:01,447 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 21:16:01,588 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 21:16:01,900 INFO  [UpdateChecker] Checking if a new version is available
2011-05-18 21:16:02,040 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 21:16:02,258 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 21:16:02,399 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 21:16:02,742 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 21:16:03,335 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 21:16:04,037 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 21:16:04,099 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 21:16:04,520 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-05-18 21:16:04,520 INFO  [Device] Created UPnP Device with UUID: e6d7c36c-a17d-3810-8c21-7795ba2933b0, bound address: 192.168.1.135
2011-05-18 21:16:04,739 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 21:16:04,770 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 21:16:04,770 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 21:16:04,770 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 21:16:04,786 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:16:04,786 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 21:16:04,786 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305771364786, LastAccessTime = 1305771364786, getTimeToLiveSeconds() = -1, createTime = 1305771364786 ]
2011-05-18 21:16:04,786 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 21:16:05,285 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 21:16:05,285 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:16:05,285 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 21:16:05,285 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 21:16:05,285 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:16:05,285 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 21:16:05,285 INFO  [CompositeCacheConfigurator] Finished configuration in 515 ms.
2011-05-18 21:16:05,503 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 21:16:06,767 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 21:16:06,985 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 21:16:07,360 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 21:16:08,561 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:16:08,795 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 21:16:08,842 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:16:08,842 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 21:16:08,842 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:16:10,656 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 21:16:10,656 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:16:12,512 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 21:16:14,915 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 21:16:35,928 INFO  [ServiioConsole] Leaving Serviio Console
2011-05-18 21:16:40,707 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 21:16:40,712 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 21:18:20,031 INFO  [ServiioConsole] Leaving Serviio Console
2011-05-18 21:21:03,991 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-05-18 21:21:04,131 INFO  [WebServer] WebServer shutting down
2011-05-18 21:21:04,132 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:21:04,132 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:21:04,133 INFO  [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:21:05,880 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-05-18 21:21:07,159 INFO  [DatabaseManager] Shutting down database
2011-05-18 21:21:07,471 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:22:42,221 INFO  [ServiioConsole] Starting Serviio Console
2011-05-18 21:22:43,595 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:22:44,032 INFO  [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:22:44,034 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 21:22:44,034 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-05-18 21:22:44,034 INFO  [MediaServer] http://www.serviio.org
2011-05-18 21:22:44,035 INFO  [MediaServer]
2011-05-18 21:22:44,035 INFO  [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 21:22:44,035 INFO  [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 21:22:44,035 INFO  [MediaServer] File encoding: windows-1252
2011-05-18 21:22:44,035 INFO  [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:22:45,481 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 21:22:46,006 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 21:22:57,940 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 21:23:02,542 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 21:23:05,943 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 21:23:06,661 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 21:23:07,098 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 21:23:07,269 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 21:23:07,488 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 21:23:07,597 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 21:23:08,002 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 21:23:08,096 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 21:23:08,892 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 21:23:09,843 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 21:23:10,093 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 21:23:10,452 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 21:23:11,060 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:23:11,169 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-05-18 21:23:11,263 INFO  [Device] Created UPnP Device with UUID: e6d7c36c-a17d-3810-8c21-7795ba2933b0, bound address: 192.168.1.135
2011-05-18 21:23:11,310 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 21:23:11,341 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 21:23:11,341 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 21:23:11,341 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 21:23:11,341 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:23:11,341 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 21:23:11,341 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305771791341, LastAccessTime = 1305771791341, getTimeToLiveSeconds() = -1, createTime = 1305771791341 ]
2011-05-18 21:23:11,372 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 21:23:11,372 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 21:23:11,403 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 21:23:11,403 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:23:11,403 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 21:23:11,403 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 21:23:11,403 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:23:11,403 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 21:23:11,403 INFO  [CompositeCacheConfigurator] Finished configuration in 62 ms.
2011-05-18 21:23:11,434 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:23:11,434 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 21:23:11,654 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:23:11,669 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 21:23:11,685 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:23:24,399 INFO  [Messages] Loaded console message bundle for locale: en
2011-05-18 21:23:24,539 INFO  [UpdateChecker] Checking if a new version is available
2011-05-18 21:23:32,558 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 21:23:33,681 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 21:23:43,109 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 21:23:43,113 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 21:23:46,901 INFO  [WebServer] WebServer shutting down
2011-05-18 21:23:46,902 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:23:46,903 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:23:46,967 INFO  [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:23:49,868 INFO  [Device] Updated bound IP address of Device with UUID: e6d7c36c-a17d-3810-8c21-7795ba2933b0, bound address: 192.168.1.134
2011-05-18 21:23:49,884 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:23:49,962 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:23:49,962 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 21:23:49,978 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 21:23:49,978 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:23:49,978 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 21:23:51,727 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-05-18 21:23:52,616 INFO  [WebServer] WebServer shutting down
2011-05-18 21:23:52,616 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:23:52,632 INFO  [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:23:52,725 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-05-18 21:23:55,783 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:23:55,783 INFO  [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:23:55,874 INFO  [EventDispatcher] Starting EventDispatcher
2011-05-18 21:23:55,874 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 21:23:55,890 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:23:55,890 INFO  [WebServer] WebServer starting on port 8895
2011-05-18 21:24:03,206 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
Post Thu May 19, 2011 7:09 am
Post Thu May 19, 2011 8:29 am
So 192.168.1.135 is the correct IP of the Serviio box?
BluePriest
Post Thu May 19, 2011 1:26 pm
Illico wrote:http://www.serviio.org/component/content/article/21#q1
Ive already looked through all of those. went through each and every step before I posted.
zip wrote:So 192.168.1.135 is the correct IP of the Serviio box?
Serviio Box? Do you mean the blu ray player? if so, then yes, but i tried with and without a bound IP address. I never needed one before, however, since it wasnt showing, I gave it a shot.
Post Thu May 19, 2011 1:51 pm
What he means is the Computer that serviio is running on. Place that IP address in the bound box.
BluePriest
Post Thu May 19, 2011 2:30 pm
hmmm I thought it was the other way around. You learn something new every day. Just tried putting my ip address in there (used http://www.whatsmyip.org/) to figure it out, and still nothing on my blu ray player. Even manually checked for new networks to be on the safe side.My DNS numbers were messed up one day and I had to reset my router. That wouldnt cause a problem would it? The computeres been restarted several times since then, as have the blu ray player. Sorry, should have mentioned that earlier probably.
Post Thu May 19, 2011 2:51 pm
Fix the IP addresses of all your network devices:
For example:
Router
- Router : 192.168.1.1 /255.255.255.0
Devices:
- PC (Serviio) : 192.168.1.100
- BDPS570 : 192.168.1.101
- TV : 192.168.1.102
- Printer : 192.168.1.103
use 255.255.225.0 mask and 192.168.1.1 for devices DNS
Post Thu May 19, 2011 2:53 pm
you need to put in your local IP address not your internet IP address. You can get your local IP address a lot of different ways. It looks like it will be something like this 192.168.1.x . try going to 192.168.1.1 in your internet browser and see if your router responds. That is usually the best way to get your IP addresses.
try running this command in a windows command window.
netstat -an |find /i "listening"
right click on the windows after running this command then without moving the mouse hit ctrl-c to copy the information and then post it here.
if you do not know how to get a windows command console type cmd in the windows search box.
Post Thu May 19, 2011 3:25 pm
You can also run:
cmd
ipconfig
IP config will print out all your network cards, find the one you're using and get the IP address value
BluePriest
Post Thu May 19, 2011 3:50 pm
Ok, I put in my local IP. Still no serviio though. The IP of my blu ray player is 1 different though. (135 while my computers 134 for the final numbers) Is that normal?
Post Thu May 19, 2011 3:54 pm
yes it is normal.
did you run the
command it should show if your ports are open or not. Post the results on here per prior post.
BluePriest
Post Thu May 19, 2011 10:34 pm
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Todd>netstat -an |find /i "listening"
  TCP    0.0.0.0:135            0.0.0.0:0              LISTENING
  TCP    0.0.0.0:445            0.0.0.0:0              LISTENING
  TCP    0.0.0.0:554            0.0.0.0:0              LISTENING
  TCP    0.0.0.0:2869           0.0.0.0:0              LISTENING
  TCP    0.0.0.0:5151           0.0.0.0:0              LISTENING
  TCP    0.0.0.0:5357           0.0.0.0:0              LISTENING
  TCP    0.0.0.0:8093           0.0.0.0:0              LISTENING
  TCP    0.0.0.0:8895           0.0.0.0:0              LISTENING
  TCP    0.0.0.0:10243          0.0.0.0:0              LISTENING
  TCP    0.0.0.0:49152          0.0.0.0:0              LISTENING
  TCP    0.0.0.0:49153          0.0.0.0:0              LISTENING
  TCP    0.0.0.0:49154          0.0.0.0:0              LISTENING
  TCP    0.0.0.0:49155          0.0.0.0:0              LISTENING
  TCP    0.0.0.0:49157          0.0.0.0:0              LISTENING
  TCP    0.0.0.0:49159          0.0.0.0:0              LISTENING
  TCP    127.0.0.1:23423        0.0.0.0:0              LISTENING
  TCP    192.168.1.134:139      0.0.0.0:0              LISTENING
  TCP    192.168.1.134:44331    0.0.0.0:0              LISTENING
  TCP    192.168.1.134:44332    0.0.0.0:0              LISTENING
  TCP    [::]:135               [::]:0                 LISTENING
  TCP    [::]:445               [::]:0                 LISTENING
  TCP    [::]:554               [::]:0                 LISTENING
  TCP    [::]:2869              [::]:0                 LISTENING
  TCP    [::]:5357              [::]:0                 LISTENING
  TCP    [::]:10243             [::]:0                 LISTENING
  TCP    [::]:49152             [::]:0                 LISTENING
  TCP    [::]:49153             [::]:0                 LISTENING
  TCP    [::]:49154             [::]:0                 LISTENING
  TCP    [::]:49155             [::]:0                 LISTENING
  TCP    [::]:49157             [::]:0                 LISTENING
  TCP    [::]:49159             [::]:0                 LISTENING
C:\Users\Todd>
Post Thu May 19, 2011 11:28 pm
is port UDP 1900 open in your firewall.
BluePriest
Post Thu May 19, 2011 11:51 pm
moltra wrote:is port UDP 1900 open in your firewall.
im not sure how to do that. Comodo is confusing.I compeltely disabled my firewall though, it still doesnt show it.
