Sony BDP 570 not displaying Serviio
By the way, I went through all the steps in the FAQ for the device not showing...
2011-05-18 17:24:03,941 INFO [LibraryAdditionsCheckerThread] Added file 'Limitless.2011.R5.Full.LiNE.XviD.AbSurdiTy.avi' (title: Limitless) to Library
2011-05-18 18:25:23,156 INFO [ServiioConsole] Starting Serviio Console
2011-05-18 18:25:24,129 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 18:25:30,812 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-18 18:25:30,812 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 18:25:30,812 INFO [MediaServer] Petr Nejedly 2009-2011
2011-05-18 18:25:30,812 INFO [MediaServer] http://www.serviio.org
2011-05-18 18:25:30,812 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 18:25:30,812 INFO [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 18:25:30,812 INFO [MediaServer] File encoding: windows-1252
2011-05-18 18:25:31,483 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 18:25:31,873 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 18:25:43,277 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 18:25:57,161 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 18:25:58,471 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 18:25:58,892 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 18:25:59,079 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 18:25:59,235 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 18:25:59,438 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 18:25:59,532 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 18:25:59,813 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 18:25:59,875 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 18:26:00,405 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 18:26:01,092 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 18:26:01,591 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 18:26:01,809 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 18:26:02,153 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 18:26:02,184 INFO [WebServer] Socket buffer set to 65535 bytes
2011-05-18 18:26:02,309 INFO [WebServer] WebServer starting on port 8895
2011-05-18 18:26:03,728 INFO [Device] Created UPnP Device with UUID: 24da2adc-a745-301f-bd8e-4588fd81c846, bound address: 192.168.1.134
2011-05-18 18:26:07,098 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 18:26:07,145 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 18:26:07,145 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 18:26:07,160 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 18:26:07,160 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 18:26:07,160 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 18:26:07,160 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305761167160, LastAccessTime = 1305761167160, getTimeToLiveSeconds() = -1, createTime = 1305761167160 ]
2011-05-18 18:26:07,160 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 18:26:07,191 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 18:26:07,191 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 18:26:07,191 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 18:26:07,191 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 18:26:07,191 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 18:26:07,191 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 18:26:07,191 INFO [CompositeCacheConfigurator] Finished configuration in 46 ms.
2011-05-18 18:26:07,301 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 18:26:07,301 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 18:26:07,316 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 18:26:07,316 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 18:26:07,332 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 18:26:07,332 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 18:26:17,797 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 18:26:17,937 INFO [UpdateChecker] Checking if a new version is available
2011-05-18 18:26:26,330 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 18:26:27,360 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 18:26:36,423 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 18:26:36,455 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 18:47:15,978 INFO [RendererManager] Stored a new renderer: uuid='b6130dc6-12bb-4852-b2e7-1174c05e915e', name = 'Sony BD Player', ipAddress='192.168.1.135', profile = '10'
2011-05-18 20:47:40,443 INFO [WebServer] WebServer shutting down
2011-05-18 20:47:40,444 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 20:47:40,452 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 20:47:40,453 INFO [EventDispatcher] Leaving EventDispatcher
2011-05-18 20:47:41,414 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-05-18 20:47:42,506 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 20:47:42,513 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 20:47:42,595 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 20:47:42,657 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 20:47:42,720 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 20:47:42,720 INFO [WebServer] WebServer starting on port 8895
2011-05-18 20:47:43,496 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-05-18 20:48:30,068 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-05-18 20:48:30,277 INFO [WebServer] WebServer shutting down
2011-05-18 20:48:30,278 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 20:48:30,279 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 20:48:30,279 INFO [EventDispatcher] Leaving EventDispatcher
2011-05-18 20:48:30,888 INFO [DatabaseManager] Shutting down database
2011-05-18 20:48:31,184 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 20:49:42,492 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-18 20:49:42,607 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 20:49:42,607 INFO [MediaServer] Petr Nejedly 2009-2011
2011-05-18 20:49:42,607 INFO [MediaServer] http://www.serviio.org
2011-05-18 20:49:42,608 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 20:49:42,608 INFO [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 20:49:42,608 INFO [MediaServer] File encoding: windows-1252
2011-05-18 20:49:42,608 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-18 20:49:43,488 INFO [ServiioConsole] Starting Serviio Console
2011-05-18 20:49:43,942 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 20:49:44,406 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 20:49:44,579 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 20:49:53,281 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 20:50:00,083 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 20:50:02,329 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 20:50:03,000 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 20:50:03,530 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 20:50:04,170 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 20:50:04,810 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 20:50:05,044 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 20:50:05,652 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 20:50:05,777 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 20:50:06,775 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 20:50:07,914 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 20:50:08,195 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 20:50:08,476 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 20:50:09,256 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 20:50:09,349 INFO [WebServer] Socket buffer set to 65535 bytes
2011-05-18 20:50:09,724 INFO [WebServer] WebServer starting on port 8895
2011-05-18 20:50:13,561 INFO [Device] Created UPnP Device with UUID: 24da2adc-a745-301f-bd8e-4588fd81c846, bound address: 192.168.1.134
2011-05-18 20:50:13,624 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 20:50:13,639 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 20:50:13,655 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 20:50:13,655 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 20:50:13,655 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 20:50:13,655 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 20:50:13,655 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305769813655, LastAccessTime = 1305769813655, getTimeToLiveSeconds() = -1, createTime = 1305769813655 ]
2011-05-18 20:50:13,655 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 20:50:13,686 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 20:50:13,686 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 20:50:13,686 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 20:50:13,686 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 20:50:13,686 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 20:50:13,686 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 20:50:13,686 INFO [CompositeCacheConfigurator] Finished configuration in 47 ms.
2011-05-18 20:50:13,733 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 20:50:13,748 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 20:50:13,893 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 20:50:13,908 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 20:50:13,924 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 20:50:13,940 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 20:50:25,125 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 20:50:25,250 INFO [UpdateChecker] Checking if a new version is available
2011-05-18 20:50:33,923 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 20:50:35,218 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 20:50:43,658 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 20:50:43,658 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 21:03:58,568 INFO [RendererManager] Stored a new renderer: uuid='7d25df7a-76cf-452e-b7fd-e15d289a9fc4', name = 'Unrecognized device', ipAddress='192.168.1.124', profile = '1'
2011-05-18 21:05:44,791 INFO [WebServer] WebServer shutting down
2011-05-18 21:05:44,792 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:05:44,792 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:05:44,793 INFO [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:05:46,340 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-05-18 21:05:46,347 INFO [Device] Updated bound IP address of Device with UUID: 24da2adc-a745-301f-bd8e-4588fd81c846, bound address: 192.168.1.135
2011-05-18 21:05:46,368 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:05:46,539 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:05:46,552 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 21:05:46,554 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:05:46,555 INFO [WebServer] WebServer starting on port 8895
2011-05-18 21:05:49,287 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-05-18 21:08:02,586 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:08:02,596 INFO [WebServer] WebServer shutting down
2011-05-18 21:08:02,597 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:08:02,598 INFO [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:08:05,032 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:08:05,215 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 21:08:05,215 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:08:05,216 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:08:05,216 INFO [WebServer] WebServer starting on port 8895
2011-05-18 21:09:59,710 INFO [ServiioConsole] Leaving Serviio Console
2011-05-18 21:10:00,541 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-05-18 21:10:00,847 INFO [WebServer] WebServer shutting down
2011-05-18 21:10:00,848 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:10:00,849 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:10:00,850 INFO [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:10:02,214 INFO [DatabaseManager] Shutting down database
2011-05-18 21:10:03,019 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:10:28,767 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:10:28,770 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 21:10:28,770 INFO [MediaServer] Petr Nejedly 2009-2011
2011-05-18 21:10:28,770 INFO [MediaServer] http://www.serviio.org
2011-05-18 21:10:28,770 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 21:10:28,770 INFO [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 21:10:28,771 INFO [MediaServer] File encoding: windows-1252
2011-05-18 21:10:28,771 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:10:29,027 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 21:10:29,378 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 21:10:32,249 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 21:10:33,623 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 21:10:33,960 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 21:10:34,139 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 21:10:34,277 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 21:10:35,319 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 21:10:35,452 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 21:10:35,721 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 21:10:35,811 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 21:10:36,490 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 21:10:37,542 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 21:10:37,752 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 21:10:38,065 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 21:10:38,373 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:10:38,469 INFO [WebServer] Socket buffer set to 65535 bytes
2011-05-18 21:10:38,586 INFO [WebServer] WebServer starting on port 8895
2011-05-18 21:10:38,600 INFO [Device] Created UPnP Device with UUID: e6d7c36c-a17d-3810-8c21-7795ba2933b0, bound address: 192.168.1.135
2011-05-18 21:10:38,675 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 21:10:38,706 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 21:10:38,714 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 21:10:38,715 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 21:10:38,718 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:10:38,718 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 21:10:38,718 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305771038718, LastAccessTime = 1305771038718, getTimeToLiveSeconds() = -1, createTime = 1305771038718 ]
2011-05-18 21:10:38,728 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 21:10:38,763 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 21:10:38,764 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:10:38,764 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 21:10:38,764 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 21:10:38,767 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:10:38,767 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 21:10:38,768 INFO [CompositeCacheConfigurator] Finished configuration in 58 ms.
2011-05-18 21:10:39,073 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:10:39,087 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 21:10:39,088 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:10:39,096 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 21:10:39,096 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:10:47,639 INFO [ServiioConsole] Starting Serviio Console
2011-05-18 21:10:47,855 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:10:49,949 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 21:10:50,709 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 21:10:50,838 INFO [UpdateChecker] Checking if a new version is available
2011-05-18 21:10:58,262 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 21:10:59,537 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 21:11:08,667 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 21:11:08,672 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 21:12:55,263 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-05-18 21:12:55,432 INFO [WebServer] WebServer shutting down
2011-05-18 21:12:55,433 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:12:55,434 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:12:55,434 INFO [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:12:56,652 INFO [DatabaseManager] Shutting down database
2011-05-18 21:12:56,917 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:14:03,561 INFO [ServiioConsole] Starting Serviio Console
2011-05-18 21:14:05,080 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:14:16,387 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-05-18 21:14:24,421 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-05-18 21:14:24,671 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 21:14:31,971 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-05-18 21:14:42,189 INFO [ServiioConsole] Leaving Serviio Console
2011-05-18 21:14:54,576 INFO [ServiioConsole] Starting Serviio Console
2011-05-18 21:14:54,997 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:15:03,218 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-05-18 21:15:10,457 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-05-18 21:15:10,675 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 21:15:17,945 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-05-18 21:15:20,971 INFO [ServiioConsole] Leaving Serviio Console
2011-05-18 21:15:43,451 INFO [ServiioConsole] Starting Serviio Console
2011-05-18 21:15:43,669 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:15:51,710 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-05-18 21:15:55,784 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:15:55,800 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 21:15:55,800 INFO [MediaServer] Petr Nejedly 2009-2011
2011-05-18 21:15:55,800 INFO [MediaServer] http://www.serviio.org
2011-05-18 21:15:55,800 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 21:15:55,800 INFO [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 21:15:55,800 INFO [MediaServer] File encoding: windows-1252
2011-05-18 21:15:55,800 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:15:56,128 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 21:15:56,268 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 21:15:59,747 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 21:16:01,447 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 21:16:01,588 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 21:16:01,900 INFO [UpdateChecker] Checking if a new version is available
2011-05-18 21:16:02,040 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 21:16:02,258 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 21:16:02,399 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 21:16:02,742 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 21:16:03,335 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 21:16:04,037 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 21:16:04,099 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 21:16:04,520 INFO [WebServer] Socket buffer set to 65535 bytes
2011-05-18 21:16:04,520 INFO [Device] Created UPnP Device with UUID: e6d7c36c-a17d-3810-8c21-7795ba2933b0, bound address: 192.168.1.135
2011-05-18 21:16:04,739 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 21:16:04,770 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 21:16:04,770 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 21:16:04,770 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 21:16:04,786 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:16:04,786 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 21:16:04,786 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305771364786, LastAccessTime = 1305771364786, getTimeToLiveSeconds() = -1, createTime = 1305771364786 ]
2011-05-18 21:16:04,786 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 21:16:05,285 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 21:16:05,285 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:16:05,285 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 21:16:05,285 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 21:16:05,285 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:16:05,285 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 21:16:05,285 INFO [CompositeCacheConfigurator] Finished configuration in 515 ms.
2011-05-18 21:16:05,503 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 21:16:06,767 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 21:16:06,985 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 21:16:07,360 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 21:16:08,561 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:16:08,795 INFO [WebServer] WebServer starting on port 8895
2011-05-18 21:16:08,842 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:16:08,842 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 21:16:08,842 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:16:10,656 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 21:16:10,656 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:16:12,512 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 21:16:14,915 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 21:16:35,928 INFO [ServiioConsole] Leaving Serviio Console
2011-05-18 21:16:40,707 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 21:16:40,712 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 21:18:20,031 INFO [ServiioConsole] Leaving Serviio Console
2011-05-18 21:21:03,991 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-05-18 21:21:04,131 INFO [WebServer] WebServer shutting down
2011-05-18 21:21:04,132 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:21:04,132 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:21:04,133 INFO [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:21:05,880 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-05-18 21:21:07,159 INFO [DatabaseManager] Shutting down database
2011-05-18 21:21:07,471 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:22:42,221 INFO [ServiioConsole] Starting Serviio Console
2011-05-18 21:22:43,595 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-05-18 21:22:44,032 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:22:44,034 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-05-18 21:22:44,034 INFO [MediaServer] Petr Nejedly 2009-2011
2011-05-18 21:22:44,034 INFO [MediaServer] http://www.serviio.org
2011-05-18 21:22:44,035 INFO [MediaServer]
2011-05-18 21:22:44,035 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-05-18 21:22:44,035 INFO [MediaServer] OS Windows 7 amd64 6.1
2011-05-18 21:22:44,035 INFO [MediaServer] File encoding: windows-1252
2011-05-18 21:22:44,035 INFO [MediaServer] ------------------------------------------------------------------------
2011-05-18 21:22:45,481 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-05-18 21:22:46,006 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-05-18 21:22:57,940 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 21:23:02,542 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-05-18 21:23:05,943 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-05-18 21:23:06,661 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-05-18 21:23:07,098 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-05-18 21:23:07,269 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-05-18 21:23:07,488 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-05-18 21:23:07,597 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-05-18 21:23:08,002 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-05-18 21:23:08,096 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-05-18 21:23:08,892 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-05-18 21:23:09,843 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-05-18 21:23:10,093 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-05-18 21:23:10,452 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-05-18 21:23:11,060 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-05-18 21:23:11,169 INFO [WebServer] Socket buffer set to 65535 bytes
2011-05-18 21:23:11,263 INFO [Device] Created UPnP Device with UUID: e6d7c36c-a17d-3810-8c21-7795ba2933b0, bound address: 192.168.1.135
2011-05-18 21:23:11,310 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-05-18 21:23:11,341 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-05-18 21:23:11,341 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-05-18 21:23:11,341 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-05-18 21:23:11,341 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:23:11,341 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-05-18 21:23:11,341 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1305771791341, LastAccessTime = 1305771791341, getTimeToLiveSeconds() = -1, createTime = 1305771791341 ]
2011-05-18 21:23:11,372 INFO [WebServer] WebServer starting on port 8895
2011-05-18 21:23:11,372 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-05-18 21:23:11,403 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-05-18 21:23:11,403 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:23:11,403 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-05-18 21:23:11,403 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-05-18 21:23:11,403 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-05-18 21:23:11,403 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-05-18 21:23:11,403 INFO [CompositeCacheConfigurator] Finished configuration in 62 ms.
2011-05-18 21:23:11,434 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:23:11,434 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-05-18 21:23:11,654 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:23:11,669 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 21:23:11,685 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:23:24,399 INFO [Messages] Loaded console message bundle for locale: en
2011-05-18 21:23:24,539 INFO [UpdateChecker] Checking if a new version is available
2011-05-18 21:23:32,558 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-05-18 21:23:33,681 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-05-18 21:23:43,109 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-05-18 21:23:43,113 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-05-18 21:23:46,901 INFO [WebServer] WebServer shutting down
2011-05-18 21:23:46,902 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-05-18 21:23:46,903 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:23:46,967 INFO [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:23:49,868 INFO [Device] Updated bound IP address of Device with UUID: e6d7c36c-a17d-3810-8c21-7795ba2933b0, bound address: 192.168.1.134
2011-05-18 21:23:49,884 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:23:49,962 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:23:49,962 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 21:23:49,978 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 21:23:49,978 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:23:49,978 INFO [WebServer] WebServer starting on port 8895
2011-05-18 21:23:51,727 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-05-18 21:23:52,616 INFO [WebServer] WebServer shutting down
2011-05-18 21:23:52,616 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-05-18 21:23:52,632 INFO [EventDispatcher] Leaving EventDispatcher
2011-05-18 21:23:52,725 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-05-18 21:23:55,783 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-05-18 21:23:55,783 INFO [RendererSearchSender] Searching for Renderer devices
2011-05-18 21:23:55,874 INFO [EventDispatcher] Starting EventDispatcher
2011-05-18 21:23:55,874 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.134, timeout = 0
2011-05-18 21:23:55,890 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-05-18 21:23:55,890 INFO [WebServer] WebServer starting on port 8895
2011-05-18 21:24:03,206 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
Illico wrote:http://www.serviio.org/component/content/article/21#q1
zip wrote:So 192.168.1.135 is the correct IP of the Serviio box?
BluePriest wrote:zip wrote:So 192.168.1.135 is the correct IP of the Serviio box?
Serviio Box? Do you mean the blu ray player? if so, then yes, but i tried with and without a bound IP address. I never needed one before, however, since it wasnt showing, I gave it a shot.
moltra wrote:BluePriest wrote:zip wrote:So 192.168.1.135 is the correct IP of the Serviio box?
What he means is the Computer that serviio is running on. Place that IP address in the bound box.
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Todd>netstat -an |find /i "listening"
TCP 0.0.0.0:135 0.0.0.0:0 LISTENING
TCP 0.0.0.0:445 0.0.0.0:0 LISTENING
TCP 0.0.0.0:554 0.0.0.0:0 LISTENING
TCP 0.0.0.0:2869 0.0.0.0:0 LISTENING
TCP 0.0.0.0:5151 0.0.0.0:0 LISTENING
TCP 0.0.0.0:5357 0.0.0.0:0 LISTENING
TCP 0.0.0.0:8093 0.0.0.0:0 LISTENING
TCP 0.0.0.0:8895 0.0.0.0:0 LISTENING
TCP 0.0.0.0:10243 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49152 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49153 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49154 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49155 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49157 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49159 0.0.0.0:0 LISTENING
TCP 127.0.0.1:23423 0.0.0.0:0 LISTENING
TCP 192.168.1.134:139 0.0.0.0:0 LISTENING
TCP 192.168.1.134:44331 0.0.0.0:0 LISTENING
TCP 192.168.1.134:44332 0.0.0.0:0 LISTENING
TCP [::]:135 [::]:0 LISTENING
TCP [::]:445 [::]:0 LISTENING
TCP [::]:554 [::]:0 LISTENING
TCP [::]:2869 [::]:0 LISTENING
TCP [::]:5357 [::]:0 LISTENING
TCP [::]:10243 [::]:0 LISTENING
TCP [::]:49152 [::]:0 LISTENING
TCP [::]:49153 [::]:0 LISTENING
TCP [::]:49154 [::]:0 LISTENING
TCP [::]:49155 [::]:0 LISTENING
TCP [::]:49157 [::]:0 LISTENING
TCP [::]:49159 [::]:0 LISTENING
C:\Users\Todd>moltra wrote:is port UDP 1900 open in your firewall.
