Mac user with a PS3
Post Wed May 18, 2011 10:18 pm
Re: Mac user with a PS3
Thank you. We are working on a sticky for a Mac, but need input from Mac users.
jedicaveman
Post Wed May 18, 2011 11:43 pm
I'm very Mac savvy, so let me know if there is anything I can help with in that regard. I just have to familiarize myself with this software more. I'll update the profile file as suggested and test things later. Stay tuned...
jedicaveman
Post Thu May 19, 2011 4:03 am
Ok, I tried both suggestions in the profiles.xml. Neither worked. Apple movies say "data corrupt" and the ones from my camera say "unsupported data"...
Post Thu May 19, 2011 7:01 am
Grrrrr...
Turn on detailed logging (see link) you should be able to see the FFmpeg command that is used for the transcode.
Could you post here the FFmpeg command used for both profiles.xml I suggested?
jedicaveman
Post Thu May 19, 2011 1:54 pm
Yeah, who knew this would be such a bear... I'll try again with logging. Last night I gave up on the movie trailers and converted them to m4v so we could actually watch them. In retrospect, I do actually remember movie trailers having issues with the old PS3 Media Server. They would actually play... but the last few seconds would get cut off. Last night as a test, I copied one to the PS3 internal hard drive and it would not play there either. This tells me those will always have to be converted. However, like I said, the MOV files from my camera play flawlessly when copied to the PS3 hard drive. There has to be a way to stream them...
Post Thu May 19, 2011 1:59 pm
We appreciate you sticking with serviio and helping us make it better.
jedicaveman
Post Thu May 19, 2011 2:13 pm
No problem. Where should I go for official feedback? One thing I notice is this sucker uses a LOT of CPU power. I'm assuming it's just updating the library folders since I'm not streaming anything... but right now it's in the background and using up to 277%! What's really weird is even though I have the server set to only use 2 CPU cores, it's still using all 4.
Mac Pro
266Ghz x4 cores
11GB RAM
MacOS 10.6.7
Also, how long is it supposed to take to update the library? This thing's been chugging along for days.
Post Thu May 19, 2011 2:44 pm
It all depends on how many files you have in your library. It should lower alot after everything is added to the library.
You can leave your Official Feedback here on the forums. Zip the creator of serviio reads and responds to posts on here every day.
jedicaveman
Post Thu May 19, 2011 2:47 pm
Yeah... it could be taking longer due to my 500GB music library being on a NAS...
Post Thu May 19, 2011 3:36 pm
jedicaveman wrote:Yeah... it could be taking longer due to my 500GB music library being on a NAS...
Probably. You can check the log to see list of added files and how long it takes to add one.
Once you have added all files you can turn of automatic library checking or have it enabled only for certain folders (if you have some where the content hardly changes).
I don't have PS3 so it's harder to produce a 100% working profile, unlike the guys at PS3MS where they shaped the whole product around supporting PS3 mainly - which then left them with some incompatibilities for other devices. So bear with us, hopefully we can get the profile spot on.
jedicaveman
Post Thu May 19, 2011 4:00 pm
Hey, I appreciate the fact that you guys are working on this. I really do like the features. I've obviously got to rename some of my files though... it puts a Star Trek poster on about 60% of the movies I have. :) Quick question, how do I get MKV support? ALL of my MKVs show up in the list as unsupported data. I assume I just need to add something to the profiles.xml (which I have bookmarked in BBedit ;) )
Post Thu May 19, 2011 4:04 pm
I check movies on http://www.themoviedb.organd http://www.thetvdb.com to verify the names.
Post Thu May 19, 2011 4:43 pm
The MKV's should play - transcoded. Can you post ffmpeg -i of the MKV file, MediaInfo result of the file as well and detailed log of when you're trying to play that file
jedicaveman
Post Thu May 19, 2011 5:04 pm
That's just it. I dont even get the chance to try to play them because they show up right in the PS3 menu list as "unsupported data". Should I go ahead and try to play one and see what happens?
Post Thu May 19, 2011 5:14 pm
I would try one.
joethezombie
Post Thu May 19, 2011 7:40 pm
Hello. I am also a Mac user with a PS3. I have files that play perfectly on the PS3 via internal HDD, but serviio sends as "Unsupported Data" which can not be played: "The data type is not supported."
Note that I have turned off the transcoding options in serviio... these files are natively supported by the ps3.
For instance,
./ffmpeg -i 1408.m4v
  built on Jan 12 2011 19:51:48 with gcc 4.0.1 (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '1408.m4v':
    major_brand     : mp42
    minor_version   : 0
    creation_time   : 2011-05-10 14:53:16
    encoder         : HandBrake 3975svn 2011050901
    title           : 1408
    artist          : John Cusack, Samuel L. Jackson, Tony Shalhoub, Mary McCormack, Jasmine Jessica Anthony, David Nicholson, Alexandra Silber, Emily Harvey, Noah Lee Margetts
    date            : 2007-06-22T00:00:00Z
    genre           : Horror
    description     : Based on a short story by Stephen King, a man who specializes in
 debunking the paranormal checks into the infamous room 1408 in the
 Dolphin Hotel, only to discover; the terror is real.
    synopsis        : The cynical and skeptical writer Mike Enslin writes books evaluating supernatural phenomena in hotels, graveyards and other haunted places, usually debunking the mystery. While writing his last book, he travels from Los Angeles to New York to spend one night in the evil room 1408 of the Dolphin Hotel, which is permanently unavailable for guests. The reluctant manager Mr. Gerald Olin objects to his request and offers an upgrade, expensive booze and finally the reports relating the death of more than fifty guests along decades in the cursed room. However, Mike threatens Mr. Oiln, promising to sue the hotel, and finally checks in the room. Along the night, he finds that guests of room 1408 can check out when they like, but they can never leave the room alive.
  Duration: 01:52:25.81, start: 0.000000, bitrate: 5131 kb/s
    Stream #0.0(und): Video: h264, yuv420p, 1920x798 [PAR 1:1 DAR 320:133], 4321 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 6 channels, s16, 640 kb/s
    Stream #0.2(eng): Audio: aac, 48000 Hz, stereo, s16, 164 kb/s
MediaInfo:
Complete name                    : /Users/Shared/Movies/1408.m4v
Format                           : MPEG-4
Format profile                   : Base Media / Version 2
Codec ID                         : mp42
File size                        : 4.03 GiB
Duration                         : 1h 52mn
Overall bit rate                 : 5 131 Kbps
Movie name                       : 1408
Performer                        : John Cusack, Samuel L. Jackson, Tony Shalhoub, Mary McCormack, Jasmine Jessica Anthony, David Nicholson, Alexandra Silber, Emily Harvey, Noah Lee Margetts
Genre                            : Horror
Recorded date                    : UTC 2007-06-22 00:00:00
Encoded date                     : UTC 2011-05-10 14:53:16
Tagged date                      : UTC 2011-05-10 21:07:10
Writing application              : HandBrake 3975svn 2011050901
Cover                            : Yes
iTunEXTC                         : mpaa|PG-13|300|
desc                             : Based on a short story by Stephen King, a man who specializes in  /  debunking the paranormal checks into the infamous room 1408 in the  /  Dolphin Hotel, only to discover; the terror is real.
ldes                             : The cynical and skeptical writer Mike Enslin writes books evaluating supernatural phenomena in hotels, graveyards and other haunted places, usually debunking the mystery. While writing his last book, he travels from Los Angeles to New York to spend one night in the evil room 1408 of the Dolphin Hotel, which is permanently unavailable for guests. The reluctant manager Mr. Gerald Olin objects to his request and offers an upgrade, expensive booze and finally the reports relating the death of more than fifty guests along decades in the cursed room. However, Mike threatens Mr. Oiln, promising to sue the hotel, and finally checks in the room. Along the night, he finds that guests of room 1408 can check out when they like, but they can never leave the room alive.
stik                             : 0
iTunMOVI                         : <?xml version="1.0" encoding="UTF-8"?> / <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> / <plist version="1.0"> / <dict> /    <key>cast</key> /    <array> /       <dict> /          <key>name</key> /          <string>John Cusack</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Samuel L. Jackson</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Tony Shalhoub</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Mary McCormack</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Jasmine Jessica Anthony</string> /       </dict> /       <dict> /          <key>name</key> /          <string>David Nicholson</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Alexandra Silber</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Emily Harvey</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Noah Lee Margetts</string> /       </dict> /    </array> /    <key>directors</key> /    <array> /       <dict> /          <key>name</key> /          <string>Mikael Håfström</string> /       </dict> /    </array> /    <key>producers</key> /    <array> /       <dict> /          <key>name</key> /          <string>Lorenzo di Bonaventura</string> /       </dict> /    </array> /    <key>screenwriters</key> /    <array> /       <dict> /          <key>name</key> /          <string>Matt Greenberg</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Scott Alexander</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Larry Karaszewski</string> /       </dict> /    </array> / </dict> / </plist>
rtng                             : 0
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 1h 52mn
Bit rate mode                    : Variable
Bit rate                         : 4 321 Kbps
Width                            : 1 920 pixels
Height                           : 798 pixels
Display aspect ratio             : 2.40:1
Frame rate mode                  : Variable
Frame rate                       : 23.976 fps
Minimum frame rate               : 23.974 fps
Maximum frame rate               : 23.981 fps
Bits/(Pixel*Frame)               : 0.118
Stream size                      : 3.39 GiB (84%)
Writing library                  : x264 core 115
Encoding settings                : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / vbv_maxrate=15000 / vbv_bufsize=15000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Tagged date                      : UTC 2011-05-10 19:44:24
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : ac-3
Duration                         : 1h 52mn
Bit rate                         : 640 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 515 MiB (12%)
Language                         : English
Audio #2
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Duration                         : 1h 52mn
Bit rate                         : 164 Kbps
Maximum bit rate                 : 253 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Stream size                      : 132 MiB (3%)
Language                         : English
This is an mp4 (m4v) file encoded with HandBrake, then tagged with MetaX. It works perfectly on the Mac via Quicktime or VLC. It works perfectly on the PS3 if copied over to the internal drive. It also streams fine via DLNA if using TVMOBiLi (no transcoder) on the Mac or even WMP12 on Win7. Heck, the PS3 will even play it HTTP streamed via "python -m SimpleHTTPServer 3333"! But, sadly, my favorite application serviio hands out "Unsupported Data". :(
Interestingly enough, another file I encoded using the same process works just fine:
./ffmpeg -i "Tron Legacy.m4v"
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Tron Legacy.m4v':
    major_brand     : mp42
    minor_version   : 0
    creation_time   : 2011-05-09 04:48:40
    title           : Tron Legacy
    artist          : Jeff Bridges, Garrett Hedlund, Olivia Wilde, Bruce Boxleitner, Michael Sheen
    date            : 2010-05-09T00:00:00Z
    genre           : Sci-Fi & Fantasy
    description     : The son of a virtual world designer goes looking for his father and ends up inside the digital world that his father designed. He meets his father's creation turned bad and a unique ally who was born inside the digital domain of The Grid.
    synopsis        : Sam Flynn, the tech-savvy 27-year-old son of Kevin Flynn, looks into his father's disappearance and finds himself pulled into the same world of fierce programs and gladiatorial games where his father has been living for 20 years. Along with Kevin's loyal confidant, father and son embark on a life-and-death journey across a visually-stunning cyber universe that has become far more advanced and exceedingly dangerous. Written by ZootCatchy
  Duration: 02:05:08.67, start: 0.000000, bitrate: 5466 kb/s
    Stream #0.0(und): Video: h264, yuv420p, 1920x816 [PAR 1:1 DAR 40:17], 4828 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
    Stream #0.1(und): Audio: aac, 48000 Hz, 5.1, s16, 466 kb/s
    Stream #0.2(und): Audio: aac, 48000 Hz, stereo, s16, 164 kb/s
MediaInfo:
Complete name                    : /Users/Shared/Movies/Tron Legacy.m4v
Format                           : MPEG-4
Codec ID                         : mp42
File size                        : 4.78 GiB
Duration                         : 2h 5mn
Overall bit rate                 : 5 467 Kbps
Movie name                       : Tron Legacy
Performer                        : Jeff Bridges, Garrett Hedlund, Olivia Wilde, Bruce Boxleitner, Michael Sheen
Genre                            : Sci-Fi & Fantasy
Recorded date                    : UTC 2010-05-09 00:00:00
Encoded date                     : UTC 2011-05-09 04:48:40
Tagged date                      : UTC 2011-05-09 14:07:42
Cover                            : Yes
iTunEXTC                         : mpaa|PG|200|
desc                             : The son of a virtual world designer goes looking for his father and ends up inside the digital world that his father designed. He meets his father's creation turned bad and a unique ally who was born inside the digital domain of The Grid.
ldes                             : Sam Flynn, the tech-savvy 27-year-old son of Kevin Flynn, looks into his father's disappearance and finds himself pulled into the same world of fierce programs and gladiatorial games where his father has been living for 20 years. Along with Kevin's loyal confidant, father and son embark on a life-and-death journey across a visually-stunning cyber universe that has become far more advanced and exceedingly dangerous. Written by ZootCatchy
stik                             : 0
iTunMOVI                         : <?xml version="1.0" encoding="UTF-8"?> / <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> / <plist version="1.0"> / <dict> /    <key>cast</key> /    <array> /       <dict> /          <key>name</key> /          <string>Jeff Bridges</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Garrett Hedlund</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Olivia Wilde</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Bruce Boxleitner</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Michael Sheen</string> /       </dict> /    </array> /    <key>directors</key> /    <array> /       <dict> /          <key>name</key> /          <string>Joseph Kosinski</string> /       </dict> /    </array> /    <key>producers</key> /    <array> /       <dict> /          <key>name</key> /          <string>Sean Bailey</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Steven Lisberger</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Jeffrey Silver</string> /       </dict> /    </array> /    <key>screenwriters</key> /    <array> /       <dict> /          <key>name</key> /          <string>Edward Kitsis</string> /       </dict> /       <dict> /          <key>name</key> /          <string>Adam Horowitz</string> /       </dict> /    </array> / </dict> / </plist>
rtng                             : 0
Codec ID                         : avc1
Duration                         : 2h 5mn
Bit rate                         : 4 829 Kbps
Height                           : 816 pixels
Display aspect ratio             : 2.35:1
Minimum frame rate               : 23.968 fps
Bits/(Pixel*Frame)               : 0.129
Stream size                      : 4.22 GiB (88%)
Tagged date                      : UTC 2011-05-09 10:33:14
Audio #1
Format                           : AAC
Format profile                   : LC
Codec ID                         : 40
Duration                         : 2h 5mn
Bit rate                         : 466 Kbps
Maximum bit rate                 : 726 Kbps
Stream size                      : 417 MiB (9%)
Audio #2
Format                           : AAC
Format profile                   : LC
Codec ID                         : 40
Duration                         : 2h 5mn
Bit rate                         : 164 Kbps
Maximum bit rate                 : 275 Kbps
Stream size                      : 147 MiB (3%)
The only difference would be the 5.1 AC3 audio passthru in the "Unsupported Data" file, whereas the one the works contains 6 channel AAC.
EDIT: So I took the first file with AC3 track, demuxed it into elementary streams with mp4box. I then remuxed just the h264 stream and the AAC stream, and the file can now be served successfully. It appears as though serviio is choking when the mp4 contains an AC3 audio track.
Post Fri May 20, 2011 6:49 am
I think this is due to x264 encoding settings that your PS3 does not support: I mean "b_pyramid=2", must be "b_pyramid=1"
Internal DD or USB did not use the same hardware/software than DLNA, that could explain why your file play over DD/USB and not over DNLA.
This the same issue with Sony Bravia TV where more codecs are supported over USB (ex DivX) and not over DLNA.
Post Fri May 20, 2011 8:29 am
Could you have a look at how TVMobili serves the file in Intel's AV Media Controller? Just browse to the file, get Properties ans one of the Resources will be the file. Post protocol-info of the resource.
This will only work on Windows though. Alternatively you could capture packets via Wireshark between PS3 and TvMobili when you start playing the file. It might be that the mime-type is different.
joethezombie
Post Fri May 20, 2011 2:15 pm
Illico wrote:I think this is due to x264 encoding settings that your PS3 does not support: I mean "b_pyramid=2", must be "b_pyramid=1"
Naw, b-pyramid=2 is the equivalent of "--b-pyramid normal", and affects the video stream only. It is fully supported by the PS3. Note that once I removed the AC3 audio track, the video stream played flawlessly. Also note that every other DLNA (even TvMobili, which has no transcode ability) is capable of sending the file with no issue. There's just something about serviio. :o
zip wrote:Could you have a look at how TVMobili serves the file in Intel's AV Media Controller? Just browse to the file, get Properties ans one of the Resources will be the file. Post protocol-info of the resource.
Sure thing. That was my next step, but I can't work on it until tomorrow... I'll let you know the results.
joethezombie
Post Thu May 26, 2011 6:09 am
This is for the file containing AC3 referenced earlier that doesn't work with serviio. (1408.m4v)
resource#1:
http://10.1.1.20:30888/__contentStreamUPnP/936786e976ad83d7df05856c8b8c226d/TVMOBiLi/0-860e8a64f3727db856fc8a6aba0df480x251y11z1306389183
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000
resource#2:
http://10.1.1.20:30888/__albumArt/936786e976ad83d7df05856c8b8c226d/TVMOBiLi/0-860e8a64f3727db856fc8a6aba0df480x251y11z1306389183
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01D00000000000000000000000000000
resource#3:
http://10.1.1.20:30888/__subtitle/4226e59c4f9df1bee1a9f565be690705/TVMOBiLi/0-860e8a64f3727db856fc8a6aba0df480x251y11z1306389183.
Users browsing this forum: Baidu [Spider] and 3 guests
