Quick Assist-m4v files, 0.5.2, file is corrupt or invalid
• Page 2 of 3 • 1, 2, 3
Got it. Didn't realize there would be a new output file. After I transcode, I'll save off the current file and replace with the new one and force a library refresh. Will advise.
Re: Quick Assist-m4v files, 0.5.2, file is corrupt or inval
Update. File did not play, same error on the BD player. Here's the (more extended log) from Debug mode.
Here's a second log snip from another file that was coded by an earlier version of handbrake. Including this just for comparison.
Question - how much working space (tmp space) does Serviio need? The partition that serviio is installed on is relatively tight for free space. In the menu, I changed the location of the tmp space to a new drive that has much more space. Unfortunately, this didn't fix anything however I did see a pretty big file get generated in that directory (3+ GB).
- Code:
2011-05-19 08:31:30,342 DEBUG [VideoDAOImpl] Retrieving list of videos with initial T (from=0, count=10)
2011-05-19 08:31:30,386 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2011-05-19 08:31:30,396 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 75)
2011-05-19 08:31:30,415 DEBUG [MediaItemDAOImpl] Getting file of media item 75
2011-05-19 08:31:30,421 DEBUG [VideoDAOImpl] Reading a Video (id = 75)
2011-05-19 08:31:30,445 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 75 and profile Sony BD Player
2011-05-19 08:31:30,450 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 69)
2011-05-19 08:31:30,517 DEBUG [VideoDAOImpl] Retrieving number of videos with initial T
2011-05-19 08:31:30,523 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-05-19 08:31:30,531 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-05-19 08:31:32,902 DEBUG [WebServer] Incoming connection from /172.31.0.138:63330
2011-05-19 08:31:32,997 DEBUG [ResourceTransportRequestHandler] HEAD /resource/75/MEDIA_ITEM/AVC_TS_MP_SD_AAC_MULT5_ISO$1 HTTP/1.1, headers = [Host: 172.31.0.2:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2011-05-19 08:31:32,998 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 172.31.0.138
2011-05-19 08:31:32,999 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:33,001 DEBUG [ResourceTransportRequestHandler] Request for resource 75 and type 'MEDIA_ITEM' received
2011-05-19 08:31:33,001 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 75)
2011-05-19 08:31:33,002 DEBUG [VideoDAOImpl] Reading a Video (id = 75)
2011-05-19 08:31:33,004 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 75, format AVC_TS_MP_SD_AAC_MULT5_ISO and profile Sony BD Player
2011-05-19 08:31:33,007 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-05-19 08:31:33,007 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/vnd.dlna.mpeg-tts,Content-Length: 1178352980,Date: Thu, 19 May 2011 15:31:33 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-19 08:31:33,017 DEBUG [ResourceTransportRequestHandler] GET /resource/75/MEDIA_ITEM/AVC_TS_MP_SD_AAC_MULT5_ISO$1 HTTP/1.1, headers = [Host: 172.31.0.2:8895,Accept: */*,Range: bytes=0-1023,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2011-05-19 08:31:33,017 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 172.31.0.138
2011-05-19 08:31:33,018 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:33,019 DEBUG [ResourceTransportRequestHandler] Request for resource 75 and type 'MEDIA_ITEM' received
2011-05-19 08:31:33,019 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 75)
2011-05-19 08:31:33,020 DEBUG [VideoDAOImpl] Reading a Video (id = 75)
2011-05-19 08:31:33,021 DEBUG [VideoDeliveryEngine] Delivering item '75' for client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:33,021 DEBUG [VideoDeliveryEngine] Delivering file 'transcoding-temp-9-MPEG2TS.ts' in native format
2011-05-19 08:31:33,021 DEBUG [MediaItemDAOImpl] Getting file of media item 75
2011-05-19 08:31:33,024 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 75) as read
2011-05-19 08:31:33,079 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-05-19 08:31:33,079 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1024
2011-05-19 08:31:33,080 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-19 08:31:33,080 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/vnd.dlna.mpeg-tts,Content-Range: bytes 0-1023/1178352980,Content-Length: 1024,Date: Thu, 19 May 2011 15:31:33 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-19 08:31:33,097 DEBUG [ResourceTransportRequestHandler] HEAD /resource/75/MEDIA_ITEM/AVC_TS_MP_SD_AAC_MULT5_ISO$1 HTTP/1.1, headers = [Host: 172.31.0.2:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2011-05-19 08:31:33,097 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 172.31.0.138
2011-05-19 08:31:33,098 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:33,099 DEBUG [ResourceTransportRequestHandler] Request for resource 75 and type 'MEDIA_ITEM' received
2011-05-19 08:31:33,099 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 75)
2011-05-19 08:31:33,100 DEBUG [VideoDAOImpl] Reading a Video (id = 75)
2011-05-19 08:31:33,101 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 75, format AVC_TS_MP_SD_AAC_MULT5_ISO and profile Sony BD Player
2011-05-19 08:31:33,101 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-05-19 08:31:33,101 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/vnd.dlna.mpeg-tts,Content-Length: 1178352980,Date: Thu, 19 May 2011 15:31:33 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-19 08:31:33,121 DEBUG [ResourceTransportRequestHandler] GET /resource/75/MEDIA_ITEM/AVC_TS_MP_SD_AAC_MULT5_ISO$1 HTTP/1.1, headers = [Host: 172.31.0.2:8895,Accept: */*,Range: bytes=0-1023,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2011-05-19 08:31:33,121 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 172.31.0.138
2011-05-19 08:31:33,122 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:33,122 DEBUG [ResourceTransportRequestHandler] Request for resource 75 and type 'MEDIA_ITEM' received
2011-05-19 08:31:33,123 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 75)
2011-05-19 08:31:33,124 DEBUG [VideoDAOImpl] Reading a Video (id = 75)
2011-05-19 08:31:33,125 DEBUG [VideoDeliveryEngine] Delivering item '75' for client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:33,125 DEBUG [VideoDeliveryEngine] Delivering file 'transcoding-temp-9-MPEG2TS.ts' in native format
2011-05-19 08:31:33,125 DEBUG [MediaItemDAOImpl] Getting file of media item 75
2011-05-19 08:31:33,127 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 75) as read
2011-05-19 08:31:33,137 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-05-19 08:31:33,137 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1024
2011-05-19 08:31:33,138 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-19 08:31:33,138 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/vnd.dlna.mpeg-tts,Content-Range: bytes 0-1023/1178352980,Content-Length: 1024,Date: Thu, 19 May 2011 15:31:33 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-19 08:31:33,217 DEBUG [ResourceTransportRequestHandler] GET /resource/75/MEDIA_ITEM/AVC_TS_MP_SD_AAC_MULT5_ISO$1 HTTP/1.1, headers = [Host: 172.31.0.2:8895,Accept: */*,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0",Range: bytes=0-]]
2011-05-19 08:31:33,217 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 172.31.0.138
2011-05-19 08:31:33,218 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:33,219 DEBUG [ResourceTransportRequestHandler] Request for resource 75 and type 'MEDIA_ITEM' received
2011-05-19 08:31:33,219 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 75)
2011-05-19 08:31:33,220 DEBUG [VideoDAOImpl] Reading a Video (id = 75)
2011-05-19 08:31:33,221 DEBUG [VideoDeliveryEngine] Delivering item '75' for client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:33,221 DEBUG [VideoDeliveryEngine] Delivering file 'transcoding-temp-9-MPEG2TS.ts' in native format
2011-05-19 08:31:33,221 DEBUG [MediaItemDAOImpl] Getting file of media item 75
2011-05-19 08:31:33,223 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 75) as read
2011-05-19 08:31:33,229 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-05-19 08:31:33,229 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1178352980
2011-05-19 08:31:33,229 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-19 08:31:33,229 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/vnd.dlna.mpeg-tts,Content-Range: bytes 0-1178352979/1178352980,Content-Length: 1178352980,Date: Thu, 19 May 2011 15:31:33 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-19 08:31:33,677 DEBUG [WebServer] I/O error: Broken pipe
- Code:
2011-05-19 08:31:48,612 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:48,612 DEBUG [ResourceTransportRequestHandler] Request for resource 66 and type 'MEDIA_ITEM' received
2011-05-19 08:31:48,612 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 66)
2011-05-19 08:31:48,613 DEBUG [VideoDAOImpl] Reading a Video (id = 66)
2011-05-19 08:31:48,614 DEBUG [VideoDeliveryEngine] Delivering item '66' for client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:48,615 DEBUG [VideoDeliveryEngine] Delivering file 'Who-redo.m4v' using transcoding
2011-05-19 08:31:48,615 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/172.31.0.138, Profile=Sony BD Player'
2011-05-19 08:31:48,617 DEBUG [MediaItemDAOImpl] Getting file of media item 66
2011-05-19 08:31:48,619 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /media/8E92B90A92B8F7B3/Users/Jeff/Videos/01_MP4/Who-redo.m4v
2011-05-19 08:31:48,620 DEBUG [ProcessExecutor] Starting ffmpeg -i /media/8E92B90A92B8F7B3/Users/Jeff/Videos/01_MP4/Who-redo.m4v -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec copy -map 0:0 -map 0:1 -sn -f mpegts /media/8E92B90A92B8F7B3/Users/Jeff/Videos/tmp/Serviio/transcoding-temp-66-MPEG2TS.stf
2011-05-19 08:31:49,122 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Who-redo.m4v: AVC_TS_MP_SD_AAC_MULT5_ISO
2011-05-19 08:31:49,122 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-05-19 08:31:49,123 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 66) as read
2011-05-19 08:31:49,246 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-05-19 08:31:49,246 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2011-05-19 08:31:49,246 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2011-05-19 08:31:49,246 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-19 08:31:49,246 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/vnd.dlna.mpeg-tts,TimeSeekRange.dlna.org: npt=0.0-8648.0/8648,Date: Thu, 19 May 2011 15:31:49 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-19 08:31:49,262 DEBUG [WebServer] I/O error: Broken pipe
Just as a check, I configured .jpg and .mp3 streaming to the BD player - all works OK. It's just the videos that are having issues.
After editing the files did you restart serviio? If not I would recommend restarting serviio and trying the files again.
Yes, the services were stopped / started each time after a configuration change.
Tried the Windows version of Serviio to see if it would stream the same file. Same error at the BD player - file is corrupt or invalid.
try and play the file in another render if you can. there are several software renders (players) out there that work pretty good. If you cannot figure out one to use let me know.
Probably your suggestion(s) would be good. Can run on either Ubuntu or Win7. Thanks in advance.
Still broken on my end. No m4v files will play.
I'm about to write off serviio.
Ok, so you have some m4v files playing (encoded by older version of Handbrake) and some that won't (encoded with latest Handbrake)? It would seems that the stream encoding is the problem. Does the file play from a USB stick? (sorry if you mentioned this before, I didn't read the whole thread)
Petr
Help translate Serviio
Thanks Zip. I had missed the USB test, just did it. The M4V file won't play from a USB stick. Same error - file is corrupt or invalid.
What does work:
What does not work:
Also not working
Do I need to change my Handbrake encoding? WMP is not a solution for me, I really need a player that will work on Ubuntu linux. Re-coding the library would suck!
What does work:
Windows 7 Host
Windows media player v12
Wireless streaming to Sony BDP-570
Any M4V file that I have encoded with various handbrake versions
What does not work:
- Windows 7 host
Serviio media player
Any M4V file
Also not working
- m4v file on USB directly plugged to Sony player
If you want to stream the files natively then it looks like you'll have to reencode them. I suspect WMP transcodes eveyting into mpeg2, maybe you can notice the quality is not great and the CPU is quite high when you play the file.. ?
We could set up the same behaviour but your CPU will go mad
Petr
Well, thanks for all the help.
What are the recommended handbrake encoding settings that would work with Serviio?
I was suffering from this issue on my BDP-S480.
Handbrake 0.94 encoded files (MP4 - H264/AAC) worked fine, 0.95 files with the same settings came back with "corrupt or invalid"
If I put the mp4 through handbrake 0.94 with the frame rate forced to 25fps rather then "same as source" the files worked ok.
Re-encoding removed the ffmpeg error:
"Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 90000.00 (180000/2)"
Today Sony pushed out an update for my player (M07.R.0319) which seems to have fixed the issue with 0.95 encoded files.
Hope this helps someone!
Graeme
PS Thanks for creating such a fantastic bit of software!
Graeme
I have spent the past couple days dealing with exactly this problem as well. Finding that others ran across the same problem is a bit of a relief, and I've been delighted to see all the support in addressing this issue. Thanks!
Unfortunately I have a Sony S370 (running the latest firmware, M03.R.742) for which it is unlikely that they will issue the necessary update to work with the HB 0.95 encoded files. I'm running on Windows XP. I've got a wired connection, so bandwidth shouldn't be an issue. So I have 3 questions:
1. What magic incantation can I add to the Serviio config for the Sony BD player to have it do all the transcoding for the time being? While not the ideal solution, my computer should be able to handle decent quality transcoding in real time until I re-encode my library.
2. In the future, how should I change the default options in HB 0.95 to make the (re)encoded files compatible with the Sony S370 via Serviio?
3. In the process of trying to debug this, I spent ages staring down my log file. It's filled with repetitions of the a WARN. This seems to be a red herring with regards my current problem, but it would be nice to understand what it's about and to solve it. Note that I'm running Symantec Endpoint Protection, which is has really aggressive firewalling, and I had to add a rule to allow all IP traffic between the WinXP server and the Sony S370. Despite that I had to manually add the Sony S370 as a renderer, as it couldn't be found automatically. I also had to explicitly bind Serviio to the IP address of my Gigabit port (it was apparently trying to use a different IP before). After that, everything works perfectly except for the errors discussed on this thread and my log file filling dramatically. I attach the headers and a few repetitions of the WARN; it's not kidding when it says "will try again."
2011-06-18 23:28:18,923 INFO [MediaServer] ------------------------------------------------------------------------
2011-06-18 23:28:18,923 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-06-18 23:28:18,923 INFO [MediaServer] Petr Nejedly 2009-2011
2011-06-18 23:28:18,923 INFO [MediaServer] http://www.serviio.org
2011-06-18 23:28:18,923 INFO [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-06-18 23:28:18,923 INFO [MediaServer] OS Windows XP x86 5.1
2011-06-18 23:28:18,923 INFO [MediaServer] File encoding: windows-1252
2011-06-18 23:28:19,079 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-06-18 23:28:19,157 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-06-18 23:28:20,579 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-06-18 23:28:20,845 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-06-18 23:28:20,938 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-06-18 23:28:21,001 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-06-18 23:28:21,032 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-06-18 23:28:21,079 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-06-18 23:28:21,110 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-06-18 23:28:21,188 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-06-18 23:28:21,204 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-06-18 23:28:21,376 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-06-18 23:28:21,595 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-06-18 23:28:21,641 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-06-18 23:28:21,704 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-06-18 23:28:21,782 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-06-18 23:28:21,798 INFO [WebServer] Socket buffer set to 65535 bytes
2011-06-18 23:28:21,829 INFO [WebServer] WebServer starting on port 8895
2011-06-18 23:28:21,845 INFO [Device] Created UPnP Device with UUID: <deleted>, bound address: <deleted>
2011-06-18 23:28:21,876 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-06-18 23:28:21,876 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-06-18 23:28:21,891 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-06-18 23:28:21,891 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-06-18 23:28:21,891 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-06-18 23:28:21,891 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-06-18 23:28:21,891 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1308464901891, LastAccessTime = 1308464901891, getTimeToLiveSeconds() = -1, createTime = 1308464901891 ]
2011-06-18 23:28:21,891 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-06-18 23:28:21,907 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-06-18 23:28:21,907 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-06-18 23:28:21,907 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-06-18 23:28:21,907 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-06-18 23:28:21,907 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-06-18 23:28:21,907 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-06-18 23:28:21,907 INFO [CompositeCacheConfigurator] Finished configuration in 16 ms.
2011-06-18 23:28:21,907 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-06-18 23:28:21,907 INFO [EventDispatcher] Starting EventDispatcher
2011-06-18 23:28:21,907 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-06-18 23:28:21,923 INFO [RendererSearchSender] Searching for Renderer devices
2011-06-18 23:28:21,923 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-06-18 23:28:21,923 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetXtreme 57xx Gigabit Controller - Teefer2 Miniport) and address 10.33.10.3, timeout = 0
2011-06-18 23:28:22,126 WARN [RendererSearchSender] Search for Renderers using interface eth4 (Microsoft TV/Video Connection) failed: The requested address is not valid in its context
2011-06-18 23:28:25,766 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
java.net.SocketException: The requested address is not valid in its context
at java.net.PlainDatagramSocketImpl.socketSetOption(Native Method)
at java.net.PlainDatagramSocketImpl.setOption(Unknown Source)
at java.net.MulticastSocket.setInterface(Unknown Source)
at org.serviio.util.MultiCastUtils.startMultiCastSocketForSending(MultiCastUtils.java:57)
at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAliveToSingleInterface(DiscoveryAdvertisementNotifier.java:155)
at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAlive(DiscoveryAdvertisementNotifier.java:128)
at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.run(DiscoveryAdvertisementNotifier.java:96)
at java.lang.Thread.run(Unknown Source)
2011-06-18 23:28:28,626 INFO [ServiioConsole] Starting Serviio Console
2011-06-18 23:28:28,657 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-06-18 23:28:29,657 INFO [Messages] Loaded console message bundle for locale: en
2011-06-18 23:28:30,438 INFO [Messages] Loaded console message bundle for locale: en
2011-06-18 23:28:30,548 INFO [UpdateChecker] Checking if a new version is available
2011-06-18 23:28:34,454 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2011-06-18 23:28:36,329 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-06-18 23:28:36,751 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-06-18 23:28:43,126 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
Hanging on here, having exact same problem; no m4v files playing. When using other formats results in either much larger files or worse quality...
Advice for Serviio / S470 compatibility
This thread has been quiet for a while. However, it there seems to be a real problem using HandBrake 0.95 m4v's with the Sony S470, which could be fixed either by Serviio transcoding or by changes to the use of HandBrake. However I (and apparently others) don't know how to solve these problems.
Sorry to repeat, but I wonder if anyone could answer the following queries from a previous post?
Many thanks!
Many thanks!
To transcode everything, try this:
- Code:
<Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
<Matches container="mp4" />
<Matches container="avi" />
<Matches container="mpegts" />
<Matches container="mpegvideo" />
<Matches container="asf" />
<Matches container="flv" />
Petr
Plays everything I've tried now...
/Per
/Per
Re: Advice for Serviio / S470 compatibility
tidge wrote:2. In the future, how should I change the default options in HB 0.95 to make the (re)encoded files compatible with the Sony S370 via Serviio?
use HB 0.94
Users browsing this forum: Baidu [Spider] and 11 guests
