New install error:Please Define EXE4_JAVA_HOME
Help!!!
SiegeX wrote:I got that same error as well on 64bit Windows7. Find and install the 64bit JDk, it's called jdk-6u17-windows-x64.exe. That fixed the error right up.
zip wrote: Setting an environment variable JAVA_HOME pointing to your Java installation location (something like: c:\Program Files\Java\jre1.6.0_07\ ) should also solve the problem.
zip wrote:Do you have 64bit Windows? Try uninstalling all Java you have on your PC and installing the 64bit again. If it doesn't work, uninstall the 64bit java and try to install 32bit Java instead.
gismo31 wrote:
can you please explain how i can Create environment variable JAVA_HOME pointing to your java installation directory, and add the path to servio.bat ? i'm not goog at this stuff.
Users browsing this forum: Google [Bot] and 42 guests
