New install error:Please Define EXE4_JAVA_HOME
zack832
Post Sat Dec 26, 2009 9:14 pm
Came across a posting that Serviio works with the Samsung DNLA TV's, and hating the Samsung server I decided to try Serviio. I'm running Win 7 on a 64 bit platform. I updated Java, and it is installed correctly. Every time I click on Serviio I get an error message, and I have no idea how to define where Java is since I never get to the console.
Help!!!
zack832
Post Sat Dec 26, 2009 11:36 pm
Re: New install error:Please Define EXE4_JAVA_HOME
Just an update, the server is apparently running, Serviio shows up on my Samsung TV. However no matter what I do I can't get into the console.....
Post Sun Dec 27, 2009 10:49 am
Check that the Windows service is running.
Then you can run the console by either executing ServiioConsole.exe (which runs as a part of Windows start), but this seems to cause you troubles. There is also a serviio-console.bat file, try that instead of the .exe.
Setting an environment variable JAVA_HOME pointing to your Java installation location (something like: c:\Program Files\Java\jre1.6.0_07\ ) should also solve the problem.
SiegeX
Post Sun Dec 27, 2009 8:38 pm
I got that same error as well on 64bit Windows7. Find and install the 64bit JDk, it's called jdk-6u17-windows-x64.exe. That fixed the error right up.
zack832
Post Thu Dec 31, 2009 7:29 am
Thanks, I'll try that. The program has been working but I have to click on each file in the.bat folder to get it to run. I rarely reboot so once it's up and running I'm good. I'm downloading the java program now, I'll run it and see how well it works....
zack832
Post Sun Jan 03, 2010 12:12 am
Thanks all, it's working fine now...
philokokus
Post Sun May 02, 2010 8:59 am
SiegeX wrote:I got that same error as well on 64bit Windows7. Find and install the 64bit JDk, it's called jdk-6u17-windows-x64.exe. That fixed the error right up.
Hi
I am new to all this. I have installed it but still the consolo can't find it.
Any Help Please.
Best Regards
Jose
philokokus
Post Wed May 05, 2010 5:39 pm
zip wrote: Setting an environment variable JAVA_HOME pointing to your Java installation location (something like: c:\Program Files\Java\jre1.6.0_07\ ) should also solve the problem.
how do I do that?
Post Wed May 05, 2010 9:18 pm
Do you have 64bit Windows? Try uninstalling all Java you have on your PC and installing the 64bit again. If it doesn't work, uninstall the 64bit java and try to install 32bit Java instead.
philokokus
Post Sat May 08, 2010 2:55 pm
zip wrote:Do you have 64bit Windows? Try uninstalling all Java you have on your PC and installing the 64bit again. If it doesn't work, uninstall the 64bit java and try to install 32bit Java instead.
Done that but still not working.
I have a 64bit window7
Tks
fizze
Post Sat May 08, 2010 4:23 pm
Just install the 32bit Java Runtime and you should be fine. Be sure to get rid of the 64bit stuff first.
That did the trick on my win7 x64.
Intel SS4200 - Ubuntu Server 8.04
LG BD - 390
gismo31
Post Wed May 19, 2010 10:08 am
hi, i've got the same problem ! i tried to install several times the JAVA program but no way ... I'm using windows 7 64 bit. PS3 media player works so javi is installed. any help ?
gismo31
Post Fri Jun 04, 2010 7:02 am
still not solved with the 0.4 version : when i install, servia says : no java and it installs java after dowlonading. then it says program installed. when i run servio, i still got the same error message :o :twisted: :evil:
when i go on java.com, and check if java is installed : Version 6 Update 20 installed ???
please help !!!
Post Fri Jun 04, 2010 8:18 am
I'll look into it a bit more. In the meantime you can use the .bat files located in the bin directory instead of the .exe (I presume for both, server and console).
gismo31
Post Sat Jun 05, 2010 12:22 pm
hi, thanks for the answer. servio.bat doesnt work either : it says javaw not found. ps3mediaplayer works and is also based on java. I'm using windows 7 64 bit.
Post Sat Jun 05, 2010 4:32 pm
Create environment variable JAVA_HOME pointing to your java installation directory, mine is
C:\Program Files\Java\jdk1.6.0_18\
and restart your PC. If you want the .bat to work you have to add the variable to your PATH environment variable, e.g.
...existing path entires...;%JAVA_HOME%\bin
gismo31
Post Sun Jun 06, 2010 5:32 am
hi, javaw is located in C:\Program Files (x86)\Java\jre6\bin
can you please explain how i can Create environment variable JAVA_HOME pointing to your java installation directory, and add the path to servio.bat ? i'm not goog at this stuff.
Sopmod
Post Sun Jun 06, 2010 6:21 am
Hey there, I added:
SET PATH=C:\Program Files (x86)\Java\jre6\bin
SET JAVA_HOME=C:\Program Files (x86)\Java\jre6\bin
to the top of my *.bat files as the second and third entries in the files. Like this:
@echo off
set BATCH_FILE=%~dp0
*Rest of the file*
Now it works and I can try Serviio.
To the developer. You HAVE to make installation a no brainer. It must just work. This is a major requirement to get right regardless of the maturity of the software. Non technical people just will not try to solve these issues and you'll lose a user base member.
gismo31
Post Sun Jun 06, 2010 9:26 am
yippie this works !!! thanks alot :D :D :D
i've to select servioconsole.bat to make it work ( *.exe doenst work ) but great news !
i hope the developper will change this soon !
Post Sun Jun 06, 2010 12:34 pm
If you add it to the .bat it will not work with the .exe. You should add it to your Windows env variables, like this (this is for WIndows 7): http://www.itechtalk.com/thread3595.html
This problem doesn't appear for most users, for some reason the Java installation doesn't register itself properly for some of you guys.
