2011-07-17 14:21:42,203 INFO [ServiioConsole] Starting Serviio Console
2011-07-17 14:21:42,265 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-17 14:21:49,484 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-07-17 14:21:56,703 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-07-17 14:21:56,796 INFO [Messages] Loaded console message bundle for locale: en
2011-07-17 14:22:03,593 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-07-17 14:22:05,453 INFO [ServiioConsole] Leaving Serviio Console
2011-07-17 14:22:18,875 INFO [MediaServer] ------------------------------------------------------------------------
2011-07-17 14:22:18,875 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-07-17 14:22:18,875 INFO [MediaServer] Petr Nejedly 2009-2011
http://www.serviio.org2011-07-17 14:22:18,875 INFO [MediaServer]
2011-07-17 14:22:18,875 INFO [MediaServer] Java 1.6.0_13-Sun Microsystems Inc.
2011-07-17 14:22:18,875 INFO [MediaServer] OS Windows XP x86 5.1
2011-07-17 14:22:18,875 INFO [MediaServer] File encoding: windows-1252
2011-07-17 14:22:18,968 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-17 14:22:19,015 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-17 14:22:20,125 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-17 14:22:20,578 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-17 14:22:20,875 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-17 14:22:21,062 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-17 14:22:21,203 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-17 14:22:21,375 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-17 14:22:21,500 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-17 14:22:21,765 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-17 14:22:21,875 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-17 14:22:22,265 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-17 14:22:22,921 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-17 14:22:23,109 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-17 14:22:23,265 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-17 14:22:23,312 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-17 14:22:23,328 INFO [WebServer] Socket buffer set to 65535 bytes
2011-07-17 14:22:23,359 INFO [WebServer] WebServer starting on port 8895
2011-07-17 14:22:23,531 INFO [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-07-17 14:22:23,546 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-17 14:22:23,562 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-17 14:22:23,562 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-17 14:22:23,562 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-17 14:22:23,562 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-17 14:22:23,562 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-17 14:22:23,562 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1310905343562, LastAccessTime = 1310905343562, getTimeToLiveSeconds() = -1, createTime = 1310905343562 ]
2011-07-17 14:22:23,562 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-17 14:22:23,578 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-17 14:22:23,578 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-17 14:22:23,578 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-17 14:22:23,578 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-17 14:22:23,578 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-17 14:22:23,578 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-17 14:22:23,578 INFO [CompositeCacheConfigurator] Finished configuration in 16 ms.
2011-07-17 14:22:23,578 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-17 14:22:23,578 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-17 14:22:23,578 INFO [EventDispatcher] Starting EventDispatcher
2011-07-17 14:22:23,578 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8102E Family PCI-E Fast Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-07-17 14:22:23,609 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-17 14:22:23,609 INFO [RendererSearchSender] Searching for Renderer devices
2011-07-17 14:22:24,421 INFO [ServiioConsole] Starting Serviio Console
2011-07-17 14:22:24,468 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-17 14:22:25,343 INFO [Messages] Loaded console message bundle for locale: en
2011-07-17 14:22:30,781 INFO [Messages] Loaded console message bundle for locale: en
2011-07-17 14:22:30,890 INFO [UpdateChecker] Checking if a new version is available
2011-07-17 14:22:36,500 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-17 14:22:37,453 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-07-17 14:22:49,625 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-17 14:22:49,625 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-17 14:23:19,640 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-07-17 14:23:19,640 INFO [WebServer] WebServer shutting down
2011-07-17 14:23:19,640 INFO [EventDispatcher] Leaving EventDispatcher
2011-07-17 14:23:19,640 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-17 14:23:19,640 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-17 14:23:19,640 INFO [Device] Updated bound IP address of Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2011-07-17 14:23:19,640 INFO [WebServer] WebServer starting on port 8895
2011-07-17 14:23:19,640 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-17 14:23:19,640 INFO [RendererSearchSender] Searching for Renderer devices
2011-07-17 14:23:19,640 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-17 14:23:19,640 INFO [EventDispatcher] Starting EventDispatcher
2011-07-17 14:23:19,640 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8102E Family PCI-E Fast Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-07-17 14:23:23,625 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-07-17 14:23:32,437 INFO [WebServer] WebServer shutting down
2011-07-17 14:23:32,437 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-07-17 14:23:32,437 INFO [EventDispatcher] Leaving EventDispatcher
2011-07-17 14:23:32,437 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-07-17 14:23:33,421 INFO [WebServer] WebServer starting on port 8895
2011-07-17 14:23:33,421 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-17 14:23:33,421 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8102E Family PCI-E Fast Ethernet NIC - Pakketplanner-minipoort) and address 192.168.2.4, timeout = 0
2011-07-17 14:23:33,421 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-17 14:23:33,421 INFO [RendererSearchSender] Searching for Renderer devices
2011-07-17 14:23:33,421 INFO [EventDispatcher] Starting EventDispatcher
2011-07-17 14:23:43,531 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
