[SOLVED] Version 0.6, Mac OS, and Sony SMP N-100
Shvingy
Post Sat Sep 24, 2011 4:08 pm
5.2 has worked flawlessly for me, but 0.6 will start up and recognize my SMP N-100 but the SMP will not recognize media server? I have tried everything I can think of but it will not pick it up as a media server option?
I have just uninstalled 0.6 and reinstalled 5.2 and it works, bang right away.
Curious.
Post Sat Sep 24, 2011 4:11 pm
Re: Version 0.6, Mac OS, and Sony SMP N-100
Bound IP detection might have changed. Try putting your mac IP address to the Bound IP field in the console.
Shvingy
Post Sat Sep 24, 2011 4:37 pm
I get an invalid ip address error message when I try to put mac address in Serviio console bound field.
Fast reply though, I am very impressed.
iMcRabbi
Post Sat Sep 24, 2011 4:41 pm
Try going into the settings on your N-100 and deleting the Serviio item out of the server list, then reboot the N-100. Do you have another device you can check to see if Serviio is broadcasting properly?
Shvingy
Post Sat Sep 24, 2011 4:46 pm
I have tried the resetting and rebooting of the SMP with no luck, but my PS3 does not recognize this version 0.6 either. It does work with 0.52.
Post Sat Sep 24, 2011 6:19 pm
what IP did you try to use in the field?
Post Sat Sep 24, 2011 7:09 pm
Shvingy wrote:I get an invalid ip address error message when I try to put mac address in Serviio console bound field.
he ment put the IP ADDRESS of your mac in the bound ip field not your mac address.
Post Sat Sep 24, 2011 7:11 pm
:-) I didn't think about it, English is a funny language
Shvingy
Post Sat Sep 24, 2011 10:07 pm
This did not work either :(
Post Sat Sep 24, 2011 10:20 pm
ok so here we go back to basics.
Make sure you enter the IP of the pc running serviio into the bound ip field on the console. now remove all renderers from the console (its the same page the box above bound ip field), now all you need to do is restart the pc running serviio and try again.
Shvingy
Post Sat Sep 24, 2011 11:06 pm
OK Yes, this worked. Thanks for all the help. I tried all these things but in the wrong order.
Post Sat Sep 24, 2011 11:37 pm
your welcome :)
Shvingy
Post Mon Sep 26, 2011 12:03 am
My .mkv files work now as well. Very cool.
Post Mon Sep 26, 2011 1:14 am
see im just magic i fix things without trying to :P
seriously though all thanks for the sony profiles has to go to illico and patter, they have made great improvement in them for the 0.6 release
iMcRabbi
Post Mon Sep 26, 2011 5:52 am
I had worse results on my N100 with the new profiles. Just put the old one back. Had to fix a couple errors but it pretty much plays anything now.
Sent from my LG-P999 using THE FORCE
Post Mon Sep 26, 2011 9:18 am
iMcRabbi wrote:I had worse results on my N100 with the new profiles. Just put the old one back. Had to fix a couple errors but it pretty much plays anything now.
Can you share?
patters
Post Wed Sep 28, 2011 12:12 am
Re: [SOLVED] Version 0.6, Mac OS, and Sony SMP N-100
When I searched the forum prior to including the one for 0.6, most of the profile examples for the SMP that had been posted involved transcoding everything to Mpeg2. Is it one of those?
