Sun Oct 16, 2011 10:02 pm by dpippin
The file played fine from Serviio when I manually downloaded it and added it to my library. I'm not quite sure why it can't pick it up from the RSS Feed. Below is info from ffmpeg and mediainfo.
FFMPEG -i - Code:
FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1.2, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --extra-version=4:0.5.1-1ubuntu1.2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
built on Sep 16 2011 17:04:18, gcc: 4.4.3
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (5994/100) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '66852713001_1205467357001_2011-10-3010-elder-jeffrey-r-holland-8000k-eng.mp4':
Duration: 00:15:26.89, start: 0.000000, bitrate: 1231 kb/s
Stream #0.0(und): Video: h264, yuv420p, 720x404, 29.97 tbr, 29.97 tbn, 59.94 tbc
Stream #0.1(und): Audio: aac, 44100 Hz, stereo, s16
Info from Mediainfo:- Code:
Complete name : C:\Users\dpippin\Desktop\Jdownloader\66852713001_1205467357001_2011-10-3010-elder-jeffrey-r-holland-8000k-eng.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 136 MiB
Duration : 15mn 26s
Overall bit rate : 1 232 Kbps
Writing application : Lavf53.4.0
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 15mn 26s
Bit rate : 1 100 Kbps
Width : 720 pixels
Height : 404 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.126
Stream size : 122 MiB (89%)
Writing library : x264 core 116
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=5 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=150 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1100 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.41 / aq=1:1.00
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 15mn 22s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 14.1 MiB (10%)
Any help on why the RSS Feed rejected the video file would help. Thanks,
