[SOLVED] LDS Feeds (Conference)
dpippin
Post Sat Oct 01, 2011 7:22 pm
I've been trying for a couple of weeks on programing this one all to no avail (I no little to nothing about programming).
The feed is http://feeds.lds.org/LDSGCComplete_eng_mp4
XML Feed is http://feeds.lds.org/LDSGCComplete_eng_mp4?format=xml
I'm thinking it will be fairly easy:
1. Capture the file name (see in blue) from XML <media:content url="http://feeds.lds.org/~r/lds-general-conference-sd-eng/~5/BT1XK2LXo5o/66852713001_859513978001_2011-03-0001-high-on-the-mountain-top-8000k-eng.mp4"
2. Also Capture the first 11 numbers in the file name 66852713001
3. Add a forward slash to the capture number 66852713001/ = 66852713001/
4. Then add first 11 numbers plus a slash and then filename above at the end of the URL http://brightcove.lds.com.edgesuite.net/66852713001/66852713001_859513978001_2011-03-0001-high-on-the-mountain-top-8000k-eng.mp4
Thank you for the help.
By the way I don't know if it will work but I found this code for extracting filename from a URL
 def id = linkurl.substring(url.lastindexof('/'+1, linkurl.length()))
Thanks I would greatly appreciate this.
Post Sun Oct 09, 2011 2:33 pm
Re: LDS Feeds (Conference)
this should work without a plugin. are you seeing any errors?
dpippin
Post Sun Oct 16, 2011 9:31 pm
It looks like it is pulling the right information and getting the file name. From reading the log (see below) it looks like it can't decode the mp4 file "Unknown video file type". I'm running Serviio 0.6 on Linux.
2011-10-09 10:44:40,122 DEBUG [FeedUpdaterThread] Retrieving information about the video stream
2011-10-09 10:44:40,122 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://feeds.lds.org/~r/lds-general-conference-sd-eng/~5/lKNHPzxuEEU/66852713001_1205467357001_2011-10-3010-elder-jeffrey-r-holland-8000k-eng.mp4
2011-10-09 10:44:40,123 DEBUG [ProcessExecutor] Starting ffmpeg -i http://feeds.lds.org/~r/lds-general-conference-sd-eng/~5/lKNHPzxuEEU/66852713001_1205467357001_2011-10-3010-elder-jeffrey-r-holland-8000k-eng.mp4
2011-10-09 10:44:40,345 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for http://feeds.lds.org/~r/lds-general-conference-sd-eng/~5/lKNHPzxuEEU/66852713001_1205467357001_2011-10-3010-elder-jeffrey-r-holland-8000k-eng.mp4. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
   at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
   ... 1 more
I went to that site and I am downloading that exact file right now. I will load it into Serviio and try to play it manually and let you know. Thank you for the response.
dpippin
Post Sun Oct 16, 2011 10:02 pm
The file played fine from Serviio when I manually downloaded it and added it to my library. I'm not quite sure why it can't pick it up from the RSS Feed. Below is info from ffmpeg and mediainfo.
FFMPEG -i
FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1.2, Copyright (c) 2000-2009 Fabrice Bellard, et al.
  configuration: --extra-version=4:0.5.1-1ubuntu1.2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
  libavutil     49.15. 0 / 49.15. 0
  libavcodec    52.20. 1 / 52.20. 1
  libavformat   52.31. 0 / 52.31. 0
  libavdevice   52. 1. 0 / 52. 1. 0
  libavfilter    0. 4. 0 /  0. 4. 0
  libswscale     0. 7. 1 /  0. 7. 1
  libpostproc   51. 2. 0 / 51. 2. 0
  built on Sep 16 2011 17:04:18, gcc: 4.4.3
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (5994/100) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '66852713001_1205467357001_2011-10-3010-elder-jeffrey-r-holland-8000k-eng.mp4':
  Duration: 00:15:26.89, start: 0.000000, bitrate: 1231 kb/s
    Stream #0.0(und): Video: h264, yuv420p, 720x404, 29.97 tbr, 29.97 tbn, 59.94 tbc
    Stream #0.1(und): Audio: aac, 44100 Hz, stereo, s16
Info from Mediainfo:
Complete name                    : C:\Users\dpippin\Desktop\Jdownloader\66852713001_1205467357001_2011-10-3010-elder-jeffrey-r-holland-8000k-eng.mp4
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 136 MiB
Duration                         : 15mn 26s
Overall bit rate                 : 1 232 Kbps
Writing application              : Lavf53.4.0
Format profile                   : Main@L3.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 1 frame
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 15mn 26s
Bit rate                         : 1 100 Kbps
Width                            : 720 pixels
Height                           : 404 pixels
Frame rate mode                  : Constant
Frame rate                       : 29.970 fps
Bits/(Pixel*Frame)               : 0.126
Stream size                      : 122 MiB (89%)
Writing library                  : x264 core 116
Encoding settings                : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=5 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=150 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1100 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.41 / aq=1:1.00
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Duration                         : 15mn 22s
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 44.1 KHz
Stream size                      : 14.1 MiB (10%)
Any help on why the RSS Feed rejected the video file would help. Thanks,
Post Sun Oct 16, 2011 11:10 pm
try updating your FFmpeg first, you have version 0.5, they are now on 0.8.
dpippin
Post Tue Oct 18, 2011 4:28 am
It worked Thank You!
Return to Plugin requests
