Web UI in PHP
patters
Post Mon Oct 03, 2011 9:49 pm
Re: Web UI in PHP
I'll take a look. I haven't really got my head around the REST stuff yet. I've fixed another annoyance, which was that when paths or feed names were too long they made a mess of the page (super-wide). I have made it cut them off with "..." at 80 characters and added the full title as a title tag so you can see it when you mouse over, which mimics the behaviour of the full Serviio Console.
mpemberton5
Post Wed Oct 05, 2011 4:37 am
Re: Web UI in PHP
Here's an updated version of Web UI in PHP. This will work with 0.6.0.1 and has an updated library section that displays the sources in tabs.
http://dl.dropbox.com/u/42061/serviio-0.6.0.1.zip
Please let me know if you have any issues.
I do know of the known issue with the QNAP users where the presentation section is still broken. I'm working on a possible solution.
Thanks all,
cburbs
Post Wed Oct 05, 2011 5:59 pm
Re: Web UI in PHP
Mine still won't save any paths I add. All other pages save any changes ok. Whenever I click the save button it ends up going to a blank page. The other ones seem to work OK.
I am running this on Vortexbox and the old version worked fine with the library.
I also just updated to your newest web ui.
patters
Post Thu Oct 06, 2011 3:28 pm
Re: Web UI in PHP
mpemberton5 wrote:Here's an updated version of Web UI in PHP. This will work with 0.6.0.1 and has an updated library section that displays the sources in tabs.
Thanks all,
I probably should have posted my work earlier to avoid unnecessary duplication of effort, but I had wanted to kind of finish it first. Anyway, here is where I got to:
http://dl.dropbox.com/u/1188556/serviio ... -v1.tar.gz
changes:
. updated the version check to 0.6.0.1 - is this really necessary?
. added the Online sources as a tab rather than lower down on the Library page
. moved the selectable tabs from align=center to align=left. On the Serviio Console they're obvious but since they're not so well highlighted in the Web UI it seems clearer to have them on the left.
. Library Status is not shown for Online Sources since it only relates to Shared Folders, like the proper Serviio Console. Feeds are cached at Serviio startup, or at expiry time, but not by user control
. fixed the tables display (why the red dot in the top left?), added padding in the stylesheet rather than static 20px column sizes
. added the mouse-over text for the coloured blobs in Status view (with i18n) which the proper Serviio Console has
. ensured only the selected tab is bolded, even when first landing on a page with several tabs
. added bolding of the selected main tab across the top
. edited the css to stop the links from being coloured purple once followed
. fixed the displaying of long feed names in Online Sources (showing the full name on mouse-over, which more closely mimics the real Serviio Console - Gametrailers.com ones are huge)
. I have tried to add i18n support to all the new 0.6 features (some of yours were guesses which aren't the actual names Zip used for 0.6's new items)
. fixed a few missing i18n fields from earlier versions of the webui
. freshened the messages_{lang-name} files with the ones from Serviio 0.6.0.1 - very few are up to date though (use my bundled Italian one from the forum for testing which has all new fields for 0.6)
. included my edited style sheet to mimic the Synology Control Panel UI - I think it looks way nicer than the standard one
. got rid of the horizontal rules which were cluttering the presentation
still remaining to do:
. i18n support for dialog boxes (like Add sources) and dropdowns
. possibly remove the 'Are you sure' message on save, since the real Serviio UI does not have this and there are no translations for it
. testing :) - I noticed that it mangled one of my feeds when I edited a different one. Definitely needs more work...
cburbs
Post Thu Oct 06, 2011 9:35 pm
Re: Web UI in PHP
Anyone have any ideas why my library won't hold the correct info I put in? I can't save any changes on the library page but the rest of them work fine.
Post Thu Oct 06, 2011 9:49 pm
Re: Web UI in PHP
did you upgrade from 0.5 to 0.6? How are you entering the information into your library?
cburbs
Post Thu Oct 06, 2011 10:10 pm
Re: Web UI in PHP
Yes I was running 5.2 and now running 6.0.1.
Downloaded newest 6.0.1 and newest web ui.
I run this on a vortexbox which is based off of fedora14 right now.
Storage is shared like the following /storage/movies
But like I said even if I uncheck "Search for updates of currently shared files" and click save it goes to a blank page -
All other tabs seem to work fine if I make changes to them.
The Reset on that tab seems to work fine it just seems like the save button is not working correctly.
patters
Post Thu Oct 06, 2011 11:01 pm
Re: Web UI in PHP
I can add and remove paths in Shared Folders without issue on Linux on Synology NAS. Did you have this problem with the 0.5.2 Web UI or has this started with the newer versions?
cburbs
Post Thu Oct 06, 2011 11:57 pm
Re: Web UI in PHP
This started with the newer version.
I will try and test a few things in a vmware of what I currently am running to see if it does the same thing.
I have my old test session still running 5.2 and that one works fine just like my main box was - odd that only the library tab/page is messed up and the rest of them work.
patters
Post Fri Oct 07, 2011 7:32 am
Re: Web UI in PHP
Well the library tab is the one that's been altered so that would explain it. I'll have a detailed look when I have time.
HellesAngel
Post Fri Oct 07, 2011 12:13 pm
Re: Web UI in PHP
First post on this board so hello everyone, and so far thanks for some excellent software. Unfortunately I'm also having the 'Cannot put repository' problem, I found a workaround so it's not the end of the world.
The problems: I have noticed that if /usr/share/serviio/bin/serviio.sh is run from the command line as root or as a normal user (the same user given in /etc/default/serviio) then it is possible to add paths, either local or not, from the web GUI. If serviio is started as with service serviio start, then it is not possible to add paths. Also if serviio is started as a service, or running in a shell as a non-root user, then the TV can't access any media, although it does see the server. If started as root from the command line then the TV can play everything.
The server is running Ubuntu Server 10.10, has a clean install of serviio-0.6.0.1-linux.tar.gz in /usr/share/serviio and a clean install of http://dl.dropbox.com/u/42061/serviio-0.6.0.1.zip in /var/www. The only modifications to these have been correcting the path & user name in the /etc/default/serviio and the location changes in the $pc5dczc_host in /var/www/serviio/config.php. The server & web GUI are both running, my Sony Bravia has found the server - apart from the 'add paths' problem, everything looks great.
It seems that it is also necessary that serviio/the gui has write access to the directories or the same error is generated, which I can't fathom why. I prefer to have my media libraries mounted read only on players - r/w only when necessary.
Any ideas? Permissions probably, but what? Thanks in advance.
patters
Post Fri Oct 07, 2011 5:14 pm
Re: Web UI in PHP
The user Serviio runs as should own all the files in the Serviio folder. Use chown -R user /path/to/serviio/folder
However, since the webui uses Serviio's REST API to submit changes it should not need any special permissions.
Xmantium
Post Sun Oct 09, 2011 4:05 am
Re: Web UI in PHP
Patters im liking the updates you've made, you should joint collaborate with mark on this project and can be offcial on AcidumIraes serviio development webpage.
Cantello
Post Wed Oct 12, 2011 7:51 am
Re: Web UI in PHP
Cerberus wrote:So in short you will need to install cURL extension onto your device to make the webui work.
This would be something to put in the first post - I was wondering why it wouldn't work... :-)
Now works well here (Ubuntu 11.04, apache2).
Post Wed Oct 12, 2011 8:06 am
Re: Web UI in PHP
i would but i dnt have ability to ;)
patters
Post Mon Oct 17, 2011 11:08 pm
Re: Web UI in PHP
Online feed URLs containing ampersands are getting chewed up by the Web UI - e.g.:
http://feeds.gametrailers.com/rssgenerate.php?s1=&favplats[xb360]=xb360&vidformat[flv]=on&type[review]=on&quality[hd]=on&agegate[no]=on&orderby=newest&limit=20
is cropped to:
Despite tinkering with this I'm not a web developer so I'm not sure how this needs to be fixed. It's seems that they need translating to &amp; as the URL is read from input. Would we manually do this as a string substitution, or is there a function to do these HTML special chars automatically? I'm guessing this could be relevant:
http://www.w3.org/QA/2005/04/php-session
mpemberton5
Post Tue Oct 18, 2011 1:54 am
Re: Web UI in PHP
patters wrote:Online feed URLs containing ampersands are getting chewed up by the Web UI - e.g.:
is cropped to:
The encodeurl() function will encode too many things so for now let's just replace the ampersand.
Try replacing this line (approx line 535) in lib/serviio.php:
Before:
            $Folder->appendChild($xmlDoc->createElement("contentUrl", $entry[1]));
After:
            $Folder->appendChild($xmlDoc->createElement("contentUrl", str_replace("&", "&amp;", $entry[1])));
patters
Post Tue Oct 18, 2011 8:25 am
Re: Web UI in PHP
Thing is, then we get problems with recursive substitution if you then add another feed with the Web UI - resulting in &amp;amp; for the first feed since the data for all feeds is resubmitted via REST.
This page offers a nice regex for the job:
&(?![A-Za-z]+;|#[0-9]+;)
patters
Post Tue Oct 18, 2011 10:13 am
Re: Web UI in PHP
I tried:
$Folder->appendChild($xmlDoc->createElement("contentUrl", preg_replace ("&(?![A-Za-z]+;|#[0-9]+;)", "&amp;", $entry[1])));
but it isn't working (no new feeds can be added). How can I debug it, since that bit isn't outputting to the HTML, and the library page is being reloaded straight away after the submit?
I suspect that some of the characters in that regex might need escaping. Can you cast an eye over it for anything obvious?
patters
Post Tue Oct 18, 2011 10:50 am
Re: Web UI in PHP
Sweet, fixed. I just needed to delimit the regex with slashes like so:
$Folder->appendChild($xmlDoc->createElement("contentUrl", preg_replace ("/&(?![A-Za-z]+;|#[0-9]+;)/", "&amp;", $entry[1])));
Users browsing this forum: Baidu [Spider] and 19 guests
