Re: Web UI in PHP
mpemberton5 wrote:Here's an updated version of Web UI in PHP. This will work with 0.6.0.1 and has an updated library section that displays the sources in tabs.
http://dl.dropbox.com/u/42061/serviio-0.6.0.1.zip
Please let me know if you have any issues.
I do know of the known issue with the QNAP users where the presentation section is still broken. I'm working on a possible solution.
Thanks all,
Cerberus wrote:So in short you will need to install cURL extension onto your device to make the webui work.
Cantello wrote:Cerberus wrote:So in short you will need to install cURL extension onto your device to make the webui work.
This would be something to put in the first post - I was wondering why it wouldn't work...
Now works well here (Ubuntu 11.04, apache2).
patters wrote:Online feed URLs containing ampersands are getting chewed up by the Web UI - e.g.:
http://feeds.gametrailers.com/rssgenerate.php?s1=&favplats[xb360]=xb360&vidformat[flv]=on&type[review]=on&quality[hd]=on&agegate[no]=on&orderby=newest&limit=20
is cropped to:
Despite tinkering with this I'm not a web developer so I'm not sure how this needs to be fixed. It's seems that they need translating to & as the URL is read from input. Would we manually do this as a string substitution, or is there a function to do these HTML special chars automatically? I'm guessing this could be relevant:
http://www.w3.org/QA/2005/04/php-session
