[SOLVED] MKV files get error fileformat not supported
kephry
Post Wed Oct 05, 2011 12:06 pm
Hi Guys.
When trying to play MKV files i get the error "fileformat not supported". I have searched around the FAQ, but havent found the answer yet and hope someone can help me. I have downloaded a new profile.xml which should support mkv files and tried a stunt with the mkvmerge. Still no luck.
Suggestions anyone?
Post Wed Oct 05, 2011 12:41 pm
Re: MKV files get error fileformat not supported
can you enable detailed logging (see signature) and post your serviio.log file.
See signature on how to provide information on file that will not play.
Post Wed Oct 05, 2011 12:43 pm
Could you post "ffmpeg -i" result of your mkv file, and also MediaInfo result?
kephry
Post Wed Oct 05, 2011 1:32 pm
ffmpeg result:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i f:\mkv\the.fighter\the.fighter.
mkv
nfig
[matroska,webm @ 016389c0] max_analyze_duration 5000000 reached at 5024000
[matroska,webm @ 016389c0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'f:\mkv\the.fighter\the.fighter.mkv':
  Duration: 01:55:38.52, start: 0.000000, bitrate: 640 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x536 [PAR 1:1 DAR 160:67]
, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s (default)
    Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000 (default)
    Stream #0.3(ara): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.4(por): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.5(dut): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.6(fre): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.7(ita): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.8(spa): Subtitle: [0][0][0][0] / 0x0000
kephry
Post Wed Oct 05, 2011 1:38 pm
Media info:
Unique ID                        : 174407838681062944751518078417087069211 (0x8335BA57FE4B47ECAE64C265F2A17C1B)
Complete name                    : Z:\MKV\The.Fighter\The.Fighter.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 2.18 GiB
Duration                         : 1h 55mn
Overall bit rate                 : 2 702 Kbps
Encoded date                     : UTC 2011-03-07 21:49:16
Writing application              : mkvmerge v4.5.0 ('Speed of Light') gemaakt op Feb  1 2011 02:10:32
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Format profile                   : High@L5.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 55mn
Bit rate                         : 2 060 Kbps
Width                            : 1 280 pixels
Height                           : 536 pixels
Display aspect ratio             : 2.40:1
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.125
Stream size                      : 1.62 GiB (74%)
Writing library                  : x264 core 80 r1376M 3feaec2
Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=2060 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Muxing mode                      : Header stripping
Codec ID                         : A_AC3
Duration                         : 1h 55mn
Bit rate                         : 640 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 529 MiB (24%)
Text #1
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Language                         : English
Text #2
Format                           : UTF-8
Language                         : Arabic
Text #3
Format                           : UTF-8
Language                         : Portuguese
Text #4
Format                           : UTF-8
Language                         : Dutch
Text #5
Format                           : UTF-8
Language                         : French
Text #6
Format                           : UTF-8
Language                         : Italian
Text #7
Format                           : UTF-8
Language                         : Spanish
Post Wed Oct 05, 2011 1:43 pm
The h264 profile level is too high, not supported by Samsung TV (max H@L4.1), must be transcoded to mpeg2video.
kephry
Post Wed Oct 05, 2011 1:56 pm
Thanks for reply.
Another movie have High@L3.1, but i cant play that one either.
I have a toshiba tv, but a Samsung BD-D5800 blue-ray player .Its the samsung i use as dnla client. I dont know if that is relevant?
Post Wed Oct 05, 2011 3:00 pm
kephry wrote:...Another movie have High@L3.1, but i cant play that one either.
Same, please provide "ffmpeg -i" and MediaInfo informations...
kephry
Post Wed Oct 05, 2011 4:35 pm
F:\MKV\Knight.And.Day.DVDRip.x264.dxva-TiMPE>"C:\Program Files (x86)\Serviio\lib
\ffmpeg.exe" -i timpe-knightandday.mkv
nfig
[matroska,webm @ 013f8a40] Estimating duration from bitrate, this may be inaccur
ate
Input #0, matroska,webm, from 'timpe-knightandday.mkv':
  Duration: 01:49:31.12, start: 0.000000, bitrate: N/A
    Chapter #0.0: start 0.097000, end 6571.125000
      title           : 00:00:00.097
    Stream #0.0(eng): Video: h264 (High), yuv420p, 720x304 [PAR 1:1 DAR 45:19],
      title           : Video encoded by Quiker @ TiMPE
    Stream #0.1(eng): Audio: aac, 48000 Hz, 5.1, s16 (default)
      title           : Audio encoded by Quiker @ TiMPE
mediainfo.txt
(3.09 KiB) Downloaded 720 times
Post Wed Oct 05, 2011 5:14 pm
This one use header compression, not supported by Samsung TV, so must be transcode into MPEG2TS for example, try with TsMuxer...
kephry
Post Wed Oct 05, 2011 5:46 pm
Thanks for quick and good answers :D
Post Thu Oct 06, 2011 9:55 am
So topic could be set to [SOLVED] ?
Post Thu Oct 06, 2011 8:12 pm
Illico, I believe your previous post and solution for this problem http://forum.serviio.org/viewtopic.php?f=6&t=1132#p5402 should be posted as a sticky.
