Serviio not seeing Sony TV
Post Tue Oct 04, 2011 8:41 am
Re: Serviio not seeing Sony TV
Do you have the latest Sony firmware?
mwsmorris
Post Tue Oct 04, 2011 11:43 am
I have no idea on the Bravia firmware? Do they update often? Would the TV not auto update?
I could phone Sony and check.
Post Tue Oct 04, 2011 1:24 pm
mwsmorris wrote:I could phone Sony and check.
No, http://support.sony-europe.com/tvhc/ima ... 503&s=SM18
On your TV sony menu:
Home--> Product Support --> System Information : must be PKG4.107EUL-0108 firmware version
mwsmorris
Post Tue Oct 04, 2011 3:52 pm
Checked the FW and I have the version you mentioned.
System update is set to "on" so I assume it will update when required.
Phil.cdtpixel
Post Tue Oct 04, 2011 3:59 pm
Did you change the name of the renderer into TV network menu ?
I did that two weeks ago and Serviio had problems to see my SONY TV, rename it in "Bravia KDL-32CX520" and now no problem for detection and auto profile...
Post Tue Oct 04, 2011 6:53 pm
Phil.cdtpixel wrote:Did you change the name of the renderer into TV network menu ?
Please do not change the renderer name !! Serviio autodetection is based on it.
mwsmorris
Post Tue Oct 04, 2011 6:57 pm
I have not changed anything on the TV side apart from fixing the IP address to 192.168.1.20.
Phil.cdtpixel
Post Wed Oct 05, 2011 10:05 am
Yes i see that :lol:
Change renderer name is bad like "cross the streams" (croiser les effluves)
Post Wed Oct 05, 2011 7:22 pm
ROFL @ the Ghostbusters comment
Post Wed Oct 05, 2011 7:34 pm
Have you tried to see if your TV will see any other DLNA servers?
mwsmorris
Post Wed Oct 05, 2011 9:54 pm
No I haven't tried any other DLNA SW., not really had time as yet. Are you trying to get rid of me? :lol:
I have some questions which I will ask Sony Tech Support when I am next home during the day. But can anyone tell me what they see when they go into Setting/Network/Renderer/Renderer Access control? All I see is "No devices are currently permitted to access the renderer function. Confirm connections and update the device list."
I am not sure if this is due to no communication from my PC getting out or some Sony bug.
Another question
The TCP port connection 8895 seems to function fine. I did a netstat before starting serviio and then after and I can see that TCP port 8895 opens and is listening after starting serviio.
However for UDP port 1900 I am not so sure about (see attached gif). I have been checking the I/O on ports for Serviio on my Comodo Firewall and I can see that there is never any return for the UDP communication. Should thiere be some returned data?
I have been trying t see where/why any coms are being blocked and
ScreenHunter_01 Oct. 05 19.33.gif (15.01 KiB) Viewed 9897 times
alpha786
Post Tue Mar 06, 2012 3:25 pm
Sony tv rocks
Previous
Users browsing this forum: Google [Bot] and 6 guests
