Sony Bravia 2010 series
This topic has become too large, so it has been closed.
You will found the sticky Readme-only topic : [Readme] Sony Bravia 2010 series
For support, create new specific topic
_
zip wrote:Cool, can you confirm what files are playable with the generic profile?
<Profile id="9" name="Sony Bravia EX/HX/NX5" extendsProfileId="1">
<Detection>
<X-AV-Client-Info>(BRAVIA KDL.+EX40)|(BRAVIA KDL.+EX50)|(BRAVIA KDL.+EX60)|(BRAVIA KDL.+EX70)|(BRAVIA KDL.+HX70)|(BRAVIA KDL.+NX503)</X-AV-Client-Info>
</Detection>
<DeviceDescription>
<FriendlyName>Serviio ({computerName})</FriendlyName>
<ModelName>Serviio Media Server</ModelName>
</DeviceDescription>
<!-- transcode other than mpegts container -->
<Matches container="asf" />
<Matches container="mpeg" />
<Matches container="mp4" />
[size=75]2010-07-23 20:50:36,062 INFO [MediaServer] ------------------------------------------------------------------------
2010-07-23 20:50:36,062 INFO [MediaServer] Serviio DLNA media streaming server v 0.4.1 (rev. 41111e4c0a72)
2010-07-23 20:50:36,062 INFO [MediaServer] Petr Nejedly 2009-2010
2010-07-23 20:50:36,062 INFO [MediaServer] http://www.serviio.org
2010-07-23 20:50:36,062 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2010-07-23 20:50:36,062 INFO [MediaServer] OS Windows XP x86 5.1
2010-07-23 20:50:36,062 INFO [MediaServer] File encoding: windows-1252
2010-07-23 20:50:36,093 INFO [ORBServer] Starting Corba server exposed on localhost:23423
2010-07-23 20:50:36,093 INFO [NamingService] Starting Corba Naming service on port 23423
2010-07-23 20:50:36,484 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2010-07-23 20:50:37,890 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2010-07-23 20:50:38,093 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2010-07-23 20:50:38,156 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (B-series)' (id=2)
2010-07-23 20:50:38,218 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2010-07-23 20:50:38,250 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2010-07-23 20:50:38,296 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (A-series)' (id=5)
2010-07-23 20:50:38,328 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2010-07-23 20:50:38,375 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (C-series)' (id=7)
2010-07-23 20:50:38,390 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2010-07-23 20:50:38,437 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia EX/HX/NX5 series' (id=9)
2010-07-23 20:50:38,734 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-07-23 20:50:38,765 INFO [WebServer] WebServer starting on port 8895
2010-07-23 20:50:38,765 INFO [Device] Created UPnP Device with UUID: 223a9375-eb61-3269-abcf-3ad9f2e63b1f, bound address: 192.168.1.6
2010-07-23 20:50:38,812 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2010-07-23 20:50:38,812 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2010-07-23 20:50:38,812 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2010-07-23 20:50:38,812 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2010-07-23 20:50:38,828 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 20:50:38,828 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2010-07-23 20:50:38,828 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1279911038828, LastAccessTime = 1279911038828, getTimeToLiveSeconds() = -1, createTime = 1279911038828 ]
2010-07-23 20:50:38,828 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2010-07-23 20:50:38,843 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2010-07-23 20:50:38,843 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 20:50:38,843 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2010-07-23 20:50:38,843 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2010-07-23 20:50:38,843 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 20:50:38,843 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2010-07-23 20:50:38,843 INFO [CompositeCacheConfigurator] Finished configuration in 31 ms.
2010-07-23 20:50:38,843 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-07-23 20:50:38,843 INFO [DiscoverySearchListener] Starting DiscoverySearchListener using interface 192.168.1.6
2010-07-23 20:50:38,843 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-07-23 20:50:38,843 INFO [EventDispatcher] Starting EventDispatcher
2010-07-23 20:50:40,531 INFO [ServiioConsole] Starting Serviio Console
2010-07-23 20:50:41,562 INFO [UpdateChecker] Checking if a new version is available
2010-07-23 20:50:58,843 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2010-07-23 20:50:58,906 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2010-07-23 20:52:29,890 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2010-07-23 20:53:13,156 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2010-07-23 20:53:13,171 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2010-07-23 20:53:13,171 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2010-07-23 20:53:49,187 WARN [VideoDeliveryEngine] Cannot get media info for transcoded file Sample-Matroska-MPEG4VDivX5-AAC-Vorbis.mkv: MPEG2TS video file Sample-Matroska-MPEG4VDivX5-AAC-Vorbis.mkv does not match any supported DLNA profile
2010-07-23 20:53:49,187 WARN [VideoDeliveryEngine] Cannot get media info for transcoded file Sample-Matroska-MPEG4XviD-AC3.mkv: MPEG2TS video file Sample-Matroska-MPEG4XviD-AC3.mkv does not match any supported DLNA profile
2010-07-23 20:53:49,187 WARN [VideoDeliveryEngine] Cannot get media info for transcoded file Sample-MPEG4-MPEG4V-AAC.mp4: MPEG2TS video file Sample-MPEG4-MPEG4V-AAC.mp4 does not match any supported DLNA profile
2010-07-23 20:53:49,453 WARN [VideoDeliveryEngine] Cannot resolve DLNA format profile of the original file: Sample-MPEGTS-AVCML5.0-MP1L2.mpg
2010-07-23 20:53:49,453 WARN [VideoDeliveryEngine] Cannot get media info for transcoded file Sample-WindowsMedia-VC-1-WMA.wmv: MPEG2TS video file Sample-WindowsMedia-VC-1-WMA.wmv does not match any supported DLNA profile
2010-07-23 21:16:40,656 INFO [AbstractModel] Remote exception occured, removing the listener: CORBA COMM_FAILURE 1398079689 No; nested exception is:
org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 201 completed: No
2010-07-23 21:16:40,656 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2010-07-23 21:16:40,656 INFO [EventDispatcher] Leaving EventDispatcher
2010-07-23 21:16:40,656 INFO [DiscoverySearchListener] Leaving DiscoverySearchListener
2010-07-23 21:16:40,656 INFO [DatabaseManager] Shutting down database
2010-07-23 21:16:41,187 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2010-07-23 21:16:41,187 INFO [WebServer] WebServer shutting down
2010-07-23 21:16:42,921 INFO [ORBServer] Stopped Corba server
2010-07-23 21:16:42,921 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-07-23 21:19:52,046 INFO [MediaServer] ------------------------------------------------------------------------
2010-07-23 21:19:52,078 INFO [MediaServer] Serviio DLNA media streaming server v 0.4.1 (rev. 41111e4c0a72)
2010-07-23 21:19:52,078 INFO [MediaServer] Petr Nejedly 2009-2010
2010-07-23 21:19:52,078 INFO [MediaServer] http://www.serviio.org
2010-07-23 21:19:52,078 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2010-07-23 21:19:52,078 INFO [MediaServer] OS Windows XP x86 5.1
2010-07-23 21:19:52,078 INFO [MediaServer] File encoding: windows-1252
2010-07-23 21:19:52,078 INFO [MediaServer] ------------------------------------------------------------------------
2010-07-23 21:19:53,062 INFO [ORBServer] Starting Corba server exposed on localhost:23423
2010-07-23 21:19:53,062 INFO [NamingService] Starting Corba Naming service on port 23423
2010-07-23 21:20:00,250 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2010-07-23 21:20:07,171 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2010-07-23 21:20:07,406 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2010-07-23 21:20:07,500 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (B-series)' (id=2)
2010-07-23 21:20:07,562 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2010-07-23 21:20:07,593 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2010-07-23 21:20:07,625 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (A-series)' (id=5)
2010-07-23 21:20:07,656 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2010-07-23 21:20:07,703 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (C-series)' (id=7)
2010-07-23 21:20:07,718 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2010-07-23 21:20:07,750 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia EX/HX/NX5 series' (id=9)
2010-07-23 21:20:08,765 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-07-23 21:20:08,875 INFO [WebServer] WebServer starting on port 8895
2010-07-23 21:20:08,890 INFO [Device] Created UPnP Device with UUID: 223a9375-eb61-3269-abcf-3ad9f2e63b1f, bound address: 192.168.1.6
2010-07-23 21:20:09,046 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2010-07-23 21:20:09,078 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2010-07-23 21:20:09,078 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2010-07-23 21:20:09,078 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2010-07-23 21:20:09,078 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 21:20:09,078 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2010-07-23 21:20:09,078 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1279912809078, LastAccessTime = 1279912809078, getTimeToLiveSeconds() = -1, createTime = 1279912809078 ]
2010-07-23 21:20:09,078 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2010-07-23 21:20:09,109 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2010-07-23 21:20:09,109 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 21:20:09,109 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2010-07-23 21:20:09,109 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2010-07-23 21:20:09,109 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 21:20:09,109 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2010-07-23 21:20:09,109 INFO [CompositeCacheConfigurator] Finished configuration in 31 ms.
2010-07-23 21:20:09,125 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-07-23 21:20:09,125 INFO [DiscoverySearchListener] Starting DiscoverySearchListener using interface 192.168.1.6
2010-07-23 21:20:09,125 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-07-23 21:20:09,125 INFO [EventDispatcher] Starting EventDispatcher
2010-07-23 21:20:09,171 ERROR [DiscoverySearchListener] Cannot open multicast socket
java.net.SocketException: L'adresse demandée n'est pas valide dans son contexte
at java.net.PlainDatagramSocketImpl.socketSetOption(Native Method)
at java.net.PlainDatagramSocketImpl.setOption(Unknown Source)
at java.net.MulticastSocket.setInterface(Unknown Source)
at org.serviio.util.MultiCastUtils.startMultiCastSocket(MultiCastUtils.java:34)
at org.serviio.upnp.discovery.DiscoverySearchListener.run(DiscoverySearchListener.java:98)
at java.lang.Thread.run(Unknown Source)
2010-07-23 21:20:09,171 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAlive(DiscoveryAdvertisementNotifier.java:122)
at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.run(DiscoveryAdvertisementNotifier.java:92)
2010-07-23 21:20:09,171 INFO [DiscoverySearchListener] Leaving DiscoverySearchListener
2010-07-23 21:20:14,171 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2010-07-23 21:20:19,171 WARN [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2010-07-23 21:20:29,171 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2010-07-23 21:20:29,281 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2010-07-23 21:21:54,343 INFO [ServiioConsole] Starting Serviio Console
2010-07-23 21:22:04,015 INFO [UpdateChecker] Checking if a new version is available
[/size]010-07-24 20:38:56,812 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2010-07-24 20:38:56,843 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 3 (from=0, count=10)
2010-07-24 20:38:56,859 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2010-07-24 20:38:56,859 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 32)
2010-07-24 20:38:56,875 DEBUG [MediaItemDAOImpl] Getting file of media item 32
2010-07-24 20:38:56,875 DEBUG [VideoDAOImpl] Reading a Video (id = 32)
2010-07-24 20:38:56,890 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 32 and profile Sony Bravia TV
2010-07-24 20:38:56,890 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Sample-AVI-MPEG4XviD-MP3.AVI: MPEG_PS_PAL
2010-07-24 20:38:56,890 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49)
2010-07-24 20:38:56,921 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2010-07-24 20:38:56,921 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-07-24 20:38:56,921 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-07-24 20:38:57,140 DEBUG [WebServer] Incoming connection from /192.168.1.9:36680
2010-07-24 20:38:57,140 DEBUG [ResourceTransportRequestHandler] GET /resource/49/COVER_IMAGE HTTP/1.1, headers = [transferMode.dlna.org: Interactive, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX501";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX501"; mv="1.7";, Host: 192.168.1.6:8895, ]
2010-07-24 20:38:57,140 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:38:57,140 DEBUG [ResourceTransportRequestHandler] Request for resource 49 and type 'COVER_IMAGE' received
2010-07-24 20:38:57,140 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49)
2010-07-24 20:38:57,156 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 49
2010-07-24 20:38:57,156 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2010-07-24 20:38:57,156 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-07-24 20:38:57,156 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4.1, transferMode.dlna.org: Interactive, ]
2010-07-24 20:43:05,531 DEBUG [WebServer] Incoming connection from /192.168.1.9:36681
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] HEAD /resource/32/MEDIA_ITEM/MPEG_PS_PAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1, Pragma: getIfoFileURI.dlna.org, transferMode.dlna.org: Streaming, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX501";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX501"; mv="1.7";, Host: 192.168.1.6:8895, ]
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] Request for resource 32 and type 'MEDIA_ITEM' received
2010-07-24 20:43:05,531 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 32)
2010-07-24 20:43:05,531 DEBUG [VideoDAOImpl] Reading a Video (id = 32)
2010-07-24 20:43:05,531 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 32, format MPEG_PS_PAL and profile Sony Bravia TV
2010-07-24 20:43:05,531 DEBUG [VideoDeliveryEngine] Getting media info for transcoded version of file Sample-AVI-MPEG4XviD-MP3.AVI
2010-07-24 20:43:05,531 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Sample-AVI-MPEG4XviD-MP3.AVI: MPEG_PS_PAL
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4.1, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=81100000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-07-24 20:43:05,546 DEBUG [WebServer] Incoming connection from /192.168.1.9:36682
2010-07-24 20:43:05,546 DEBUG [ResourceTransportRequestHandler] GET /resource/32/MEDIA_ITEM/MPEG_PS_PAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-, getcontentFeatures.dlna.org: 1, Pragma: getIfoFileURI.dlna.org, transferMode.dlna.org: Streaming, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX501";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX501"; mv="1.7";, Host: 192.168.1.6:8895, ]
2010-07-24 20:43:05,546 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:43:05,546 DEBUG [ResourceTransportRequestHandler] Request for resource 32 and type 'MEDIA_ITEM' received
2010-07-24 20:43:05,546 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 32)
2010-07-24 20:43:05,546 DEBUG [VideoDAOImpl] Reading a Video (id = 32)
2010-07-24 20:43:05,546 DEBUG [VideoDeliveryEngine] Delivering item '32' for client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:43:05,546 DEBUG [VideoDeliveryEngine] Delivering file 'Sample-AVI-MPEG4XviD-MP3.AVI' using transcoding
2010-07-24 20:43:05,546 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:43:05,546 DEBUG [MediaItemDAOImpl] Getting file of media item 32
2010-07-24 20:43:05,546 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: C:\Sample\Sample-AVI-MPEG4XviD-MP3.AVI
2010-07-24 20:43:05,546 DEBUG [ProcessExecutor] Starting C:\Serviio\bin\\..\lib/ffmpeg.exe -threads 2 -i C:\Sample\Sample-AVI-MPEG4XviD-MP3.AVI -y -vcodec mpeg2video -sameq -r 25.0 -g 15 -copyts -acodec copy -sn -f vob C:\WINDOWS\TEMP\Serviio\transcoding-temp-32-MPEG2PS.stf
2010-07-24 20:43:06,109 WARN [ProcessExecutor] Process C:\Serviio\bin\\..\lib/ffmpeg.exe has a return code of -1073741819! This is a possible error.
2010-07-24 20:43:06,109 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2010-07-24 20:43:13,046 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2010-07-24 20:43:21,640 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-07-24 20:43:21,640 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Sample
2010-07-24 20:43:21,656 DEBUG [LibraryAdditionsCheckerThread] Found file 'Sample-AVI-MPEG4XviD-MP3.AVI', checking if it's already in the Library
2010-07-24 20:43:21,656 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Sample-AVI-MPEG4XviD-MP3.AVI
2010-07-24 20:43:21,656 DEBUG [MediaItemDAOImpl] Media item Sample-AVI-MPEG4XviD-MP3.AVI already exists in DB
<Profile id="9" name="Sony Bravia TV" extendsProfileId="1">
<Detection>
<X-AV-Client-Info>BRAVIA.*</X-AV-Client-Info>
</Detection>
<!-- [mp3, mp2, ac3, aac, dca, wmav2, pcm_s16le] Audio profile codec-->
<!-- [vc1, mpeg4, msmpeg4, mpeg2video, mpeg1video, h264, wmv2, mjpeg] Video codec -->
<!-- [mp4, asf, mpegvideo, mpeg, mpegts, matroska, avi] container -->
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp3"> <!-- This is MPEG_PS_PAL profile -->
<Matches container="avi" vCodec="mpeg4" aCodec="mp3" /> <!-- container=AVI, audioCodec=MP3, videoCodec=MPEG4 TESTED OK -->
<Matches container="avi" vCodec="wmv2" aCodec="aac" /> <!-- container=AVI, audioCodec=AAC, videoCodec=WMV TESTED OK -->
<Matches container="matroska" vCodec="mpeg4" aCodec="aac" /> <!-- container=MATROSKA, audioCodec=AAC, videoCodec=MPEG4 TESTED OK -->
<Matches container="mp4" vCodec="h264" aCodec="aac" /><!-- container=MP4, audioCodec=AAC, videoCodec=H264 TESTED OK-->
</Profile><Profile id="9" name="Sony Bravia TV" extendsProfileId="1">
<Detection>
</Detection>
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3">
<Matches container="avi" />
zip wrote:It's weird if Mpeg2TS is not supported, as the protocol info lists a lot of those.
paul49 wrote: Only started using Serviio on Sunday, so early days yet.
Great piece of software!
Cheers,
Paul.
Users browsing this forum: No registered users and 82 guests
