Sony Bravia 2010 series
Post Fri Jul 23, 2010 9:42 am
____________INFO____________
This topic has become too large, so it has been closed.
You will found the sticky Readme-only topic : [Readme] Sony Bravia 2010 series
For support, create new specific topic
_
Post Fri Jul 23, 2010 10:58 am
Re: [Device] Sony Bravia 2010 Familly (EX4, EX5, EX6, EX7, HX7)
Cool, can you confirm what files are playable with the generic profile?
Post Fri Jul 23, 2010 11:00 am
zip wrote:Cool, can you confirm what files are playable with the generic profile?
I complete the first post with "Media compatibility results with DLNA Media servers" from support.sony-europe.com, i will test with generic profil this evening.
bstick
Post Fri Jul 23, 2010 5:14 pm
Re: [Device] Sony Bravia 2010 series (EX4, EX5, EX6, EX7, HX7)
I have the EX4 and can confirm the generic profile does not work as I cannot see AVI files.
I had to create a separate entry for Bravia in the profile as per instructions in another post.
Have some further issues though and will raise them later.
Post Fri Jul 23, 2010 6:07 pm
With generic profil, bravia tv can read:
Audio : only mp3 files
Photo: only jpeg files
Video: nothing
Post Fri Jul 23, 2010 7:27 pm
I'm creating the following profile for "Sony Bravia"
and sharing C:\Temp folder with samples files (*..avi, *.mkv, *.m2ts,etc)
<Profile id="9" name="Sony Bravia EX/HX/NX5" extendsProfileId="1">
<Detection>
<X-AV-Client-Info>(BRAVIA KDL.+EX40)|(BRAVIA KDL.+EX50)|(BRAVIA KDL.+EX60)|(BRAVIA KDL.+EX70)|(BRAVIA KDL.+HX70)|(BRAVIA KDL.+NX503)</X-AV-Client-Info>
</Detection>
<DeviceDescription>
<FriendlyName>Serviio ({computerName})</FriendlyName>
<ModelName>Serviio Media Server</ModelName>
</DeviceDescription>
<!-- transcode other than mpegts container -->
<Matches container="asf" />
<Matches container="mpeg" />
<Matches container="mp4" />
The log file:
[size=75]2010-07-23 20:50:36,062 INFO  [MediaServer] ------------------------------------------------------------------------
2010-07-23 20:50:36,062 INFO  [MediaServer] Serviio DLNA media streaming server v 0.4.1 (rev. 41111e4c0a72)
2010-07-23 20:50:36,062 INFO  [MediaServer] Petr Nejedly 2009-2010
2010-07-23 20:50:36,062 INFO  [MediaServer] http://www.serviio.org
2010-07-23 20:50:36,062 INFO  [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2010-07-23 20:50:36,062 INFO  [MediaServer] OS Windows XP x86 5.1
2010-07-23 20:50:36,062 INFO  [MediaServer] File encoding: windows-1252
2010-07-23 20:50:36,093 INFO  [ORBServer] Starting Corba server exposed on localhost:23423
2010-07-23 20:50:36,093 INFO  [NamingService] Starting Corba Naming service on port 23423
2010-07-23 20:50:36,484 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2010-07-23 20:50:37,890 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2010-07-23 20:50:38,093 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2010-07-23 20:50:38,156 INFO  [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (B-series)' (id=2)
2010-07-23 20:50:38,218 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2010-07-23 20:50:38,250 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2010-07-23 20:50:38,296 INFO  [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (A-series)' (id=5)
2010-07-23 20:50:38,328 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2010-07-23 20:50:38,375 INFO  [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (C-series)' (id=7)
2010-07-23 20:50:38,390 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2010-07-23 20:50:38,437 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia EX/HX/NX5 series' (id=9)
2010-07-23 20:50:38,734 INFO  [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-07-23 20:50:38,765 INFO  [WebServer] WebServer starting on port 8895
2010-07-23 20:50:38,765 INFO  [Device] Created UPnP Device with UUID: 223a9375-eb61-3269-abcf-3ad9f2e63b1f, bound address: 192.168.1.6
2010-07-23 20:50:38,812 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2010-07-23 20:50:38,812 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2010-07-23 20:50:38,812 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2010-07-23 20:50:38,812 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2010-07-23 20:50:38,828 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 20:50:38,828 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2010-07-23 20:50:38,828 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1279911038828, LastAccessTime = 1279911038828, getTimeToLiveSeconds() = -1, createTime = 1279911038828 ]
2010-07-23 20:50:38,828 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2010-07-23 20:50:38,843 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2010-07-23 20:50:38,843 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 20:50:38,843 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2010-07-23 20:50:38,843 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2010-07-23 20:50:38,843 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 20:50:38,843 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2010-07-23 20:50:38,843 INFO  [CompositeCacheConfigurator] Finished configuration in 31 ms.
2010-07-23 20:50:38,843 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-07-23 20:50:38,843 INFO  [DiscoverySearchListener] Starting DiscoverySearchListener using interface 192.168.1.6
2010-07-23 20:50:38,843 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-07-23 20:50:38,843 INFO  [EventDispatcher] Starting EventDispatcher
2010-07-23 20:50:40,531 INFO  [ServiioConsole] Starting Serviio Console
2010-07-23 20:50:41,562 INFO  [UpdateChecker] Checking if a new version is available
2010-07-23 20:50:58,843 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2010-07-23 20:50:58,906 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2010-07-23 20:52:29,890 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2010-07-23 20:53:13,156 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2010-07-23 20:53:13,171 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2010-07-23 20:53:13,171 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2010-07-23 20:53:49,187 WARN  [VideoDeliveryEngine] Cannot get media info for transcoded file Sample-Matroska-MPEG4VDivX5-AAC-Vorbis.mkv: MPEG2TS video file Sample-Matroska-MPEG4VDivX5-AAC-Vorbis.mkv does not match any supported DLNA profile
2010-07-23 20:53:49,187 WARN  [VideoDeliveryEngine] Cannot get media info for transcoded file Sample-Matroska-MPEG4XviD-AC3.mkv: MPEG2TS video file Sample-Matroska-MPEG4XviD-AC3.mkv does not match any supported DLNA profile
2010-07-23 20:53:49,187 WARN  [VideoDeliveryEngine] Cannot get media info for transcoded file Sample-MPEG4-MPEG4V-AAC.mp4: MPEG2TS video file Sample-MPEG4-MPEG4V-AAC.mp4 does not match any supported DLNA profile
2010-07-23 20:53:49,453 WARN  [VideoDeliveryEngine] Cannot resolve DLNA format profile of the original file: Sample-MPEGTS-AVCML5.0-MP1L2.mpg
2010-07-23 20:53:49,453 WARN  [VideoDeliveryEngine] Cannot get media info for transcoded file Sample-WindowsMedia-VC-1-WMA.wmv: MPEG2TS video file Sample-WindowsMedia-VC-1-WMA.wmv does not match any supported DLNA profile
2010-07-23 21:16:40,656 INFO  [AbstractModel] Remote exception occured, removing the listener: CORBA COMM_FAILURE 1398079689 No; nested exception is:
   org.omg.CORBA.COMM_FAILURE:   vmcid: SUN  minor code: 201  completed: No
2010-07-23 21:16:40,656 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2010-07-23 21:16:40,656 INFO  [EventDispatcher] Leaving EventDispatcher
2010-07-23 21:16:40,656 INFO  [DiscoverySearchListener] Leaving DiscoverySearchListener
2010-07-23 21:16:40,656 INFO  [DatabaseManager] Shutting down database
2010-07-23 21:16:41,187 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2010-07-23 21:16:41,187 INFO  [WebServer] WebServer shutting down
2010-07-23 21:16:42,921 INFO  [ORBServer] Stopped Corba server
2010-07-23 21:16:42,921 INFO  [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-07-23 21:19:52,046 INFO  [MediaServer] ------------------------------------------------------------------------
2010-07-23 21:19:52,078 INFO  [MediaServer] Serviio DLNA media streaming server v 0.4.1 (rev. 41111e4c0a72)
2010-07-23 21:19:52,078 INFO  [MediaServer] Petr Nejedly 2009-2010
2010-07-23 21:19:52,078 INFO  [MediaServer] http://www.serviio.org
2010-07-23 21:19:52,078 INFO  [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2010-07-23 21:19:52,078 INFO  [MediaServer] OS Windows XP x86 5.1
2010-07-23 21:19:52,078 INFO  [MediaServer] File encoding: windows-1252
2010-07-23 21:19:52,078 INFO  [MediaServer] ------------------------------------------------------------------------
2010-07-23 21:19:53,062 INFO  [ORBServer] Starting Corba server exposed on localhost:23423
2010-07-23 21:19:53,062 INFO  [NamingService] Starting Corba Naming service on port 23423
2010-07-23 21:20:00,250 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2010-07-23 21:20:07,171 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2010-07-23 21:20:07,406 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2010-07-23 21:20:07,500 INFO  [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (B-series)' (id=2)
2010-07-23 21:20:07,562 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2010-07-23 21:20:07,593 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2010-07-23 21:20:07,625 INFO  [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (A-series)' (id=5)
2010-07-23 21:20:07,656 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2010-07-23 21:20:07,703 INFO  [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (C-series)' (id=7)
2010-07-23 21:20:07,718 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2010-07-23 21:20:07,750 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia EX/HX/NX5 series' (id=9)
2010-07-23 21:20:08,765 INFO  [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-07-23 21:20:08,875 INFO  [WebServer] WebServer starting on port 8895
2010-07-23 21:20:08,890 INFO  [Device] Created UPnP Device with UUID: 223a9375-eb61-3269-abcf-3ad9f2e63b1f, bound address: 192.168.1.6
2010-07-23 21:20:09,046 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2010-07-23 21:20:09,078 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2010-07-23 21:20:09,078 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2010-07-23 21:20:09,078 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2010-07-23 21:20:09,078 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 21:20:09,078 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2010-07-23 21:20:09,078 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1279912809078, LastAccessTime = 1279912809078, getTimeToLiveSeconds() = -1, createTime = 1279912809078 ]
2010-07-23 21:20:09,078 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2010-07-23 21:20:09,109 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2010-07-23 21:20:09,109 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 21:20:09,109 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2010-07-23 21:20:09,109 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2010-07-23 21:20:09,109 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-07-23 21:20:09,109 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2010-07-23 21:20:09,109 INFO  [CompositeCacheConfigurator] Finished configuration in 31 ms.
2010-07-23 21:20:09,125 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-07-23 21:20:09,125 INFO  [DiscoverySearchListener] Starting DiscoverySearchListener using interface 192.168.1.6
2010-07-23 21:20:09,125 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-07-23 21:20:09,125 INFO  [EventDispatcher] Starting EventDispatcher
2010-07-23 21:20:09,171 ERROR [DiscoverySearchListener] Cannot open multicast socket
java.net.SocketException: L'adresse demandée n'est pas valide dans son contexte
   at java.net.PlainDatagramSocketImpl.socketSetOption(Native Method)
   at java.net.PlainDatagramSocketImpl.setOption(Unknown Source)
   at java.net.MulticastSocket.setInterface(Unknown Source)
   at org.serviio.util.MultiCastUtils.startMultiCastSocket(MultiCastUtils.java:34)
   at org.serviio.upnp.discovery.DiscoverySearchListener.run(DiscoverySearchListener.java:98)
   at java.lang.Thread.run(Unknown Source)
2010-07-23 21:20:09,171 WARN  [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAlive(DiscoveryAdvertisementNotifier.java:122)
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.run(DiscoveryAdvertisementNotifier.java:92)
2010-07-23 21:20:09,171 INFO  [DiscoverySearchListener] Leaving DiscoverySearchListener
2010-07-23 21:20:14,171 WARN  [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2010-07-23 21:20:19,171 WARN  [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier, will try again
2010-07-23 21:20:29,171 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2010-07-23 21:20:29,281 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2010-07-23 21:21:54,343 INFO  [ServiioConsole] Starting Serviio Console
2010-07-23 21:22:04,015 INFO  [UpdateChecker] Checking if a new version is available
[/size]
Post Fri Jul 23, 2010 8:47 pm
the profile that you have will not properly work (transcoding wise). You have to define target codec(s) for some formats, eg asf (wmv) cannot be just rewrapped into mpegts, it has to be transcoded into mpeg2video as well.
You can have multiple transcoding blocks, like:
This one means: for ASF files, transcode into mpegts with mpeg2 video and ac3 audio (no matter what the codecs are, but most likely wmv + wma); for mp4 and mkv files, just rewrap them into mpegts, keeping their current streams as they are. Then it's up to test if it plays all files you throw at it.
I suppose mpeg2 (ps) should be supported looking at the profileinfo (MPEG_PS_PAL).
The video in your log (Sample-Matroska-MPEG4XviD-AC3.mkv) might not work with 0.4.1 if it's a HD movie (that profile will be added in 0.4.2).
Post Sat Jul 24, 2010 6:46 pm
I was too optimistic
Then I resume the analysis step by step
1) I Share a simple avi file in "C:\Sample" folder named Sample-AVI-MPEG4XviD-MP3.AVI
With MediaInfo:
Format : AVI
Video Format : MPEG-4 Visual, Codec : XVID, 720x576 pixels, 25 fps, PAL
Audio Format: MPEG Audio Version 1 Layer 3 (MP3), 112 Kbps, 2 Channels, 48.0 KHz
2) Select "Generic DLNA profile" in console and restart serviio service and console.
--> I can see the Serviio server on Bravia Menu, and can navigate in all the menus/folders
--> In "Sample" folder nothing was found "Il n'y a aucun élément à afficher"
3) Create and select a simple Bravia profile in console, restart serviio service and console
<Profile id="9" name="Sony Bravia TV" extendsProfileId="1">
      <Detection>
         <X-AV-Client-Info>BRAVIA.*</X-AV-Client-Info>
      </Detection>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp3">
         <Matches container="avi" />
--> In "Sample" folder i can see the "Sample-AVI-MPEG4XviD-MP3" file with a good thumbnail
--> Select the file but nothing work : "Impossible d'accéder temporairement au serveur. Merci de réessayer"
with the end of log file:
010-07-24 20:38:56,812 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2010-07-24 20:38:56,843 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 3 (from=0, count=10)
2010-07-24 20:38:56,859 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2010-07-24 20:38:56,859 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 32)
2010-07-24 20:38:56,875 DEBUG [MediaItemDAOImpl] Getting file of media item 32
2010-07-24 20:38:56,875 DEBUG [VideoDAOImpl] Reading a Video (id = 32)
2010-07-24 20:38:56,890 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 32 and profile Sony Bravia TV
2010-07-24 20:38:56,890 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Sample-AVI-MPEG4XviD-MP3.AVI: MPEG_PS_PAL
2010-07-24 20:38:56,890 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49)
2010-07-24 20:38:56,921 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2010-07-24 20:38:56,921 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-07-24 20:38:56,921 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-07-24 20:38:57,140 DEBUG [WebServer] Incoming connection from /192.168.1.9:36680
2010-07-24 20:38:57,140 DEBUG [ResourceTransportRequestHandler] GET /resource/49/COVER_IMAGE HTTP/1.1, headers = [transferMode.dlna.org: Interactive, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX501";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX501"; mv="1.7";, Host: 192.168.1.6:8895, ]
2010-07-24 20:38:57,140 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:38:57,140 DEBUG [ResourceTransportRequestHandler] Request for resource 49 and type 'COVER_IMAGE' received
2010-07-24 20:38:57,140 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49)
2010-07-24 20:38:57,156 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 49
2010-07-24 20:38:57,156 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2010-07-24 20:38:57,156 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-07-24 20:38:57,156 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4.1, transferMode.dlna.org: Interactive, ]
2010-07-24 20:43:05,531 DEBUG [WebServer] Incoming connection from /192.168.1.9:36681
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] HEAD /resource/32/MEDIA_ITEM/MPEG_PS_PAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1, Pragma: getIfoFileURI.dlna.org, transferMode.dlna.org: Streaming, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX501";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX501"; mv="1.7";, Host: 192.168.1.6:8895, ]
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] Request for resource 32 and type 'MEDIA_ITEM' received
2010-07-24 20:43:05,531 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 32)
2010-07-24 20:43:05,531 DEBUG [VideoDAOImpl] Reading a Video (id = 32)
2010-07-24 20:43:05,531 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 32, format MPEG_PS_PAL and profile Sony Bravia TV
2010-07-24 20:43:05,531 DEBUG [VideoDeliveryEngine] Getting media info for transcoded version of file Sample-AVI-MPEG4XviD-MP3.AVI
2010-07-24 20:43:05,531 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Sample-AVI-MPEG4XviD-MP3.AVI: MPEG_PS_PAL
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2010-07-24 20:43:05,531 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4.1, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=81100000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-07-24 20:43:05,546 DEBUG [WebServer] Incoming connection from /192.168.1.9:36682
2010-07-24 20:43:05,546 DEBUG [ResourceTransportRequestHandler] GET /resource/32/MEDIA_ITEM/MPEG_PS_PAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-, getcontentFeatures.dlna.org: 1, Pragma: getIfoFileURI.dlna.org, transferMode.dlna.org: Streaming, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-46EX501";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-46EX501"; mv="1.7";, Host: 192.168.1.6:8895, ]
2010-07-24 20:43:05,546 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:43:05,546 DEBUG [ResourceTransportRequestHandler] Request for resource 32 and type 'MEDIA_ITEM' received
2010-07-24 20:43:05,546 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 32)
2010-07-24 20:43:05,546 DEBUG [VideoDAOImpl] Reading a Video (id = 32)
2010-07-24 20:43:05,546 DEBUG [VideoDeliveryEngine] Delivering item '32' for client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:43:05,546 DEBUG [VideoDeliveryEngine] Delivering file 'Sample-AVI-MPEG4XviD-MP3.AVI' using transcoding
2010-07-24 20:43:05,546 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.9, Profile=Sony Bravia TV'
2010-07-24 20:43:05,546 DEBUG [MediaItemDAOImpl] Getting file of media item 32
2010-07-24 20:43:05,546 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: C:\Sample\Sample-AVI-MPEG4XviD-MP3.AVI
2010-07-24 20:43:05,546 DEBUG [ProcessExecutor] Starting C:\Serviio\bin\\..\lib/ffmpeg.exe -threads 2 -i C:\Sample\Sample-AVI-MPEG4XviD-MP3.AVI -y -vcodec mpeg2video -sameq -r 25.0 -g 15 -copyts -acodec copy -sn -f vob C:\WINDOWS\TEMP\Serviio\transcoding-temp-32-MPEG2PS.stf
2010-07-24 20:43:06,109 WARN [ProcessExecutor] Process C:\Serviio\bin\\..\lib/ffmpeg.exe has a return code of -1073741819! This is a possible error.
2010-07-24 20:43:06,109 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2010-07-24 20:43:13,046 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2010-07-24 20:43:21,640 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-07-24 20:43:21,640 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Sample
2010-07-24 20:43:21,656 DEBUG [LibraryAdditionsCheckerThread] Found file 'Sample-AVI-MPEG4XviD-MP3.AVI', checking if it's already in the Library
2010-07-24 20:43:21,656 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Sample-AVI-MPEG4XviD-MP3.AVI
2010-07-24 20:43:21,656 DEBUG [MediaItemDAOImpl] Media item Sample-AVI-MPEG4XviD-MP3.AVI already exists in DB
Post Sat Jul 24, 2010 6:52 pm
I try the following command on shell:
ffmpeg.exe crashed, why !!?
The profile used was DLNA.ORG_PN=MPEG_PS_PAL
Post Sat Jul 24, 2010 7:41 pm
With another ffmpeg version ("SVN-r22628-Sherpya") transcode works.
Post Sat Jul 24, 2010 10:10 pm
See my latest profile.xml for Bravia :
      <Detection>
      </Detection>
         <!-- [mp3, mp2, ac3, aac, dca, wmav2, pcm_s16le] Audio profile codec-->
         <!-- [vc1, mpeg4, msmpeg4, mpeg2video, mpeg1video, h264, wmv2, mjpeg] Video codec -->
         <!-- [mp4, asf, mpegvideo, mpeg, mpegts, matroska, avi] container -->
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp3"> <!-- This is MPEG_PS_PAL profile -->
            <Matches container="avi" vCodec="mpeg4" aCodec="mp3" /> <!-- container=AVI, audioCodec=MP3, videoCodec=MPEG4 TESTED OK -->
            <Matches container="avi" vCodec="wmv2" aCodec="aac" /> <!-- container=AVI, audioCodec=AAC, videoCodec=WMV TESTED OK -->
            <Matches container="matroska" vCodec="mpeg4" aCodec="aac" /> <!-- container=MATROSKA, audioCodec=AAC, videoCodec=MPEG4 TESTED OK -->
            <Matches container="mp4" vCodec="h264" aCodec="aac" /><!-- container=MP4, audioCodec=AAC, videoCodec=H264 TESTED OK-->
- That could be interresting to have HD profile (ex:AVC_TS_HD_EU_T) compatible with BRAVIA
- Message: Unknown video file type : Flash Video container type not supported by ffmpeg
- Message: Unknown audio codec: if no audio track, media not add to the video library
Con't
PaulBravia
Post Sun Jul 25, 2010 4:24 am
Hi Illico that would be an excellent idea to have a common Sony Bravia TV Profile (in this case a Profile ID of 9).
Normally it would be backward compatible, but in this case its possibly formward compatible. Going by the Sony Website in Australia sony.com.au, my old KDL-40WE5 as far as DLNA is concerned appears to be more advanced with more features than the latest 3D IPTV Bravia Marvels!!!!!!
From the Specs, my old KDL-40WE5 is
DLNA Photo (JPEG), Music (MP3, LPCM), Video (MPEG2 PS, MPEG2 TS, AVCHD)
while latest KDL-52LX900 (integrated 3D receiver, integrate wireless and IPTV and IP Widgets) has only DLNA specs of
DLNA Photo (JPEG), Music (MP3, LPCM), Video (MPEG2, AVCHD)
So Zip can safely add our code snippet for Sony Bravia TV to the next versiopn Serviio 0.4.2. To improve things even further, I added provision for .mp4 and .mkv video files as well.
            <Detection>
            </Detection>
               <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3">
I have a desktop running Windows Professional 7 32 bit and a laptop running Windows 7 Home Premium 64 bit
It would appear that on the 32bit version, both .mp4 and.mkv files work fine, but on the 64 bit only I managed to get only .mp4 to work.
Also the Thumbnails seem to have a problems with .mkv videos, don't show up (maybe need some more testing)
I also downloaded the latest MPlayer for Win32 FFmpeg.exe {FFmpeg-svn-24254 from Sherpya} and it does not seem to make any difference as far as .mkv files are concerned with Servio running on a 64bit OS.
Another quirky thing, on the Serviio running on 32 bit Win 7 OS the .mp4 and .mkv video files appear with no thumbnail in "All Titles" but not in "Movies" - you would expect to see the same movie in both places. On 64 bit Win 7, Servio has the same, but only in this case for .mp4 files.
Cheers,
Paul
Post Sun Jul 25, 2010 10:47 am
Guys, great thread!
Just one thing - not sure if you're on Linux (as you have your own FFmpeg), but if that is the case you should compile FFmpeg using the source that is available on serviio.org (download page). It includes some patches that are not available in the FFmpeg repository (and therefore in a official releases). That way you'll get the same version as the Windows/OSX users.
Post Sun Jul 25, 2010 12:30 pm
For Windows users (like me), the latest ffmpeg.exe can be downloaded here.
bstick
Post Sun Jul 25, 2010 9:57 pm
Re: [Profile] Sony Bravia 2010 series (EX4, EX5, EX6, EX7, HX7)
I am able to play most of my AVIs with the current profile set up:
(Mpegts does not seem to be supported)
<Profile id="9" name="Sony Bravia EX" extendsProfileId="1">
<Detection>
<X-AV-Client-Info>.*BRAVIA.*</X-AV-Client-Info>
</Detection>
However, I am not seeing all (if any) MP4s and some AVis are still not displaying.
I am a bit raw to the technical details being discussed so hope I will catch up.
I believe I need to run ffmpeg on the individual files to uncover particular issues?
Also, has anyone been able to view and play .MOV files?
Lastly, how is subtitle support added into the profile (if not, how else to get the support for .SRT files)?
Post Sun Jul 25, 2010 10:12 pm
.MOV files are just MP4 files. I'm not sure if the TV supports streaming subtitles, if not then you won't be able to see them.
It's weird if Mpeg2TS is not supported, as the protocol info lists a lot of those.
paul49
Post Tue Jul 27, 2010 2:38 am
zip wrote:It's weird if Mpeg2TS is not supported, as the protocol info lists a lot of those.
I thought so, too but my 40HX700 won't play Mpeg2TS either.
But I've added <Matches container="mpegts" /> to Illico's profile and they seem to play OK. now. Only started using Serviio on Sunday, so early days yet.
Great piece of software!
Cheers,
Paul.
Post Tue Jul 27, 2010 8:33 am
Could you make a test with this profile, please check that profile is chosen on console, save and restart service before testing.
<Detection>
</Detection>
Post Tue Jul 27, 2010 8:41 am
paul49 wrote: Only started using Serviio on Sunday, so early days yet.
Cheers,
Paul.
I'm also a newbie, I try to understand how to put on at best serviio with my Bravia TV. Goog job zip/Petr.
Post Tue Jul 27, 2010 12:53 pm
I found the DLNA Certification for KDL-46EX501 model
REG03302057.pdf
Link added to the first top of the topic
Users browsing this forum: Bing [Bot] and 101 guests
