New D Series Samsung
sohail579
Post Thu Jun 30, 2011 9:36 pm
Hi Mods & Zip
I used to have a Samsung C series TV and Serviio was simply the best avilible and now i have a D series and its just more of the same!!
If there is anything i can test out for you just let me know!
Cheerz Zip
Post Thu Jun 30, 2011 10:28 pm
Re: New D Series Samsung
keep using the C/D profile and report back if you find a file that doesn't play. thanks.
sohail579
Post Thu Jun 30, 2011 11:48 pm
no problem will do!!
Scoty
Post Fri Jul 08, 2011 5:26 pm
Working fine with the new D Serie.
lindend
Post Sun Jul 17, 2011 4:07 pm
I have a D8000 and I get an incompatible file format error when I try to stream .mp4 files to it via serviio. I also have a BD-D5500 and I'll try to stream to that and post the results.
lindend
Post Sun Jul 17, 2011 4:34 pm
The Samsung BluRay player worked w/the Samsung profile, so I went back and tried w/the D8000 TV and that worked too. I then started playing content and it looks like .wmv files played on the TV creates problems for content played afterwards (they work ok on the player though).
fr4m3
Post Sat Oct 08, 2011 8:48 am
I use it on my d8000, no problem to connect, no problem to open file, but i have problem to play it...
Every 1 or 2 second play stop and buffering... it's normal?
I use serviio on pc with atom and ion with 4gb ram and w7 64bit, attached on netgear dgnd3700, tv is connected in wifi 802.11n, files are .mkv fullhd size over 13Gb.
luigui
Post Sat Oct 08, 2011 11:44 am
I have a D8000 TV and can't play youtube online feeds, it says invalid format. Anybody have tried it? Thanks.
Post Sat Oct 08, 2011 6:02 pm
fr4m3 wrote:I use it on my d8000, no problem to connect, no problem to open file, but i have problem to play it...
yer switch to a wired network rather than wifi and your router cant cope over wifi.
luigui wrote:I have a D8000 TV and can't play youtube online feeds, it says invalid format. Anybody have tried it? Thanks.
online transcoding hasnt been setup yet for D series, try using the B series profile and see if they then work.
Post Sun Oct 09, 2011 3:46 am
The C/D series profile is additive to the B series profile which is additive to the default profile so any AVC you tube streams (.mp4 and .flv) will be transcoded to MPEG2-PS. Like you however, I also have a D series TV and my transcoded .mp4 to MPEG2-PS get the same error. I have opened a ticket on this. However the D will play .mp4 natively so just comment out the .mp4 lines in profiles 1 and 2 under on-line transcoding and your youtubes should play. Let me know if this works.
Post Sun Oct 09, 2011 4:24 am
nope transcoding sections are not carried over.
fr4m3
Post Sun Oct 09, 2011 8:10 am
thx for answer!
but it's a bad news for me... i can't connect my tv with ethernet cable, if i use netgear powerline 500mbits bandwith is enough for my problem?
thx guys
Post Sun Oct 09, 2011 8:44 am
you can try it but you better of buying a better quality router if you cant go wired, do a quick search on these forums for my nick i have give info on the best router to use, from ones i tested.
Post Sun Oct 09, 2011 3:54 pm
Cerberus wrote:nope transcoding sections are not carried over.
Phil, that does not match my experience. Using the C/D profile (7) (which has no on-line transcoding section), my online .mp4 sources are being transcoded to MPEG-PS per the B (2) profile which overrides the MPEG-TS transcoding in the default (1) profile. At least it seems that way. I can't see any other way.
Post Sun Oct 09, 2011 4:12 pm
yep, OnlineTranscoding is inherited, as per: http://www.serviio.org/index.php?option ... icle&id=24
fr4m3
Post Mon Oct 10, 2011 12:17 pm
Good news... i remake a wireless setup on d8000 now it's linked to my 5Ghz frequency and i can streem full hd film!
Thx guys!
Post Thu Oct 13, 2011 2:21 pm
Thats true if you are using "low quality" for on-line,because youtube uses H263.flv's for those but its a bug unique to the D series TV's.
See ticket #429 https://bitbucket.org/xnejp03/serviio/issue/429/samsung-d-series-tv-wont-play-transcoded
Switch to "medium quality" where youtube uses avc and they will play fine.
I have opened Ticket #432 requesting that the Samsung profiles be corrected to support proper on line playback for the D series. https://bitbucket.org/xnejp03/serviio/issue/432/samsung-c-d-series-on-line-transcoding
luigui
Post Thu Oct 20, 2011 3:57 pm
I have tried low, medium and high quality, but it didn't worked in any case. I'll try again with the firmware that just came out today...
Post Thu Oct 20, 2011 6:28 pm
Whats the firmware number. My D550 has the original 1009 level dated Feb/2011, and the online update says it is current.
The Samsung site however says the latest for my D series TV is 1018 dated September but i have not installed it because online is not indicating it is required.
Please post your firmware version and how it is working.
Also post your YouTube feed url so I can test it here.
PS: to all you D series users. Are you willing to join me in testing D Series capabilities? I would provide files via Rapidshare for you to play and report results. This would let us build a more complete list of Features/Problems/Workarounds that I have started at http://forum.serviio.org/viewtopic.php?f=10&t=3618, and also to verify bugs for zip that I have reported in the issue log https://bitbucket.org/xnejp03/serviio/issues/
luigui
Post Thu Oct 20, 2011 7:39 pm
TV: Samsung 40D8000
Firmware: 1017.3 (and previously 1016.3)
Feed tested: http://gdata.youtube.com/feeds/api/stan ... /top_rated (medium quality)
Result: Not Supported File Format
Return to General discussion
Users browsing this forum: Google Adsense [Bot] and 23 guests
