New D Series Samsung
I used to have a Samsung C series TV and Serviio was simply the best avilible and now i have a D series and its just more of the same!!
If there is anything i can test out for you just let me know!
Cheerz Zip
fr4m3 wrote:I use it on my d8000, no problem to connect, no problem to open file, but i have problem to play it...
Every 1 or 2 second play stop and buffering... it's normal?
I use serviio on pc with atom and ion with 4gb ram and w7 64bit, attached on netgear dgnd3700, tv is connected in wifi 802.11n, files are .mkv fullhd size over 13Gb.
luigui wrote:I have a D8000 TV and can't play youtube online feeds, it says invalid format. Anybody have tried it? Thanks.
Cerberus wrote:nope transcoding sections are not carried over.
jhb50 wrote:luigui wrote:I have a D8000 TV and can't play youtube online feeds, it says invalid format. Anybody have tried it? Thanks.
Thats true if you are using "low quality" for on-line,because youtube uses H263.flv's for those but its a bug unique to the D series TV's.
See ticket #429 https://bitbucket.org/xnejp03/serviio/issue/429/samsung-d-series-tv-wont-play-transcoded
Switch to "medium quality" where youtube uses avc and they will play fine.
I have opened Ticket #432 requesting that the Samsung profiles be corrected to support proper on line playback for the D series. https://bitbucket.org/xnejp03/serviio/issue/432/samsung-c-d-series-on-line-transcoding
Users browsing this forum: Google [Bot] and 27 guests
