XBMC as client: subtitles not working
Elvis71
Post Sun Oct 16, 2011 10:04 am
Hi, I have a laptop with Windows 7 and am using XBMC as DLNA client. It is not displaying subtitles. I have tried both Generic DLNA profiles and XBOX 360 profile. Anyone has got that working? Any suggestions for other DLNA players on Windows 7? Thx.
Strupniveral
Post Sat Mar 24, 2012 6:43 pm
Re: XBMC as client: subtitles not working
I have the same issue...
Do you know if this is something related to the profile or to XBMC?
Post Sat Mar 24, 2012 7:08 pm
Not sure if XBMC supports subtitles via UPnP, but neither of the 2 mentioned profiles send subtitles anyway. The LG/Panasonic profiles.
Strupniveral
Post Sun Mar 25, 2012 7:57 am
I see... Thanks for the info!
I will try asap with Samsung profile and will upgrade to XBMC 11 and will let you know.
Strupniveral
Post Sun Mar 25, 2012 3:36 pm
I tried to force the Samsung profile (workin perfectly with my TV) for my XBMC client without any luck. Upgrading fro v.10.something to 11 didn't solved the issue.
Also did a couple of searches and found other users with similar questions (they didn't stated the used server, but here the issue seems to be related to the client).
Since I didn't find any clear statement from their end, I just opened a new post there; I will come back here as soon as I get something, it might be useful for future references...
Post Sun Mar 25, 2012 7:10 pm
cool
akosszabo
Post Sun Jun 24, 2012 8:05 pm
hey guys
any news on the issue? I would love to keep using XBMC as my client for Servioo, but for that, I'd need the subtitle support.
UPDATE: OK, if I choose the Philips profile instead of the Generic one, it seems to work. Awesome, love you Servioo
zamana
Post Sat Jun 30, 2012 10:04 pm
zip wrote:Not sure if XBMC supports subtitles via UPnP, but neither of the 2 mentioned profiles send subtitles anyway. The LG/Panasonic profiles.
Yes, it supports. I used another DLNA server (I don't know if I can tell which one here) and the subtitles worked out of the box.
