XBMC as client: subtitles not working
• Page 1 of 1
Hi, I have a laptop with Windows 7 and am using XBMC as DLNA client. It is not displaying subtitles. I have tried both Generic DLNA profiles and XBOX 360 profile. Anyone has got that working? Any suggestions for other DLNA players on Windows 7? Thx.
Re: XBMC as client: subtitles not working
I have the same issue...
Do you know if this is something related to the profile or to XBMC?
Not sure if XBMC supports subtitles via UPnP, but neither of the 2 mentioned profiles send subtitles anyway. The LG/Panasonic profiles.
Petr
Help translate Serviio
I see... Thanks for the info!
I will try asap with Samsung profile and will upgrade to XBMC 11 and will let you know.
I tried to force the Samsung profile (workin perfectly with my TV) for my XBMC client without any luck. Upgrading fro v.10.something to 11 didn't solved the issue.
Also did a couple of searches and found other users with similar questions (they didn't stated the used server, but here the issue seems to be related to the client).
Since I didn't find any clear statement from their end, I just opened a new post there; I will come back here as soon as I get something, it might be useful for future references...
cool
Petr
hey guys
any news on the issue? I would love to keep using XBMC as my client for Servioo, but for that, I'd need the subtitle support.
UPDATE: OK, if I choose the Philips profile instead of the Generic one, it seems to work. Awesome, love you Servioo
zip wrote:Not sure if XBMC supports subtitles via UPnP, but neither of the 2 mentioned profiles send subtitles anyway. The LG/Panasonic profiles.
Yes, it supports. I used another DLNA server (I don't know if I can tell which one here) and the subtitles worked out of the box.
• Page 1 of 1
