Samsung BD-C5500 cant play mkv files but.....
dualc
Post Sun Oct 16, 2011 3:26 pm
XBMC under Windows can..
Can somone explain this.?
I have putted some *.mkv files on my Serviio install... and i cant get whem to work on my Blurayplayer, i trie to start whem but whey got laggy all the way...
I can also see the netstream seems laggy as the picture.
If i trie to look at the same files in my XBMC install on my work computer i use right now.. it's seems to work very well.. soo my thought it should be my serviio lagging out seems not be correct.
Do somone have any ideas why my Bluray player's not be able to play the files, cose i got some nice movies in MKV i cant get to see....
/M
BlurayPlayer: Samsung BD-C5500
TV: Samsung LE40B535
Post Sun Oct 16, 2011 5:35 pm
Re: Samsung BD-C5500 cant play mkv files but.....
you must post ffmpeg -i and mediainfo data about the file to get any help with this. Also what is the specific error and what profile does the console show is being used with your device..
dualc
Post Sun Oct 16, 2011 8:13 pm
jhb50 wrote:you must post ffmpeg -i and mediainfo data about the file to get any help with this. Also what is the specific error and what profile does the console show is being used with your device..
I can get u specific error, .. some files playes laggy ... some plays correct (this is testfiles i have tried), ... i also got a movie .. but i cant get it 2 play at all.
The profile im using is the one Serviio seems to find, Samsung C profile, .. for my BlueRay player.
I will .. post the other stuff laters..
/M
Post Sun Oct 16, 2011 10:55 pm
How is your BD-C5500 connected to the computer running Serviio? How is the computer that you ran the movie on with XBMC connected? Also please see signature below and give information on the file that you cannot get to play.
dualc
Post Mon Oct 17, 2011 2:39 pm
Okey some new info, .. i have both my blueray player and the computer with xbmc connected to the same network as serviio via an .. Linksys Router.
I will post Info from Media info here, from a "shrek" testfile who is not playable at all on my Bluray player but works perfekt on XBMC.
Allmänt
UniqueID/String                  : 198078643662735499678677303192891040300 (0x95048F2250D671A7ADAA2EB48D3A222C)
 Fullständigt namn               : \\SAMBA\Alla - Filer\Film\mkv - testfil\Shrek.2.2004.1080p.HDTV.x264-ESiR-Sample.mkv
 Format                          : Matroska
Format_Version                   : Version 1
 Filstorlek                      : 80,0 MiB
Duration/String                  : 1 min
 Generell Bitrate                : 8 118 Kbps
 Kodningsdatum                   : UTC 2006-12-16 01:53:25
 Skrivande applikation           : mkvmerge v1.7.0 ('What Do You Take Me For') built on Apr 28 2006 17:20:19
 Skrivande bibliotek             : libebml v0.7.7 + libmatroska v0.8.0
 Format                          : AVC
 Format/                         : Advanced Video Codec
Format_Profile                   : High@L5.1
Format_Settings_CABAC/String     :  Ja
Format_Settings_RefFrames/String : 8 frame
CodecID                          : V_MPEG4/ISO/AVC
 Bitrate                         : 7 573 Kbps
 Bredd                           : 1 920 pixlar
 Höjd                            : 1 072 pixlar
 Bildförhållande                 : 16:9
DisplayAspectRatio_Original/Stri : 16:9
 Bildhastighet (Frame rate)      : 25,000 fps
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
 Bits/(Pixel*Frame)              : 0.147
StreamSize/String                : 74,6 MiB (93%)
 titel                           : x264 Videostream
 Språk                           :  Engelska
 Format                          : AC-3
 Format/                         : Audio Coding 3
Format_Settings_ModeExtension    : CM (complete main)
CodecID                          : A_AC3
 Bitrate                         : 384 Kbps
 Kanal(er)                       : 6 kanaler
 Kanalplatser                    : Front: L C R, Side: L R, LFE
 Samplingstakt                   : 48,0 KHz
BitDepth/String                  : 16 bits
StreamSize/String                : 3,79 MiB (5%)
 titel                           : DD 5.1
 Språk                           :  Engelska
 Text #1
 Format                          : UTF-8
CodecID                          : S_TEXT/UTF8
/                                : UTF-8 Plain Text
 titel                           : English
 Språk                           :  Engelska
 Text #2
 Format                          : UTF-8
Here is also MediaInfo from a Transformers movie i try to see also, it doesent start at all on my Blueray player but plays fine on my XBMC.
Allmänt
UniqueID/String                  : 207093745514988380292803846446173190412 (0x9BCCCDF8D74CEA888C429B6045ACF90C)
 Fullständigt namn               : \\SAMBA\Alla - Filer\Film\Transformers 1\Transformers.mkv
 Format                          : Matroska
Format_Version                   : Version 2
 Filstorlek                      : 2,19 GiB
Duration/String                  : 2 h 23 min
 Generell Bitrate                : 2 183 Kbps
 Kodningsdatum                   : UTC 2011-05-11 16:07:47
 Skrivande applikation           : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
 Skrivande bibliotek             : libebml v1.2.0 + libmatroska v1.1.0
 Format                          : AVC
Format_Profile                   : High@L4.1
Format_Settings_RefFrames/String : 4 frame
MuxingMode                       : Header stripping
BitRate_Nominal/String           : 1 925 Kbps
 Bredd                           : 1 280 pixlar
 Höjd                            : 528 pixlar
 Bildförhållande                 : 2,40:1
 Bildhastighet (Frame rate)      : 23,976 fps
ColorSpace                       : YUV
 Bits/(Pixel*Frame)              : 0.119
 Skrivande bibliotek             : x264 core 115 r1947 b5a8ad7
 Kodningsinställningar           : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=5 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1925 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
 Format                          : AAC
 Format/                         : Advanced Audio Codec
Format_Profile                   : LC
CodecID                          : A_AAC
 Språk                           :  Engelska
 Text #1
 Format                          : UTF-8
 Språk                           :  Svenska
 Text #2
 Format                          : UTF-8
 Språk                           :  Engelska
 Text #3
 Format                          : UTF-8
 Språk                           :  Turkiska
Will add FFMPG -i output's soon as i must access my serviio install...
Lets see, .. here is the FFMPG -i info for the both files.
SHREK:
ffmpeg -i /mnt/filer/Film/mkv\ -\ testfil/Shrek.2.2004.1080p.HDTV.x264-ESiR-Sample.mkv
FFmpeg version 0.6.2-4:0.6.2-1ubuntu1.1, Copyright (c) 2000-2010 the Libav developers
  built on Sep 16 2011 16:57:46 with gcc 4.5.2
  configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
  WARNING: library configuration mismatch
  libavutil   configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavcodec  configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavformat configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavdevice configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavfilter configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libswscale  configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libpostproc configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
[matroska @ 0x9538420]Estimating duration from bitrate, this may be inaccurate
Input #0, matroska, from '/mnt/filer/Film/mkv - testfil/Shrek.2.2004.1080p.HDTV.x264-ESiR-Sample.mkv':
    doctype         : matroska
  Duration: 00:01:22.68, start: 0.000000, bitrate: 384 kb/s
    Stream #0.0(eng): Video: h264, yuv420p, 1920x1072, PAR 134:135 DAR 16:9, 25 fps, 25 tbr, 1k tbn, 50 tbc
      title           : x264 Videostream
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
      title           : DD 5.1
    Stream #0.2(eng): Subtitle: 0x0000
      title           : English
    Stream #0.3(swe): Subtitle: 0x0000
      title           : Swedish
Transformers:
ffmpeg -i /mnt/filer/Film/Transformers\ 1/Transformers.mkv
[matroska @ 0x8588420]max_analyze_duration reached
[matroska @ 0x8588420]Estimating duration from bitrate, this may be inaccurate
Input #0, matroska, from '/mnt/filer/Film/Transformers 1/Transformers.mkv':
    doctype         : matroska
  Duration: 02:23:27.38, start: 0.000000, bitrate: N/A
    Stream #0.0: Video: h264, yuv420p, 1280x528, PAR 1:1 DAR 80:33, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0.1(eng): Audio: aac, 48000 Hz, 5.1, s16
    Stream #0.2(swe): Subtitle: 0x0000
    Stream #0.3(eng): Subtitle: 0x0000
    Stream #0.4(tur): Subtitle: 0x0000
Hope this info will help some..??
/M
Post Mon Oct 17, 2011 3:03 pm
update your version of FFmpeg, as it is very old and also has some configuration errors that are more than likely causing these issues.
dualc
Post Mon Oct 17, 2011 3:17 pm
Cerberus wrote:update your version of FFmpeg, as it is very old and also has some configuration errors that are more than likely causing these issues.
Strange, it's the FFMpeg following Ubuntu 11.04.. but maybee it's to old if u say so.
Post Mon Oct 17, 2011 3:55 pm
For Shrek : "Format_Profile : High@L5.1" --> Level > 4.1 not supported --> Workarround (not 100%) change profile level : viewtopic.php?f=17&t=2118
For transformer : "MuxingMode : Header stripping" --> Header compression not supported --> Solution : viewtopic.php?f=6&t=1132
dualc
Post Mon Oct 17, 2011 4:06 pm
Okey, new tries.. have compiled the FFMpeg 0.8.5 now.. so i hope it will go better now.
/M
Post Mon Oct 17, 2011 4:08 pm
Do you read my previous post?
dualc
Post Mon Oct 17, 2011 4:20 pm
Illico wrote:Do you read my previous post?
Sorry i missed it :/, .. and will in not work even if i installed new FFMpeg?
/M
Post Mon Oct 17, 2011 4:54 pm
dualc wrote:Sorry i missed it :/, .. and will in not work even if i installed new FFMpeg?
Don't think so, but you could try...also see my solution/workarround.
dualc
Post Mon Oct 17, 2011 5:23 pm
Transformersmovie seems to work now.. a liiiiiitle bit laggy and the movie + sound seems not synced..
But anyway .. it's a walk in right direction.. :)
Havent tried to fix the shrek movie.. but it is from a bunch of mkv testfiles soo maybee it should not work.
/M
