Sony Bravia / 2011 -profile
mikexo
Post Wed Oct 19, 2011 1:56 pm
Hey,
What's the main difference with the two profiles? I have a problem where my TV/Serviio won't play some .avi files when I have the 2011-profile selected. With the older Bravia profile it plays those files just fine. When I tried to use the 2011 profile TV just says "Can't play" and the Serviio log file said something like "socket write error" in the end.
FFMPEG info from one of the .avis:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "G:\Videos\Movies\Movie.avi"
nfig
Input #0, avi, from 'G:\Videos\Movies\Movie.avi':
    encoder         : VirtualDubMod 1.5.10.2 (build 2540/release)
  Duration: 01:27:14.64, start: 0.000000, bitrate: 3957 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 1280x544 [PAR 1:1 DAR 40:17], 23.98 tbr,
 23.98 tbn, 23.98 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Post Wed Oct 19, 2011 2:11 pm
Re: Sony Bravia / 2011 -profile
mikexo wrote: Stream #0.0: Video: mpeg4, yuv420p, 1280x544 [PAR 1:1 DAR 40:17], 23.98 tbr, 23.98 tbn, 23.98 tbc
Sony TV 2010 profile : transcoded avi into a mpeg2 video stream (supported by 2010 and 2011 models)
Sony Tv 2011 profile : delivered avi file in native format, but its seems that 2011 models only supports SD format, not HD (1280x544 in this case)
mikexo
Post Wed Oct 19, 2011 2:16 pm
OK.. That seems weird. What do I lose if just keep using the older profile w/ Serviio?
Post Wed Oct 19, 2011 2:20 pm
mikexo wrote:What do I lose if just keep using the older profile w/ Serviio?
For the moment, only AVI SD files delivered in native format with 2011 profile, so more cpu usage when 2010 profile used.
But in future 2011 profile could be updated to support more formats in native (mp4,asf,etc)
Post Wed Oct 19, 2011 3:00 pm
Please, could you provide "MediaInfo" result of this file (see signature links) ?
mikexo
Post Wed Oct 19, 2011 8:00 pm
Here you go..
This is maybe a weird format..
Format                           : AVI
Format/Info                      : Audio Video Interleave
Format profile                   : OpenDML
File size                        : 2.41 GiB
Duration                         : 1h 27mn
Overall bit rate                 : 3 957 Kbps
Writing application              : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library                  : VirtualDubMod build 2540/release
Format                           : MPEG-4 Visual
Format profile                   : Advanced Simple@L5
Format settings, BVOP            : 2
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 1h 27mn
Bit rate                         : 3 498 Kbps
Width                            : 1 280 pixels
Height                           : 544 pixels
Display aspect ratio             : 2.35:1
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.210
Stream size                      : 2.13 GiB (88%)
Writing library                  : XviD 1.2.1 (UTC 2008-12-04)
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : 2000
Duration                         : 1h 27mn
Bit rate                         : 448 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 280 MiB (11%)
Alignment                        : Split accross interleaves
Interleave, duration             : 42 ms (1.00 video frame)
Interleave, preload duration     : 500 ms
mikexo
Post Sun Oct 30, 2011 4:18 pm
And even though the older profile is able to play these files, they lag and stutter quite a bit, making it almost unwatchable.
