Sony Bravia 2011 Series
Post Tue Oct 25, 2011 8:41 am
Re: Sony Bravia 2011 Series
hyperwill wrote:...but some AVI with those properties do not (work fine)
Could you provide "MediaInfo" result detailed of this avi file?
DivX HD not supported.
Could you also try MP4 samples (H264/AAC) files with that modified profile? viewtopic.php?f=11&t=2079&start=110#p24386
hyperwill
Post Wed Oct 26, 2011 2:36 am
wow. thanks for the quick reply and sorry for the late response.
have tried the modified profile but no joy.
i'm getting "temporarily cannot access server. please try again." message for the mp4 files.
still getting the "playback not available" message for the avi files.
so i'm going to revert the profile xml file back to the original.
could you tell me how do i go about obtaining the "MediaInfo" result please?
hyperwill
Post Wed Oct 26, 2011 2:58 am
doh!
i just saw your signature. results below :)
C:\Program Files\Serviio\lib>ffmpeg.exe -i "c:\Documents and Settings\Will\Desktop\Green.avi"
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
[mpeg4 @ 01719720] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'c:\Documents and Settings\Will\Desktop\Green.avi':
encoder : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50
JUNK :
Duration: 01:53:59.95, start: 0.000000, bitrate: 1521 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 640x272 [PAR 1:1 DAR 40:17], 23.98 tbr,23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 192 kb/s
Post Wed Oct 26, 2011 7:05 am
hyperwill wrote:...[mpeg4 @ 01719720] Invalid and inefficient vfw-avi packed B frames detected
Looks like dodgy AVI file, re-encode it
Post Wed Oct 26, 2011 7:21 am
I never try these tools but you could have a look :
viewtopic.php?f=17&t=2186
http://www.videohelp.com/tools/MPEG4-Modifier
Could you provide "mediaInfo" result too ?
Lowlander
Post Sun Oct 30, 2011 6:52 am
Should the 0.6 Bravia 2011 profile be able to handle AVI (mpeg4/mp3) without video transcoding? I have got quite a few of them, and they only started playing after I added a matching rule for mpeg4/mp3 to the transcode-anything-the-tv-can't-play-to-mpeg2/ac3 section of the profile.
CU,
Low
Post Mon Oct 31, 2011 1:05 pm
That was the outcome of 0.6 beta. NX3 might shed some light on it.
NX3
Post Wed Nov 02, 2011 8:04 pm
Lowlander wrote:Should the 0.6 Bravia 2011 profile be able to handle AVI (mpeg4/mp3) without video transcoding? I have got quite a few of them, and they only started playing after I added a matching rule for mpeg4/mp3 to the transcode-anything-the-tv-can't-play-to-mpeg2/ac3 section of the profile.
To full understand, these aren't xvid or divx video codec AVI but mpeg4 something ? Can you clarify exactly what codec ? All the AVI's I have are xvid with mp3 but I had some test samples of other and they are working well with the 2011 profile.
NX3
Post Wed Nov 02, 2011 8:36 pm
Illico wrote:I would like to modify the 0.6.1 version of "Sony TV 2011" profile to allow MP4 playing natively... (MP4 / H264 / AAC)
So I comment some lines
<!-- <Matches container="mp4" vCodec="h264" /> -->
<!-- <Matches container="mp4" /> -->
Mp4/h264 with ac3 audio is not supported so the following line is kept:
<Matches container="mp4" vCodec="h264" aCodec="ac3" />
So please, could you modify the profiles.xml file with my previous modify profile, found a MP4/H264/AAC sample and test with your 2011 TV model.
EDIT: for example; : TINTIN Teaser 480p, 720p and 1080p
I tried to play the 480p and 1080p TinTin trailer before the changes, listed as AVC and played. I then made the changes, rebooted the server for good measure and tried again. Both are listed as AVC again and play.... How can I tell is Serviio is doing anything different as from the tv end, its the same ?
Post Thu Nov 03, 2011 8:12 am
NX3 wrote:I tried to play the 480p and 1080p TinTin trailer before the changes, listed as AVC and played. I then made the changes, rebooted the server for good measure and tried again. Both are listed as AVC again and play.... How can I tell is Serviio is doing anything different as from the tv end, its the same ?
Good new, could you check the log file to confirm that MP4/AVC/AAC are delivered in native format? (so aac audio track in fist position is not a problem for Sony TV?)
NX3
Post Thu Nov 03, 2011 8:10 pm
It says "delivering file in native format" :-)
Lowlander
Post Thu Nov 03, 2011 8:42 pm
NX3 wrote:To full understand, these aren't xvid or divx video codec AVI but mpeg4 something ?
Here's mediainfo's output for an avi that doesn't play with an unmodified 0.6 profile.
Complete name                    : T:\the-file-that-wouldn't-play-with-06-profile.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 350 MiB
Duration                         : 41mn 38s
Overall bit rate                 : 1 176 Kbps
Writing application              : transcode-1.0.4
Format                           : MPEG-4 Visual
Format profile                   : Advanced Simple@L5
Format settings, BVOP            : 2
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 41mn 38s
Bit rate                         : 994 Kbps
Width                            : 624 pixels
Height                           : 352 pixels
Frame rate                       : 29.970 fps
Bits/(Pixel*Frame)               : 0.151
Stream size                      : 296 MiB (84%)
Writing library                  : XviD 1.2.1 (UTC 2008-12-04)
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 41mn 38s
Bit rate mode                    : Variable
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
Stream size                      : 50.2 MiB (14%)
Alignment                        : Aligned on interleaves
Interleave, duration             : 24 ms (0.72 video frame)
After adding this line
<Matches container="avi" vCodec="mpeg4" />
to the existing
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384">
section, the file gets transcoded and plays. Just remuxing doesn't seem to do the trick.
Post Thu Nov 03, 2011 8:55 pm
Lowlander wrote:Here's mediainfo's output for an avi that doesn't play with an unmodified 0.6 profile.
Codec ID : XVID
to the existing
Could you check your avi file with that tools? http://www.videohelp.com/tools/DivFixPP
Lowlander
Post Fri Nov 04, 2011 9:41 am
DivFix doesn't show any errors.
villadude
Post Fri Nov 11, 2011 2:36 pm
I have the new Sony 46nx723 and am based in europe. The TV was released about a month ago here.
Had the same issue with certain avi files playing and others not playing on the profile "Sony TV - 2011".
Have changed it to "Sony TV" which transcodes all avi to be played well via transcoding. What am I missing out on? does transcoding decrease quality?
If you need me to do any tests or know what code to add to only transcode avi files but not mp4, please let me know.
Thank you..
Post Fri Nov 11, 2011 8:18 pm
villadude wrote:Had the same issue with certain avi files playing and others not playing on the profile "Sony TV - 2011".
Could you check with "MediaInfo" tools what are differences between files playing and others not playing?
you could post mediainfo results here.
NX3
Post Tue Nov 15, 2011 7:44 pm
I've come across some AVI's that seem to meet the specs to play but don't, "playback not available" message on the tv.
eneral
Complete name                    : file.avi
Format                           : AVI
File size                        : 175 MiB
Duration                         : 22mn 0s
Overall bit rate                 : 1 113 Kbps
Writing application              : transcode-1.0.6
Codec ID                         : XVID
Duration                         : 22mn 0s
Bit rate                         : 975 Kbps
Width                            : 624 pixels
Height                           : 352 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.185
Stream size                      : 154 MiB (88%)
Writing library                  : XviD 1.2.0SMP (UTC 2006-01-08)
Format                           : MPEG Audio
Mode                             : Joint stereo
Mode extension                   : MS Stereo
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 22mn 0s
Bit rate                         : 128 Kbps
Stream size                      : 19.6 MiB (11%)
Interleave, duration             : 24 ms (0.58 video frame)
Writing library                  : LAME3.90.
Encoding settings                : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
Whereas this one does work (these are tv series, all the same):
Format                           : AVI
File size                        : 174 MiB
Duration                         : 21mn 58s
Overall bit rate                 : 1 110 Kbps
Writing application              : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library                  : VirtualDubMod build 2540/release
Format settings, Matrix          : Default (MPEG)
Muxing mode                      : Packed bitstream
Codec ID                         : XVID
Duration                         : 21mn 58s
Bit rate                         : 954 Kbps
Width                            : 624 pixels
Height                           : 352 pixels
Bits/(Pixel*Frame)               : 0.181
Stream size                      : 150 MiB (86%)
Writing library                  : XviD 1.1.2 (UTC 2006-11-01)
Format                           : MPEG Audio
Mode                             : Joint stereo
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 21mn 58s
Bit rate                         : 144 Kbps
Minimum bit rate                 : 128 Kbps
Stream size                      : 22.6 MiB (13%)
Interleave, preload duration     : 128 ms
Writing library                  : LAME3.97
Encoding settings                : -m j -V 2 -q 3 -lowpass 18.6 --vbr-new -b 128
and the log from playing the problem file, I can't see an error ...
2011-11-15 21:01:03,200 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:03,201 DEBUG [VideoDeliveryEngine] Delivering file 'The Food Wife.avi' in native format
2011-11-15 21:01:03,201 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-11-15 21:01:03,205 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1) as read
2011-11-15 21:01:03,334 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-11-15 21:01:03,334 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 183650230
2011-11-15 21:01:03,334 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-15 21:01:03,335 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/avi,Content-Range: bytes 0-183650229/183650230,Content-Length: 183650230,Date: Tue, 15 Nov 2011 21:01:03 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-15 21:01:04,340 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-11-15 21:01:04,349 DEBUG [WebServer] Incoming connection from /192.168.1.240:46655
2011-11-15 21:01:04,349 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1/MEDIA_ITEM/AVI$0 HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";,Host: 192.168.1.101:8895]]
2011-11-15 21:01:04,350 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:04,351 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:04,351 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2011-11-15 21:01:04,352 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2011-11-15 21:01:04,352 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2011-11-15 21:01:04,353 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2011-11-15 21:01:04,355 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1, format AVI and profile Sony Bravia TV 2011
2011-11-15 21:01:04,356 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-11-15 21:01:04,356 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/avi,Content-Length: 183650230,Date: Tue, 15 Nov 2011 21:01:04 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-15 21:01:04,367 DEBUG [WebServer] Incoming connection from /192.168.1.240:46656
2011-11-15 21:01:04,367 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM/AVI$0 HTTP/1.1, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";,Host: 192.168.1.101:8895]]
2011-11-15 21:01:04,367 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:04,369 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:04,369 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2011-11-15 21:01:04,369 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2011-11-15 21:01:04,369 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2011-11-15 21:01:04,371 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2011-11-15 21:01:04,373 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:04,374 DEBUG [VideoDeliveryEngine] Delivering file 'The Food Wife.avi' in native format
2011-11-15 21:01:04,374 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-11-15 21:01:04,378 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1) as read
2011-11-15 21:01:04,552 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-11-15 21:01:04,553 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 183650230
2011-11-15 21:01:04,553 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-15 21:01:04,553 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/avi,Content-Range: bytes 0-183650229/183650230,Content-Length: 183650230,Date: Tue, 15 Nov 2011 21:01:04 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-15 21:01:05,558 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-11-15 21:01:05,757 DEBUG [WebServer] Incoming connection from /192.168.1.240:46657
2011-11-15 21:01:05,764 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1/MEDIA_ITEM/AVI$0 HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";,Host: 192.168.1.101:8895]]
2011-11-15 21:01:05,764 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:05,766 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:05,766 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2011-11-15 21:01:05,766 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2011-11-15 21:01:05,766 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2011-11-15 21:01:05,768 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2011-11-15 21:01:05,770 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1, format AVI and profile Sony Bravia TV 2011
2011-11-15 21:01:05,770 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-11-15 21:01:05,771 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/avi,Content-Length: 183650230,Date: Tue, 15 Nov 2011 21:01:05 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-15 21:01:05,783 DEBUG [WebServer] Incoming connection from /192.168.1.240:46658
2011-11-15 21:01:05,784 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM/AVI$0 HTTP/1.1, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";,Host: 192.168.1.101:8895]]
2011-11-15 21:01:05,784 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:05,786 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:05,786 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2011-11-15 21:01:05,786 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2011-11-15 21:01:05,786 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2011-11-15 21:01:05,788 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2011-11-15 21:01:05,790 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:05,790 DEBUG [VideoDeliveryEngine] Delivering file 'The Food Wife.avi' in native format
2011-11-15 21:01:05,790 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-11-15 21:01:05,794 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1) as read
2011-11-15 21:01:05,804 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-11-15 21:01:05,804 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 183650230
2011-11-15 21:01:05,804 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-15 21:01:05,804 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/avi,Content-Range: bytes 0-183650229/183650230,Content-Length: 183650230,Date: Tue, 15 Nov 2011 21:01:05 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-15 21:01:05,927 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2011-11-15 21:01:05,945 DEBUG [WebServer] Incoming connection from /192.168.1.240:46659
2011-11-15 21:01:05,945 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM/AVI$0 HTTP/1.1, headers = [Range: bytes=2036-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";,Host: 192.168.1.101:8895]]
2011-11-15 21:01:05,945 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:05,946 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:05,946 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2011-11-15 21:01:05,946 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2011-11-15 21:01:05,946 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2011-11-15 21:01:05,947 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2011-11-15 21:01:05,948 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:05,948 DEBUG [VideoDeliveryEngine] Delivering file 'The Food Wife.avi' in native format
2011-11-15 21:01:05,948 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-11-15 21:01:05,951 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 183648194
2011-11-15 21:01:05,951 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-15 21:01:05,951 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/avi,Content-Range: bytes 2036-183650229/183650230,Content-Length: 183648194,Date: Tue, 15 Nov 2011 21:01:05 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-15 21:01:06,077 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2011-11-15 21:01:06,092 DEBUG [WebServer] Incoming connection from /192.168.1.240:46660
2011-11-15 21:01:06,094 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM/AVI$0 HTTP/1.1, headers = [Range: bytes=182263246-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";,Host: 192.168.1.101:8895]]
2011-11-15 21:01:06,094 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:06,095 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:06,096 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2011-11-15 21:01:06,096 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2011-11-15 21:01:06,096 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2011-11-15 21:01:06,097 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2011-11-15 21:01:06,099 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:06,100 DEBUG [VideoDeliveryEngine] Delivering file 'The Food Wife.avi' in native format
2011-11-15 21:01:06,100 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-11-15 21:01:06,104 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1386984
2011-11-15 21:01:06,104 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-15 21:01:06,104 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/avi,Content-Range: bytes 182263246-183650229/183650230,Content-Length: 1386984,Date: Tue, 15 Nov 2011 21:01:06 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-15 21:01:06,624 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM/AVI$0 HTTP/1.1, headers = [Range: bytes=4092-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";,Host: 192.168.1.101:8895]]
2011-11-15 21:01:06,624 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:06,625 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:06,626 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2011-11-15 21:01:06,626 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2011-11-15 21:01:06,626 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2011-11-15 21:01:06,628 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2011-11-15 21:01:06,630 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:06,630 DEBUG [VideoDeliveryEngine] Delivering file 'The Food Wife.avi' in native format
2011-11-15 21:01:06,630 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-11-15 21:01:06,634 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 183646138
2011-11-15 21:01:06,634 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-15 21:01:06,634 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/avi,Content-Range: bytes 4092-183650229/183650230,Content-Length: 183646138,Date: Tue, 15 Nov 2011 21:01:06 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-15 21:01:10,334 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2011-11-15 21:01:10,370 DEBUG [WebServer] Incoming connection from /192.168.1.240:46661
2011-11-15 21:01:10,370 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM/AVI$0 HTTP/1.1, headers = [Range: bytes=4092-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";,Host: 192.168.1.101:8895]]
2011-11-15 21:01:10,371 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:10,373 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:10,373 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2011-11-15 21:01:10,373 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2011-11-15 21:01:10,373 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2011-11-15 21:01:10,376 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2011-11-15 21:01:10,379 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/192.168.1.240, Profile=Sony Bravia TV 2011'
2011-11-15 21:01:10,379 DEBUG [VideoDeliveryEngine] Delivering file The Food Wife.avi' in native format
2011-11-15 21:01:10,379 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2011-11-15 21:01:10,385 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 183646138
2011-11-15 21:01:10,385 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-11-15 21:01:10,385 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/avi,Content-Range: bytes 4092-183650229/183650230,Content-Length: 183646138,Date: Tue, 15 Nov 2011 21:01:10 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-11-15 21:01:11,644 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-11-15 21:01:11,648 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2011-11-15 21:01:11,650 DEBUG [FeedCacheDecorator] Found entry in the cache (online_feeds), returning it
2011-11-15 21:01:11,655 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2011-11-15 21:01:11,657 DEBUG [FeedCacheDecorator] Found entry in the cache (online_feeds), returning it
2011-11-15 21:01:11,664 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 3)
2011-11-15 21:01:11,665 DEBUG [FeedCacheDecorator] Found entry in the cache (online_feeds), returning it
2011-11-15 21:01:15,664 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-11-15 21:01:22,074 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)) and address 192.168.1.101, timeout = 0
2011-11-15 21:01:22,075 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 29e0c7b2-e2bf-3f96-91e2-08c360085651
2011-11-15 21:01:22,796 DEBUG [WebServer] Incoming connection from /192.168.1.240:46662
2011-11-15 21:01:22,797 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 29e0c7b2-e2bf-3f96-91e2-08c360085651 from 192.168.1.240 (headers = [Host: 192.168.1.101:8895,Date: Tue, 15 Nov 2011 21:01:20 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";])
2011-11-15 21:01:22,797 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:22,799 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.101:8895,Date: Tue, 15 Nov 2011 21:01:20 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";]
2011-11-15 21:01:22,800 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:22,804 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV 2011'
2011-11-15 21:01:22,833 DEBUG [WebServer] Incoming connection from /192.168.1.240:46663
2011-11-15 21:01:22,833 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-11-15 21:01:22,835 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-11-15 21:01:22,860 DEBUG [WebServer] Incoming connection from /192.168.1.240:46664
2011-11-15 21:01:22,860 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-11-15 21:01:22,863 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-11-15 21:01:22,889 DEBUG [WebServer] Incoming connection from /192.168.1.240:46665
2011-11-15 21:01:22,890 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.240:
2011-11-15 21:01:22,890 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:23,109 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-15 21:01:23,120 DEBUG [WebServer] Incoming connection from /192.168.1.240:46666
2011-11-15 21:01:23,121 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.240:
2011-11-15 21:01:23,121 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:23,331 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV 2011'
2011-11-15 21:01:23,343 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-15 21:01:23,415 DEBUG [WebServer] Incoming connection from /192.168.1.240:46667
2011-11-15 21:01:23,416 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 29e0c7b2-e2bf-3f96-91e2-08c360085651 from 192.168.1.240 (headers = [Host: 192.168.1.101:8895,Date: Tue, 15 Nov 2011 21:01:21 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";])
2011-11-15 21:01:23,417 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:23,418 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.101:8895,Date: Tue, 15 Nov 2011 21:01:21 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-26EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-26EX320"; mv="1.7";]
2011-11-15 21:01:23,419 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:23,421 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV 2011'
2011-11-15 21:01:23,450 DEBUG [WebServer] Incoming connection from /192.168.1.240:46668
2011-11-15 21:01:23,451 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2011-11-15 21:01:23,451 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-11-15 21:01:23,478 DEBUG [WebServer] Incoming connection from /192.168.1.240:46669
2011-11-15 21:01:23,478 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-11-15 21:01:23,479 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-11-15 21:01:23,509 DEBUG [WebServer] Incoming connection from /192.168.1.240:46670
2011-11-15 21:01:23,510 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.240:
2011-11-15 21:01:23,510 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:23,723 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-15 21:01:23,737 DEBUG [WebServer] Incoming connection from /192.168.1.240:46671
2011-11-15 21:01:23,738 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.240:
2011-11-15 21:01:23,738 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.240
2011-11-15 21:01:23,876 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:03
2011-11-15 21:01:23,949 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV 2011'
2011-11-15 21:01:23,970 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-15 21:02:11,672 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-11-15 21:02:11,674 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2011-11-15 21:02:11,675 DEBUG [FeedCacheDecorator] Found entry in the cache (online_feeds), returning it
2011-11-15 21:02:11,679 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2011-11-15 21:02:11,681 DEBUG [FeedCacheDecorator] Found entry in the cache (online_feeds), returning it
2011-11-15 21:02:11,686 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 3)
2011-11-15 21:02:11,688 DEBUG [FeedCacheDecorator] Found entry in the cache (online_feeds), returning it
gshodg
Post Wed Nov 16, 2011 2:22 pm
Hi I'm a newbie, have read the threads, but cannot work out what to edit to make the following AVI file playable to a Sony Bravia 2001 Series (the model is KDL-40EX524), I get the error "playback not available" on the TV. Other .AVI files have played, as have .MKV files.
Here's the code from the FFmpeg.exe:
I:\Program Files\Serviio\lib>ffmpeg.exe -i "I:\Documents and Settings\dell\My Do
cuments\My Videos\Bridesmaids\Bridesmaids 2011.avi"
nfig
[mpeg4 @ 0177a700] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'I:\Documents and Settings\dell\My Documents\My Videos\Bride
smaids\Bridesmaids 2011.avi':
    encoder         : VirtualDubMod 1.5.10.3 | www.virtualdub-fr.org || (build 2
550/release)
  Duration: 02:10:17.81, start: 0.000000, bitrate: 3859 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 1280x536 [PAR 1:1 DAR 160:67], 23.98 tbr
, 23.98 tbn, 23.98 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Do I need to provide further info, or could you help with what I've provided above? Many thanks.
Post Wed Nov 16, 2011 2:35 pm
NX3 wrote:I've come across some AVI's that seem to meet the specs to play but don't, "playback not available" message on the tv.
But there were some differences for the video stream:
    BAD
- Writing application : transcode-1.0.6
- Writing library : XviD 1.2.0
- Format settings, Matrix : Default (H.263)
- Muxing mode: n/a
    OK
- Writing application : VirtualDubMod 1.5.10.2
- Writing library : XviD 1.1.2
- Format settings, Matrix : Default (MPEG)
- Muxing mode : Packed bitstream
You could found some other samples and look at these values.
Post Wed Nov 16, 2011 2:36 pm
gshodg wrote:Do I need to provide further info, or could you help with what I've provided above? Many thanks.
Yes please, could you also provide "MediaInfo" tool result from the same file (see my signature links)?
