rtve.es
Post Wed Nov 16, 2011 6:41 pm
rtve.es
Plugin for rtve.es
Created 16/11/2011
RTVE.groovy
(2.54 KiB) Downloaded 2207 times
Vintila
Post Thu Nov 17, 2011 10:45 am
Re: rtve.es
Thanks a thillion!
nachotheix
Post Thu Nov 17, 2011 10:03 pm
Re: rtve.es
I'm testing this URL
http://www.rtve.es/api/programas/1705/contents.mrss
but Online Feed folder appear empty.
Serviio: 0.6 (MacOS)
TV: Samsung 37C6000
and plugin has been added correctly
2011-11-17 18:32:27,870 INFO [PluginCompilerThread] Added plugin RTVE (RTVE.groovy)
Vintila
Post Thu Nov 17, 2011 10:13 pm
Re: rtve.es
Post Thu Nov 17, 2011 10:58 pm
Re: rtve.es
Yep, the feed is a bit weird, they keep the thumbnail in enclosure element so Serviio thinks it's image feed. 0.6.1 will fix this.
nachotheix
Post Fri Nov 18, 2011 12:07 am
Re: rtve.es
Ok ... that links work ok ... good work.
but TVE website has a lot of media content in this format
http://www.rtve.es/api/programas/1705/multimedias.rss --> Redes (http://www.rtve.es/alacarta/videos/redes/)
http://www.rtve.es/api/programas/29010/multimedias.rss --> Aguila Roja (http://www.rtve.es/alacarta/videos/aguila-roja/)
http://www.rtve.es/api/programas/11332/multimedias.rss --> Comando Actualidad
http://www.rtve.es/api/programas/1573/multimedias.rss --> Cuentame
http://www.rtve.es/api/programas/1631/multimedias.rss --> Informe Semanal
etc .. etc.. etc..
and if I put these links, in my TV i only see empty folders.
Why?
Thanks in advance for your attention.
Post Fri Nov 18, 2011 12:12 am
Re: rtve.es
as per my previous reply
Vintila
Post Fri Jan 06, 2012 11:50 pm
Re: rtve.es
zip wrote:Yep, the feed is a bit weird, they keep the thumbnail in enclosure element so Serviio thinks it's image feed. 0.6.1 will fix this.
True!
Tested the links and now all of them work!..
Many thanks and keep up the good work!
felipito
Post Sat Jan 07, 2012 6:35 am
Re: rtve.es
Hi everyone, I am totally newbie with serviio and I have a question on this groovy. :? Does it work only for the "redes" show ? Do I have to modify it to get other shows from rtve? Thnx
Post Sat Jan 07, 2012 8:42 am
Re: rtve.es
no modding of groovy is required it supports all rtve shows. :) just add relevent rss for your show to console.
XoXe
Post Thu Jun 07, 2012 6:42 pm
Re: rtve.es
Hello, i copied this groovy to the plugins directory, but how does it work?
How do you start this plugin?
Serviio -> Samsung LE32C550
ignasigarcia
Post Wed Jul 11, 2012 12:28 pm
Re: rtve.es
Hi there. I'm unable to make this plugin work. I've tried first using the official rss urls from rtve's page without any success. Then, based on user contribution to this forum I've tried other urls, all without success. Could anybody confirm that this plugin still works? BTW, I'm using Serviio 0.6.2 under Debian.
Thanks in advance.
Ignacio
Post Thu Jul 12, 2012 8:32 am
Re: rtve.es
do you have any errors in the log?
ignasigarcia
Post Mon Jul 16, 2012 8:52 pm
Re: rtve.es
Sorry I could not answer before.
This is what I did:
I had my plugin enabled as it looks in my log:
2012-07-16 22:49:23,038 INFO [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy)
Then I added a feed with this URL:
http://www.rtve.es/api/programas/45030/contents.mrss
However, the feed is empty, and also the log shows nothing after adding this feed.
Thanks in advance,
Ignacio
Luilly
Post Tue Jun 24, 2014 4:43 pm
Re: rtve.es
Hello.
This plugin doesn't work.
It should be necessary to rewrite it like xbmc plugin:
https://xbmc-tvalacarta.googlecode.com/svn/trunk/tvalacarta/tvalacarta/channels/rtve.py
Can anybody help me?
Thank you and regards.
Return to Available plugins
