Sony 46CX520 avi and mkv playback issues
term4
Post Thu Nov 24, 2011 11:08 pm
Have probs playing avi files (divx and xvid) if the filesize is larger than 700mb
Also i can play 720p mkv files without problems, but when i want to play 1080p it says "Temporary cannot access the server. Please retry."
I retried few times and same message appears all over again
Post Fri Nov 25, 2011 11:00 am
Re: Sony 46CX520 avi and mkv playback issues
term4
Post Fri Nov 25, 2011 12:03 pm
MKV file
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Faruk>cd "\Program Files (x86)\Serviio\lib
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "D:\mtorrent\Transformers trilo
gy (2007-2011) 1080 multi [mkvonly]\2009 Transformers Revenge of the Fallen [mkv
only].mkv"
nfig
[matroska,webm @ 017e8d20] max_analyze_duration 5000000 reached at 5000000
[matroska,webm @ 017e8d20] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (18
0000/1) -> 1000.00 (1000/1)
Input #0, matroska,webm, from 'D:\mtorrent\Transformers trilogy (2007-2011) 1080
 multi [mkvonly]\2009 Transformers Revenge of the Fallen [mkvonly].mkv':
  Duration: 02:29:53.02, start: 0.000000, bitrate: 1536 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x800, PAR 1:1 DAR 12:5, 2
3.97 fps, 1k tbr, 1k tbn, 180k tbc (default)
      title           : 2009 Transformers Revenge of the Fallen [mkvonly]
    Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default)
    Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000 (default)
      title           : sdh
    Stream #0.3(eng): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.4(dan): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.5(dut): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.6(fin): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.7(fre): Subtitle: [0][0][0][0] / 0x0000
      title           : forced
    Stream #0.8(fre): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.9(ger): Subtitle: [0][0][0][0] / 0x0000
      title           : forced
    Stream #0.10(ger): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.11(hun): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.12(ita): Subtitle: [0][0][0][0] / 0x0000
      title           : forced
    Stream #0.13(ita): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.14(nor): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.15(spa): Subtitle: [0][0][0][0] / 0x0000
      title           : forced
    Stream #0.16(spa): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.17(swe): Subtitle: [0][0][0][0] / 0x0000
mediainfo
Unique ID                        : 221544308593372972729478026035528308260 (0xA6ABE1BD2D2F3FA3879D354ED8519624)
Complete name                    : D:\mtorrent\Transformers trilogy (2007-2011) 1080 multi [mkvonly]\2009 Transformers Revenge of the Fallen [mkvonly].mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 7.13 GiB
Duration                         : 2h 29mn
Overall bit rate                 : 6 809 Kbps
Encoded date                     : UTC 2011-10-14 22:52:39
Writing application              : mkvmerge v4.0.0 ('The Stars were mine') built on Jun  5 2010 17:44:09
Writing library                  : libebml v1.0.0 + libmatroska v1.0.0
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 2h 29mn
Bit rate                         : 5 300 Kbps
Width                            : 1 920 pixels
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Frame rate mode                  : Variable
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.144
Stream size                      : 5.41 GiB (76%)
Title                            : 2009 Transformers Revenge of the Fallen [mkvonly]
Writing library                  : x264 core 88
Encoding settings                : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=5300 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Default                          : Yes
Forced                           : No
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 2h 29mn
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 24 bits
Stream size                      : 1.58 GiB (22%)
Language                         : English
Default                          : Yes
Forced                           : No
Text #1
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Title                            : sdh
Language                         : English
Default                          : Yes
Forced                           : No
Text #2
Format                           : UTF-8
Language                         : English
Default                          : No
Forced                           : No
Text #3
Format                           : UTF-8
Language                         : Danish
Default                          : No
Forced                           : No
Text #4
Format                           : UTF-8
Language                         : Dutch
Default                          : No
Forced                           : No
Text #5
Format                           : UTF-8
Language                         : Finnish
Default                          : No
Forced                           : No
Text #6
Format                           : UTF-8
Title                            : forced
Language                         : French
Default                          : No
Forced                           : No
Text #7
Format                           : UTF-8
Language                         : French
Default                          : No
Forced                           : No
Text #8
Format                           : UTF-8
Title                            : forced
Language                         : German
Default                          : No
Forced                           : No
Text #9
Format                           : UTF-8
Language                         : German
Default                          : No
Forced                           : No
Text #10
Format                           : UTF-8
Language                         : Hungarian
Default                          : No
Forced                           : No
Text #11
Format                           : UTF-8
Title                            : forced
Language                         : Italian
Default                          : No
Forced                           : No
Text #12
Format                           : UTF-8
Language                         : Italian
Default                          : No
Forced                           : No
Text #13
Format                           : UTF-8
Language                         : Norwegian
Default                          : No
Forced                           : No
Text #14
Format                           : UTF-8
Title                            : forced
Language                         : Spanish
Default                          : No
Forced                           : No
Text #15
Format                           : UTF-8
Language                         : Spanish
Default                          : No
Forced                           : No
Text #16
Format                           : UTF-8
Language                         : Swedish
Default                          : No
Forced                           : No
AVI file
ffmpeg info
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "D:\mtorrent\Cars 2\Cars 2.avi"
nfig
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/
2733) -> 23.98 (2500000/104271)
Input #0, avi, from 'D:\mtorrent\Cars 2\Cars 2.avi':
    encoder         : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50
    JUNK            :
  Duration: 01:47:01.42, start: 0.000000, bitrate: 2019 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 720x304 [PAR 1:1 DAR 45:19], 23.98 tbr,
23.98 tbn, 23.98 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
mediainfo
Complete name                    : D:\mtorrent\Cars 2\Cars 2.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
Format profile                   : OpenDML
Format settings                  : rec
File size                        : 1.51 GiB
Duration                         : 1h 47mn
Overall bit rate                 : 2 020 Kbps
Writing application              : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50
Format                           : MPEG-4 Visual
Format profile                   : Advanced Simple@L5
Format settings, BVOP            : 2
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Custom
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 1h 47mn
Bit rate                         : 1 631 Kbps
Width                            : 720 pixels
Height                           : 304 pixels
Display aspect ratio             : 2.35:1
Bits/(Pixel*Frame)               : 0.311
Stream size                      : 1.22 GiB (81%)
Writing library                  : XviD 58
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : 2000
Duration                         : 1h 46mn
Bit rate                         : 384 Kbps
Bit depth                        : 16 bits
Stream size                      : 293 MiB (19%)
Alignment                        : Aligned on interleaves
Interleave, duration             : 64 ms (1.54 video frames)
Interleave, preload duration     : 192 ms
Post Fri Nov 25, 2011 12:19 pm
term4 wrote:MKV file:
Format : Matroska
Height : 800 pixels
The maximum H264/AVC profile level supported is L4.1, your movie is very close to 5.0 : http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
You have too many Sub stream. Could you remux this file with MkvToolnixtools by removing the extra tracks?
term4 wrote:AVI file
Format : AVI
Codec ID : XVID
Width : 720 pixels
Height : 304 pixels
Format : AC-3
Not sure that AVI container with AC3 audio is supported, should be MP3.
term4
Post Fri Nov 25, 2011 12:35 pm
what to do when tracks are removed? want me to post information again?
when i add this file to tsmuxer it shows 4.0 :) if that matters anything lol
about that ac3 thingy, is it possible for servio to recognize those files somehow and transcode them?
Post Fri Nov 25, 2011 1:11 pm
term4 wrote:what to do when tracks are removed? want me to post information again?
Ooups, sorry make a mistake, mkv are remuxed into mpegts with "Sony 2011 profile", and DTS audio is encoded into AC3 and Sub are ignored.
Could you check the detailed logging file (see signature link) ? I think ffmpeg crashed.
term4 wrote:when i add this file to tsmuxer it shows 4.0 :) if that matters anything lol
This information is stored in the AVC header, so tsmuxer checkout it. Its probably not the problem for this file.
term4 wrote:about that ac3 thingy, is it possible for servio to recognize those files somehow and transcode them?
Yes, you can edit the profiles.xml (Sony Bravia 2011 section) like this
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="192">
            <Matches container="avi" aCodec="ac3 />
            <Matches container="asf" />
            <Matches container="mp4" />
            <Matches container="flv" />
            <Matches container="wtv" />
            <Matches container="ogg" />
