Sony 46CX520 avi and mkv playback issues
Also i can play 720p mkv files without problems, but when i want to play 1080p it says "Temporary cannot access the server. Please retry."
I retried few times and same message appears all over again
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Faruk>cd "\Program Files (x86)\Serviio\lib
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "D:\mtorrent\Transformers trilo
gy (2007-2011) 1080 multi [mkvonly]\2009 Transformers Revenge of the Fallen [mkv
only].mkv"
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
[matroska,webm @ 017e8d20] max_analyze_duration 5000000 reached at 5000000
[matroska,webm @ 017e8d20] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (18
0000/1) -> 1000.00 (1000/1)
Input #0, matroska,webm, from 'D:\mtorrent\Transformers trilogy (2007-2011) 1080
multi [mkvonly]\2009 Transformers Revenge of the Fallen [mkvonly].mkv':
Duration: 02:29:53.02, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x800, PAR 1:1 DAR 12:5, 2
3.97 fps, 1k tbr, 1k tbn, 180k tbc (default)
title : 2009 Transformers Revenge of the Fallen [mkvonly]
Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default)
Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000 (default)
title : sdh
Stream #0.3(eng): Subtitle: [0][0][0][0] / 0x0000
Stream #0.4(dan): Subtitle: [0][0][0][0] / 0x0000
Stream #0.5(dut): Subtitle: [0][0][0][0] / 0x0000
Stream #0.6(fin): Subtitle: [0][0][0][0] / 0x0000
Stream #0.7(fre): Subtitle: [0][0][0][0] / 0x0000
title : forced
Stream #0.8(fre): Subtitle: [0][0][0][0] / 0x0000
Stream #0.9(ger): Subtitle: [0][0][0][0] / 0x0000
title : forced
Stream #0.10(ger): Subtitle: [0][0][0][0] / 0x0000
Stream #0.11(hun): Subtitle: [0][0][0][0] / 0x0000
Stream #0.12(ita): Subtitle: [0][0][0][0] / 0x0000
title : forced
Stream #0.13(ita): Subtitle: [0][0][0][0] / 0x0000
Stream #0.14(nor): Subtitle: [0][0][0][0] / 0x0000
Stream #0.15(spa): Subtitle: [0][0][0][0] / 0x0000
title : forced
Stream #0.16(spa): Subtitle: [0][0][0][0] / 0x0000
Stream #0.17(swe): Subtitle: [0][0][0][0] / 0x0000
C:\Program Files (x86)\Serviio\lib>General
Unique ID : 221544308593372972729478026035528308260 (0xA6ABE1BD2D2F3FA3879D354ED8519624)
Complete name : D:\mtorrent\Transformers trilogy (2007-2011) 1080 multi [mkvonly]\2009 Transformers Revenge of the Fallen [mkvonly].mkv
Format : Matroska
Format version : Version 2
File size : 7.13 GiB
Duration : 2h 29mn
Overall bit rate : 6 809 Kbps
Encoded date : UTC 2011-10-14 22:52:39
Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 5 2010 17:44:09
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 29mn
Bit rate : 5 300 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Variable
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.144
Stream size : 5.41 GiB (76%)
Title : 2009 Transformers Revenge of the Fallen [mkvonly]
Writing library : x264 core 88
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=5300 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format : DTS
Codec ID : A_DTS
Duration : 2h 29mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.58 GiB (22%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : sdh
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Language : Danish
Default : No
Forced : No
Text #4
Format : UTF-8
Language : Dutch
Default : No
Forced : No
Text #5
Format : UTF-8
Language : Finnish
Default : No
Forced : No
Text #6
Format : UTF-8
Title : forced
Language : French
Default : No
Forced : No
Text #7
Format : UTF-8
Language : French
Default : No
Forced : No
Text #8
Format : UTF-8
Title : forced
Language : German
Default : No
Forced : No
Text #9
Format : UTF-8
Language : German
Default : No
Forced : No
Text #10
Format : UTF-8
Language : Hungarian
Default : No
Forced : No
Text #11
Format : UTF-8
Title : forced
Language : Italian
Default : No
Forced : No
Text #12
Format : UTF-8
Language : Italian
Default : No
Forced : No
Text #13
Format : UTF-8
Language : Norwegian
Default : No
Forced : No
Text #14
Format : UTF-8
Title : forced
Language : Spanish
Default : No
Forced : No
Text #15
Format : UTF-8
Language : Spanish
Default : No
Forced : No
Text #16
Format : UTF-8
Language : Swedish
Default : No
Forced : NoMicrosoft Windows [Version 6.1.7601]
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "D:\mtorrent\Cars 2\Cars 2.avi"
nfig
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/
2733) -> 23.98 (2500000/104271)
Input #0, avi, from 'D:\mtorrent\Cars 2\Cars 2.avi':
encoder : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50
JUNK :
Duration: 01:47:01.42, start: 0.000000, bitrate: 2019 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 720x304 [PAR 1:1 DAR 45:19], 23.98 tbr,
23.98 tbn, 23.98 tbc
Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
Complete name : D:\mtorrent\Cars 2\Cars 2.avi
Format : AVI
Format profile : OpenDML
Format settings : rec
File size : 1.51 GiB
Duration : 1h 47mn
Overall bit rate : 2 020 Kbps
Writing application : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 47mn
Bit rate : 1 631 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.311
Stream size : 1.22 GiB (81%)
Writing library : XviD 58
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 46mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 293 MiB (19%)
Alignment : Aligned on interleaves
Interleave, duration : 64 ms (1.54 video frames)
Interleave, preload duration : 192 ms
term4 wrote:MKV file:
Format : Matroska
Height : 800 pixels
term4 wrote:AVI file
Format : AVI
Codec ID : XVID
Width : 720 pixels
Height : 304 pixels
Format : AC-3
term4 wrote:what to do when tracks are removed? want me to post information again?
term4 wrote:when i add this file to tsmuxer it shows 4.0if that matters anything lol
term4 wrote:about that ac3 thingy, is it possible for servio to recognize those files somehow and transcode them?
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="192">
<Matches container="avi" aCodec="ac3 />
<Matches container="asf" />
<Matches container="mp4" />
<Matches container="flv" />
<Matches container="wtv" />
<Matches container="ogg" />
</Video>Users browsing this forum: No registered users and 39 guests
