Samsung BD-D6900M MKV's are an unsupported format
bouncy
Post Wed Nov 30, 2011 7:36 pm
I am just wondering if anyone can help me. I have just bought a BD-D6900M bluray player with smart hub, and ensured it is up to date. Whenever I attempt to play MKV files, it advises me that im trying to play an unsupported format. If i play the same mkv file on my Samsung UE40D7000, the same MKV file plays fine. I have noticed in the servio console, it states that the device is unknown, so i have changed it to Samsung TV/Player C/D however this has not corrected the issue. My Samsung D7000 is recognised fine in the Servio Console. Im guessing this is a profile issue, unfortunately I have no experience with these profiles, so cannot correct it myself.
Can anyone help???/
Brian
Post Wed Nov 30, 2011 7:53 pm
Re: Samsung BD-D6900M MKV's are an unsupported format
Can you post information on both what formats the device can play and information on the video. See signature for both.
bouncy
Post Wed Nov 30, 2011 9:52 pm
Im really sorry, but following the guide on the link, It does not have the urn:upnp-org:serviceId:ConnectionManager:1 service
Am i doing something wrong?
Post Wed Nov 30, 2011 9:55 pm
Did you have the machine on and in the DLNA mode when you tried? Some machines do not show up.
bouncy
Post Wed Nov 30, 2011 10:19 pm
i had the bluray player powered on, servio selected as its source, and at the menu where it displayed the folders that servio was presenting to it.
Post Wed Nov 30, 2011 10:58 pm
It plays the following. From http://certification.dlna.org/certs/REG23645541.pdf
Image - Play only
     JPEG_LRG
     JPEG_MED
     JPEG_SM
Audio - Play and Stop
     LPCM
     MP3
Video - Play and Stop
     MPEG_PS_NTSC
     MPEG_TS_SD_NA
     MPEG_TS_SD_NA_ISO
     MPEG_TS_SD_NA_T
This player is limited in what it can play via DLNA.
I would try the DirectTV profile since it transcodes everything.
To make a custom profile you will have to do the following.
You will need to edit the profiles.xml file per below.
You will need to copy the existing samsung c & d profile and paste it at the end of the file, renumber the profile to the next number.  And edit the new profile to transcode to one of the above.
bouncy
Post Thu Dec 01, 2011 7:55 am
ah so what your saying is that the player cannot play mkv's where the tv's can. how strange.
Again I know nothing about profiles, however does the Samsung C/D one not already do this?? It states it transcodes to mpegts which appears to be what you have advised is the format this player supports.
Post Thu Dec 01, 2011 8:43 am
bouncy wrote:Again I know nothing about profiles, however does the Samsung C/D one not already do this?? It states it transcodes to mpegts which appears to be what you have advised is the format this player supports.
Samsung C/D profile provides Matroska in native format (h264 with aac or ac3 audio)
<MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
only some no standard mkv are remuxed or transcoded
<Matches container="matroska" vCodec="vc1" />
Post Thu Dec 01, 2011 11:47 am
In the console try using the DirectTV profile and see if the MKV's play, from there we can customize a profile to work better.
bouncy
Post Thu Dec 01, 2011 3:18 pm
The direct tv profile does appear to work, albiet i dont think that surround sound is being passed to my amp via hdmi.
Post Thu Dec 01, 2011 3:26 pm
bouncy wrote:The direct tv profile does appear to work, albiet i dont think that surround sound is being passed to my amp via hdmi.
Ok this is a start then. Since the directTV profile transcodes everything, we will need to create a new profile and copy the directTV profile there. Once we have done that we can work on automatic selection and tweaking the profile to only transcode what has to be transcoded.
Can you profile the ffmpeg -i and mediatool information on one of the MKV's that are was not playing before selecting the directTV profile.
Can you also enable detailed logging and try and play something. What we are looking for in the log is the "Name" of the D6900M that serviio is seeing. This will allow us to do the automatic selection of the correct profile.
bouncy
Post Thu Dec 01, 2011 4:36 pm
i wont be able to until the weekend, but i really do appreciate the help.
still cant believe that this player doesnt play mkv's via dlna yet will play them over usb
Post Thu Dec 01, 2011 6:02 pm
bouncy wrote:still cant believe that this player doesnt play mkv's via dlna yet will play them over usb
This actually happens alot.
And you are welcome, that is what we are here for.
Post Thu Dec 01, 2011 8:26 pm
AFAIC all the D series are the same and use the same firmware.
You need to post the ffmpeg -i and mediainfo output for this file so we can figure out why the C/D profile is not doing the job for you. My BD-D5300 plays all my mkv's without problem but there are reasons some files need tweaks in the c/d profile, but without the file info no one can do the necessary analysis. Even better is to upload the file to a U/D service so we can test it for you.
Post Thu Dec 01, 2011 8:35 pm
I have a D5300 but all most all my files are in AVI format. I need to check mkv's on mine.
Post Thu Dec 01, 2011 9:28 pm
I meant 5300 for mine too
Post Fri Dec 02, 2011 9:09 am
moltra wrote:I need to check mkv's on mine.
Some mkv samples here (free download):
http://www.divx.com/en/electronics/solu ... on/divx-hd
Some other used by ffmpeg/Mplayer developpers
http://samples.mplayerhq.hu/Matroska/
Silka
Post Sat Jan 21, 2012 12:44 pm
i have BD-D6900, it plays MKV's just fine with transcoding turned OFF!
