Samsung BD-D6900M MKV's are an unsupported format
Can anyone help???/
Brian
To make a custom profile you will have to do the following.
You will need to edit the profiles.xml file per below.
You will need to copy the existing samsung c & d profile and paste it at the end of the file, renumber the profile to the next number. And edit the new profile to transcode to one of the above.bouncy wrote:Again I know nothing about profiles, however does the Samsung C/D one not already do this?? It states it transcodes to mpegts which appears to be what you have advised is the format this player supports.
bouncy wrote:The direct tv profile does appear to work, albiet i dont think that surround sound is being passed to my amp via hdmi.
bouncy wrote:still cant believe that this player doesnt play mkv's via dlna yet will play them over usb
moltra wrote:I need to check mkv's on mine.
