Wireless stream of 3D movies
• Page 2 of 2 • 1, 2
so i copied the file to a External HD and the same thing happened... so the problem is not serviio =)
Re: Wireless stream of 3D movies
SuperMiguel wrote:so i copied the file to a External HD and the same thing happened... so the problem is not serviio =)
any idea what the problem could be??
SuperMiguel wrote:any idea what the problem could be??
File not compliant or corrupt (VLC is very permissive and can play a lot of weird files).
Try to reencode original.
Illico wrote:SuperMiguel wrote:any idea what the problem could be??
You know of any Mac (OSX) program to reencode this type of file??
Try using google. With a little effort you can answer all of your questions.
jhb50 wrote:Try using google. With a little effort you can answer all of your questions.
i tried but i can't find any software to do that
here is where I go if I am looking for any video tool or information.
http://www.videohelp.com/tools
You did not try very hard.
A search using "how do i encode video" gives lots of answers.
Here are the generated Google and Dogpile result url's:
http://www.google.ca/search?sourceid=ie ... 0QHJmaXVDQ
http://www.dogpile.com/info.dogpl/searc ... code+video
