Wireless stream of 3D movies
SuperMiguel
Post Wed Nov 30, 2011 10:55 pm
Re: Wireless stream of 3D movies
so i copied the file to a External HD and the same thing happened... so the problem is not serviio =)
SuperMiguel
Post Thu Dec 01, 2011 5:49 am
SuperMiguel wrote:so i copied the file to a External HD and the same thing happened... so the problem is not serviio =)
any idea what the problem could be??
Post Thu Dec 01, 2011 8:39 am
SuperMiguel wrote:any idea what the problem could be??
File not compliant or corrupt (VLC is very permissive and can play a lot of weird files).
Try to reencode original.
SuperMiguel
Post Thu Dec 01, 2011 10:40 am
You know of any Mac (OSX) program to reencode this type of file??
Post Thu Dec 01, 2011 8:14 pm
Try using google. With a little effort you can answer all of your questions.
SuperMiguel
Post Thu Dec 01, 2011 10:19 pm
jhb50 wrote:Try using google. With a little effort you can answer all of your questions.
i tried but i can't find any software to do that :(
Post Thu Dec 01, 2011 10:36 pm
here is where I go if I am looking for any video tool or information.
http://www.videohelp.com/tools
Post Fri Dec 02, 2011 1:16 pm
You did not try very hard.
A search using "how do i encode video" gives lots of answers.
Here are the generated Google and Dogpile result url's:
http://www.google.ca/search?sourceid=ie ... 0QHJmaXVDQ
http://www.dogpile.com/info.dogpl/searc ... code+video
Previous
Users browsing this forum: Google [Bot] and 11 guests
