Help me before I loose my mind:(
Bjur
Post Thu Dec 01, 2011 11:31 am
I have desperately been trying to setup Serviio on my WHS 2011 without success. None of my other equipment discovers the DLNA server. I have been trying anything I can think of. Disabled the firewall etc.
The most annyoing thing is that if I install on my W7 client machine Serviio it discover my devices right away..
What can I do?
Post Thu Dec 01, 2011 12:01 pm
Re: Help me before I loose my mind:(
Can you post the serviio.log from the whs?
My device doesn't see Serviio
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
If you are on a Linux based OS, make sure you set up multicast routes properly.
If on Windows, you can push Serviio service down in starting order.
Bjur
Post Thu Dec 01, 2011 12:19 pm
The log is below. I REALLY hope you can help..
2011-12-01 13:14:40,635 INFO [MediaServer] ------------------------------------------------------------------------
2011-12-01 13:14:40,760 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.0.1 (rev. 8e4ee98bff12)
2011-12-01 13:14:40,760 INFO [MediaServer] Petr Nejedly 2009-2011
2011-12-01 13:14:40,760 INFO [MediaServer] http://www.serviio.org
2011-12-01 13:14:40,760 INFO [MediaServer] Java 1.6.0_29-Sun Microsystems Inc.
2011-12-01 13:14:40,760 INFO [MediaServer] OS Windows Server 2008 R2 amd64 6.1
2011-12-01 13:14:40,760 INFO [MediaServer] File encoding: windows-1252
2011-12-01 13:14:40,807 INFO [MediaServer] Headless mode enabled: true
2011-12-01 13:14:40,807 INFO [MediaServer] User home dir: C:\
2011-12-01 13:14:40,807 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2011-12-01 13:14:40,807 INFO [MediaServer] ------------------------------------------------------------------------
2011-12-01 13:14:44,457 INFO [RestletServer] Starting Restlet server exposed on port 23423
2011-12-01 13:14:45,799 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-12-01 13:15:05,424 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-12-01 13:15:06,547 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-12-01 13:15:06,921 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-12-01 13:15:07,108 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-12-01 13:15:07,233 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-12-01 13:15:07,327 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-12-01 13:15:07,420 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-12-01 13:15:07,654 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-12-01 13:15:07,686 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-12-01 13:15:07,888 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-12-01 13:15:08,169 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-12-01 13:15:08,263 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-12-01 13:15:08,341 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-12-01 13:15:08,372 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-12-01 13:15:08,388 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-12-01 13:15:08,434 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-12-01 13:15:08,450 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-12-01 13:15:08,497 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-12-01 13:15:08,653 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-12-01 13:15:08,793 INFO [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-12-01 13:15:08,949 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-12-01 13:15:09,074 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-12-01 13:15:09,090 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-12-01 13:15:09,090 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-12-01 13:15:09,105 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-01 13:15:09,105 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-12-01 13:15:09,105 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1322741709105, LastAccessTime = 1322741709105, getTimeToLiveSeconds() = -1, createTime = 1322741709105 ]
2011-12-01 13:15:09,183 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-12-01 13:15:09,183 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-01 13:15:09,183 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-12-01 13:15:09,183 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-01 13:15:09,183 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-12-01 13:15:09,183 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-12-01 13:15:09,183 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-01 13:15:09,183 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-12-01 13:15:09,183 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-12-01 13:15:09,183 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-12-01 13:15:09,183 INFO [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-12-01 13:15:09,183 INFO [CompositeCacheConfigurator] Finished configuration in 93 ms.
2011-12-01 13:15:09,745 INFO [WebServer] Socket buffer set to 65535 bytes
2011-12-01 13:15:09,760 INFO [Device] Created UPnP Device with UUID: 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65, bound address: 192.168.1.10
2011-12-01 13:15:10,041 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files (x86)\Serviio\bin\..\plugins
2011-12-01 13:15:10,041 INFO [PluginCompilerThread] Started looking for plugins
2011-12-01 13:15:11,008 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-12-01 13:15:11,211 INFO [WebServer] WebServer starting on port 8895
2011-12-01 13:15:11,258 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-12-01 13:15:11,274 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-12-01 13:15:11,274 INFO [EventDispatcher] Starting EventDispatcher
2011-12-01 13:15:11,320 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.10, timeout = 0
2011-12-01 13:15:11,336 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-12-01 13:15:11,336 INFO [RendererSearchSender] Searching for Renderer devices
2011-12-01 13:15:37,752 INFO [FeedUpdaterThread] Started looking for information about online feeds
2011-12-01 13:15:37,783 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-12-01 13:15:37,783 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-12-01 13:17:52,147 INFO [ServiioConsole] Starting Serviio Console
2011-12-01 13:17:56,055 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-12-01 13:18:03,883 INFO [Messages] Loaded console message bundle for locale: en
2011-12-01 13:18:05,345 INFO [Messages] Loaded console message bundle for locale: en
2011-12-01 13:18:05,462 INFO [UpdateChecker] Checking if a new version is available
2011-12-01 13:18:14,655 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-12-01 13:18:15,193 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
Post Thu Dec 01, 2011 1:14 pm
Did you verify that the ports was opened?
Can you try and ping the devices from the Server running WHS?
What are the IP addresses of your devices?
Bjur
Post Thu Dec 01, 2011 1:53 pm
moltra wrote:Did you verify that the ports was opened?
Hi again. I have completely disabled WHS 2011 Firewall and have no other Firewall installed. The closest is MSE.
I have also disabled SSDP service to get port 1900 free.
I have tried to ping 192.168.1.50 which is my Yahama receiver and I can ping it. No problem. The W7 client machines finds it with no problem in Serviio but not my WHS which is the important one.
I'm guessing it has something to do with ports. Perhaps port 1900 is occupied, but If I try netstat -abn I get the following on port 1900.
[svchost.exe]
TCP [::]:3587 [::]:0 LISTENING
p2pimsvc
[svchost.exe]
TCP [::]:5357 [::]:0 LISTENING
Can not obtain ownership information
TCP [::]:6602 [::]:0 LISTENING
[SMSvcHost.exe]
TCP [::]:9202 [::]:0 LISTENING
TCP [::]:47001 [::]:0 LISTENING
TCP [::]:49152 [::]:0 LISTENING
[wininit.exe]
TCP [::]:49153 [::]:0 LISTENING
eventlog
[svchost.exe]
TCP [::]:49154 [::]:0 LISTENING
Schedule
[svchost.exe]
TCP [::]:49155 [::]:0 LISTENING
[lsass.exe]
TCP [::]:49156 [::]:0 LISTENING
[certsrv.exe]
TCP [::]:49254 [::]:0 LISTENING
[services.exe]
TCP [::]:49255 [::]:0 LISTENING
PolicyAgent
[svchost.exe]
TCP [::]:49303 [::]:0 LISTENING
RPCHTTPLBS
[svchost.exe]
TCP [::]:65500 [::]:0 LISTENING
TCP [::]:65510 [::]:0 LISTENING
TCP [::]:65515 [::]:0 LISTENING
TCP [::]:65520 [::]:0 LISTENING
TCP [fe80::948c:6b1b:833:ad6%13]:445 [fe80::948c:6b1b:833:ad6%13]:49269 E
STABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:5357 [fe80::f96b:aca0:cc0d:5879%13]:54588
TIME_WAIT
TCP [fe80::948c:6b1b:833:ad6%13]:6602 [fe80::948c:6b1b:833:ad6%13]:49177
ESTABLISHED
[SMSvcHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:6602 [fe80::948c:6b1b:833:ad6%13]:49178
ESTABLISHED
[SMSvcHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:6602 [fe80::948c:6b1b:833:ad6%13]:49179
ESTABLISHED
[SMSvcHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:6602 [fe80::948c:6b1b:833:ad6%13]:49187
ESTABLISHED
[SMSvcHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:6602 [fe80::948c:6b1b:833:ad6%13]:49200
ESTABLISHED
[SMSvcHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:6602 [fe80::948c:6b1b:833:ad6%13]:49208
ESTABLISHED
[SMSvcHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:6602 [fe80::948c:6b1b:833:ad6%13]:49219
ESTABLISHED
[SMSvcHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:6602 [fe80::948c:6b1b:833:ad6%13]:49229
ESTABLISHED
[SMSvcHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:6602 [fe80::948c:6b1b:833:ad6%13]:49260
ESTABLISHED
[SMSvcHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:49177 [fe80::948c:6b1b:833:ad6%13]:6602
ESTABLISHED
[SharedServiceHost.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:49178 [fe80::948c:6b1b:833:ad6%13]:6602
ESTABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49179 [fe80::948c:6b1b:833:ad6%13]:6602
ESTABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49187 [fe80::948c:6b1b:833:ad6%13]:6602
ESTABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49200 [fe80::948c:6b1b:833:ad6%13]:6602
ESTABLISHED
[MediaStreamingProvider.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:49208 [fe80::948c:6b1b:833:ad6%13]:6602
ESTABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49219 [fe80::948c:6b1b:833:ad6%13]:6602
ESTABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49229 [fe80::948c:6b1b:833:ad6%13]:6602
ESTABLISHED
[storageservice.exe]
TCP [fe80::948c:6b1b:833:ad6%13]:49260 [fe80::948c:6b1b:833:ad6%13]:6602
ESTABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49269 [fe80::948c:6b1b:833:ad6%13]:445 E
STABLISHED
UDP 0.0.0.0:123 *:*
W32Time
[svchost.exe]
UDP 0.0.0.0:500 *:*
IKEEXT
[svchost.exe]
UDP 0.0.0.0:600 *:*
[DVBVservice.exe]
UDP 0.0.0.0:1645 *:*
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
UDP 0.0.0.0:1646 *:*
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
UDP 0.0.0.0:1812 *:*
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
UDP 0.0.0.0:1813 *:*
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
UDP 0.0.0.0:1900 *:*
[ServiioService.exe]
UDP 0.0.0.0:3544 *:*
iphlpsvc
[svchost.exe]
UDP 0.0.0.0:3702 *:*
EventSystem
[svchost.exe]
EventSystem
[svchost.exe]
FDResPub
[svchost.exe]
FDResPub
[svchost.exe]
UDP 0.0.0.0:4500 *:*
IKEEXT
[svchost.exe]
UDP 0.0.0.0:5355 *:*
Dnscache
[svchost.exe]
UDP 0.0.0.0:6783 *:*
[SRServer.exe]
UDP 0.0.0.0:8912 *:*
UDP 0.0.0.0:49933 *:*
EventSystem
[svchost.exe]
UDP 0.0.0.0:58705 *:*
EventSystem
[svchost.exe]
UDP 0.0.0.0:63000 *:*
FDResPub
[svchost.exe]
UDP 192.168.1.10:137 *:*
UDP 192.168.1.10:138 *:*
UDP 192.168.1.10:54814 *:*
iphlpsvc
[svchost.exe]
UDP 192.168.1.10:62618 *:*
[DataProxy.exe]
UDP [::]:123 *:*
W32Time
[svchost.exe]
UDP [::]:500 *:*
IKEEXT
[svchost.exe]
UDP [::]:3540 *:*
p2pimsvc
[svchost.exe]
UDP [::]:3702 *:*
FDResPub
[svchost.exe]
UDP [::]:3702 *:*
FDResPub
[svchost.exe]
UDP [::]:3702 *:*
EventSystem
[svchost.exe]
UDP [::]:3702 *:*
EventSystem
[svchost.exe]
UDP [::]:4500 *:*
IKEEXT
[svchost.exe]
UDP [::]:5355 *:*
Dnscache
[svchost.exe]
UDP [::]:8912 *:*
UDP [::]:49934 *:*
EventSystem
[svchost.exe]
UDP [::]:58706 *:*
EventSystem
[svchost.exe]
UDP [::]:63001 *:*
FDResPub
[svchost.exe]
UDP [::1]:64568 *:*
IAS
[svchost.exe]
UDP [::1]:64569 *:*
IAS
[svchost.exe]
UDP [::ffff:192.168.1.10]:1645 *:*
IAS
[svchost.exe]
UDP [::ffff:192.168.1.10]:1646 *:*
IAS
[svchost.exe]
UDP [::ffff:192.168.1.10]:1812 *:*
IAS
[svchost.exe]
UDP [::ffff:192.168.1.10]:1813 *:*
IAS
[svchost.exe]
UDP [2001:0:5ef5:79fd:51:d48e:a059:2931]:1645 *:*
IAS
[svchost.exe]
UDP [2001:0:5ef5:79fd:51:d48e:a059:2931]:1646 *:*
IAS
[svchost.exe]
UDP [2001:0:5ef5:79fd:51:d48e:a059:2931]:1812 *:*
IAS
[svchost.exe]
UDP [2001:0:5ef5:79fd:51:d48e:a059:2931]:1813 *:*
IAS
[svchost.exe]
UDP [fe80::51:d48e:a059:2931%12]:1645 *:*
IAS
[svchost.exe]
UDP [fe80::51:d48e:a059:2931%12]:1646 *:*
IAS
[svchost.exe]
UDP [fe80::51:d48e:a059:2931%12]:1812 *:*
IAS
[svchost.exe]
UDP [fe80::51:d48e:a059:2931%12]:1813 *:*
IAS
[svchost.exe]
UDP [fe80::948c:6b1b:833:ad6%13]:546 *:*
Dhcp
[svchost.exe]
UDP [fe80::948c:6b1b:833:ad6%13]:1645 *:*
IAS
[svchost.exe]
UDP [fe80::948c:6b1b:833:ad6%13]:1646 *:*
IAS
[svchost.exe]
UDP [fe80::948c:6b1b:833:ad6%13]:1812 *:*
IAS
[svchost.exe]
UDP [fe80::948c:6b1b:833:ad6%13]:1813 *:*
IAS
[svchost.exe]
C:\Users\Administrator>
Post Thu Dec 01, 2011 2:48 pm
how is your network connected? is there a upnp setting on your router?
Bjur
Post Thu Dec 01, 2011 2:56 pm
I have a ISP router and another behind that one, but now I have disabled UpNP on the 2 routers, but I can try to turn them on again and see, but it's still very strange, that the W7 client can do it and not the WHS 2011.
They are both on wired cable.
Post Thu Dec 01, 2011 3:00 pm
Can you enable detailed logging per signature and post the log here as an attachment.
Bjur
Post Fri Dec 02, 2011 7:51 am
Here is my debug log. I hope it can help, so I can get it working. I really want it to. I have also disabled SSDP like on the W7 client machine, but still no joy:(
(45.76 KiB) Downloaded 528 times
Post Fri Dec 02, 2011 9:22 am
Bjur wrote:Here is my debug log.
Nothing...
Do you try with INTEL Upnp tool, see my signature link?
Could you also try this tool in both W7 and WHS ?
you have to invoke it from the folder where ListNic.class is stored.
viewtopic.php?f=3&t=3923#p26629
Bjur
Post Fri Dec 02, 2011 9:38 am
See this post earlier viewtopic.php?f=7&t=4105&p=27057#p27057 I did ran the tool
And the java tool:
ip: 127.0.0.1,
display name: Software Loopback Interface 1
loopback: true
p2p: false
up: true
virtual: false
multicast: true
ip:
display name: WAN Miniport (SSTP)
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (L2TP)
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (PPTP)
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (PPPOE)
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (IPv6)
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (Network Monitor)
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (IP)
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: RAS Async Adapter
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (IKEv2)
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: Microsoft ISATAP Adapter
loopback: false
p2p: true
up: false
virtual: false
multicast: false
ip:
display name: Teredo Tunneling Pseudo-Interface
loopback: false
p2p: true
up: true
virtual: false
multicast: false
ip: 192.168.1.10,
display name: Realtek PCIe GBE Family Controller
loopback: false
p2p: false
up: true
virtual: false
multicast: true
ip:
display name: Realtek PCIe GBE Family Controller-QoS Packet Scheduler-0000
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: Realtek PCIe GBE Family Controller-WFP LightWeight Filter-0000
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (IPv6)-QoS Packet Scheduler-0000
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (IP)-QoS Packet Scheduler-0000
loopback: false
p2p: false
up: false
virtual: false
multicast: true
ip:
display name: WAN Miniport (Network Monitor)-QoS Packet Scheduler-0000
loopback: false
p2p: false
up: false
virtual: false
multicast: true
Post Fri Dec 02, 2011 10:25 am
Bjur wrote:See this post earlier viewtopic.php?f=7&t=4105&p=27057#p27057 I did ran the tool
Sorry, I didn't make the link...there are too many posts!!
To resume, your device is seen with INTEL Upnp tool on your Windows Server 2008 ?
Could you check :
Start -> Run -> services.msc -> OK -> Select Services
And check if there is a Service :SSDP Discovery.
- set to automaically start
- click start button
Bjur
Post Fri Dec 02, 2011 10:54 am
Could you check :
I have disabled it yesterday to avoid any conflict with Serviio, since I thought Serviio didn't used it, but have it enabled now.
But when I run Intel UpNp Device Spy it does NOT find my Yamaha Receiver, but it does on W7 machine. Does that make sense?
Netstat -abn shows:
PolicyAgent
[svchost.exe]
TCP [::]:49305 [::]:0 LISTENING
RPCHTTPLBS
[svchost.exe]
TABLISHED
TIME_WAIT
TIME_WAIT
TIME_WAIT
STABLISHED
[SMSvcHost.exe]
STABLISHED
[SMSvcHost.exe]
STABLISHED
[SMSvcHost.exe]
STABLISHED
[SMSvcHost.exe]
STABLISHED
[SMSvcHost.exe]
STABLISHED
[SMSvcHost.exe]
STABLISHED
[SMSvcHost.exe]
STABLISHED
[SMSvcHost.exe]
STABLISHED
[SMSvcHost.exe]
STABLISHED
STABLISHED
STABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49180 [fe80::948c:6b1b:833:ad6%13
STABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49188 [fe80::948c:6b1b:833:ad6%13
STABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49203 [fe80::948c:6b1b:833:ad6%13
STABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49206 [fe80::948c:6b1b:833:ad6%13
STABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49222 [fe80::948c:6b1b:833:ad6%13
STABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49228 [fe80::948c:6b1b:833:ad6%13
STABLISHED
TCP [fe80::948c:6b1b:833:ad6%13]:49257 [fe80::948c:6b1b:833:ad6%13
TABLISHED
UDP 0.0.0.0:123 *:*
W32Time
[svchost.exe]
UDP 0.0.0.0:500 *:*
IKEEXT
[svchost.exe]
UDP 0.0.0.0:600 *:*
[DVBVservice.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
EventSystem
[svchost.exe]
FDResPub
[svchost.exe]
FDResPub
[svchost.exe]
EventSystem
[svchost.exe]
IKEEXT
[svchost.exe]
UDP 0.0.0.0:5004 *:*
[wmpnetwk.exe]
UDP 0.0.0.0:5005 *:*
[wmpnetwk.exe]
Dnscache
[svchost.exe]
[SRServer.exe]
UDP 0.0.0.0:50102 *:*
EventSystem
[svchost.exe]
UDP 0.0.0.0:50363 *:*
FDResPub
[svchost.exe]
UDP 0.0.0.0:50836 *:*
EventSystem
[svchost.exe]
UDP 127.0.0.1:1900 *:*
SSDPSRV
[svchost.exe]
UDP 127.0.0.1:59580 *:*
SSDPSRV
[svchost.exe]
UDP 192.168.1.10:1900 *:*
SSDPSRV
[svchost.exe]
UDP 192.168.1.10:59579 *:*
SSDPSRV
[svchost.exe]
UDP 192.168.1.10:60969 *:*
[DataProxy.exe]
UDP [::]:123 *:*
W32Time
[svchost.exe]
UDP [::]:500 *:*
IKEEXT
[svchost.exe]
UDP [::]:3540 *:*
p2pimsvc
[svchost.exe]
UDP [::]:3702 *:*
FDResPub
[svchost.exe]
UDP [::]:3702 *:*
EventSystem
[svchost.exe]
UDP [::]:3702 *:*
EventSystem
[svchost.exe]
UDP [::]:3702 *:*
FDResPub
[svchost.exe]
UDP [::]:4500 *:*
IKEEXT
[svchost.exe]
UDP [::]:5004 *:*
[wmpnetwk.exe]
UDP [::]:5005 *:*
[wmpnetwk.exe]
UDP [::]:5355 *:*
Dnscache
[svchost.exe]
UDP [::]:8912 *:*
UDP [::]:50103 *:*
EventSystem
[svchost.exe]
UDP [::]:50364 *:*
FDResPub
[svchost.exe]
UDP [::]:50837 *:*
EventSystem
[svchost.exe]
UDP [::1]:1900 *:*
SSDPSRV
[svchost.exe]
UDP [::1]:55251 *:*
IAS
[svchost.exe]
UDP [::1]:55252 *:*
IAS
[svchost.exe]
UDP [::1]:59578 *:*
SSDPSRV
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
UDP [2001:0:5ef5:79fb:6:2549:3f57:fef5]:1645 *:*
IAS
[svchost.exe]
UDP [2001:0:5ef5:79fb:6:2549:3f57:fef5]:1646 *:*
IAS
[svchost.exe]
UDP [2001:0:5ef5:79fb:6:2549:3f57:fef5]:1812 *:*
IAS
[svchost.exe]
UDP [2001:0:5ef5:79fb:6:2549:3f57:fef5]:1813 *:*
IAS
[svchost.exe]
UDP [fe80::6:2549:3f57:fef5%12]:1645 *:*
IAS
[svchost.exe]
UDP [fe80::6:2549:3f57:fef5%12]:1646 *:*
IAS
[svchost.exe]
UDP [fe80::6:2549:3f57:fef5%12]:1812 *:*
IAS
[svchost.exe]
UDP [fe80::6:2549:3f57:fef5%12]:1813 *:*
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
IAS
[svchost.exe]
UDP [fe80::948c:6b1b:833:ad6%13]:1900 *:*
SSDPSRV
[svchost.exe]
UDP [fe80::948c:6b1b:833:ad6%13]:59577 *:*
SSDPSRV
[svchost.exe]
Post Fri Dec 02, 2011 1:03 pm
Bjur wrote:I have disabled it yesterday to avoid any conflict with Serviio, since I thought Serviio didn't used it, but have it enabled now.
It's very hard to understand (my poor english probably)...To resume:
Windows Server 8
- when Windows Upnp service is enabled (SSDP), Upnp Device Spy does not find your Yamaha Receiver.
- when Windows Upnp service is disabled (SSDP), Upnp Device Spy finds your Yamaha Receiver.
- Serviio never finds your Yamaha Receiver
Windows 7
- All is fine.
Do you have another device found with Upnp Device Spy ?
Bjur
Post Fri Dec 02, 2011 1:17 pm
Windows Server 8
Windows 7
- All is fine.
When Windows SSDP service is enabled and UpNP is enable on WHS 2011 (Windows Server 2008) Intel device spy only lists Serviio on WHS 2011 and no other devices are found.
When Windows SSDP service is disabled and UpNP is disabled on WHS 2011 (Windows Server 2008) Intel device spy only lists Serviio on WHS 2011 and no other devices are found.
So Serviio never found my DLNA devices no matter what on the WHS 2011 machine.
And when running netstat with SSDP enabled it says:
Post Fri Dec 02, 2011 2:32 pm
Bjur wrote:When Windows SSDP service is enabled and UpNP is enable on WHS 2011 (Windows Server 2008) Intel device spy only lists Serviio on WHS 2011 and no other devices are found.
So Intel Device Spy never found your Yamaha device on WHS 2011.
Bjur
Post Fri Dec 02, 2011 2:39 pm
No.
Post Sat Dec 03, 2011 10:37 am
Do you have a Antivirus software installed?
Bjur
Post Sat Dec 03, 2011 10:57 am
Yes mse
Bjur
Post Mon Dec 05, 2011 8:16 am
But even if I disable it so it does not start up I still can't find any device..
Users browsing this forum: No registered users and 67 guests
