Transcoding question - old MOV files
stualden
Post Sun Dec 04, 2011 8:29 pm
Shown below is MediaInfo output for a MOV file created by an older digital camera, with "jpeg" video and PCM audio. Could someone please tell me if this is transcodable to something a Samsung C-series TV can play, and if so, what additional lines I should add to the profile? I searched this forum and did not see any relevant reference to this format (and I am confused by the reference to JPEG, since this is a video, not a still picture format). Thank you!
Complete name : \\basement11\video\Home Movies\Pict0018.mov
Format : QuickTime
Format/Info : Original Apple specifications
File size : 7.74 MiB
Duration : 9mn 9s
Overall bit rate : 118 Kbps
Encoded date : UTC 2008-04-11 14:18:48
Tagged date : UTC 2008-04-11 14:18:48
Writing library : mino
Origin : Digital Camera
MMA1 : lta Co., Ltd.
Format : JPEG
Codec ID : jpeg
Duration : 42s 167ms
Bit rate mode : Variable
Bit rate : 1 343 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 24.000 fps
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.729
Stream size : 6.75 MiB (87%)
Language : English
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : raw
Duration : 9mn 9s
Bit rate mode : Constant
Bit rate : 1 625 Kbps
Channel(s) : 1 channel
Sampling rate : 7 812 Hz
Bit depth : 16 bits
Stream size : 106 MiB
Language : English
Material_Duration : 42167
Material_StreamSize : 8564556
Post Mon Dec 05, 2011 1:19 pm
Re: Transcoding question - old MOV files
post ffmpeg -i of the file as well
stualden
Post Mon Dec 05, 2011 2:26 pm
Thank you - here it is:
>ffmpeg -i pict0018.mov
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-memalign-hack --extra-cflags=-D__NO_ISOCEXT -I/usr/lo
cal/include --extra-ldflags=-L/usr/local/lib --enable-mp3lame
built on Aug 18 2008 14:47:42, gcc: 3.4.5 (mingw-vista special r3)
Input #0, mov,mp4,m4a,3gp,3g2, from 'pict0018.mov':
Duration: 00:00:42.1, start: 0.000000, bitrate: 1540 kb/s
Stream #0.0, 600.00 fps: Video: mjpeg, yuvj422p, 320x240
Stream #0.1: Audio: pcm_u8, 7812 Hz, mono, 62 kb/s
Must supply at least one output file
Post Mon Dec 05, 2011 2:45 pm
upgrade your ffmpeg and try again
WildRushSykes
Post Mon Dec 05, 2011 2:50 pm
Deleted
Post Mon Dec 05, 2011 4:26 pm
he's on Linux probably
stualden
Post Tue Dec 06, 2011 11:22 am
Sorry, I must be living in the past! (Not Linux, I'm on 64-bit win 7):
ffmpeg version N-35462-g61b1d85, Copyright (c) 2000-2011 the FFmpeg developers
built on Dec 5 2011 14:28:46 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 30. 0 / 51. 30. 0
libavcodec 53. 40. 0 / 53. 40. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 51. 0 / 2. 51. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 600.00 (600/1
) -> 24.00 (24/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'pict0018.mov':
creation_time : 2008-04-11 14:18:48
Duration: 00:00:42.16, start: 0.000000, bitrate: 1540 kb/s
Stream #0:0(eng): Video: mjpeg (jpeg / 0x6765706A), yuvj422p, 320x240, 1342
kb/s, 24 fps, 24 tbr, 600 tbn, 600 tbc
handler_name :
Stream #0:1(eng): Audio: pcm_s16be (raw / 0x20776172), 7812 Hz, 1 channels,
s16, 124 kb/s
handler_name :
Post Tue Dec 06, 2011 11:30 am
I assume you're using the ffmpeg bundled with Serviio (if you haven't changed anything in the installation then it's a yes)
WildRushSykes
Post Tue Dec 06, 2011 11:37 am
well according the that info hes upgraded his ffmpeg as that is the latest build built on december 5th same as mine :)
Post Tue Dec 06, 2011 12:33 pm
Suggest to add this
<Matches container="mp4" vCodec="mjpeg" aCodec="lpcm" />
in the first <video> </video> section of Samsung C/D profile.
Users browsing this forum: Baidu [Spider] and 3 guests
