Transcoding question - old MOV files
Complete name : \\basement11\video\Home Movies\Pict0018.mov
Format : QuickTime
Format/Info : Original Apple specifications
File size : 7.74 MiB
Duration : 9mn 9s
Overall bit rate : 118 Kbps
Encoded date : UTC 2008-04-11 14:18:48
Tagged date : UTC 2008-04-11 14:18:48
Writing library : mino
Origin : Digital Camera
MMA1 : lta Co., Ltd.
Format : JPEG
Codec ID : jpeg
Duration : 42s 167ms
Bit rate mode : Variable
Bit rate : 1 343 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 24.000 fps
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.729
Stream size : 6.75 MiB (87%)
Language : English
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : raw
Duration : 9mn 9s
Bit rate mode : Constant
Bit rate : 1 625 Kbps
Channel(s) : 1 channel
Sampling rate : 7 812 Hz
Bit depth : 16 bits
Stream size : 106 MiB
Language : English
Material_Duration : 42167
Material_StreamSize : 8564556
