ffmpeg.exe encoutered a problem
Post Fri Dec 09, 2011 11:32 pm
Re: ffmpeg.exe encoutered a problem
ah ok your trying to use java 7 beta and windows XP.
1. uninstall java 7 from your pc.
2. install java 6 update 29
3. try again.
jbfarin
Post Sat Dec 10, 2011 2:31 am
thanks for the reply...will do and let you know
jbfarin
Post Sat Dec 10, 2011 4:14 am
maybe so far looks great...will leave it going for awhile but usually would have already had an error message so I think you Da man ;-)
jbfarin
Post Sat Dec 10, 2011 5:19 pm
I spoke too soon...woke up this morning and I had the same message about 20 times ( as compared to hundred before) so getting better but had something new too...serviio crashed.....need a new log?
Post Mon Dec 12, 2011 5:05 pm
it's nothing to do with Serviio's code but your OS for some reason doesn't like the FFmpeg executable. Can you enable detailed logging, and try to find the ffmpeg command that seems to cause the crash? Then run it manually.
jbfarin
Post Mon Dec 12, 2011 5:15 pm
run it manually? i figured had soemthing to do with the OS since I am running it too ona laptop using windows 7 and the computer that am having the issues is old and running xp.....
Post Mon Dec 12, 2011 5:18 pm
you'll see executions of ffmpeg.exe in the log. copy the line and paste in into cmd terminal (viewtopic.php?f=5&t=960)
Post Tue Dec 13, 2011 9:27 pm
jbfarin wrote:I spoke too soon...woke up this morning and I had the same message about 20 times ( as compared to hundred before) so getting better but had something new too...serviio crashed.....need a new log?
as i valued techie in the industry i can not be held resonsible for the pile of uselessness more commonly know as windows XP. ;)
jbfarin
Post Tue Dec 13, 2011 10:12 pm
I so understand...:-) i got another windows 7 machine....going to make that my server...appreciate everything i will donate on payday ...ama very poor teacher haha
Post Tue Dec 13, 2011 11:27 pm
your welcome :) plus windows 7 supports JAVA 7 ;) hint hint
jbfarin
Post Wed Dec 14, 2011 2:21 am
ok tried for hours to get this to work then read your hint....but says java 7 not available yet...where do i get it....can you belive I really am a very educated man haha
Post Wed Dec 14, 2011 3:02 am
ok so whats your setup now then, as serviio will just work on a plain install of windows 7 straight out of the box, on either java 6 update 29 or java 7. If its not working then u have something else installed that is breaking things.
jbfarin
Post Wed Dec 14, 2011 3:09 am
i change the profile for the direct receivers in the comfig too...running windows 7, 32 bit....did upgrade the java to 6 update 29....service log? so lost ...my ip settings are identical to my other machine too and it reconizes the media players but the media players doesnt reconize serviio....
Post Wed Dec 14, 2011 4:10 am
then its a port issue and not a setup issue. have u checked the correct ports are open and availible?
jbfarin
Post Wed Dec 14, 2011 3:04 pm
no....how do I do that? again thanks...
Post Wed Dec 14, 2011 7:19 pm
from CMD type the following and copy and paste the infoprnmation here:
netstat -an |find /i "listening"
also can you do this one while your there too
ipconfig
jbfarin
Post Thu Dec 15, 2011 12:40 am
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\jbfarin>netstat -an |find /i "listening"
TCP 0.0.0.0:135 0.0.0.0:0 LISTENING
TCP 0.0.0.0:445 0.0.0.0:0 LISTENING
TCP 0.0.0.0:3389 0.0.0.0:0 LISTENING
TCP 0.0.0.0:5357 0.0.0.0:0 LISTENING
TCP 0.0.0.0:8895 0.0.0.0:0 LISTENING
TCP 0.0.0.0:23423 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49152 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49153 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49154 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49155 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49157 0.0.0.0:0 LISTENING
TCP 192.168.1.19:139 0.0.0.0:0 LISTENING
TCP 192.168.1.19:44331 0.0.0.0:0 LISTENING
TCP 192.168.1.19:44332 0.0.0.0:0 LISTENING
TCP [::]:135 [::]:0 LISTENING
TCP [::]:445 [::]:0 LISTENING
TCP [::]:3389 [::]:0 LISTENING
TCP [::]:5357 [::]:0 LISTENING
TCP [::]:49152 [::]:0 LISTENING
TCP [::]:49153 [::]:0 LISTENING
TCP [::]:49154 [::]:0 LISTENING
TCP [::]:49155 [::]:0 LISTENING
TCP [::]:49157 [::]:0 LISTENING
C:\Users\jbfarin>
C:\Users\jbfarin>
C:\Users\jbfarin>
jbfarin
Post Thu Dec 15, 2011 12:42 am
C:\Users\jbfarin>ipconfig
Windows IP Configuration
Wireless LAN adapter Wireless Network Connection 2:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::94a6:c1ff:8dbd:ebe7%20
IPv4 Address. . . . . . . . . . . : 192.168.1.19
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter Local Area Connection:
Tunnel adapter isatap.{5D67A5E6-215F-4CE6-B41D-FE525001D411}:
Tunnel adapter Local Area Connection* 9:
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:c54:9a:3f57:feec
Link-local IPv6 Address . . . . . : fe80::c54:9a:3f57:feec%12
Default Gateway . . . . . . . . . : ::
Tunnel adapter isatap.{2E868121-D080-4C6D-8F6C-C2951FADD8BB}:
Tunnel adapter isatap.{23DBCFE9-288F-490A-B052-30A5691C7531}:
C:\Users\jbfarin>
Post Thu Dec 15, 2011 12:55 am
ok its listening on 8895 but on a loopback ip so thats not gunan work, you will need to enter 192.168.1.19 into teh BOUND ip field in console and restart serviio server.
jbfarin
Post Thu Dec 15, 2011 1:03 am
would you believe it was already that...i found that to work on my other machine if I put the same ip address in the bound it would work....
