ffmpeg.exe encoutered a problem
• Page 4 of 4 • 1, 2, 3, 4
and also with hat same ip address an unronized windows player shows up and I remove that then restart and usually it works but not on this machine....would you believe that i dropped my external hard drive and now lost a ton of my movies too...the luck i have...
Re: ffmpeg.exe encoutered a problem
jbfarin wrote:and also with hat same ip address an unronized windows player shows up and I remove that then restart and usually it works but not on this machine....would you believe that i dropped my external hard drive and now lost a ton of my movies too...the luck i have...
oooooooooo have you disabled the windows network sharing service???
http://www.mydigitallife.info/how-to-di ... -wmpnetwk/
Good question....i bet thats it...out to dinner..will check when get homek
Again thanks
Again thanks
bad news that wasn't it......am I sol? any other ideas?
can i have a recap of exact the problem now please.
You tired of me yet? serviio won't show up on any of my media players. I have changed the profile for directtv. I am running servioo on windows 7. The computer shows green lights next to the media players but for what ever reason the computer doesn't show up in the media players...hope that makes sense...
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
1. Set bound ip as above. (192.168.1.19) you can confirm this ip is still correct but running ipconfig from CMD.
2. Run cmd and tyoe netstat -an then post information here.
2. Set static ips for all your devices.
3. Clear all renderers from serviio console and restart serviio.
hurah!!!!...ok it showed up....i had to in the firewall settings allow it to communicate on my "private/home" network....thank you ...am sure will talk again......going to add harddrives this weekend.....again thanks...
your very welcome
I would say one last question but we both know thats not true as i will be back but now that we found it was the firewall/port issue can i turn back on windows media sharing...Hate to mess with anything if I am just going to mess things up as this thing is working fantastic....
i would say yes but if anything bad happens turn it back off
but im running window 7 ultimate n edition so dont have windows media player at all so dont know for sure
NO it must stay disabled or it play havoc with the ports.
