ffmpeg.exe encoutered a problem
jbfarin
Post Thu Dec 15, 2011 1:17 am
Re: ffmpeg.exe encoutered a problem
and also with hat same ip address an unronized windows player shows up and I remove that then restart and usually it works but not on this machine....would you believe that i dropped my external hard drive and now lost a ton of my movies too...the luck i have...
Post Thu Dec 15, 2011 2:33 am
jbfarin wrote:and also with hat same ip address an unronized windows player shows up and I remove that then restart and usually it works but not on this machine....would you believe that i dropped my external hard drive and now lost a ton of my movies too...the luck i have...
oooooooooo have you disabled the windows network sharing service???
http://www.mydigitallife.info/how-to-di ... -wmpnetwk/
jbfarin
Post Thu Dec 15, 2011 2:42 am
Good question....i bet thats it...out to dinner..will check when get homek
Again thanks
jbfarin
Post Thu Dec 15, 2011 10:51 pm
bad news that wasn't it......am I sol? any other ideas?
Post Thu Dec 15, 2011 11:20 pm
can i have a recap of exact the problem now please.
jbfarin
Post Thu Dec 15, 2011 11:25 pm
You tired of me yet? serviio won't show up on any of my media players. I have changed the profile for directtv. I am running servioo on windows 7. The computer shows green lights next to the media players but for what ever reason the computer doesn't show up in the media players...hope that makes sense...
Post Thu Dec 15, 2011 11:34 pm
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
1. Set bound ip as above. (192.168.1.19) you can confirm this ip is still correct but running ipconfig from CMD.
2. Run cmd and tyoe netstat -an then post information here.
2. Set static ips for all your devices.
3. Clear all renderers from serviio console and restart serviio.
jbfarin
Post Fri Dec 16, 2011 12:08 am
hurah!!!!...ok it showed up....i had to in the firewall settings allow it to communicate on my "private/home" network....thank you ...am sure will talk again......going to add harddrives this weekend.....again thanks...
Post Fri Dec 16, 2011 2:05 am
your very welcome :)
jbfarin
Post Fri Dec 16, 2011 4:38 pm
I would say one last question but we both know thats not true as i will be back but now that we found it was the firewall/port issue can i turn back on windows media sharing...Hate to mess with anything if I am just going to mess things up as this thing is working fantastic....
WildRushSykes
Post Fri Dec 16, 2011 5:00 pm
i would say yes but if anything bad happens turn it back off :D but im running window 7 ultimate n edition so dont have windows media player at all so dont know for sure :?
Post Fri Dec 16, 2011 8:19 pm
NO it must stay disabled or it play havoc with the ports.
Previous
Users browsing this forum: Google [Bot] and 11 guests
