Is there a sticky???
wildman
Post Mon Dec 26, 2011 9:00 am
Why do I feel like I'm the only one on here that is soooo frustrated????? I have been through all of the threads and FAQ's but all I get is GEEK..... 2 weeks I've been struggling but just can't find the answers . I have 3 samsung tv's one 58 inch plasma "d" series and un32c5000 and un46c5000. Sometimes serviio works great....other times like Loungo in the playoffs :). Anyway got this from the Forum:
HOWTO: Provide details of a video file that doesn't play
If a video file cannot be played, locale FFmpeg executable (in lib folder in Serviio installation directory, or a part of your Linux distribution), run this command and post the result in the forum:
On Windows (details here):
ffmpeg.exe -i "<your_file_location>"
On Linux/ Mac (details here):
ffmpeg -i <your_file_location>
How do I find my file location??? What File am I looking for??? (might seem obvious if ur a hacker but for the rest of us that bought samsung tv's and have a MAC.....not so much)
My Problem:
I have a MAC osx. 3 samsung tv's (d series and 2 c's) D link dir-825 router, DGS-1008G switch, hard wired cat5e. Seems like the network connection is very slow yet everything is 10/100/1000. Drops connection on all tv's anywhere from not starting to 20 min in to a file. It either says "network connection unavailable" or "file format not supported..i think) on a good day those exact same files will play awesome. This happens on simple avi files as well MKV. Just can't figure it out. One Last thing....I've been on a lot of forums. This one seems to lack "how to" stickies. There are a few but IMO could have better and more detailed ones.
Alot of people are changing from windows to mac and now have to be a newb at both a mac and the programs they use....please be patient with us :)
Lastly.....from what I've read Servio is the way to go!!! I'm confident if I can get mine working I will happy just like the rest of you guys that are enjoying Serviio.
Thanks for helping
Sometimes, it is also useful to provide output of MediaInfo (especially for H264 MOV/MP4/MKV files)
Also make sure you mention your OS, renderer device and we might ask you for a detailed log as well.
Post Mon Dec 26, 2011 12:18 pm
Re: Is there a sticky???
There is a few places that have the information you are looking for.
http://wiki.serviio.org/doku.php
http://www.serviio.org/support
Your file location depends on where you saved the file. On my system, that is on my linux box. So I know the file location based on what folder I saved it in.
Basically the file location should be the folder that you setup for serviio to find the videos in, in the console.
ie.  ffpmeg -i  "C:\my documents\videos\video1.avi"
Can you give more information on how your network is configured? Is it all hardwired? or are you using a hybrid wireless / wired setup?
Can you post your serviio.log file. It is in the log folder of the serviio directory.
Post Mon Dec 26, 2011 11:21 pm
wildman wrote: One Last thing....I've been on a lot of forums. This one seems to lack "how to" stickies. There are a few but IMO could have better and more detailed ones.
serviio has one of the best support groups of ANY media serviio currently availible for both free and paid, we provide support forums, FAQs and a growing (by the day, i have to work to) wiki site all avilible free to everyone and reference in the sugniture (the bit at bottom of my message ) of all the helpers (none of us are paid).
Suport section from main site including FAQ : http://www.serviio.org/support
Supprt forums ( here ) : http://forum.serviio.org/
growing wiki: http://wiki.serviio.org/
tbh if we added all the HowTO topics are stick it would take 3 pages before you even got to the actual support posts in each section. ;)
we are already very aware that MAC users are growing ( imho they are mad but each to his own ) that is why there is sections dedicated to mac users on the wiki, with sepcific information on using serviio and mac and even helpful tools that can be used to fix/organise your media. If there is anything else that you would like information on regarding MAC (related to serviio) please feel free to contact me via PM ( private message ) i will be happy to add that information to the wiki.
wildman
Post Tue Dec 27, 2011 6:34 am
Moltra,
Thank you for taking the time to respond to my issues in such a timely manner.
My Network:
ISP modem plugged in to D'link wireless router
"D" series samsung pluged in to router
2T network HD pluged in to router
iMac plugged in to router
D'link switch plugged in to router
2 "C" series tv's plugged into switch.
Laptop and iphones on wireless wouter.
Serviio running on iMac
IP of iMac is 192.168.0.197 and is bound in serviio console.
all IP addressees are reserved in router
in terms of Serviio - all hard wired cat5e
opened ports tcp 8895 and udp 1900 on router.....I think (is there a way to test this on mac?)
I have attached log fill.....I Think(there are a few)
Is there anything else you need??
Cerberus....thank you will take you up on that if need be. Thank you for your efforts, it is very much appreciated(believe me)
Cheers
(86.83 KiB) Downloaded 731 times
Post Tue Dec 27, 2011 12:03 pm
Look at this thread. There is a few Mac programs (eyeconnect and "hamachi client tunneling engine") that lock the multicasting port.
http://forum.serviio.org/viewtopic.php?f=5&t=1765&p=9797#p9797
Here is more information from another thread,
Hubert wrote:
zip wrote:Do you have EyeConnect installed? It seems to block the 1900 UDP port for use by other apps. Also enter your PC IP address in the console.
Got rid of EyeConnect using App Cleaner, now the TV 'sees' EyeConnect, where it wouldn't see anything before :?
When you say that ll IP addresses are reserved in the Router are you meaning that you have them setup to be static? that is the best way to get this to work properly.
wildman
Post Tue Dec 27, 2011 6:55 pm
Here is a copy of Activity Monitor:
0 kernel_task root 4.5 55 153.62 MB 2.33 GB Intel
1 launchd root 0.0 3 564.00 KB 586.74 MB Intel
64 WindowServer _windowserver 0.4 5 83.63 MB 1.00 GB Intel
36 mds root 0.0 16 46.34 MB 691.08 MB Intel
62 coreservicesd root 0.0 4 20.34 MB 609.90 MB Intel
37 loginwindow paulwild 0.0 3 7.89 MB 944.07 MB Intel
1360 mdworker paulwild 0.0 4 3.89 MB 601.55 MB Intel
11 DirectoryService root 0.0 6 3.71 MB 589.39 MB Intel
600 AppleFileServer root 0.0 2 3.54 MB 589.40 MB Intel
51 blued root 0.0 2 2.35 MB 597.13 MB Intel
1370 mdworker _spotlight 0.0 3 2.26 MB 599.84 MB Intel
21 securityd root 0.0 2 2.06 MB 587.46 MB Intel
14 configd root 0.0 4 1.96 MB 587.78 MB Intel
28 cupsd root 0.0 2 1.89 MB 586.87 MB Intel
150 coreaudiod root 0.0 2 1.80 MB 588.80 MB Intel
54 socketfilterfw root 0.0 3 1.60 MB 585.93 MB Intel
103 HPIO Trap Monito root 0.1 3 1.52 MB 588.58 MB Intel
41 hidd root 0.5 3 1.48 MB 587.21 MB Intel
42 fseventsd root 0.0 14 1.47 MB 593.67 MB Intel
10 kextd root 0.0 2 1.27 MB 586.19 MB Intel
17 mDNSResponder _mdnsresponder 0.0 2 1.20 MB 587.49 MB Intel
29 nmbd root 0.0 1 1.18 MB 586.93 MB Intel
30 usbmuxd _usbmuxd 0.0 3 1.16 MB 588.21 MB Intel
39 kdcmond root 0.0 2 1.00 MB 585.73 MB Intel
93 krb5kdc root 0.0 1 1.38 MB 586.05 MB Intel
46 diskarbitrationd root 0.0 1 1,024.00 KB 585.69 MB Intel
27 ntpd root 0.0 1 844.00 KB 586.12 MB Intel
95 hpusbmond root 0.0 1 788.00 KB 586.77 MB Intel
16 distnoted daemon 0.0 1 780.00 KB 585.59 MB Intel
180 check_afp root 0.0 2 736.00 KB 585.67 MB Intel
44 dynamic_pager root 0.0 1 704.00 KB 585.61 MB Intel
32 SystemStarter root 0.0 1 680.00 KB 585.61 MB Intel
52 autofsd root 0.0 1 672.00 KB 585.62 MB Intel
38 KernelEventAgent root 0.0 2 668.00 KB 585.68 MB Intel
107 hpdot4d root 0.1 2 640.00 KB 587.42 MB Intel
130 launchd paulwild 0.0 3 532.00 KB 585.74 MB Intel
228 Serviio-Console paulwild 0.0 24 169.95 MB 3.27 GB Intel (64 bit)
1137 Safari paulwild 1.4 23 125.69 MB 1.13 GB Intel
227 Serviio paulwild 0.5 46 117.69 MB 3.22 GB Intel (64 bit)
521 OpenOffice.org paulwild 0.0 5 116.79 MB 1.07 GB Intel
152 Finder paulwild 0.0 11 44.55 MB 1,006.53 MB Intel
1466 Activity Monitor paulwild 2.4 5 25.11 MB 995.75 MB Intel
1467 pmTool root 0.9 1 1.35 MB 595.70 MB Intel
1170 Console paulwild 0.0 5 21.37 MB 975.47 MB Intel
144 Dock paulwild 0.0 3 18.02 MB 956.62 MB Intel
151 SystemUIServer paulwild 0.0 7 11.16 MB 939.23 MB Intel
1151 Terminal paulwild 0.0 3 7.53 MB 929.26 MB Intel
149 ATSServer paulwild 0.0 2 5.97 MB 637.91 MB Intel
464 AppleSpell.service paulwild 0.0 1 5.43 MB 601.87 MB Intel
140 Spotlight paulwild 0.0 2 4.12 MB 861.43 MB Intel
136 AirPort Base Station Agent paulwild 0.0 2 2.91 MB 892.13 MB Intel
141 UserEventAgent paulwild 0.0 3 2.82 MB 600.32 MB Intel
134 Folder Actions Dispatcher paulwild 0.0 1 2.73 MB 860.37 MB Intel
145 pboard paulwild 0.0 1 588.00 KB 586.74 MB Intel
12 notifyd root 0.0 2 476.00 KB 586.17 MB Intel
13 syslogd root 0.0 4 460.00 KB 587.24 MB Intel
55 pcloudd root 0.0 2 460.00 KB 2.57 GB Intel (64 bit)
31 update root 0.0 1 288.00 KB 585.57 MB Intel
I don't have either of those 2 programs installed. I did have "air video" installed so I could stream to my iphone.
I will check to see if any other programs could be blocking that port.
The IP addresses are static
Thanks again
Post Tue Dec 27, 2011 7:12 pm
I found this, I am not sure if it is installed on every mac or not. Try and see if any of this helps.
Using Mac OS X's Built-in Port Scanner
It’s not nmap, but then it’s not meant to be.  Network Utility has a port scanner – it’s built in and really easy to use.  Since Network Utility is distributed with every copy of Mac OS X it stands to reason that every copy of Mac OS X has the ability to scan a port without using a GUI tool.  Enter one of the best named tools in Mac OS X, stroke.  Stroke is the command line back-end to the Port Scan tab of Network Utility.  To use stroke, you will need to cd into the Network Utility application bundle and then cd into Contents and then Resources.
Once you are in the /Applications/Utilities/Network Utility.app/Contents/Resources, you will need to provide stroke with an IP address (or name), followed by the first port to scan and then the last (or the same number twice if your range is only one IP address.  For example, if you want to port scan port 80 on your own system you could use the following:
./stroke 127.0.0.1 80 80
But you shouldn’t just stroke yourself (sorry, couldn’t help it). Â You should also stroke others (Clarence Carter be damned!). Â So if you want to port scan www.google.com for port 80 the following would achieve such a lofty goal:
./stroke www.google.com 80 80
Because the name www.google.com has to resolve, you’re actually able to check whether a DNS error occurs and whether you can communicate over port 80 to the host in one command. Â If you want to make a copy of stroke into a directory and then add it to your environment variable’s PATH you can then use it without needing to change your working directory.
Portscan also comes in current OS X version in GUI: Applications > Utilities > Network Utility, tab Port Scan.
OSX has a command line port scanner. It’s just super sekrit is all. The questionably named stroke command, is part of Network Utility, which is nestled in your Utilities folder. Normally it’s only exposed through Network Utility’s GUI, but there is a way to get at it from your command prompt.
First, create a link to stroke, preferably somewhere in your $PATH.
ian@mymac:~$ ln /Applications/Utilities/Network\ Utility.app/Contents/Resources/stroke stroke
Next make it executable, if it isn’t already.
ian@mymac:~$ chmod uo+x stroke
Now let’s do a port scan. We will scan the localhost, ports 49152 thru 65535.
ian@mymac:~$ ./stroke 127.0.0.1 49152 65535
Can you install nmap, or even nessus instead? Absolutely. But in an, ehrm, pinch — stroke will do nicely.
Post Tue Dec 27, 2011 8:11 pm
sorry just wont to be clear on this as it can get confusing, when trying to debug issues.
Static IP and reserved IP are completely different.
static IP = asigned on the device and not controlled by DHCP (for this to work DHCP has to be off) if unknown device is connected it wont work until it has beens set its own IP.
Reserved/Prefered IP = asigned to the MAC address of the device from a router and is controlled by DHCP so that if a new unknown device is connected it will then be assigned a random ip by DHCP that has not already been reserved by another device.
wildman
Post Tue Dec 27, 2011 11:40 pm
Ok here is the result of the port scan of my iMac which is the machine Serviio is running on...
Port Scan has started ...
Port Scanning host: 192.168.0.197
Open TCP Port: 88 kerberos
Open TCP Port: 139 netbios-ssn
Open TCP Port: 445 microsoft-ds
Open TCP Port: 515 printer
Open TCP Port: 548 afpovertcp
Open TCP Port: 631 ipp
Open TCP Port: 8895
Open TCP Port: 23423
Open TCP Port: 44331
Open TCP Port: 44332
Port Scan has completed ...
I noticed there are no UDP ports????
Cerberus....my IP's are reserved. Thanks for the clarification. Should I assign Static IP's instead?
Post Wed Dec 28, 2011 12:19 am
nope reserved are perfect :)
can you run these command for me as it gives me more specific information on MAC OSx: http://wiki.serviio.org/doku.php?id=portinfo_mac
BTW as i know you asked earlier there is now more Mac information on the wiki.
How To's: http://wiki.serviio.org/doku.php?id=mac_install
Useful Tools: http://wiki.serviio.org/doku.php?id=mactools
wildman
Post Wed Dec 28, 2011 12:33 am
Last login: Mon Dec 26 19:18:47 on ttys000
paul-wilds-imac:~ paulwild$ sudo lsof -i -P | grep LISTEN
Password:
sudo lsof -i udp:1900
launchd 1 root 13u IPv6 0xbfb9be8 0t0 TCP *:515 (LISTEN)
launchd 1 root 14u IPv4 0xc295e64 0t0 TCP *:515 (LISTEN)
launchd 1 root 15u IPv6 0xbfb9984 0t0 TCP localhost:631 (LISTEN)
launchd 1 root 16u IPv4 0xc295a68 0t0 TCP activate-sjc0.adobe.com:631 (LISTEN)
launchd 1 root 56u IPv6 0xbfb9720 0t0 TCP *:548 (LISTEN)
launchd 1 root 59u IPv4 0xc29566c 0t0 TCP *:548 (LISTEN)
launchd 1 root 63u IPv4 0xc295270 0t0 TCP *:139 (LISTEN)
launchd 1 root 64u IPv4 0xc85ce64 0t0 TCP *:445 (LISTEN)
cupsd 28 root 4u IPv6 0xbfb9984 0t0 TCP localhost:631 (LISTEN)
cupsd 28 root 7u IPv4 0xc295a68 0t0 TCP activate-sjc0.adobe.com:631 (LISTEN)
cupsd 28 root 9u IPv6 0xbfb94bc 0t0 TCP *:631 (LISTEN)
cupsd 28 root 10u IPv4 0xc85ca68 0t0 TCP *:631 (LISTEN)
krb5kdc 93 root 12u IPv6 0xbfb9258 0t0 TCP *:88 (LISTEN)
krb5kdc 93 root 13u IPv4 0x129c666c 0t0 TCP *:88 (LISTEN)
JavaAppli 227 paulwild 54u IPv4 0x1069ea68 0t0 TCP 192.168.0.197:44331 (LISTEN)
JavaAppli 227 paulwild 56u IPv4 0xc85c66c 0t0 TCP *:23423 (LISTEN)
JavaAppli 227 paulwild 79u IPv4 0x1069e66c 0t0 TCP *:8895 (LISTEN)
JavaAppli 228 paulwild 39u IPv4 0x106afa68 0t0 TCP 192.168.0.197:44332 (LISTEN)
AppleFile 600 root 3u IPv6 0xbfb9720 0t0 TCP *:548 (LISTEN)
AppleFile 600 root 4u IPv4 0xc29566c 0t0 TCP *:548 (LISTEN)
paul-wilds-imac:~ paulwild$ sudo lsof -i udp:1900
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
JavaAppli 227 paulwild 80u IPv4 0xbfb4f40 0t0 UDP *:ssdp
paul-wilds-imac:~ paulwild$ sudo lsof -i tcp:8895
wildman
Post Sat Dec 31, 2011 4:12 am
OK update!!!
Decided to move file directly to imac desktop and point serviio to the desktop. Everything works perfectly!!! I don't exactly know what this means but seems like (obviously) somethings up with my WD mybookworld network drive????
Any takers?????
thanks
Post Sat Dec 31, 2011 6:21 am
how was you accessing your network drive?
like this h:\movies
or like this \\server\movies
wildman
Post Sat Dec 31, 2011 9:21 am
Mounted the Network drive on the desktop.
/Volumes/Public/Shared Movies
Post Sat Dec 31, 2011 9:30 am
wildman
Post Sat Dec 31, 2011 10:37 am
Hi Cerberus
Thanks for the link....I have read that many times but that was not my issue as my drive has always been mounted and I was always able to see my folders and files in it. The problem I was having is that the tv would stop playing the file and say "network disconnected"...or ""not supported codec" or "not supported file".
Anyway I will try a new network drive tomorrow and seee how it goes.
Cerberus....did you look at the results of the commands I ran??? I can't really make sense of it.
Will post after upgrading NAD
Cheers
Post Sat Dec 31, 2011 10:51 am
wildman wrote:Hi Cerberus
Cheers
yer it told me that correct ports are open and working, it is a little confusing to read but you get used to them
activity monitor - told me what PID number related to serviio and serviioconsole 227 and 228
then the port scan told me that 227 had port 8895 and 1900 open :) which is what we want :)
and as you found out once files were on local drive it worked fine so the error messages were abit misleading as it was actual serviio loosing access to files rather than tv loosing access to serviio.
Post Sat Dec 31, 2011 5:28 pm
another thing to look at is that the user runnning serviio must have permission to access the remote drive.
