Sony SMP-N100 Media Player
jctoad
Post Mon Dec 26, 2011 10:19 pm
Re: Sony SMP-N100 Media Player
Media info from vlc player
Stream 0
Type: Video
Codec: MPEG-4 Video (FMP4)
Resolution: 480x360
Frame rate: 29.970029
Stream 1
Type: Audio
Codec: MPEG Audio layer 1/2/3 (mpga)
Channels: Stereo
Sample rate: 48000 Hz
Bitrate: 32 kb/s
Stream 2
Type: Subtitle
Codec: Text subtitles with various tags (subt)
I've had this file for years. Just to be sure, I let the file play last night with vlc and it never hung up or glitched. I have even tried removing the subtitle file from the folder that contains the avi file.
The file is a 700Mb movie so it's not that easy to send to someone else for testing. Life will go on if I can not play this file. I am just wondering if I should be able to play this file. If this codec is not supported by the Sony box, can support be added into serviio to avoid future problems?
Update: I tried changing the file extension from .avi to .mp4 just to see if it made any difference when trying to play it from usb. It did not.
NX3
Post Wed Dec 28, 2011 10:16 am
FMP4 codec, the default MPEG4 format used by tool mencoder. Audio is all fine, might be something to do with the codec making the box struggle. Try updating the FourCC to xvid or divx and see if it plays ? Can you get the mediainfo full output, see link in my signature for a guide on how to.
jctoad
Post Wed Dec 28, 2011 11:25 pm
Complete name                    : E:\Sicko.2007.DVDrip\Sicko.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 679 MiB
Duration                         : 2h 3mn
Overall bit rate                 : 766 Kbps
Writing application              : MEncoder 2:1.0~rc1-0ubuntu9
Writing library                  : MPlayer
Original source form             : DVD ripped by acidrip.sf.net
Format                           : MPEG-4 Visual
Format profile                   : Simple@L1
Format settings, BVOP            : No
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : FMP4
Duration                         : 2h 3mn
Bit rate                         : 617 Kbps
Width                            : 480 pixels
Height                           : 360 pixels
Display aspect ratio             : 4:3
Frame rate                       : 29.970 fps
Bits/(Pixel*Frame)               : 0.119
Stream size                      : 547 MiB (81%)
Writing library                  : Lavc51.21.0
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Mode                             : Joint stereo
Mode extension                   : MS Stereo
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 2h 3mn
Bit rate                         : 32.0 Kbps
Channel(s)                       : 2 channels
Stream size                      : 119 MiB (18%)
Alignment                        : Aligned on interleaves
Interleave, duration             : 24 ms (0.72 video frame)
Interleave, preload duration     : 119 ms
Writing library                  : LAME3.96.1
NX3
Post Thu Dec 29, 2011 8:26 am
Did you try changing the FourCC to DIVX or XVID ?
jctoad
Post Thu Dec 29, 2011 2:52 pm
NX3 wrote:Did you try changing the FourCC to DIVX or XVID ?
No. I wasn't the one that encoded the file either.
NX3
Post Thu Dec 29, 2011 3:57 pm
You can use FourCC Changer (free download)
http://www.free-codecs.com/download/avi ... hanger.htm
Take a copy of the file, change the FourCC to that of a working divx or xvid that that you have, apply the settings then test the file to see if it now plays. This will help to work out if it is the FMP4 FourCC setting that is causing it not to play.
jctoad
Post Thu Dec 29, 2011 8:25 pm
I downloaded FourCC Changer but it only had 4 codecs in it so I used div3. That got the file to at least try to play. Just audio and it would randomly restart, but that was improvement. I got so spoiled with vlc player that I never installed any codecs on this computer. So I installed Xvid, (Xvid-1.3.2-20110601.exe) but that still didn't allow me to use the xvid codec in the changer. I found Nic's mini fourcc changer which was installed with the xvid codec. That changer shows the xvid codec in the drop down list. I changed it to xvid and now it plays fine through the serviio. So it works, but what was the cause of the problem? Thanks for the help. :) Here's the new mediaInfo
Format                           : AVI
File size                        : 679 MiB
Duration                         : 2h 3mn
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 2h 3mn
Bit rate                         : 617 Kbps
Width                            : 480 pixels
Height                           : 360 pixels
Format                           : MPEG Audio
Mode                             : Joint stereo
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 2h 3mn
NX3
Post Fri Dec 30, 2011 8:03 am
The problem would appear to be that the FourCC was FMP4. FourCC might not has preset in the dropdowns but you can manually enter entries, anyway you resolved it :)
Previous
