Original XBox transcoding profile reqd
Fes
Post Wed Dec 28, 2011 1:25 pm
I'm sure one must have been posted but I have searched & cannot find a transcoding profile for the original XBox (mainly, I want .MKVs transcoding but I have no clue regards the profile config).
Thanks,
Fes
Post Wed Dec 28, 2011 3:47 pm
Re: Original XBox transcoding profile reqd
Any idea what formats it can play? Also I doubt it's got DLNA / UPnP.
Post Wed Dec 28, 2011 4:05 pm
I think the original xbox used the original XBMC (Xbox Media Center). Alot depends on if the xbox is modded or not. I think it use to support upnp. I will have to dig out my sons old xbox and hook it up and see if it works.
Post Wed Dec 28, 2011 6:08 pm
moltra wrote:I think the original xbox used the original XBMC (Xbox Media Center). Alot depends on if the xbox is modded or not. I think it use to support upnp. I will have to dig out my sons old xbox and hook it up and see if it works.
yes that correct had to be modded to add the function. :)
Post Wed Dec 28, 2011 10:49 pm
that's what I thought, XBMC on it... but then why would you really need DLNA?
Post Wed Dec 28, 2011 11:04 pm
exactly zip but each to there own and tbh the generic profile should work with xbmc.
Fes
Post Thu Dec 29, 2011 10:39 am
The original XBox with XBMC cannot playback .mkv files (lack of power) - I heard Serviio could be used to transcode the .mkv files
Fes
Post Thu Dec 29, 2011 11:15 am
I found this profile that supposedly does it but I think it's syntax is incorrect - service stops with:
2011-12-28 13:59:14,521 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-complex-type.2.4.a: Invalid content was found starting with element 'User-Agent'. One of '{UPnPSearch, HttpHeaders}' is expected.
<Profile id="21" name="XBOX-XBMC" extendsProfileId="1">
<Detection>
<User-Agent>.*XBMC.*</User-Agent>
</Detection>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="8192">
<Matches container="mp4" />
<Matches container="asf" />
As I said, I'm not up to speed with all this, my apologies, I was hoping there was one floating around for xbox xbmc
Post Thu Dec 29, 2011 11:38 am
If you only want to transcode mkv files then try this:
It might also be enough to only remux the h264 inside mkv to mpegts like this:
<Video targetContainer="mpegts" targetACodec="ac3" >
<Matches container="matroska" vCodec="h264"/>
Fes
Post Thu Dec 29, 2011 4:50 pm
I'll give that a go - didn't want to make work here btw lol.
Post Thu Dec 29, 2011 4:55 pm
Fes wrote:I'll give that a go - didn't want to make work here btw lol.
No you are fine, I had forgotten about using an original xbox as a renderer. If we can get this working I can hook up one more of my TV's to serviio.
Post Thu Dec 29, 2011 6:30 pm
*confused* if you dont need it why did u ask :S ??
